查看: 905|回复: 2
[SandForce] 求asp900s7-128gm开卡id 60073909 5300463844
发表于 2022-7-3 12:49:25 | 显示全部楼层 |阅读模式
求asp900s7-128gm开卡id 60073909 5300463844  前面四个颗粒 后面四个
发表于 2022-7-3 16:26:18 | 显示全部楼层
28044
 楼主| 发表于 2022-7-4 11:32:04 | 显示全部楼层
试了不行  25644 28044 28060 28218 28219  等都试了不行 到百分81就不行了  Starting command:[/root/Desktop/SF1.7.5/SF_Genesis -PROCESS_SSD 3:0:0:0 "/root/MPT/FW_SF-2000_MP_6-0-A--0/FW_SF-2000_MP_6-0-A.0.mfp" "/root/MPT/FW_SF-2000_MP_6-0-A--0/Configuration_Files/28060.0.driveconfig" 123 456  LOG="/root/SOFT/123_localhost.localdomain_DATETIMESTAMP_3.0.0.0_PROCESS_SSD_RESULT.log"   ]...
SandForce Genesis Utility v1.7.5.00620140820-fc14-32bit
SF_Core Library: v1.7.1.20140820-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Sun 07/03/2022 20:28:22] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 3:0:0:0
                      argv[3]: /root/MPT/FW_SF-2000_MP_6-0-A--0/FW_SF-2000_MP_6-0-A.0.mfp
                      argv[4]: /root/MPT/FW_SF-2000_MP_6-0-A--0/Configuration_Files/28060.0.driveconfig
                      argv[5]: 123
                      argv[6]: 456
                      argv[7]: LOG=/root/SOFT/123_localhost.localdomain_DATETIMESTAMP_3.0.0.0_PROCESS_SSD_RESULT.log
[Sun 07/03/2022 20:28:22] - Instructing the operating system to purge any existing cached data for device: '3:0:0:0'
[Sun 07/03/2022 20:28:27] - Issuing a discovery command for device: '3:0:0:0'
[Sun 07/03/2022 20:28:32] - Discovery command completed...
[Sun 07/03/2022 20:28:32] - Waiting 5 seconds for the system to settle...
[Sun 07/03/2022 20:28:37] - Device designation string '3:0:0:0' is mapped to node '/dev/sg2'
[Sun 07/03/2022 20:28:37] - Power Management enforcement enabled.
[Sun 07/03/2022 20:28:37] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = /root/MPT/FW_SF-2000_MP_6-0-A--0/FW_SF-2000_MP_6-0-A.0.mfp
      Configuration File = /root/MPT/FW_SF-2000_MP_6-0-A--0/Configuration_Files/28060.0.driveconfig
              Serial No. = 123
         World Wide Name = 456
[Sun 07/03/2022 20:28:38] - Successfully received the IDENTIFY data from the drive...
[Sun 07/03/2022 20:28:38] - Validating Manufacturing Firmware Package: /root/MPT/FW_SF-2000_MP_6-0-A--0/FW_SF-2000_MP_6-0-A.0.mfp
[Sun 07/03/2022 20:28:59] - Successfully opened the package: /root/MPT/FW_SF-2000_MP_6-0-A--0/FW_SF-2000_MP_6-0-A.0.mfp
[Sun 07/03/2022 20:28:59] - file  /root/MPT/FW_SF-2000_MP_6-0-A--0/Configuration_Files/28060.0.driveconfig Loaded successfully
[Sun 07/03/2022 20:28:59] - Warning:  Unable to query diagnostics information to perform power management settings check
[Sun 07/03/2022 20:28:59] - B01 Power Management configuration request detected
[Sun 07/03/2022 20:28:59] - Successfully extracted *.DriveConfig file: /root/MPT/FW_SF-2000_MP_6-0-A--0/Configuration_Files/28060.0.driveconfig
[Sun 07/03/2022 20:28:59] - Extracted Config_ID: 1 (28060) in DriveConfig file: /root/MPT/FW_SF-2000_MP_6-0-A--0/Configuration_Files/28060.0.driveconfig
[Sun 07/03/2022 20:28:59] - Extracted SerialOutputControl: 0
[Sun 07/03/2022 20:28:59] - Extracted Enable DLC: 0
[Sun 07/03/2022 20:29:02] - Searching for flashware image for configuration 28060
[Sun 07/03/2022 20:29:02] - Manifest found for configuration 28060
[Sun 07/03/2022 20:29:02] - Flashware image extracted: 28060_fw_cl_mlc_MIC_64Gb_15K_MT29F64G08CBABBWP_1Q_4C_1D_S_PP_R01367_s512.vic
[Sun 07/03/2022 20:29:02] - Searching for manufacturing image for configuration 28060
[Sun 07/03/2022 20:29:02] - Manufacturing image extracted: 28060_mf_mlc_MIC_64Gb_15K_MT29F64G08CBABBWP_1Q_4C_1D_S_PP_R01367_s512.vic
[Sun 07/03/2022 20:29:02] - Proceeding in ROM mode, download feature 3...
[Sun 07/03/2022 20:29:03] - Successfully downloaded MFB to the drive...
[Sun 07/03/2022 20:29:03] - Waiting (5 sec) for the drive to settle...
[Sun 07/03/2022 20:29:08] - Successfully received the IDENTIFY data from the drive...
[Sun 07/03/2022 20:29:08] - Firmware revision reported to be: '60AABBM0'.  This indicates MFB download was successful.
[Sun 07/03/2022 20:29:08] - Successfully enabled SMART capabilities...
[Sun 07/03/2022 20:29:10] - Successfully issued a diagnostic unlock...
[Sun 07/03/2022 20:29:11] - Performing the flash test of block 0 (0x0000)...
[Sun 07/03/2022 20:29:14] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 1
        Chip Enabled Count: 4
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 3    | 0x0001 | N1                                         |    PASS |
  Total Number of test results: 16
            Number of failures: 0
         Number of Passed with warnings: 0
      No. Passed without warnings: 16
GMT+8, 2025-5-20 07:10 , Processed in 0.124801 second(s), 10 queries , Redis On.
