查看: 1105|回复: 1
[其他] 出个坏的kindle
发表于 2022-7-6 09:48:57 | 显示全部楼层 |阅读模式 IP属地:湖南长沙
坏的kindle,开机亮背光无显示拆机接TTL报错
[    1.766075] max77696-epd max77696-epd.0: EPDINT: Regulator Fault Detected [12]
[    1.773350] Regulator Fault Occurred! Retrying powerup...
<4>[    2.481668] ERROR:module.c:158:insmod():insmod(/lib/modules/mxc_epdc_fb.ko) : init_module error: error 19 (19)
<4>[    2.481860] ERROR:eink.c:287:eink_init():eink_init: failed to load eink driver /lib/modules/mxc_epdc_fb.ko: error 19 (19)
<4>[    2.481911] INFO:recovery-util.c:547:recovery_util_exit():Rebooting ...
<4>[    2.481996] DEBUG:eink.c:386:eink_shutdown():eink_shutdown: skipping shutdown because eink_fd is not initialized
<4>[    2.482081] ERROR:recovery-util.c:565:recovery_util_exit():failed to create failure log... -1
反复重启
可以fastboot,估计是硬件问题,不想折腾了
电池应该是好的,没有鼓包,TTL看了是可以正常充电的
是坏的!是坏的!是坏的!
20包邮非偏远出掉,买来实在不行就算买个电池吧
发表于 2022-7-6 14:14:24 | 显示全部楼层 IP属地:四川资阳
这连屏幕都是碎的
GMT+8, 2025-7-22 16:34 , Processed in 0.171601 second(s), 11 queries , Redis On.
