查看: 3413|回复: 10
[配件] 全国包邮 2.8寸高清屏TFT液晶带触摸彩屏(另一块不带触屏)工业用ILI9325
发表于 2020-9-2 16:26:53 | 显示全部楼层 |阅读模式 IP属地:广东省清远市 移动
抢购价6000 家元市场参考价¥0.00
仅剩1件 已抢购0件
剩余时间 : 00天00小时00分00秒
浏览人气 : 3413
成功兑换商品后,将不能取消或更改,不提供退换货服务。
  • 参与时间
    参与状态
    参与会员
    数量
    参与金额
  • 暂无兑换记录
实物图:此款TFT液晶触摸显示屏兼容8/16位数据接口 标准37PIN 1.0mm间距
屏效果图:
初始化实例代码:
void Lcm_Initcode(void)
#if 0   // HSD2.4
//************* Start Initial Sequence **********//
LCD_CtrlWrite_ILI9325(0x0001, 0x0100); // set SS and SM bit
LCD_CtrlWrite_ILI9325(0x0002, 0x0700); // set 1 line inversion
LCD_CtrlWrite_ILI9325(0x0003, 0x1030); // set GRAM write direction and BGR=1.
LCD_CtrlWrite_ILI9325(0x0004, 0x0000); // Resize register
LCD_CtrlWrite_ILI9325(0x0008, 0x0207); // set the back porch and front porch
LCD_CtrlWrite_ILI9325(0x0009, 0x0000); // set non-display area refresh cycle ISC[3:0]
LCD_CtrlWrite_ILI9325(0x000A, 0x0000); // FMARK function
LCD_CtrlWrite_ILI9325(0x000C, 0x0000); // RGB interface setting
LCD_CtrlWrite_ILI9325(0x000D, 0x0000); // Frame marker Position
LCD_CtrlWrite_ILI9325(0x000F, 0x0000); // RGB interface polarity
//*************Power On sequence ****************//
LCD_CtrlWrite_ILI9325(0x0010, 0x0000); // SAP, BT[3:0], AP, DSTB, SLP, STB
LCD_CtrlWrite_ILI9325(0x0011, 0x0007); // DC1[2:0], DC0[2:0], VC[2:0]
LCD_CtrlWrite_ILI9325(0x0012, 0x0000); // VREG1OUT voltage
LCD_CtrlWrite_ILI9325(0x0013, 0x0000); // VDV[4:0] for VCOM amplitude
delayms(200); // Dis-charge capacitor power voltage
LCD_CtrlWrite_ILI9325(0x0010, 0x1290); // SAP, BT[3:0], AP, DSTB, SLP, STB
LCD_CtrlWrite_ILI9325(0x0011, 0x0227); // DC1[2:0], DC0[2:0], VC[2:0]
delayms(50); // Delay 50ms
LCD_CtrlWrite_ILI9325(0x0012, 0x001B); // Internal reference voltage= Vci;
LCD_CtrlWrite_ILI9325(0x0013, 0x1700); // Set VDV[4:0] for VCOM amplitude
LCD_CtrlWrite_ILI9325(0x0029, 0x001E); // Set VCM[5:0] for VCOMH
LCD_CtrlWrite_ILI9325(0x002B, 0x000D); // Set Frame Rate
LCD_CtrlWrite_ILI9325(0x0020, 0x0000); // GRAM horizontal Address
LCD_CtrlWrite_ILI9325(0x0021, 0x0000); // GRAM Vertical Address
// ----------- Adjust the Gamma Curve ----------//
LCD_CtrlWrite_ILI9325(0x0030, 0x0004);
LCD_CtrlWrite_ILI9325(0x0031, 0x0007);
LCD_CtrlWrite_ILI9325(0x0032, 0x0006);
LCD_CtrlWrite_ILI9325(0x0035, 0x0206);
LCD_CtrlWrite_ILI9325(0x0036, 0x0408);
LCD_CtrlWrite_ILI9325(0x0037, 0x0507);
LCD_CtrlWrite_ILI9325(0x0038, 0x0200);
LCD_CtrlWrite_ILI9325(0x0039, 0x0707);
LCD_CtrlWrite_ILI9325(0x003C, 0x0504);
LCD_CtrlWrite_ILI9325(0x003D, 0x0F02);
//------------------ Set GRAM area ---------------//
LCD_CtrlWrite_ILI9325(0x0050, 0x0000); // Horizontal GRAM Start Address
LCD_CtrlWrite_ILI9325(0x0051, 0x00EF); // Horizontal GRAM End Address
LCD_CtrlWrite_ILI9325(0x0052, 0x0000); // Vertical GRAM Start Address
LCD_CtrlWrite_ILI9325(0x0053, 0x013F); // Vertical GRAM Start Address
LCD_CtrlWrite_ILI9325(0x0060, 0xA700); // Gate Scan Line
LCD_CtrlWrite_ILI9325(0x0061, 0x0001); // NDL,VLE, REV
LCD_CtrlWrite_ILI9325(0x006A, 0x0000); // set scrolling line
//-------------- Partial Display Control ---------//
LCD_CtrlWrite_ILI9325(0x0080, 0x0000);
LCD_CtrlWrite_ILI9325(0x0081, 0x0000);
LCD_CtrlWrite_ILI9325(0x0082, 0x0000);
LCD_CtrlWrite_ILI9325(0x0083, 0x0000);
LCD_CtrlWrite_ILI9325(0x0084, 0x0000);
LCD_CtrlWrite_ILI9325(0x0085, 0x0000);
//-------------- Panel Control -------------------//
LCD_CtrlWrite_ILI9325(0x0090, 0x0010);
LCD_CtrlWrite_ILI9325(0x0092, 0x0600);
LCD_CtrlWrite_ILI9325(0x0093, 0x0003);
LCD_CtrlWrite_ILI9325(0x0095, 0x0110);
LCD_CtrlWrite_ILI9325(0x0097, 0x0000);
LCD_CtrlWrite_ILI9325(0x0098, 0x0000);
LCD_CtrlWrite_ILI9325(0x0007, 0x0133); // 262K color and display ON
#endif
#if 0  // CMO 2414
LCD_CtrlWrite_ILI9325D(0x0001, 0x0100);        // set SS and SM bit
LCD_CtrlWrite_ILI9325D(0x0002, 0x0700);        // set 1 line inversion
LCD_CtrlWrite_ILI9325D(0x0003, 0x1030);        // set GRAM write direction and BGR=1.
LCD_CtrlWrite_ILI9325D(0x0004, 0x0000);        // Resize register
LCD_CtrlWrite_ILI9325D(0x0008, 0x0202);        // set the back porch and front porch
LCD_CtrlWrite_ILI9325D(0x0009, 0x0000);        // set non-display area refresh cycle ISC[3:0]
LCD_CtrlWrite_ILI9325D(0x000A, 0x0000);        // FMARK function
LCD_CtrlWrite_ILI9325D(0x000C, 0x0000);        // RGB interface setting
LCD_CtrlWrite_ILI9325D(0x000D, 0x0000);        // Frame marker Position
LCD_CtrlWrite_ILI9325D(0x000F, 0x0000);          // RGB interface polarity
LCD_CtrlWrite_ILI9325D(0x0010, 0x0000);            // SAP, BT[3:0], AP, DSTB, SLP, STB
LCD_CtrlWrite_ILI9325D(0x0011, 0x0007);            // DC1[2:0], DC0[2:0], VC[2:0]
LCD_CtrlWrite_ILI9325D(0x0012, 0x0000);            // VREG1OUT voltage
LCD_CtrlWrite_ILI9325D(0x0013, 0x0000);            // VDV[4:0] for VCOM amplitude
LCD_CtrlWrite_ILI9325D(0x0007, 0x0001);
LCD_CtrlWrite_ILI9325D(0x0010, 0x1690);            // SAP, BT[3:0], AP, DSTB, SLP, STB
LCD_CtrlWrite_ILI9325D(0x0011, 0x0227);            // Set DC1[2:0], DC0[2:0], VC[2:0]
LCD_CtrlWrite_ILI9325D(0x0012, 0x009C);            // External reference voltage= Vci;
LCD_CtrlWrite_ILI9325D(0x0013, 0x1800);            // VDV[4:0] for VCOM amplitude
LCD_CtrlWrite_ILI9325D(0x0029, 0x0008);            // VCM[5:0] for VCOMH
LCD_CtrlWrite_ILI9325D(0x002B, 0x000D);            // Set Frame Rate
LCD_CtrlWrite_ILI9325D(0x0020, 0x0000);            // GRAM horizontal Address
LCD_CtrlWrite_ILI9325D(0x0021, 0x0000);            // GRAM Vertical Address
LCD_CtrlWrite_ILI9325D(0x0030, 0x0000);
LCD_CtrlWrite_ILI9325D(0x0031, 0x0406);
LCD_CtrlWrite_ILI9325D(0x0032, 0x0004);
LCD_CtrlWrite_ILI9325D(0x0035, 0x0305);
LCD_CtrlWrite_ILI9325D(0x0036, 0x0004);
LCD_CtrlWrite_ILI9325D(0x0037, 0x0207);
LCD_CtrlWrite_ILI9325D(0x0038, 0x0103);
LCD_CtrlWrite_ILI9325D(0x0039, 0x0707);
LCD_CtrlWrite_ILI9325D(0x003C, 0x0503);
LCD_CtrlWrite_ILI9325D(0x003D, 0x0004);
LCD_CtrlWrite_ILI9325D(0x0050, 0x0000);          // Horizontal GRAM Start Address
LCD_CtrlWrite_ILI9325D(0x0051, 0x00EF);          // Horizontal GRAM End Address
LCD_CtrlWrite_ILI9325D(0x0052, 0x0000);          // Vertical GRAM Start Address
LCD_CtrlWrite_ILI9325D(0x0053, 0x013F);          // Vertical GRAM Start Address
LCD_CtrlWrite_ILI9325D(0x0060, 0xA700);          // Gate Scan Line
LCD_CtrlWrite_ILI9325D(0x0061, 0x0001);          // NDL,VLE, REV
LCD_CtrlWrite_ILI9325D(0x006A, 0x0000);          // set scrolling line
LCD_CtrlWrite_ILI9325D(0x0080, 0x0000);
LCD_CtrlWrite_ILI9325D(0x0081, 0x0000);
LCD_CtrlWrite_ILI9325D(0x0082, 0x0000);
LCD_CtrlWrite_ILI9325D(0x0083, 0x0000);
LCD_CtrlWrite_ILI9325D(0x0084, 0x0000);
LCD_CtrlWrite_ILI9325D(0x0085, 0x0000);
LCD_CtrlWrite_ILI9325D(0x0090, 0x0010);
LCD_CtrlWrite_ILI9325D(0x0092, 0x0600);
LCD_CtrlWrite_ILI9325D(0x0007, 0x0133);          // 262K color and display ON
#endif
// CPT2.8+ILI9325D
LCD_CtrlWrite_ILI9325D(0x0011, 0x0227); // DC1[2:0], DC0[2:0], VC[2:0]
LCD_CtrlWrite_ILI9325D(0x0012, 0x009D); // Internal reference voltage= Vci;
LCD_CtrlWrite_ILI9325D(0x0013, 0x1900); // Set VDV[4:0] for VCOM amplitude
LCD_CtrlWrite_ILI9325D(0x0029, 0x0025); // Set VCM[5:0] for VCOMH
LCD_CtrlWrite_ILI9325D(0x0030, 0x0007);
LCD_CtrlWrite_ILI9325D(0x0031, 0x0303);
LCD_CtrlWrite_ILI9325D(0x0032, 0x0003);
LCD_CtrlWrite_ILI9325D(0x0035, 0x0206);
LCD_CtrlWrite_ILI9325D(0x0036, 0x0008);
LCD_CtrlWrite_ILI9325D(0x0037, 0x0406);
LCD_CtrlWrite_ILI9325D(0x0038, 0x0304);
LCD_CtrlWrite_ILI9325D(0x0039, 0x0007);
LCD_CtrlWrite_ILI9325D(0x003C, 0x0602);
LCD_CtrlWrite_ILI9325D(0x003D, 0x0008);
发表于 2020-9-2 17:08:39 | 显示全部楼层 IP属地:浙江省宁波市 电信
 楼主| 发表于 2020-9-2 17:13:45 | 显示全部楼层 IP属地:广东省清远市 移动
发表于 2020-9-2 21:26:11 | 显示全部楼层 IP属地:广东省深圳市 电信
 楼主| 发表于 2020-9-2 22:08:34 | 显示全部楼层 IP属地:广东省清远市 电信
发表于 2020-9-3 14:10:59 | 显示全部楼层 IP属地:河北省石家庄市 联通
 楼主| 发表于 2020-9-3 14:28:45 | 显示全部楼层 IP属地:广东省清远市 电信
发表于 2020-9-3 14:36:18 | 显示全部楼层 IP属地:河北省石家庄市 联通
 楼主| 发表于 2020-9-3 15:01:53 | 显示全部楼层 IP属地:广东省清远市 电信
发表于 2020-9-8 17:00:50 | 显示全部楼层 IP属地:甘肃省白银市 电信
 楼主| 发表于 2020-9-8 18:56:19 | 显示全部楼层 IP属地:广东省清远市 移动
GMT+8, 2025-12-27 13:34 , Processed in 0.499201 second(s), 15 queries , Gzip On, Redis On.
