查看: 4107|回复: 51
[网络] (首发)开telnet和ttl。toshiba东芝USB3.0扩展坞,带wifi的那个
发表于 2020-5-11 20:29:48 | 显示全部楼层 |阅读模式
【更新1】不接电脑的时候是HOST模式,接u盘可以自动挂载的
  1. # df -h
  2. Filesystem                Size      Used Available Use% Mounted on
  3. /dev/mtdblock2            7.3M      7.3M         0 100% /
  4. devtmpfs                124.2M         0    124.2M   0% /dev
  5. <font color="#ff0000">/dev/sda1                 7.4G    666.9M      6.8G   9% /tmp/media/sda1</font>
复制代码
废话不多说,
浏览器直接打开 http://ip/telnet.asp
然后重启即可。
我怎么知道的呢?因为我上了ttl啊,不用拆开,背面的4个空就是ttl
附带着启动的日志
  1. SHMOO VER 1.13
  2. PKID07DC06011801080000000000001A103F01000000
  3. S30000197
  4. 00000F80
  5. RDLYW0 00000005
  6. RDENW0 00000030
  7. RDQSW0
  8.     0000000000111111111122222222223333333333444444444455555555556666
  9.     0123456789012345678901234567890123456789012345678901234567890123
  10. 00 -------------+++++++++++++++++++++X+++++++++++++++++++++--------
  11. 01 ---------------++++++++++++++++++++X++++++++++++++++++++--------
  12. 02 ------------++++++++++++++++++++X++++++++++++++++++++-----------
  13. 03 ------------+++++++++++++++++++++X++++++++++++++++++++----------
  14. 04 ----------++++++++++++++++++++X+++++++++++++++++++--------------
  15. 05 ----------+++++++++++++++++++++X+++++++++++++++++++++-----------
  16. 06 ----------++++++++++++++++++++++X+++++++++++++++++++++----------
  17. 07 ------------+++++++++++++++++++++X++++++++++++++++++++----------
  18. 08 ---+++++++++++++++++++++++X++++++++++++++++++++++---------------
  19. 09 ------++++++++++++++++++++++X++++++++++++++++++++++-------------
  20. 10 -----+++++++++++++++++++++X+++++++++++++++++++++----------------
  21. 11 -------++++++++++++++++++++++X+++++++++++++++++++++-------------
  22. 12 -++++++++++++++++++++++X++++++++++++++++++++++------------------
  23. 13 ------+++++++++++++++++++++X+++++++++++++++++++++---------------
  24. 14 ------++++++++++++++++++++++X+++++++++++++++++++++--------------
  25. 15 ----++++++++++++++++++++++X+++++++++++++++++++++----------------
  26. PW0
  27.     0000000000111111111122222222223333333333444444444455555555556666
  28.     0123456789012345678901234567890123456789012345678901234567890123
  29. 00 ----------+++++++++++++++++++++++X++++++++++++++++++++++--------
  30. 01 ------------++++++++++++++++++++++X+++++++++++++++++++++--------
  31. 02 ----------+++++++++++++++++++++X+++++++++++++++++++++-----------
  32. 03 ---------++++++++++++++++++++++X++++++++++++++++++++++----------
  33. 04 ------++++++++++++++++++++++X+++++++++++++++++++++--------------
  34. 05 --------++++++++++++++++++++++X++++++++++++++++++++++-----------
  35. 06 --------+++++++++++++++++++++++X++++++++++++++++++++++----------
  36. 07 --------+++++++++++++++++++++++X++++++++++++++++++++++----------
  37. 08 ---+++++++++++++++++++++++X++++++++++++++++++++++---------------
  38. 09 ------+++++++++++++++++++++++X++++++++++++++++++++++------------
  39. 10 -----+++++++++++++++++++++X+++++++++++++++++++++----------------
  40. 11 -------++++++++++++++++++++++X+++++++++++++++++++++-------------
  41. 12 --++++++++++++++++++++++X++++++++++++++++++++++-----------------
  42. 13 ------++++++++++++++++++++++X+++++++++++++++++++++--------------
  43. 14 ------++++++++++++++++++++++X++++++++++++++++++++++-------------
  44. 15 -----++++++++++++++++++++++X++++++++++++++++++++++--------------
  45. NW0
  46.     0000000000111111111122222222223333333333444444444455555555556666
  47.     0123456789012345678901234567890123456789012345678901234567890123
  48. 00 -------------++++++++++++++++++++++X++++++++++++++++++++++------
  49. 01 --------------++++++++++++++++++++++X+++++++++++++++++++++------
  50. 02 ------------+++++++++++++++++++++X++++++++++++++++++++----------
  51. 03 ------------+++++++++++++++++++++X++++++++++++++++++++----------
  52. 04 ----------+++++++++++++++++++++X++++++++++++++++++++------------
  53. 05 ----------++++++++++++++++++++++X+++++++++++++++++++++----------
  54. 06 -----------+++++++++++++++++++++X+++++++++++++++++++++----------
  55. 07 ------------+++++++++++++++++++++X+++++++++++++++++++++---------
  56. 08 ---++++++++++++++++++++++X++++++++++++++++++++++----------------
  57. 09 -----+++++++++++++++++++++++X++++++++++++++++++++++-------------
  58. 10 ---++++++++++++++++++++++X+++++++++++++++++++++-----------------
  59. 11 -------+++++++++++++++++++++X+++++++++++++++++++++--------------
  60. 12 -++++++++++++++++++++++X++++++++++++++++++++++------------------
  61. 13 ----++++++++++++++++++++++X++++++++++++++++++++++---------------
  62. 14 ------++++++++++++++++++++++X+++++++++++++++++++++--------------
  63. 15 ----++++++++++++++++++++++X+++++++++++++++++++++----------------
  64. WRDQW0
  65.     0000000000111111111122222222223333333333444444444455555555556666
  66.     0123456789012345678901234567890123456789012345678901234567890123
  67. 00 ++++++++++++++++++++X++++++++++++++++++++--------++++++++++++++-
  68. 01 +++++++++++++++++++++X++++++++++++++++++++--------+++++++++++++-
  69. 02 -++++++++++++++++++++X+++++++++++++++++++--------++++++++++++++-
  70. 03 ++++++++++++++++++++X++++++++++++++++++++-------+++++++++++++++-
  71. 04 ++++++++++++++++++++X++++++++++++++++++++--------++++++++++++++-
  72. 05 ++++++++++++++++++++X++++++++++++++++++++-------+++++++++++++++-
  73. 06 ++++++++++++++++++++X++++++++++++++++++++------+-++++++++++++++-
  74. 07 ++++++++++++++++++++X+++++++++++++++++++--------+++++++++++++++-
  75. 08 +++++++++++++++++++X+++++++++++++++++++-------+++++++++++++++++-
  76. 09 ++++++++++++++++++++X++++++++++++++++++++-------+++++++++++++++-
  77. 10 +++++++++++++++++++X+++++++++++++++++++------++++++++++++++++++-
  78. 11 +++++++++++++++++++++X++++++++++++++++++++--------+++++++++++++-
  79. 12 +++++++++++++++++++X+++++++++++++++++++-------+++++++++++++++++-
  80. 13 ++++++++++++++++++++X++++++++++++++++++++------++++++++++++++++-
  81. 14 ++++++++++++++++++++X++++++++++++++++++++-------+++++++++++++++-
  82. 15 ++++++++++++++++++++X++++++++++++++++++++--------++++++++++++++-
  83. WRDMW0 00000020
  84. WRDMW0 00000019
  85. ADDR
  86.     0000000000111111111122222222223333333333444444444455555555556666
  87.     0123456789012345678901234567890123456789012345678901234567890123
  88. 00 +++++++++++++++S+++++++++++++++X++++++++++++++++++++++++++++++++
  89. Decompressing...done
  90. Found a ST compatible (Winbond/NexFlash) serial flash with 256 64KB blocks; total size 16MB
  91. INIT for HUB&DL ...
  92. CFE version 6.37.14.93 (r469350) based on BBP 1.0.37 for BCM947XX (32bit,SP,)
  93. Build Date: 四  7月 16 04:05:47 CST 2015 (jenkins@linux-cloud)
  94. Copyright (C) 2000-2008 Broadcom Corporation.
  95. Init Arena
  96. Init Devs.
  97. Boot partition size = 262144(0x40000)
  98. DDR Clock: 800 MHz
  99. Info: DDR frequency set from clkfreq=1000,*800*
  100. srab_rreg: [0x2-0x40] => 0x5 (len 1)
  101. srab_rreg: [0x2-0x30] => 0x53012 (len 4)
  102. srab_rreg: [0x34-0x0] => 0x63 (len 1)
  103. srab_rreg: [0x34-0x1] => 0x2 (len 1)
  104. srab_rreg: [0x5-0x0] => 0x0 (len 1)
  105. srab_rreg: [0x0-0xb] => 0x6 (len 1)
  106. srab_rreg: [0x0-0x5d] => 0xa (len 1)
  107. srab_rreg: [0x0-0xb] => 0x6 (len 1)
  108. srab_rreg: [0x10-0x0] => 0x40 (len 1)
  109. srab_rreg: [0x11-0x0] => 0x40 (len 1)
  110. srab_rreg: [0x12-0x0] => 0x40 (len 1)
  111. srab_rreg: [0x13-0x0] => 0x40 (len 1)
  112. srab_rreg: [0x14-0x0] => 0x40 (len 1)
  113. et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.14.93 (r469350)
  114. CPU type 0x0: 1000MHz
  115. Tot mem: 262144 KBytes
  116. CFE mem:    0x00F00000 - 0x00FDDDC4 (908740)
  117. Data:       0x00F523EC - 0x00F528D0 (1252)
  118. BSS:        0x00F528E0 - 0x00F77DC4 (152804)
  119. Heap:       0x00F77DC4 - 0x00FDBDC4 (409600)
  120. Stack:      0x00FDBDC4 - 0x00FDDDC4 (8192)
  121. Text:       0x00F00000 - 0x00F4703C (290876)
  122. Boot:       0x00FDE000 - 0x0101E000
  123. Reloc:      I:00000000 - D:00000000
  124. Device eth0:  hwaddr 6C-0B-84-24-75-XX, ipaddr 192.168.1.1, mask 255.255.255.0
  125.         gateway not set, nameserver not set
  126. Loader:raw Filesys:tftp Dev:eth0 File:: Options:(null)
  127. Loading: Failed.
  128. Could not load :: Timeout occured
  129. Loader:raw Filesys:raw Dev:flash0.os File: Options:(null)
  130. Loading: ..... 5147680 bytes read
  131. Entry at 0x00008000
  132. Closing network.
  133. Starting program at 0x00008000
  134. Linux version 2.6.36.4brcmarm (jenkins@linux-cloud) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 SMP PREEMPT Mon Nov 23 11:06:55 CST 2015
  135. CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
  136. CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
  137. Machine: Northstar Prototype
  138. Ignoring unrecognised tag 0x00000000
  139. Memory policy: ECC disabled, Data cache writealloc
  140. MPCORE found at 19020000
  141. On node 0 totalpages: 65536
  142.   DMA zone: 256 pages used for memmap
  143.   DMA zone: 0 pages reserved
  144.   DMA zone: 32512 pages, LIFO batch:7
  145.   Normal zone: 4864 pages used for memmap
  146.   Normal zone: 27904 pages, LIFO batch:7
  147. PERCPU: Embedded 7 pages/cpu @c8215000 s4672 r8192 d15808 u65536
  148. pcpu-alloc: s4672 r8192 d15808 u65536 alloc=16*4096
  149. pcpu-alloc: [0] 0 [0] 1
  150. Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 60416
  151. Kernel command line: console=ttyS0,115200n8 root=/dev/mtdblock2 ro rootfstype=squashfs init=/sbin/preinit debug
  152. PID hash table entries: 1024 (order: 0, 4096 bytes)
  153. Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
  154. Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
  155. Memory: 128MB 128MB = 256MB total
  156. Memory: 254432k/254432k available, 7712k reserved, 0K highmem
  157. Virtual kernel memory layout:
  158.     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
  159.     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
  160.     DMA     : 0xf7e00000 - 0xffe00000   ( 128 MB)
  161.     vmalloc : 0xd0800000 - 0xf0000000   ( 504 MB)
  162.     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
  163.     modules : 0xbf000000 - 0xc0000000   (  16 MB)
  164.       .init : 0xc0008000 - 0xc0040000   ( 224 kB)
  165.       .text : 0xc0040000 - 0xc04b1000   (4548 kB)
  166.       .data : 0xc04cc000 - 0xc04f0c20   ( 148 kB)
  167. SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
  168. Hierarchical RCU implementation.
  169.         RCU-based detection of stalled CPUs is disabled.
  170.         Verbose stalled-CPUs detection is disabled.
  171. NR_IRQS:256
  172. MPCORE GIC init
  173. External imprecise Data abort at addr=0x0, fsr=0x1c06 ignored.
  174. MPCORE Global Timer Clock 500000000Hz
  175. Calibrating delay loop... 1998.84 BogoMIPS (lpj=9994240)
  176. pid_max: default: 32768 minimum: 301
  177. Mount-cache hash table entries: 512
  178. CPU: Testing write buffer coherency: ok
  179. MPCORE Private timer setup CPU0
  180. Calibrating local timer... 499.815MHz.
  181. L310: cache controller enabled 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x7a130000
  182. CPU1: Booted secondary processor
  183. MPCORE Private timer setup CPU1
  184. Brought up 2 CPUs
  185. SMP: Total of 2 processors activated (3997.69 BogoMIPS).
  186. devtmpfs: initialized
  187. atomic64 test passed
  188. NET: Registered protocol family 16
  189. Found a ST compatible (Winbond/NexFlash) serial flash with 256 64KB blocks; total size 16MB
  190. CCA UART Clock Config: Sel=1 Ovr=1 Div=48
  191. CCA UART Clock rate 125000000Hz
  192. bio: create slab <bio-0> at 0
  193. SCSI subsystem initialized
  194. libata version 3.00 loaded.
  195. usbcore: registered new interface driver usbfs
  196. usbcore: registered new interface driver hub
  197. usbcore: registered new device driver usb
  198. Switching to clocksource mpcore_gtimer
  199. NET: Registered protocol family 2
  200. IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
  201. TCP established hash table entries: 8192 (order: 4, 65536 bytes)
  202. TCP bind hash table entries: 8192 (order: 4, 98304 bytes)
  203. TCP: Hash tables configured (established 8192 bind 8192)
  204. TCP reno registered
  205. UDP hash table entries: 128 (order: 0, 4096 bytes)
  206. UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
  207. NET: Registered protocol family 1
  208. PCI: CLS 0 bytes, default 32
  209. PCI: no core
  210. PCI: no core
  211. PCI: scanning bus 0
  212. pci 0000:00:00.0: reg 10: [mem 0x18000000-0x18000fff]
  213. pci 0000:00:00.0: reg 30: [mem 0x00000000-0x000007ff pref]
  214. pci 0000:00:01.0: reg 10: [mem 0x18001000-0x18001fff]
  215. pci 0000:00:01.0: reg 14: [mem 0x18002000-0x18002fff]
  216. pci 0000:00:01.0: reg 30: [mem 0x00000000-0x000007ff pref]
  217. pci 0000:00:02.0: reg 10: [mem 0x1802c000-0x1802cfff]
  218. pci 0000:00:02.0: reg 30: [mem 0x00000000-0x000007ff pref]
  219. pci 0000:00:03.0: reg 10: [mem 0x18024000-0x18024fff]
  220. pci 0000:00:03.0: reg 30: [mem 0x00000000-0x000007ff pref]
  221. pci 0000:00:04.0: reg 10: [mem 0x18025000-0x18025fff]
  222. pci 0000:00:04.0: reg 30: [mem 0x00000000-0x000007ff pref]
  223. pci 0000:00:05.0: reg 10: [mem 0x18026000-0x18026fff]
  224. pci 0000:00:05.0: reg 30: [mem 0x00000000-0x000007ff pref]
  225. pci 0000:00:06.0: reg 10: [mem 0x18027000-0x18027fff]
  226. pci 0000:00:06.0: reg 30: [mem 0x00000000-0x000007ff pref]
  227. pci 0000:00:07.0: reg 10: [mem 0x18012000-0x18012fff]
  228. pci 0000:00:07.0: reg 30: [mem 0x00000000-0x000007ff pref]
  229. pci 0000:00:08.0: reg 10: [mem 0x18013000-0x18013fff]
  230. pci 0000:00:08.0: reg 30: [mem 0x00000000-0x000007ff pref]
  231. pci 0000:00:09.0: reg 10: [mem 0x18014000-0x18014fff]
  232. pci 0000:00:09.0: reg 30: [mem 0x00000000-0x000007ff pref]
  233. pci 0000:00:0a.0: reg 10: [mem 0x1800b000-0x1800bfff]
  234. pci 0000:00:0a.0: reg 14: [mem 0x1800c000-0x1800cfff]
  235. pci 0000:00:0a.0: reg 30: [mem 0x00000000-0x000007ff pref]
  236. pci 0000:00:0b.0: reg 10: [mem 0x18022000-0x18022fff]
  237. pci 0000:00:0b.0: reg 30: [mem 0x00000000-0x000007ff pref]
  238. pci 0000:00:0b.1: reg 10: [mem 0x18021000-0x18021fff]
  239. pci 0000:00:0b.1: reg 30: [mem 0x00000000-0x000007ff pref]
  240. pci 0000:00:0c.0: reg 10: [mem 0x18023000-0x18023fff]
  241. pci 0000:00:0c.0: reg 30: [mem 0x00000000-0x000007ff pref]
  242. pci 0000:00:0d.0: reg 10: [mem 0x18020000-0x18020fff]
  243. pci 0000:00:0d.0: reg 30: [mem 0x00000000-0x000007ff pref]
  244. pci 0000:00:0e.0: reg 10: [mem 0x1802a000-0x1802afff]
  245. pci 0000:00:0e.0: reg 30: [mem 0x00000000-0x000007ff pref]
  246. pci 0000:00:0f.0: reg 10: [mem 0x18210000-0x1821ffff]
  247. pci 0000:00:0f.0: reg 30: [mem 0x00000000-0x000007ff pref]
  248. pci 0000:00:10.0: reg 10: [mem 0x18010000-0x18010fff]
  249. pci 0000:00:10.0: reg 30: [mem 0x00000000-0x000007ff pref]
  250. pci 0000:00:11.0: reg 30: [mem 0x00000000-0x000007ff pref]
  251. pci 0000:00:12.0: reg 10: [mem 0x18028000-0x18028fff]
  252. pci 0000:00:12.0: reg 30: [mem 0x00000000-0x000007ff pref]
  253. pci 0000:00:13.0: reg 10: [mem 0x18029000-0x18029fff]
  254. pci 0000:00:13.0: reg 30: [mem 0x00000000-0x000007ff pref]
  255. PCI: Fixing up bus 0
  256. PCIE1 link=1
  257. PCIE1 switching to GEN2
  258. PCIE1 link=1
  259. pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
  260. pci 0001:00:00.0: PME# disabled
  261. PCI: Fixing up bus 0
  262. PCI: bus0: Fast back to back transfers disabled
  263. pci 0001:01:00.0: reg 10: [mem 0x08000000-0x08007fff 64bit]
  264. pci 0001:01:00.0: reg 18: [mem 0x00000000-0x001fffff 64bit]
  265. pci 0001:01:00.0: supports D1 D2
  266. pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
  267. pci 0001:01:00.0: PME# disabled
  268. PCI: Fixing up bus 1
  269. PCI: bus1: Fast back to back transfers disabled
  270. pci 0001:00:00.0: BAR 8: assigned [mem 0x08000000-0x082fffff]
  271. pci 0001:01:00.0: BAR 2: assigned [mem 0x08000000-0x081fffff 64bit]
  272. pci 0001:01:00.0: BAR 2: set to [mem 0x08000000-0x081fffff 64bit] (PCI address [0x8000000-0x81fffff]
  273. pci 0001:01:00.0: BAR 0: assigned [mem 0x08200000-0x08207fff 64bit]
  274. pci 0001:01:00.0: BAR 0: set to [mem 0x08200000-0x08207fff 64bit] (PCI address [0x8200000-0x8207fff]
  275. pci 0001:00:00.0: PCI bridge to [bus 01-01]
  276. pci 0001:00:00.0:   bridge window [io  disabled]
  277. pci 0001:00:00.0:   bridge window [mem 0x08000000-0x082fffff]
  278. pci 0001:00:00.0:   bridge window [mem pref disabled]
  279. PCIE2 link=0
  280. PCIE3 link=0
  281. GPIO registered (major=254).
  282. Kernel gpio ctrl init
  283. VFS: Disk quotas dquot_6.5.2
  284. Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
  285. squashfs: version 4.0 (2009/01/31) Phillip Lougher
  286. Registering unionfs 2.5.11 (for 2.6.36.4)
  287. NTFS driver 2.1.29 [Flags: R/W].
  288. JFFS2 version 2.2. (NAND) ? 2001-2006 Red Hat, Inc.
  289. fuse init (API version 7.15)
  290. msgmni has been set to 496
  291. io scheduler noop registered (default)
  292. io scheduler deadline registered
  293. io scheduler cfq registered
  294. Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
  295. serial8250.0: ttyS0 at MMIO 0x18000300 (irq = 117) is a 16550
  296. console [ttyS0] enabled
  297. serial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117) is a 16550
  298. brd: module loaded
  299. loop: module loaded
  300. pflash: found no supported devices
  301. bcmsflash: squash filesystem found at block 37
  302. sflash size is too small to afford two images.
  303. Creating 5 MTD partitions on "bcmsflash":
  304. 0x000000000000-0x000000040000 : "boot"
  305. 0x000000040000-0x000000ff0000 : "linux"
  306. 0x0000002551c4-0x000000fe0000 : "rootfs"
  307. 0x000000fe0000-0x000000ff0000 : "bak-nvram"
  308. 0x000000ff0000-0x000001000000 : "nvram"
  309. nflash: found no supported devices
  310. PPP generic driver version 2.4.2
  311. NET: Registered protocol family 24
  312. u32 classifier
  313.     Actions configured
  314. Netfilter messages via NETLINK v0.30.
  315. nf_conntrack version 0.5.0 (3975 buckets, 15900 max)
  316. ctnetlink v0.93: registering with nfnetlink.
  317. xt_time: kernel timezone is -0000
  318. ip_tables: (C) 2000-2006 Netfilter Core Team
  319. TCP cubic registered
  320. NET: Registered protocol family 10
  321. ip6_tables: (C) 2000-2006 Netfilter Core Team
  322. IPv6 over IPv4 tunneling driver
  323. NET: Registered protocol family 17
  324. 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
  325. All bugs added by David S. Miller <davem@redhat.com>
  326. Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012
  327. brcmnand: found no supported devices
  328. VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
  329. devtmpfs: mounted
  330. Freeing init memory: 224K
  331. /sbin/hotplug2: No such file or directory
  332. insmod: ipv6.ko: no module by that name found
  333. insmod: bcm57xx.ko: no module by that name found
  334. hotplug detected product:  1d6b/2/206
  335. hotplug detected product:  1d6b/2/206
  336. hotplug detected product:  1d6b/1/206
  337. Hit enter to continue...hotplug detected product:  1d6b/1/206
  338. hotplug detected product:  5e3/610/4920
  339. hotplug detected product:  5e3/610/4920
  340. hotplug detected product:  17e9/434b/3102
  341. hotplug detected product:  17e9/434b/3102
  342. hotplug detected product:  17e9/434b/3102
  343. hotplug detected product:  17e9/434b/3102
  344. hotplug detected product:  17e9/434b/3102
  345. hotplug detected product:  17e9/434b/3102
  346. hotplug detected product:  17e9/434b/3102
  347. hotplug detected product:  17e9/434b/3102
  348. linux_overrides = vlan WARNING: console log level set to 1
  349. eth1: cmd=231: Invalid argument
  350. eth1: WLC_SET_VAR(ampdu_retry_limit_tid): Operation not supported
  351. eth1: WLC_SET_VAR(ampdu_retry_limit_tid): Operation not supported
  352. eth1: WLC_SET_VAR(ampdu_retry_limit_tid): Operation not supported
  353. eth1: WLC_SET_VAR(ampdu_retry_limit_tid): Operation not supported
  354. eth1: WLC_SET_VAR(ampdu_retry_limit_tid): Operation not supported
  355. eth1: WLC_SET_VAR(ampdu_retry_limit_tid): Operation not supported
  356. eth1: WLC_SET_VAR(ampdu_retry_limit_tid): Operation not supported
  357. eth1: WLC_SET_VAR(ampdu_retry_limit_tid): Operation not supported
  358. eth1: WLC_SET_VAR(ampdu_rr_retry_limit_tid): Operation not supported
  359. eth1: WLC_SET_VAR(ampdu_rr_retry_limit_tid): Operation not supported
  360. eth1: WLC_SET_VAR(ampdu_rr_retry_limit_tid): Operation not supported
  361. eth1: WLC_SET_VAR(ampdu_rr_retry_limit_tid): Operation not supported
  362. eth1: WLC_SET_VAR(ampdu_rr_retry_limit_tid): Operation not supported
  363. eth1: WLC_SET_VAR(ampdu_rr_retry_limit_tid): Operation not supported
  364. eth1: WLC_SET_VAR(ampdu_rr_retry_limit_tid): Operation not supported
  365. eth1: WLC_SET_VAR(ampdu_rr_retry_limit_tid): Operation not supported
  366. eth1: WLC_SET_VAR(bg_rate): Operation not supported
  367. eth1: WLC_SET_VAR(a_rate): Operation not supported
  368. eth1: WLC_SET_VAR(bg_rate): Operation not supported
  369. eth1: WLC_SET_VAR(a_rate): Operation not supported
  370. eth1: WLC_SET_VAR(bg_mrate): Operation not supported
  371. eth1: WLC_SET_VAR(a_mrate): Operation not supported
  372. eth1: WLC_SET_VAR(bg_mrate): Operation not supported
  373. eth1: WLC_SET_VAR(a_mrate): Operation not supported
  374. eth1: WLC_SET_VAR(avg_dma_xfer_rate): Operation not supported
  375. eth1: cmd=64: Operation not supported
  376. eth2: No such device
  377. ifconfig: No such device
  378. vlan1: WLC_GET_VAR(cap): Operation not supported
  379. info, udhcp server (v0.9.8) started
  380. error, unable to parse 'option domain '
  381. telnetd: starting
  382.   port: 23; interface: br0; login program: /bin/sh
  383. telnetd: starting
  384.   port: 23; interface: vlan1; login program: /bin/sh
  385. killall: hspotap: no process killed
  386. ### wps_wfi_init(): <wl0_wfi_enable=(null)>WFI is not enabled ###
  387. BSD is not enabled: 0=0
  388. info, udhcp client (v0.9.8) started
  389. vlan1 dhcp
  390. vlan1: No such process
  391. Hit enter to continue...connect: Network is unreachable
  392. Hit enter to continue...debug, Sending select for 192.168.100.64...
  393. info, Lease of 192.168.100.64 obtained, lease time 7200
  394. recvfrom: Connection refused
  395. recvfrom: Connection refused
  396. recvfrom: Connection refused
  397. info, udhcp server (v0.9.8) started
  398. Hit enter to continue...error, unable to parse 'option domain '
  399. Hit enter to continue...USBSW_MON_BIT is LOW
  400. Switch to WiFiDock mode!!
  401. hotplug detected product:  17e9/434b/3102
  402. hotplug detected product:  17e9/434b/3102
  403. hotplug detected product:  17e9/434b/3102
  404. hotplug detected product:  17e9/434b/3102
  405. hotplug detected product:  17e9/434b/3102
  406. hotplug detected product:  5e3/610/4920
  407. hotplug detected product:  17e9/434b/3102
  408. hotplug detected product:  5e3/610/4920
  409. hotplug detected product:  17e9/434b/3102
  410. hotplug detected product:  17e9/434b/3102
  411. hotplug detected product:  5e3/610/4920
  412. hotplug detected product:  5e3/610/4920
  413. Set Ethernet P1 link status is down.
  414. hotplug detected product:  17e9/434b/3102
  415. hotplug detected product:  17e9/434b/3102
  416. hotplug detected product:  17e9/434b/3102
  417. hotplug detected product:  17e9/434b/3102
  418. hotplug detected product:  17e9/434b/3102
  419. hotplug detected product:  17e9/434b/3102
  420. hotplug detected product:  17e9/434b/3102
  421. hotplug detected product:  17e9/434b/3102
复制代码
还有一些信息
  1. BusyBox v1.7.2 (2015-11-23 11:08:12 CST) built-in shell (ash)
  2. Enter 'help' for a list of built-in commands.
  3. # ls
  4. ls     lsmod
  5. # lsmod
  6. Module                  Size  Used by    Tainted: P
  7. NetUSB                193529  0
  8. GPL_NetUSB              3955  1 NetUSB
  9. ohci_hcd               18606  0
  10. ehci_hcd               35444  0
  11. wl                   4101030  0
  12. dpsta                   2897  1 wl
  13. et                     63533  0
  14. igs                    12935  1 wl
  15. emf                    16330  2 wl,igs
  16. ctf                    17575  0
  17. #
  18. # free
  19.               total         used         free       shared      buffers
  20.   Mem:       254656        26528       228128            0         1020
  21. Swap:            0            0            0
  22. Total:       254656        26528       228128
  23. #
  24. #
  25. # df
  26. Filesystem           1k-blocks      Used Available Use% Mounted on
  27. /dev/mtdblock2            7424      7424         0 100% /
  28. devtmpfs                127216         0    127216   0% /dev
  29. # cd /www
  30. # cd dynadock/
  31. # ls *.asp
  32. basic.asp     head.asp      internet.asp  security.asp  telnet.asp
  33. filter.asp    head_w.asp    lan.asp       setup.asp     wan.asp
  34. firmware.asp  index.asp     menu.asp      ssid.asp      wifi.asp
  35. forward.asp   index2.asp    radio.asp     status.asp
  36. #
复制代码
不违规,上拆机图
参与人数 4家元 +58 收起 理由
有点不烧 + 20 謝謝分享
玛德陛下 + 20 謝謝分享
x707088 + 10 優秀文章
343873163 + 8 原創內容
发表于 2020-5-11 20:51:35 | 显示全部楼层
牛皮牛皮 给老哥点个赞。
这个真心不错,竟然还能开TELNET。。。。:funk:
 楼主| 发表于 2020-5-11 20:56:31 | 显示全部楼层
吃烧饼喝三鹿 发表于 2020-5-11 20:51
牛皮牛皮 给老哥点个赞。
不止telnet,还支持pppoe、nat、端口转发、dmz、有usb功能,居然还有nfts和smb。
发表于 2020-5-11 21:02:13 | 显示全部楼层
digitking 发表于 2020-5-11 20:56
不止telnet,还支持pppoe、nat、端口转发、dmz、有usb功能,居然还有nfts和smb。 ...
难道这是一个被单网口限制住灵魂的路由器?
 楼主| 发表于 2020-5-11 21:10:13 | 显示全部楼层
是的。
  1. br0       Link encap:Ethernet  HWaddr 6C:0B:84:24:73:bb
  2.           inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
  3.           inet6 addr: fe80::6e0b:84ff:fe24:7396/64 Scope:Link
  4.           UP BROADCAST RUNNING ALLMULTI MULTICAST  MTU:1500  Metric:1
  5.           RX packets:21 errors:0 dropped:0 overruns:0 frame:0
  6.           TX packets:84 errors:0 dropped:0 overruns:0 carrier:0
  7.           collisions:0 txqueuelen:0
  8.           RX bytes:2824 (2.7 KiB)  TX bytes:15622 (15.2 KiB)
  9. eth0      Link encap:Ethernet  HWaddr 6C:0B:84:24:75:aa
  10.           inet6 addr: fe80::6e0b:84ff:fe24:75c6/64 Scope:Link
  11.           UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
  12.           RX packets:828 errors:0 dropped:0 overruns:0 frame:0
  13.           TX packets:488 errors:0 dropped:0 overruns:0 carrier:0
  14.           collisions:0 txqueuelen:1000
  15.           RX bytes:78930 (77.0 KiB)  TX bytes:120672 (117.8 KiB)
  16.           Interrupt:179 Base address:0x4000
  17. eth1      Link encap:Ethernet  HWaddr 6C:0B:84:24:73:cc
  18.           inet6 addr: fe80::6e0b:84ff:fe24:7396/64 Scope:Link
  19.           UP BROADCAST RUNNING ALLMULTI MULTICAST  MTU:1500  Metric:1
  20.           RX packets:0 errors:0 dropped:0 overruns:0 frame:770
  21.           TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
  22.           collisions:0 txqueuelen:1000
  23.           RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
  24.           Interrupt:163
  25. lo        Link encap:Local Loopback
  26.           inet addr:127.0.0.1  Mask:255.0.0.0
  27.           inet6 addr: ::1/128 Scope:Host
  28.           UP LOOPBACK RUNNING MULTICAST  MTU:16436  Metric:1
  29.           RX packets:61 errors:0 dropped:0 overruns:0 frame:0
  30.           TX packets:61 errors:0 dropped:0 overruns:0 carrier:0
  31.           collisions:0 txqueuelen:0
  32.           RX bytes:12450 (12.1 KiB)  TX bytes:12450 (12.1 KiB)
  33. vlan1     Link encap:Ethernet  HWaddr 6C:0B:84:24:75:dd
  34.           inet addr:192.168.100.64  Bcast:192.168.100.255  Mask:255.255.255.0
  35.           inet6 addr: fe80::6e0b:84ff:fe24:75c6/64 Scope:Link
  36.           UP BROADCAST RUNNING ALLMULTI MULTICAST  MTU:1500  Metric:1
  37.           RX packets:828 errors:0 dropped:0 overruns:0 frame:0
  38.           TX packets:482 errors:0 dropped:0 overruns:0 carrier:0
  39.           collisions:0 txqueuelen:0
  40.           RX bytes:64026 (62.5 KiB)  TX bytes:120204 (117.3 KiB)
复制代码
发表于 2020-5-11 21:13:25 | 显示全部楼层
大神,这玩意能刷openwrt吗
发表于 2020-5-11 21:49:46 | 显示全部楼层
厉害了,一个扩展坞功能这么牛
 楼主| 发表于 2020-5-11 22:44:48 来自手机浏览器 | 显示全部楼层
gdd714 发表于 2020-5-11 21:31
啥配置啊
bcm4709 16m+256m
配置还可以
发表于 2020-5-12 00:38:43 | 显示全部楼层
搜索了一下MAC Vendor,是个Universal Global Scientific Industrial
然后惊奇的发现
 楼主| 发表于 2020-5-12 07:11:19 | 显示全部楼层
然后惊奇的发现
牛xx,这都被你发现了。那是我们不可分割的一部分
发表于 2020-5-12 07:29:45 | 显示全部楼层
是通过什么接口与电脑连接的
发表于 2020-5-12 07:32:29 | 显示全部楼层
这做工和用料,太给力了……
 楼主| 发表于 2020-5-12 08:30:15 来自手机浏览器 | 显示全部楼层
yogi16888 发表于 2020-5-12 07:29
是通过什么接口与电脑连接的
usb3.0接电脑是dock模式,不接电脑上路由器模式,固件屏蔽了pppoe,但是实际上有。等大神给openwrt了
 楼主| 发表于 2020-5-12 08:42:12 来自手机浏览器 | 显示全部楼层
cj8510 发表于 2020-5-12 07:32
这做工和用料,太给力了……
相当不错,而且价格给力
发表于 2020-5-12 09:01:22 | 显示全部楼层
这做工真棒,不是咯些山货能比的
 楼主| 发表于 2020-5-12 09:18:12 | 显示全部楼层
upzx 发表于 2020-5-12 09:01
这做工真棒,不是咯些山货能比的
看着那些散热片就很精致
发表于 2020-5-12 09:41:15 | 显示全部楼层
已上车,等各位的玩法大全
发表于 2020-5-12 10:45:09 | 显示全部楼层
哪里买 大婶们 pm个链接
GMT+8, 2024-4-30 19:21 , Processed in 0.140400 second(s), 12 queries , Redis On.
© 2006-2023 smzj.net
