- 跑分1——————————————————————————————————————————————————————————————
- 2K performance run parameters for coremark.
- CoreMark Size : 666
- Total ticks : 12387
- Total time (secs): 12.387000
- Iterations/Sec : 4843.787842
- Iterations : 60000
- Compiler version : GCC11.2.0
- Compiler flags : -pipe -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -ffile-prefix-map=/builder/shared-workdir/build/sdk/build_dir/target-x86_64_musl/coremark-b24e397f7103061b3673261d292a0667bd3bc1b8=coremark-b24e397f7103061b3673261d292a0667bd3bc1b8 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -flto -O3 -lrt
- Memory location : Please put data memory location here
- (e.g. code in flash, data on heap etc)
- seedcrc : 0xe9f5
- [0]crclist : 0xe714
- [0]crcmatrix : 0x1fd7
- [0]crcstate : 0x8e3a
- [0]crcfinal : 0xbd59
- Correct operation validated. See README.md for run and reporting rules.
- CoreMark 1.0 : 4843.787842 / GCC11.2.0 -pipe -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -ffile-prefix-map=/builder/shared-workdir/build/sdk/build_dir/target-x86_64_musl/coremark-b24e397f7103061b3673261d292a0667bd3bc1b8=coremark-b24e397f7103061b3673261d292a0667bd3bc1b8 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -flto -O3 -lrt / Heap
- 跑分2——————————————————————————————————————————————————————————————
- Total ticks : 18479
- Total time (secs): 18.479000
- Iterations/Sec : 11905.406137
- Iterations : 220000
- Compiler version : GCC11.3.0
- Compiler flags : -pipe -mcpu=cortex-a53 -fno-caller-saves -fno-plt -fhonour-copts -fmacro-prefix-map=/workdir/openwrt/build_dir/target-aarch64_cortex-a53_musl/coremark-eefc986ebd3452d6adde22eafaff3e5c859f29e4=coremark-eefc986ebd3452d6adde22eafaff3e5c859f29e4 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -flto -O3 -DMULTITHREAD=2 -DUSE_PTHREAD -lrt
- Parallel PThreads : 2
- seedcrc : 0xe9f5
- [1]crclist : 0xe714
- [1]crcmatrix : 0x1fd7
- [1]crcstate : 0x8e3a
- [0]crcfinal : 0x33ff
- [1]crcfinal : 0x33ff
- CoreMark 1.0 : 11905.406137 / GCC11.3.0 -pipe -mcpu=cortex-a53 -fno-caller-saves -fno-plt -fhonour-copts -fmacro-prefix-map=/workdir/openwrt/build_dir/target-aarch64_cortex-a53_musl/coremark-eefc986ebd3452d6adde22eafaff3e5c859f29e4=coremark-eefc986ebd3452d6adde22eafaff3e5c859f29e4 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -flto -O3 -DMULTITHREAD=2 -DUSE_PTHREAD -lrt / Heap / 2:PThreads
- root@OpenWrt:~#
复制代码
