查看: 2700|回复: 1
哪位高手能帮忙改下阿里云的ddns.sh文件改成华为云的
发表于 2020-10-24 20:58:18 | 显示全部楼层 |阅读模式
用来访问群辉的,原先用的是别人写好的阿里云的ddns.sh。现在阿里云到期了就换成华为云了 但是这个ddns.sh文件不会改啊,高手给改一改吧
原先阿里云的ddns.sh文件https://pan.baidu.com/share/init?surl=zNHFaSSq5Sz2o2vaj6YbHA提取码:c91u
我是照着人家的帖子做的,https://post.smzdm.com/p/a4w0z2gk/;https://post.smzdm.com/p/adwrq56p/https://post.smzdm.com/p/ax027ww9/
大佬可以参考下
#!/bin/sh
aliddnsipv6_ak="XXXXXXXXXXX"
aliddnsipv6_sk="XXXXXXXXXXX"
aliddnsipv6_name1='nas'
aliddnsipv6_domain='XXXX.cn'
aliddnsipv6_ttl="600"
if [ "$aliddnsipv6_name1" = "@" ]
then
  aliddnsipv6_name=$aliddnsipv6_domain
else
  aliddnsipv6_name=$aliddnsipv6_name1.$aliddnsipv6_domain
fi
now=`date`
die () {
    echo $1
ipv6s=`ip addr show eth0 | grep "inet6.2409" | awk '{print $2}' | awk -F"/" '{print $1}'` || die "$ipv6"
for ipv6 in $ipv6s
do
  #ipv6 = $ipv6
  break
done
echo $ipv6
current_ipv6=`nslookup -query=AAAA $aliddnsipv6_name 2>&1`
#echo $current_ipv6
current_ipv6=`echo "$current_ipv6" | grep 'Address: ' | tail -n1 | awk '{print $NF}'`
echo $current_ipv6
if [ "$?" -eq "0" ]
then
    echo $current_ipv6
    if [ "$ipv6" = "$current_ipv6" ]
    then
        echo "skipping"
    fi
# fix when A record removed by manual dns is always update error
else
    unset aliddnsipv6_record_id
fi
timestamp=`date -u "+%Y-%m-%dT%H%%3A%M%%3A%SZ"`
urlencode() {
    # urlencode <string>
    out=""
    while read -n1 c
    do
        case $c in
            [a-zA-Z0-9._-]) out="$out$c" ;;
            *) out="$out`printf '%%%02X' "'$c"`" ;;
        esac
    done
    echo -n $out
enc() {
    echo -n "$1" | urlencode
send_request() {
    local args="AccessKeyId=$aliddnsipv6_ak&Action=$1&Format=json&$2&Version=2015-01-09"
    local hash=$(echo -n "GET&%2F&$(enc "$args")" | openssl dgst -sha1 -hmac "$aliddnsipv6_sk&" -binary | openssl base64)
    curl -s "http://alidns.aliyuncs.com/?$args&Signature=$(enc "$hash")"
get_recordid() {
    grep -Eo '"RecordId":"[0-9]+"' | cut -d':' -f2 | tr -d '"'
query_recordid() {
    send_request "DescribeSubDomainRecords" "SignatureMethod=HMAC-SHA1&SignatureNonce=$timestamp&SignatureVersion=1.0&SubDomain=$aliddnsipv6_name&Timestamp=$timestamp&Type=AAAA"
update_record() {
    send_request "UpdateDomainRecord" "RR=$aliddnsipv6_name1&RecordId=$1&SignatureMethod=HMAC-SHA1&SignatureNonce=$timestamp&SignatureVersion=1.0&TTL=$aliddnsipv6_ttl&Timestamp=$timestamp&Type=AAAA&Value=$(enc $ipv6)"
add_record() {
    send_request "AddDomainRecord&DomainName=$aliddnsipv6_domain" "RR=$aliddnsipv6_name1&SignatureMethod=HMAC-SHA1&SignatureNonce=$timestamp&SignatureVersion=1.0&TTL=$aliddnsipv6_ttl&Timestamp=$timestamp&Type=AAAA&Value=$(enc $ipv6)"
#add support */%2A and @/%40 record
if [ "$aliddnsipv6_record_id" = "" ]
then
    aliddnsipv6_record_id=`query_recordid | get_recordid`
    #echo '-----------------' $aliddnsipv6_record_id
fi
then
    aliddnsipv6_record_id=`add_record | get_recordid`
    echo "added record $aliddnsipv6_record_id"
else
    update_record $aliddnsipv6_record_id
    echo "updated record $aliddnsipv6_record_id"
fi
 楼主| 发表于 2020-10-28 17:25:19 | 显示全部楼层
在网上找到了一个华为云的ddns,但是看到还得输入账号密码,那个大神能给看看有什么问题没?
https://github.com/iLay1678/huaweicloud_ddns/tree/ipv6
GMT+8, 2025-5-10 20:42 , Processed in 0.171601 second(s), 11 queries , Redis On.
