楼主 |
发表于 2022-1-19 17:26:03
显示全部楼层
用sf-flash-id-rommode 工具读出了id 可能是27423 。出现了新的进展,但还是错误。
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Wed 01/19/2022 17:21:51] - SF_Genesis has been invoked with the following parameters:
argv[1]: -PROCESS_SSD
argv[2]: 15:0:0:0
argv[3]: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp
argv[4]: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/27423.12345.test.driveconfig
argv[5]: 12345
argv[6]: www_123
argv[7]: log=/log/
[Wed 01/19/2022 17:21:51] - Instructing the operating system to purge any existing cached data for device: '15:0:0:0'
[Wed 01/19/2022 17:21:56] - Issuing a discovery command for device: '15:0:0:0'
[Wed 01/19/2022 17:22:01] - Discovery command completed...
[Wed 01/19/2022 17:22:01] - Waiting 5 seconds for the system to settle...
[Wed 01/19/2022 17:22:06] - Device designation string '15:0:0:0' is mapped to node '/dev/sg2'
[Wed 01/19/2022 17:22:06] - Proceeding to process SSD device with the following parameters:
DeviceName = /dev/sg2
MFP Package Filename = /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp
Configuration File = /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/27423.12345.test.driveconfig
Serial No. = 12345
World Wide Name = www_123
[Wed 01/19/2022 17:22:07] - Successfully received the IDENTIFY data from the drive...
[Wed 01/19/2022 17:22:07] - Validating Manufacturing Firmware Package: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp
[Wed 01/19/2022 17:22:07] - Successfully opened the package: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp
[Wed 01/19/2022 17:22:07] - file /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/27423.12345.test.driveconfig Loaded successfully
[Wed 01/19/2022 17:22:15] - Warning: Unable to query diagnostics information to perform power management settings check
[Wed 01/19/2022 17:22:15] - B01 Power Management configuration request detected
[Wed 01/19/2022 17:22:15] - Successfully extracted *.DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/27423.12345.test.driveconfig
[Wed 01/19/2022 17:22:15] - Extracted Config_ID: 1 (27423) in DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/27423.12345.test.driveconfig
[Wed 01/19/2022 17:22:15] - Extracted SerialOutputControl: 0
[Wed 01/19/2022 17:22:15] - Searching for flashware image for configuration 27423
[Wed 01/19/2022 17:22:15] - Manifest found for configuration 27423
[Wed 01/19/2022 17:22:15] - Flashware image extracted: 27423_fw_cl_mlc_Toshiba_64Gb_TH58NVG7DDJTA20_2Q_4C_1D_S_PP_R01551_s512.vic
[Wed 01/19/2022 17:22:15] - Searching for manufacturing image for configuration 27423
[Wed 01/19/2022 17:22:15] - Manufacturing image extracted: 27423_mf_mlc_Toshiba_64Gb_TH58NVG7DDJTA20_2Q_4C_1D_S_PP_R01551_s512.vic
[Wed 01/19/2022 17:22:15] - Proceeding in ROM mode, download feature 3...
[Wed 01/19/2022 17:22:15] - Successfully downloaded MFB to the drive...
[Wed 01/19/2022 17:22:15] - Waiting (5 sec) for the drive to settle...
[Wed 01/19/2022 17:22:21] - Successfully received the IDENTIFY data from the drive...
[Wed 01/19/2022 17:22:21] - Firmware revision reported to be: '582ABBM0'. This indicates MFB download was successful.
[Wed 01/19/2022 17:22:21] - Successfully enabled SMART capabilities...
[Wed 01/19/2022 17:22:23] - Successfully issued a diagnostic unlock...
[Wed 01/19/2022 17:22:24] - Performing the flash test of block 0 (0x0000)...
[Wed 01/19/2022 17:22:27] - Flash Test Results:
Flash Test Parameters:
Block Count: 0
Page Count: 1
Bus Count: 2
Chip Enabled Count: 4
Die Count: 1
Lane Count: 4
Plane Count: 2
Results Notes:
N1 - At least one page tested and passed with no bit errors.
N2 - No test data available. Test may have aborted, or failed during the testing.
N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
N4 - At least one erased page tested had bit error rate greater than half the correction power.
N5 - Walking zeros test failed.
N6 - Walking ones test failed.
N7 - Block contained factory bad block markings and testing was skipped.
N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
N9 - Block in plane 0 was marked as a factory bad block.
N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
N11 - Block in plane 1 was marked as a factory bad block.
| Bus | CE | Die | Lane | Value | Result Notes | Overall |
| 0 | 0 | 0 | 0 | 0x0304 | N8,N10 | FAIL |
| 0 | 0 | 0 | 1 | 0x0304 | N8,N10 | FAIL |
| 0 | 0 | 0 | 2 | 0x0304 | N8,N10 | FAIL |
| 0 | 0 | 0 | 3 | 0x0304 | N8,N10 | FAIL |
| 0 | 1 | 0 | 0 | 0x0304 | N8,N10 | FAIL |
| 0 | 1 | 0 | 1 | 0x0304 | N8,N10 | FAIL |
| 0 | 1 | 0 | 2 | 0x0304 | N8,N10 | FAIL |
| 0 | 1 | 0 | 3 | 0x0304 | N8,N10 | FAIL |
| 0 | 2 | 0 | 0 | 0x0380 | N7,N9,N11 | WARNING |
| 0 | 2 | 0 | 1 | 0x0380 | N7,N9,N11 | WARNING |
| 0 | 2 | 0 | 2 | 0x0380 | N7,N9,N11 | WARNING |
| 0 | 2 | 0 | 3 | 0x0380 | N7,N9,N11 | WARNING |
| 0 | 3 | 0 | 0 | 0x0380 | N7,N9,N11 | WARNING |
| 0 | 3 | 0 | 1 | 0x0380 | N7,N9,N11 | WARNING |
| 0 | 3 | 0 | 2 | 0x0380 | N7,N9,N11 | WARNING |
| 0 | 3 | 0 | 3 | 0x0380 | N7,N9,N11 | WARNING |
| 1 | 0 | 0 | 0 | 0x0304 | N8,N10 | FAIL |
| 1 | 0 | 0 | 1 | 0x0304 | N8,N10 | FAIL |
| 1 | 0 | 0 | 2 | 0x0304 | N8,N10 | FAIL |
| 1 | 0 | 0 | 3 | 0x0304 | N8,N10 | FAIL |
| 1 | 1 | 0 | 0 | 0x0304 | N8,N10 | FAIL |
| 1 | 1 | 0 | 1 | 0x0304 | N8,N10 | FAIL |
| 1 | 1 | 0 | 2 | 0x0304 | N8,N10 | FAIL |
| 1 | 1 | 0 | 3 | 0x0304 | N8,N10 | FAIL |
| 1 | 2 | 0 | 0 | 0x0380 | N7,N9,N11 | WARNING |
| 1 | 2 | 0 | 1 | 0x0380 | N7,N9,N11 | WARNING |
| 1 | 2 | 0 | 2 | 0x0380 | N7,N9,N11 | WARNING |
| 1 | 2 | 0 | 3 | 0x0380 | N7,N9,N11 | WARNING |
| 1 | 3 | 0 | 0 | 0x0380 | N7,N9,N11 | WARNING |
| 1 | 3 | 0 | 1 | 0x0380 | N7,N9,N11 | WARNING |
| 1 | 3 | 0 | 2 | 0x0380 | N7,N9,N11 | WARNING |
| 1 | 3 | 0 | 3 | 0x0380 | N7,N9,N11 | WARNING |
Total Number of test results: 32
Number of failures: 16
Number of Passed with warnings: 16
No. Passed without warnings: 0
[Wed 01/19/2022 17:22:27] - End of Genesis manufacturing log.
[Wed 01/19/2022 17:22:27] - Exiting...
[Wed 01/19/2022 17:22:27] - Overall Result for Device: /dev/sg2 ****** FAIL ******
[root@localhost SF_Genesis-v1.7]#
