现有Tigo的PS3109 120G SSD 闪存 IG5802SAPH
v2.10
Drive: 0(ATA)
Model: SATAFIRM S9
Fw : S9FM01.6
Bank00: 0x2c,0x84,0x64,0x54,0xa9,0x0,0x0,0x0 - Micron MLC 128Gb/CE 128Gb/die
Bank01: 0x2c,0x84,0x64,0x54,0xa9,0x0,0x0,0x0 - Micron MLC 128Gb/CE 128Gb/die
Bank02: 0x2c,0x84,0x64,0x54,0xa9,0x0,0x0,0x0 - Micron MLC 128Gb/CE 128Gb/die
Bank03: 0x2c,0x84,0x64,0x54,0xa9,0x0,0x0,0x0 - Micron MLC 128Gb/CE 128Gb/die
Bank04: 0x2c,0x84,0x64,0x54,0xa9,0x0,0x0,0x0 - Micron MLC 128Gb/CE 128Gb/die
Bank05: 0x2c,0x84,0x64,0x54,0xa9,0x0,0x0,0x0 - Micron MLC 128Gb/CE 128Gb/die
Bank06: 0x2c,0x84,0x64,0x54,0xa9,0x0,0x0,0x0 - Micron MLC 128Gb/CE 128Gb/die
Bank07: 0x2c,0x84,0x64,0x54,0xa9,0x0,0x0,0x0 - Micron MLC 128Gb/CE 128Gb/die
Controller : Possible PS3109/11
Flash CE : 8
PS3105/3108/3109/3111 only:
Flash Channel: 4
Dram Size,MB : 32
PS3110 only :
Flash Channel: 255
Interleave : 4
Flash Mode/Clk: 0/0 (S9) or 0/0 (S11)
Defects All Early Later
Bank00: 44 44 0
Bank01: 44 44 0
Bank02: 44 44 0
Bank03: 68 68 0
Bank04: 44 44 0
Bank05: 44 44 0
Bank06: 44 44 0
Bank07: 70 70 0
Total : 402 402 0
请问换什么主控量产好?
可否与
v0.4a
Drive: 1(ATA)
Model: KINGSTON SV300S37A120G
Fw : 60AABBF0
--- SandForce specific ---
Signature : 138-0-33205
HW Revision : 500026BB (B04)
Try to unlock the drive (default)...
Drive unlocked (default)!
FW : [60AABBF0 ]
FW string : [B:FW_PPRO_5_6_1_20140326_836378:FW_PPRO_6_0_A_Release-1134440 ]
Config file : [cfg/cfg_MLC_Micron_128Gb_33bit_FT16B08UCM1-3B_2Q_1C_1D ]
ROM Revision: [400 ]
NAND ID : 0x2c, 0x84, 0x64, 0x54, 0xa9, 0x0, 0x0, 0x0
Page Size : 18256
NAND CE : 1
Sector/Page : 8
Die/CE : 1
Block/Die : 1024
Page/Block : 512
Raw Size : 268435456
NAND Max EC : 3000
Max PE Cycles : 3000
Cur PE Cycles : 62
Life In Seconds : 0 (Not Set)
LBA Size : 234441648
Sector Size : 512
Sector Align : +0
NAND ID : 0x2c,0x84
Serial Output Control : Default(Off)
Erase R Block : Disable
Panic Handling Enabled : Disable
Panic On SATA Error : Disable
Write Throttling Test Mode: Disable
R.A.I.S.E. : Disable
Flash CE : 8
一起,做成240G?该怎么贴? |
