查看: 3534|回复: 4
[Phison] 这个msata还有得救没呀 找不到合适的固件
发表于 2020-12-19 18:42:06 | 显示全部楼层 |阅读模式
找不到合适的固件,固态上贴的闪迪标签
v0.772a
Drive: 1(ATA)
OS: 10.0 build 18363
Model: INIC6081SSDWP
Fw   : INICWP00
P/N  :
S11fw: SBFGR1T3, 2019Jun20
Bank00: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0xec,0x1c - Samsung 3d-64L TLC 16k
Bank04: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0xec,0x1c - Samsung 3d-64L TLC 16k
Bank09: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0xec,0x1c - Samsung 3d-64L TLC 16k
Bank11: 0xec,0x1c,0x98,0x3f,0x84,0xcb,0xec,0x1c - Samsung 3d-64L TLC 16k
Controller   : Possible PS3109 or PS3111
Flash CE     : 4
PS3105/3108/3109/3111 only:
Flash Channel: 2
Dram Size,MB : 32
PS3110 only  :
Flash Channel: 5
Interleave   : 2
Flash Mode/Clk: 0/0 (S9) or 3/7 (S11)
Defects All Early Later
Bank00:   9   9   0
Bank04:   7   7   0
Bank09:  15   6   9
Bank11:  17   6  11
Total :  48  28  20
Early defect list
Bank00: 20 200 201 1390 1391 1392 1393 1408 1409
Bank04: 16 1390 1391 1392 1393 1408 1409
Bank09: 1390 1391 1392 1393 1408 1409
Bank11: 1390 1391 1392 1393 1408 1409
Later defect list
Bank09: 1166 1167 2346 2422 2423 2748 2749 2750 2751
Bank11: 1158 1159 1238 1239 1858 2428 2429 2740 2741 2742 2743
PS3111 smart configuration:
Attr Tresh Flags ValId WrstId  RawId   Description
0x01: 0x32 0x0B 0x0100 0x0100 0x0100 - Number of ECC Error
0x05: 0x00 0x00 0x0000 0x0000 0x0302 - Total Later Bad Block Count
0x09: 0x00 0x32 0x0000 0x0000 0x0600 - Power on hours
0x0C: 0x00 0x00 0x0000 0x0000 0x0607 - Power on/off cycles
0xA0: 0x00 0x00 0x0000 0x0000 0x0500 - Read Fail Count
0xA1: 0x00 0x00 0x0000 0x0000 0x0001 - Return All Zero Data
0xA3: 0x00 0x00 0x0000 0x0000 0x0001 - Return All Zero Data
0xA5: 0x00 0x00 0x0000 0x0000 0x0201 - Max Erase Count
0xA6: 0x00 0x00 0x0000 0x0000 0x020B - Min Erase Cnt
0xA7: 0x00 0x00 0x0000 0x0000 0x0202 - Avg Erase Count
0xC0: 0x00 0x00 0x0000 0x0000 0x0608 - Unexpected Power Loss Count
0xC2: 0x00 0x00 0x0000 0x0000 0x0801 - Current Temp
0xC3: 0x00 0x00 0x0000 0x0000 0xF010 - HB retry count
0xC4: 0x00 0x00 0x0000 0x0000 0x0001 - Return All Zero Data
0xC7: 0x00 0x00 0x0000 0x0000 0x0001 - Return All Zero Data
0xF1: 0x00 0x00 0x0000 0x0000 0x0403 - Host Write (65536 Sectors)
0xF2: 0x00 0x00 0x0000 0x0000 0x0423 - Host Read (65536 Sectors)
发表于 2020-12-19 22:32:30 | 显示全部楼层
明明是三星的颗粒 ID都是三星颗粒的 这个配置好像暂时没有 固件
 楼主| 发表于 2020-12-22 20:47:18 来自手机浏览器 | 显示全部楼层
固态上贴的闪迪128G标签,主控是群联ps3111-s11-13内存颗粒是三星的吧
发表于 2023-9-18 15:16:37 | 显示全部楼层
我也遇到了相同的问题
发表于 2023-9-23 11:35:24 | 显示全部楼层
6081不是有开卡工具了吗?
GMT+8, 2025-8-2 22:38 , Processed in 0.140400 second(s), 9 queries , Redis On.
