查看: 8132|回复: 24
[音响] 美国 dbx 1231 舞台均衡器拆解 附官方资料
发表于 2019-5-23 20:02:31 | 显示全部楼层 |阅读模式
1231双通道31-Band均衡器
这机器已经很多年了,但目前还有新品卖,
官网售价399美元
天猫卖3000(淘宝或闲鱼则只需几百元)
The dbx® 12 Series were designed to meet the needs of the most demanding sound reinforcement environments, while offering the simplicity of straightforward controls. The 1231 provides standard features like dual-channels, 31 1/3 octave bands, ISO frequency centers, +/- 12 dB input gain range, and switchable 40Hz/18 dB per octave low-cut filters, but also includes other insightful features. These include 45 mm faders; selectable +/-6dB or +/-15dB boost/cut range for precise gain adjustments; XLR, barrier strip, and 1/4'' TRS connectors for installation ease; balanced inputs and outputs for quiet operation; and chassis/signal ground lift capabilities for quick hum isolation. The visionary design of the dbx 12 Series makes your job easier.
dbx®12系列设计用于满足最苛刻的声音增强环境的需求,同时提供简单的直接控制。 1231提供了标准的功能,如双通道,31 1/3倍频程带,ISO频率中心,+ / - 12 dB输入增益范围,并可切换的40 hz /每八度18分贝低胸过滤器,还包括其他的特性。 这些包括45毫米的投篮; 选择+ / 6 db或+ / -15分贝增加/减少范围精确增益调整; XLR阻隔带,1/4 " TRS连接器安装方便; 安静的平衡输入和输出操作; 和底盘/信号快速哼隔离地面提升能力。 dbx 12系列的有远见的设计使您的工作更加轻松。
The dbx 12 Series Equalizers were precision engineered to provide years of maintenance-free operation in any application. The magnetically isolated transformer, electronically balanced/unbalanced inputs and servo balanced/unbalanced outputs, RF-filtered inputs and outputs, and power-off hard-wire relay bypass with 2 second power up delay were steps our engineers took to ensure compatibility for all installations. Only the best components were utilized, yielding a 10Hz to 50kHz frequency response, greater than 90dB SNR (ref +4dBu), less than 0.005% THD +Noise (1kHz at +4dBu), and interchannel crosstalk of less than -80dB from 20Hz to 20kHz. All this attention to detail is contained in a 3U steel/aluminum chassis.
dbx 12系列均衡器精密工程提供年免费维修操作的任何应用程序。 磁隔离变压器、电子平衡/不平衡输入和伺服平衡不平衡输出,RF-filtered输入和输出,断电实线与2秒启动延时继电器绕过步骤我们的工程师把所有设施,以确保兼容性。 只有最好的组件是利用,产生10赫兹至50 khz的频率响应,大于90分贝信噪比(ref + 4 dbu),低于0.005% (THD +噪声(1 khz + 4 dbu)和信道间的串扰的小于-80分贝20 hz 20 khz。 所有这些关注细节都包含在一个3 u钢/铝底盘。
  • Features
    • Switchable boost/cut ranges of ±6 or ±15 dB
    • Electronically balanced/unbalanced inputs
    • Servo balanced/unbalanced outputs
    • RF filtered inputs and outputs
    • XLR, Barrier Strip, and 1/4" TRS connectors
    • -12dB/+12dB input gain range
    • 18dB/octave 40Hz Bessel low-cut filter
    • Chassis/signal ground lift capability
    • Internal power supply transformer
    • Power-off hardwire relay bypass with 2-second power-up delay
Documentation
Specifications
Input Connectors
1/4" TRS, female XLR (pin 2 hot), and barrier terminal strip
Input Type
Electronically balanced/unbalanced, RF filtered
Input Impedance
Balanced 40 kOhm, unbalanced 20 kOhm
Max Input
>+21dBu balanced or unbalanced
CMRR
>40dB, typically >55dB at 1kHz
Output Connectors
1/4" TRS, male XLR (pin 2 hot), and barrier terminal strip
Output Type
Impedance-balanced/unbalanced, RF filtered
Output Impedance
Balanced 200 ohm, unbalanced 100 ohm
Max Output
>+21dBu balanced/unbalanced into 2 kOhm or greater; >+18dBm balanced/unbalanced (into 600 ohm)
Bandwidth
20Hz to 20kHz, +0.5/-1dB
Frequency Response
<10Hz to >50kHz, +0.5/-3dB; +/-15dB range; +/-6dB range
Dynamic Range
109dB; 115dB
Signal to Noise Ratio
90dB, 97dB
THD+Noise
<0.005%
Interchannel Crosstalk
<-80db, 20Hz to 20kHz
Bypass Switch
Bypasses the graphic equalizer section in the signal path
Low cut Switch
(recessed) Activates the 40Hz 18dB/octave Bessel high-pass filter
Range Switch
(recessed) Selects either +/- 6dB or +/- 15dB slider boost/cut range
I/O Meter
4-LED bar graph (Green, Green, Yellow, Red) at -10, 0, +10, and +18dBu
Indicators
EQ Bypass (Red); Clip (Red); Low Cut (Red); +/-6dB (Yellow); +/-15dB (Red)
Operating Voltage
100VAC 50/60Hz; 120VAC 60Hz; 230VAC 50/60Hz
Power Consumption
24W
Power Connector
IEC receptacle
Dimensions
5.25" H X 19" W X 7.9" D (13.4cm x 48.3cm x 20.1cm)
Unit Weight
10.6 lbs.
Shipping Weight
11.6 lbs.
参与人数 2家元 +70 收起 理由
家睦 + 50
mxlkf + 20
 楼主| 发表于 2019-5-23 20:02:53 | 显示全部楼层
 楼主| 发表于 2019-5-23 20:04:53 | 显示全部楼层
参与人数 6家元 +98 收起 理由
wjhwpp + 18
温力口 + 14 谢谢分享。。。。。好高级的鸡鸡。。。。。.
miqi328 + 20 謝謝分享
亲爱的混蛋 + 12
williamgarci + 14 謝謝分享
发表于 2019-5-23 20:10:33 | 显示全部楼层
参与人数 1家元 +6 收起 理由
黯然销魂 + 6
发表于 2019-5-23 21:47:05 | 显示全部楼层
参与人数 1家元 +8 收起 理由
黯然销魂 + 8
发表于 2019-5-24 15:50:50 | 显示全部楼层
参与人数 1家元 +10 收起 理由
黯然销魂 + 10 运放和电位器更贵吧,零件正规渠道可不像TB.
发表于 2019-5-24 17:57:11 | 显示全部楼层
参与人数 1家元 +10 收起 理由
黯然销魂 + 10 我们平民觉得1%就是精密了,平时接触的都.
发表于 2019-5-24 18:15:38 | 显示全部楼层
参与人数 1家元 +10 收起 理由
黯然销魂 + 10
发表于 2019-5-24 18:56:20 | 显示全部楼层
参与人数 1家元 +10 收起 理由
黯然销魂 + 10 不需要,单独就可以调
发表于 2019-5-24 21:55:56 | 显示全部楼层
参与人数 1家元 +10 收起 理由
黯然销魂 + 10
发表于 2019-5-24 22:45:44 | 显示全部楼层
参与人数 1家元 +10 收起 理由
黯然销魂 + 10 这种设备还是有它存在价值的,不然早就停产.
发表于 2019-5-24 22:55:53 | 显示全部楼层
参与人数 1家元 +10 收起 理由
黯然销魂 + 10
发表于 2019-5-25 12:52:41 | 显示全部楼层
参与人数 1家元 +10 收起 理由
黯然销魂 + 10 看你个人喜好,就像功放的高低音旋钮,喜欢.
发表于 2019-5-25 19:33:58 | 显示全部楼层
发表于 2019-5-25 20:06:44 | 显示全部楼层
发表于 2019-5-25 20:15:12 | 显示全部楼层
参与人数 1家元 +20 收起 理由
黯然销魂 + 20 以資鼓勵
 楼主| 发表于 2019-5-25 20:40:11 | 显示全部楼层
发表于 2019-5-25 20:43:58 | 显示全部楼层
 楼主| 发表于 2019-5-25 21:01:34 | 显示全部楼层
发表于 2019-5-25 21:41:21 | 显示全部楼层
GMT+8, 2025-12-22 14:22 , Processed in 0.171600 second(s), 13 queries , Gzip On, Redis On.
