查看: 3652|回复: 6
[银灿] 银灿Innostor IS903产品参数存档
发表于 2021-12-4 05:24:09 | 显示全部楼层 |阅读模式
公司走了,产品还没卖完,为了方便查询特地去WebArchive挖了一下镜像并摘录产品参数放在这里存档,希望能帮到一些迷惘的路人……
P/No:IS903
Features
      -One Channel / two channel data bus by small footprint package
       -Up to 4 CEs per channel to support max. 8 Flash CEs
       -ECC protect 43 bit by 1K bytes
       -2xnm, 2ynm, 1xnm : SLC / MLC types Nand Flash supported
       -ONFI 2.1 spec. interface supported
       -Toggle DDR interface supported
       -Compliant with USB 3.0 spec. version 1.0
       -Compliant with USB 2.0 spec. backward compatible with USB1.1
       -Compliant with USB Mass Storage Class spec. version 1.0
       -High performance 1T 8051 with hardware acceleration DMA
       -F/W off-load engine embedded
       -1.2V low power consumption design
       -LED indicator to show link status and r/w traffic
       -Customized VID/ PID and serial number
       -Package: QFN 64 (8x8 mm)
Application
       -USB Flash Drive, NAND Flash Controller for devices
垃圾数码之家 该用户已被删除
发表于 2021-12-4 07:31:59 来自手机浏览器 | 显示全部楼层
发表于 2021-12-4 08:35:27 | 显示全部楼层
发表于 2021-12-4 10:48:51 | 显示全部楼层
发表于 2021-12-4 11:24:13 | 显示全部楼层
发表于 2021-12-4 13:10:56 | 显示全部楼层
发表于 2021-12-4 18:47:38 | 显示全部楼层
GMT+8, 2026-9-14 01:32 , Processed in 0.171600 second(s), 10 queries , Gzip On, Redis On.
