ssd基本信息:
型号:外壳 premier pro sp900 128Gb
板上标签 ASP900S7-128GM
主控:2241VB4
闪存:丝印 ADATA 60075959 5301472666 正反面总共8片
SF ID检测工具结果 MT29F256G08CEECB
写入31033和31027均校验失败
sudo ./SF_Genesis -PROCESS_SSD 2:0:0:0 /home/jack/tmp/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp /home/jack/tmp/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/31026.123456.driveconfig 123456 www_123 log=/home/jack/tmp/adata.log
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Tue 06/15/2021 22:32:49] - SF_Genesis has been invoked with the following parameters:
argv[1]: -PROCESS_SSD
argv[2]: 2:0:0:0
argv[3]: /home/jack/tmp/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
argv[4]: /home/jack/tmp/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/31026.123456.driveconfig
argv[5]: 123456
argv[6]: www_123
argv[7]: log=/home/jack/tmp/adata.log
[Tue 06/15/2021 22:32:49] - Instructing the operating system to purge any existing cached data for device: '2:0:0:0'
[Tue 06/15/2021 22:32:54] - Issuing a discovery command for device: '2:0:0:0'
[Tue 06/15/2021 22:32:59] - Discovery command completed...
[Tue 06/15/2021 22:32:59] - Waiting 5 seconds for the system to settle...
[Tue 06/15/2021 22:33:04] - Device designation string '2:0:0:0' is mapped to node '/dev/sg2'
[Tue 06/15/2021 22:33:04] - Proceeding to process SSD device with the following parameters:
DeviceName = /dev/sg2
MFP Package Filename = /home/jack/tmp/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
Configuration File = /home/jack/tmp/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/31026.123456.driveconfig
Serial No. = 123456
World Wide Name = www_123
[Tue 06/15/2021 22:33:04] - Successfully received the IDENTIFY data from the drive...
[Tue 06/15/2021 22:33:04] - Validating Manufacturing Firmware Package: /home/jack/tmp/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Tue 06/15/2021 22:33:07] - Successfully opened the package: /home/jack/tmp/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Tue 06/15/2021 22:33:07] - file /home/jack/tmp/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/31026.123456.driveconfig Loaded successfully
[Tue 06/15/2021 22:33:15] - B01 Power Management configuration request detected
[Tue 06/15/2021 22:33:15] - B01 Power Management conforms to hardware version 0x0
[Tue 06/15/2021 22:33:15] - Successfully extracted *.DriveConfig file: /home/jack/tmp/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/31026.123456.driveconfig
[Tue 06/15/2021 22:33:15] - Extracted Config_ID: 1 (31026) in DriveConfig file: /home/jack/tmp/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/31026.123456.driveconfig
[Tue 06/15/2021 22:33:15] - Extracted SerialOutputControl: 0
[Tue 06/15/2021 22:33:15] - Searching for flashware image for configuration 31026
[Tue 06/15/2021 22:33:15] - Manifest found for configuration 31026
[Tue 06/15/2021 22:33:15] - Flashware image extracted: 31026_fw_cl_mlc_MIC_128Gb_MT29F128G08CBCAB_1Q_2C_1D_S_PP_R02631_s512.vic
[Tue 06/15/2021 22:33:15] - Searching for manufacturing image for configuration 31026
[Tue 06/15/2021 22:33:15] - Manufacturing image extracted: 31026_mf_mlc_MIC_128Gb_MT29F128G08CBCAB_1Q_2C_1D_S_PP_R02631_s512.vic
[Tue 06/15/2021 22:33:15] - Proceeding in ROM mode, download feature 3...
[Tue 06/15/2021 22:33:16] - Successfully downloaded MFB to the drive...
[Tue 06/15/2021 22:33:16] - Waiting (5 sec) for the drive to settle...
[Tue 06/15/2021 22:33:21] - Successfully received the IDENTIFY data from the drive...
[Tue 06/15/2021 22:33:21] - Firmware revision reported to be: '582ABBM0'. This indicates MFB download was successful.
[Tue 06/15/2021 22:33:21] - Successfully enabled SMART capabilities...
[Tue 06/15/2021 22:33:23] - Successfully issued a diagnostic unlock...
[Tue 06/15/2021 22:33:24] - Performing the flash test of block 0 (0x0000)...
[Tue 06/15/2021 22:33:25] - Flash Test Results:
Flash Test Parameters:
Block Count: 0
Page Count: 1
Bus Count: 1
Chip Enabled Count: 2
Die Count: 1
Lane Count: 4
Plane Count: 2
Results Notes:
N1 - At least one page tested and passed with no bit errors.
N2 - No test data available. Test may have aborted, or failed during the testing.
N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
N4 - At least one erased page tested had bit error rate greater than half the correction power.
N5 - Walking zeros test failed.
N6 - Walking ones test failed.
N7 - Block contained factory bad block markings and testing was skipped.
N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
N9 - Block in plane 0 was marked as a factory bad block.
N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
N11 - Block in plane 1 was marked as a factory bad block.
| Bus | CE | Die | Lane | Value | Result Notes | Overall |
| 0 | 0 | 0 | 0 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 0 | 0 | 1 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 0 | 0 | 2 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 0 | 0 | 3 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 0 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 1 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 2 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 3 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
Total Number of test results: 8
Number of failures: 8
Number of Passed with warnings: 0
No. Passed without warnings: 0
[Tue 06/15/2021 22:33:25] - End of Genesis manufacturing log.
[Tue 06/15/2021 22:33:25] - Exiting...
[Tue 06/15/2021 22:33:25] - Overall Result for Device: /dev/sg2 ****** FAIL ******
[jack@localhost SF_Genesis-v1.7.2.01020130925]$ sudo ./SF_Genesis -PROCESS_SSD 2:0:0:0 /home/jack/tmp/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp /home/jack/tmp/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/31027.123456.driveconfig 123456 www_123 log=/home/jack/tmp/adata.log
[Tue 06/15/2021 22:33:39] - SF_Genesis has been invoked with the following parameters:
argv[2]: 2:0:0:0
argv[4]: /home/jack/tmp/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/Configuration_Files/31027.123456.driveconfig
argv[5]: 123456
argv[6]: www_123
请问是配置文件错误还是闪存坏了,测试短接跳线一端接地,一端为2.8V,不是应该3.3V吗,供电电路有问题?我是接到电脑主板上开卡的。
