查看: 5790|回复: 3
[SandForce] 关于intel 535的sf2281开卡问题
发表于 2021-1-28 10:49:17 | 显示全部楼层 |阅读模式
我换了8篇64Bnemcf2开卡id选33060,短接rom上电开卡失败,错误信息如下:
  1. SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
  2. SF_Core Library: v1.7.1.20130612-fc14-32bit
  3. Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
  4. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  5. [Thu 01/28/2021 10:34:26] - SF_Genesis has been invoked with the following parameters:
  6.                      ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  7.                       argv[1]: -PROCESS_SSD
  8.                       argv[2]: 7:0:0:0
  9.                       argv[3]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
  10.                       argv[4]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/33387.12345.driveconfig
  11.                       argv[5]: 12345
  12.                       argv[6]: www_123
  13.                       argv[7]: log=/root/Desktop/sf2281/log/
  14.                      ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  15. [Thu 01/28/2021 10:34:26] - Instructing the operating system to purge any existing cached data for device: '7:0:0:0'
  16. [Thu 01/28/2021 10:34:31] - Issuing a discovery command for device: '7:0:0:0'
  17. [Thu 01/28/2021 10:34:36] - Discovery command completed...
  18. [Thu 01/28/2021 10:34:36] - Waiting 5 seconds for the system to settle...
  19. [Thu 01/28/2021 10:34:41] - Device designation string '7:0:0:0' is mapped to node '/dev/sg2'
  20. [Thu 01/28/2021 10:34:41] - Proceeding to process SSD device with the following parameters:
  21.   ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  22.               DeviceName = /dev/sg2
  23.     MFP Package Filename = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
  24.       Configuration File = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/33387.12345.driveconfig
  25.               Serial No. = 12345
  26.          World Wide Name = www_123
  27.   ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  28. [Thu 01/28/2021 10:34:42] - Successfully received the IDENTIFY data from the drive...
  29. [Thu 01/28/2021 10:34:42] - Validating Manufacturing Firmware Package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
  30. [Thu 01/28/2021 10:34:42] - Successfully opened the package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
  31. [Thu 01/28/2021 10:34:42] - file  /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/33387.12345.driveconfig Loaded successfully
  32. [Thu 01/28/2021 10:34:42] - Warning:  Unable to query diagnostics information to perform power management settings check
  33. [Thu 01/28/2021 10:34:42] - B01 Power Management configuration request detected
  34. [Thu 01/28/2021 10:34:42] - Successfully extracted *.DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/33387.12345.driveconfig
  35. [Thu 01/28/2021 10:34:42] - Extracted Config_ID: 1 (33387) in DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/33387.12345.driveconfig
  36. [Thu 01/28/2021 10:34:42] - Extracted SerialOutputControl: 0
  37. [Thu 01/28/2021 10:34:42] - Searching for flashware image for configuration 33387
  38. [Thu 01/28/2021 10:34:42] - Manifest found for configuration 33387
  39. [Thu 01/28/2021 10:34:42] - Flashware image extracted: 33387_fw_cl_mlc_Intel_128Gb_generic_PF29F64B08NCMF3_2Q_4C_1D_PP_R02567_s512.vic
  40. [Thu 01/28/2021 10:34:42] - Searching for manufacturing image for configuration 33387
  41. [Thu 01/28/2021 10:34:42] - Manifest found for configuration 33387
  42. [Thu 01/28/2021 10:34:42] - Manufacturing image extracted: 33387_mf_mlc_Intel_128Gb_generic_PF29F64B08NCMF3_2Q_4C_1D_PP_R02567_s512.vic
  43. [Thu 01/28/2021 10:34:42] - Proceeding in non-ROM mode, Download feature 3...
  44. [Thu 01/28/2021 10:34:49] - FATAL_ERROR: Could not download MFB to the drive...(0x12000005:SF_SG_HOST_ABORT_ERROR)
  45. [Thu 01/28/2021 10:34:49] - End of Genesis manufacturing log.
  46. [Thu 01/28/2021 10:34:49] - Exiting...
  47. [Thu 01/28/2021 10:34:49] - Overall Result for Device: /dev/sg2 ****** FAIL******
复制代码
求大神指导,这个板子有没有解?
发表于 2021-1-28 12:57:33 | 显示全部楼层
卡不懂这个/ 到%多少错误 30%以前是 ID 颗粒 或者板子 短接 错误/30%以后就是测试颗粒PASS还是FAIL/ %70-80之间错误是写保护/90%之后错误多半是供电 用SATA接口看
 楼主| 发表于 2021-1-28 13:18:06 来自手机浏览器 | 显示全部楼层
527945545 发表于 2021-1-28 12:57
卡不懂这个/ 到%多少错误 30%以前是 ID 颗粒 或者板子 短接 错误/30%以后就是测试颗粒PASS还是FAIL/ %70-80 ...
还没到颗粒测试,看来是搞不定,还是换46en吧
发表于 2023-7-26 02:01:30 | 显示全部楼层
bga看起来好难玩的样子
GMT+8, 2025-7-23 03:58 , Processed in 0.436801 second(s), 11 queries , Redis On.
