查看: 6993|回复: 7
[SandForce] 英特尔老顽固535开卡80%format失败
发表于 2020-9-2 19:54:59 | 显示全部楼层 |阅读模式
我用5R的固件去碰运气,5R固件就很多,整了一天固态硬盘了,我用的是U盘量产网下载的centOS系统和开卡工具包,练了一下会用了,开卡,进度到80%就format失败了,作者留下的535配置文件也用了,似乎都无效,external write protect两个选项都试过没用,软件也更新至1.7.2了。我还是选小容量的,难道主控不支持开卡?
Starting command:[/media/8A67-C9B1/新建文件夹/SF_Genesis -PROCESS_SSD 26:0:0:0 "/root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp" "/root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/hy/29725.12345.240.edriveconfig" 123 456  LOG="/root/Desktop/123_localhost.localdomain_DATETIMESTAMP_26.0.0.0_PROCESS_SSD_RESULT.log"   19:0:0:0]...
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Wed 09/02/2020 19:00:54] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 26:0:0:0
                      argv[3]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
                      argv[4]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/hy/29725.12345.240.edriveconfig
                      argv[5]: 123
                      argv[6]: 456
                      argv[7]: LOG=/root/Desktop/123_localhost.localdomain_DATETIMESTAMP_26.0.0.0_PROCESS_SSD_RESULT.log
                      argv[8]: 19:0:0:0
[Wed 09/02/2020 19:00:54] - Instructing the operating system to purge any existing cached data for device: '26:0:0:0'
[Wed 09/02/2020 19:00:59] - Issuing a discovery command for device: '26:0:0:0'
[Wed 09/02/2020 19:01:05] - Discovery command completed...
[Wed 09/02/2020 19:01:05] - Waiting 5 seconds for the system to settle...
[Wed 09/02/2020 19:01:10] - Device designation string '26:0:0:0' is mapped to node '/dev/sg2'
[Wed 09/02/2020 19:01:10] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
      Configuration File = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/hy/29725.12345.240.edriveconfig
              Serial No. = 123
         World Wide Name = 456
[Wed 09/02/2020 19:01:10] - Successfully received the IDENTIFY data from the drive...
[Wed 09/02/2020 19:01:10] - Validating Manufacturing Firmware Package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Wed 09/02/2020 19:01:10] - Successfully opened the package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Wed 09/02/2020 19:01:10] - File : /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/hy/29725.12345.240.edriveconfig in processing ...
[Wed 09/02/2020 19:01:10] - file  /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/hy/29725.12345.240.edriveconfig Loaded successfully
[Wed 09/02/2020 19:01:10] - Warning:  Unable to query diagnostics information to perform power management settings check
[Wed 09/02/2020 19:01:10] - B01 Power Management configuration request detected
[Wed 09/02/2020 19:01:10] - Successfully extracted *.DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/hy/29725.12345.240.edriveconfig
[Wed 09/02/2020 19:01:10] - Extracted Config_ID: 1 (29725) in DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/hy/29725.12345.240.edriveconfig
[Wed 09/02/2020 19:01:10] - Extracted SerialOutputControl: 0
[Wed 09/02/2020 19:01:10] - Searching for flashware image for configuration 29725
[Wed 09/02/2020 19:01:10] - Manifest found for configuration 29725
[Wed 09/02/2020 19:01:10] - Flashware image extracted: 29725_fw_cl_mlc_Hynix_RDD_64Gb_H27QDG8UDE5R_2Q_2C_1D_PP_R03147_s512.vic
[Wed 09/02/2020 19:01:10] - Searching for manufacturing image for configuration 29725
[Wed 09/02/2020 19:01:10] - Manufacturing image extracted: 29725_mf_mlc_Hynix_RDD_64Gb_H27QDG8UDE5R_2Q_2C_1D_PP_R03147_s512.vic
[Wed 09/02/2020 19:01:10] - Proceeding in ROM mode, download feature 3...
[Wed 09/02/2020 19:01:10] - Successfully downloaded MFB to the drive...
[Wed 09/02/2020 19:01:10] - Waiting (5 sec) for the drive to settle...
[Wed 09/02/2020 19:01:15] - Successfully received the IDENTIFY data from the drive...
[Wed 09/02/2020 19:01:15] - Firmware revision reported to be: '60AABBM0'.  This indicates MFB download was successful.
[Wed 09/02/2020 19:01:15] - Successfully enabled SMART capabilities...
[Wed 09/02/2020 19:01:18] - Successfully issued a diagnostic unlock...
[Wed 09/02/2020 19:01:19] - Performing the flash test of block 0 (0x0000)...
[Wed 09/02/2020 19:01:21] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 2
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 2    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 1    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 3    | 0x0022 | N3,N5                                      | WARNING |
  Total Number of test results: 16
            Number of failures: 0
         Number of Passed with warnings: 16
      No. Passed without warnings: 0
[Wed 09/02/2020 19:01:21] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 250069680
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 57005 (0xDEAD)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Wed 09/02/2020 19:01:28] - FATAL_ERROR: Could not perform the FORMAT() operation on the drive... (0x12000005:SF_SG_HOST_ABORT_ERROR)
[Wed 09/02/2020 19:01:28] - End of Genesis manufacturing log.
[Wed 09/02/2020 19:01:28] - Exiting...
[Wed 09/02/2020 19:01:28] - Overall Result for Device: /dev/sg2 ****** FAIL ******
Process exited with code 8
发表于 2020-9-2 21:43:19 | 显示全部楼层
发表于 2020-9-2 23:32:06 来自手机浏览器 | 显示全部楼层
发表于 2020-9-3 07:55:21 | 显示全部楼层
发表于 2020-9-3 09:04:04 | 显示全部楼层
发表于 2020-9-3 16:06:51 | 显示全部楼层
发表于 2020-9-3 16:55:18 | 显示全部楼层
发表于 2020-9-7 21:23:26 | 显示全部楼层
GMT+8, 2025-12-20 07:42 , Processed in 0.234000 second(s), 11 queries , Gzip On, Redis On.
