查看: 13867|回复: 28
[Phison] 求助 PS3111-S11主控的SSD修复SATAFIRM S11
发表于 2021-3-12 20:23:31 | 显示全部楼层 |阅读模式
  在下有块金士顿的SA400 240G的固态硬盘,它自己想不开变成SATAFIRM   S11,在咱们论坛找了点资料,尝试修复一下,遇到如下问题,请各位大神伸出援手,拜谢!
SSD标签信息如下:
用 phison_flash_id84 检测结果如下:
v0.84a
Drive: 5(USB)
OS: 10.0 build 19042
Model: SATAFIRM   S11
Fw   : SBFK71W0
P/N  : 7829443
S11fw: SBFK71E0, 2017Feb23
S11rv: K71E0-86
Original Model: KINGSTON SA400S37240G
Bank00: 0x2c,0xb4,0x78,0x32,0xaa,0x4,0x0,0x0 - Micron 32L(B0KB) TLC 384Gb/CE 384Gb/die
Bank01: 0x2c,0xb4,0x78,0x32,0xaa,0x4,0x0,0x0 - Micron 32L(B0KB) TLC 384Gb/CE 384Gb/die
Bank02: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank03: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank04: 0x2c,0xb4,0x78,0x32,0xaa,0x4,0x0,0x0 - Micron 32L(B0KB) TLC 384Gb/CE 384Gb/die
Bank05: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank06: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank07: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank08: 0x2c,0xb4,0x78,0x32,0xaa,0x4,0x0,0x0 - Micron 32L(B0KB) TLC 384Gb/CE 384Gb/die
Bank09: 0x2c,0xb4,0x78,0x32,0xaa,0x4,0x0,0x0 - Micron 32L(B0KB) TLC 384Gb/CE 384Gb/die
Bank10: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank11: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank12: 0x2c,0xb4,0x78,0x32,0xaa,0x4,0x0,0x0 - Micron 32L(B0KB) TLC 384Gb/CE 384Gb/die
Bank13: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank14: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank15: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Controller    : PS3111
Flash CE      : 6
Flash Channel : 2
Dram Size,MB  : 32
Flash CE Mask : [++--+--- ++--+---]
Flash Mode/Clk: 5/7 (Set 5/7)
Block per Die : 2192
Block per CE  : 2192
Page per Block: 1536
SLC Cache     : Default
PE Cycle Limit: 1000
MaxBBPerPlane : 79
IOCtl: ReadParamPage failed 0x45d!
ParPage   : 00
Plane : 4
Defects        All(per plane)        Early                Later
IOCtl: APKey2 failed 0x45d!
IOCtl: APKey2 failed 0x37!
Total :          0                  0                  0
Early defect list
Later defect list
IOCtl: APKey2 failed 0x2!
IOCtl: ReadInfoBlock28 failed 0x2!
PS3111 smart configuration:
Attr Tresh Flags ValId WrstId  RawId   Description
问1,不知道用哪个固件,请教了!我用了图中黄色标注的固件都不行。
问2,在s11-flasher2.13 里用以上两个固件分别 释放出的fw.exe 的,再运行就出现 无法识别 硬件的信息,请教 如下:
请问为什么会这样啊?
附:下载的固件里有个文件说:
mdl_restricted,A400
fw_restricted,SBFK71E0:SBFK71B1
allow_primary
请问是什么意思 ?
另外,需要文件的可以向我索要,谢谢!
发表于 2021-3-12 22:18:15 | 显示全部楼层
发表于 2021-3-13 13:32:06 | 显示全部楼层
 楼主| 发表于 2021-3-13 15:53:11 来自手机浏览器 | 显示全部楼层
发表于 2021-3-14 20:48:12 | 显示全部楼层
发表于 2021-4-23 10:04:08 | 显示全部楼层
发表于 2021-8-25 16:03:07 | 显示全部楼层
发表于 2021-8-28 21:31:25 | 显示全部楼层
发表于 2021-11-25 12:37:47 | 显示全部楼层
发表于 2021-11-25 15:55:56 | 显示全部楼层
发表于 2021-11-25 16:08:29 | 显示全部楼层
发表于 2021-12-11 16:57:06 | 显示全部楼层
发表于 2022-2-7 22:00:35 | 显示全部楼层
发表于 2022-2-14 13:06:17 | 显示全部楼层
发表于 2022-2-14 13:08:24 | 显示全部楼层
发表于 2022-2-24 10:51:16 | 显示全部楼层
发表于 2022-3-27 19:43:03 | 显示全部楼层
发表于 2022-5-1 18:45:59 | 显示全部楼层
发表于 2022-5-6 01:03:58 | 显示全部楼层
发表于 2022-7-7 23:05:53 | 显示全部楼层
GMT+8, 2025-12-26 12:10 , Processed in 0.202800 second(s), 11 queries , Gzip On, Redis On.
