发表于 2024-3-5 17:18:29
显示全部楼层
- /* Copyright (c) 2002 - 2007 Marek Michalkiewicz
- All rights reserved.
- Redistribution and use in source and binary forms, with or without
- modification, are permitted provided that the following conditions are met:
- * Redistributions of source code must retain the above copyright
- notice, this list of conditions and the following disclaimer.
- * Redistributions in binary form must reproduce the above copyright
- notice, this list of conditions and the following disclaimer in
- the documentation and/or other materials provided with the
- distribution.
- * Neither the name of the copyright holders nor the names of
- contributors may be used to endorse or promote products derived
- from this software without specific prior written permission.
- THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
- LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- POSSIBILITY OF SUCH DAMAGE. */
- /* $Id: pgmspace.h,v 1.40.2.5 2009/11/15 06:42:40 dmix Exp $ */
- pgmspace.h
- Contributors:
- Created by Marek Michalkiewicz <marekm@linux.org.pl>
- Eric B. Weddington <eric@ecentral.com>
- Wolfgang Haidinger <wh@vmars.tuwien.ac.at> (pgm_read_dword())
- Ivanov Anton <anton@arc.com.ru> (pgm_read_float())
- /** \file */
- /** \defgroup avr_pgmspace <avr/pgmspace.h>: Program Space Utilities
- \code
- #include <avr/io.h>
- #include <avr/pgmspace.h>
- \endcode
- The functions in this module provide interfaces for a program to access
- data stored in program space (flash memory) of the device. In order to
- use these functions, the target device must support either the \c LPM or
- \c ELPM instructions.
- \note These functions are an attempt to provide some compatibility with
- header files that come with IAR C, to make porting applications between
- different compilers easier. This is not 100% compatibility though (GCC
- does not have full support for multiple address spaces yet).
- \note If you are working with strings which are completely based in ram,
- use the standard string functions described in \ref avr_string.
- \note If possible, put your constant tables in the lower 64 KB and use
- pgm_read_byte_near() or pgm_read_word_near() instead of
- pgm_read_byte_far() or pgm_read_word_far() since it is more efficient that
- way, and you can still use the upper 64K for executable code.
- All functions that are suffixed with a \c _P \e require their
- arguments to be in the lower 64 KB of the flash ROM, as they do
- not use ELPM instructions. This is normally not a big concern as
- the linker setup arranges any program space constants declared
- using the macros from this header file so they are placed right after
- the interrupt vectors, and in front of any executable code. However,
- it can become a problem if there are too many of these constants, or
- for bootloaders on devices with more than 64 KB of ROM.
- <em>All these functions will not work in that situation.</em>
- #ifndef __PGMSPACE_H_
- #define __PGMSPACE_H_ 1
- #define __need_size_t
- #include <inttypes.h>
- #include <stddef.h>
- #ifndef __ATTR_CONST__
- #define __ATTR_CONST__ __attribute__((__const__))
- #endif
- #ifndef __ATTR_PROGMEM__
- #define __ATTR_PROGMEM__ __attribute__((__progmem__))
- #endif
- #ifndef __ATTR_PURE__
- #define __ATTR_PURE__ __attribute__((__pure__))
- #endif
- \ingroup avr_pgmspace
- \def PROGMEM
- Attribute to use in order to declare an object being located in
- flash ROM.
- #define PROGMEM __ATTR_PROGMEM__
- #ifdef __cplusplus
- extern "C" {
- #endif
- #if defined(__DOXYGEN__)
- * Doxygen doesn't grok the appended attribute syntax of
- * GCC, and confuses the typedefs with function decls, so
- * supply a doxygen-friendly view.
- \typedef prog_void
- Type of a "void" object located in flash ROM. Does not make much
- sense by itself, but can be used to declare a "void *" object in
- flash ROM.
- typedef void PROGMEM prog_void;
- \typedef prog_char
- Type of a "char" object located in flash ROM.
- typedef char PROGMEM prog_char;
- \typedef prog_uchar
- Type of an "unsigned char" object located in flash ROM.
- typedef unsigned char PROGMEM prog_uchar;
- \typedef prog_int8_t
- Type of an "int8_t" object located in flash ROM.
- typedef int8_t PROGMEM prog_int8_t;
- \typedef prog_uint8_t
- Type of an "uint8_t" object located in flash ROM.
- typedef uint8_t PROGMEM prog_uint8_t;
- \typedef prog_int16_t
- Type of an "int16_t" object located in flash ROM.
- typedef int16_t PROGMEM prog_int16_t;
- \typedef prog_uint16_t
- Type of an "uint16_t" object located in flash ROM.
- typedef uint16_t PROGMEM prog_uint16_t;
- \typedef prog_int32_t
- Type of an "int32_t" object located in flash ROM.
- typedef int32_t PROGMEM prog_int32_t;
- \typedef prog_uint32_t
- Type of an "uint32_t" object located in flash ROM.
- typedef uint32_t PROGMEM prog_uint32_t;
- \typedef prog_int64_t
- Type of an "int64_t" object located in flash ROM.
- \note This type is not available when the compiler
- option -mint8 is in effect.
- typedef int64_t PROGMEM prog_int64_t;
- \typedef prog_uint64_t
- Type of an "uint64_t" object located in flash ROM.
- typedef uint64_t PROGMEM prog_uint64_t;
- #else /* !DOXYGEN */
- typedef void prog_void PROGMEM;
- typedef char prog_char PROGMEM;
- typedef unsigned char prog_uchar PROGMEM;
- typedef int8_t prog_int8_t PROGMEM;
- typedef uint8_t prog_uint8_t PROGMEM;
- typedef int16_t prog_int16_t PROGMEM;
- typedef uint16_t prog_uint16_t PROGMEM;
- typedef int32_t prog_int32_t PROGMEM;
- typedef uint32_t prog_uint32_t PROGMEM;
- #if !__USING_MINT8
- typedef int64_t prog_int64_t PROGMEM;
- typedef uint64_t prog_uint64_t PROGMEM;
- #endif
- #endif /* defined(__DOXYGEN__) */
- /* Although in C, we can get away with just using __c, it does not work in
- C++. We need to use &__c[0] to avoid the compiler puking. Dave Hylands
- explaned it thusly,
- Let's suppose that we use PSTR("Test"). In this case, the type returned
- by __c is a prog_char[5] and not a prog_char *. While these are
- compatible, they aren't the same thing (especially in C++). The type
- returned by &__c[0] is a prog_char *, which explains why it works
- fine. */
- * The #define below is just a dummy that serves documentation
- * purposes only.
- /** \ingroup avr_pgmspace
- \def PSTR(s)
- Used to declare a static pointer to a string in program space. */
- # define PSTR(s) ((const PROGMEM char *)(s))
- /* The real thing. */
- # define PSTR(s) (__extension__({static char __c[] PROGMEM = (s); &__c[0];}))
- #endif /* DOXYGEN */
- #define __LPM_classic__(addr) \
- (__extension__({ \
- uint16_t __addr16 = (uint16_t)(addr); \
- uint8_t __result; \
- __asm__ \
- "lpm" "\n\t" \
- "mov %0, r0" "\n\t" \
- : "=r" (__result) \
- : "z" (__addr16) \
- : "r0" \
- __result; \
- #define __LPM_enhanced__(addr) \
- __asm__ \
- "lpm %0, Z" "\n\t" \
- __result; \
- #define __LPM_word_classic__(addr) \
- uint16_t __result; \
- __asm__ \
- "lpm" "\n\t" \
- "mov %A0, r0" "\n\t" \
- "adiw r30, 1" "\n\t" \
- "lpm" "\n\t" \
- "mov %B0, r0" "\n\t" \
- : "=r" (__result), "=z" (__addr16) \
- : "1" (__addr16) \
- : "r0" \
- __result; \
- #define __LPM_word_enhanced__(addr) \
- __asm__ \
- "lpm %A0, Z+" "\n\t" \
- "lpm %B0, Z" "\n\t" \
- __result; \
- #define __LPM_dword_classic__(addr) \
- uint32_t __result; \
- __asm__ \
- "lpm" "\n\t" \
- "lpm" "\n\t" \
- "lpm" "\n\t" \
- "mov %C0, r0" "\n\t" \
- "lpm" "\n\t" \
- "mov %D0, r0" "\n\t" \
- : "r0" \
- __result; \
- #define __LPM_dword_enhanced__(addr) \
- __asm__ \
- "lpm %B0, Z+" "\n\t" \
- "lpm %C0, Z+" "\n\t" \
- "lpm %D0, Z" "\n\t" \
- __result; \
- #define __LPM_float_classic__(addr) \
- float __result; \
- __asm__ \
- "lpm" "\n\t" \
- "lpm" "\n\t" \
- "lpm" "\n\t" \
- "lpm" "\n\t" \
- : "r0" \
- __result; \
- #define __LPM_float_enhanced__(addr) \
- float __result; \
- __asm__ \
- __result; \
- #if defined (__AVR_HAVE_LPMX__)
- #define __LPM(addr) __LPM_enhanced__(addr)
- #define __LPM_word(addr) __LPM_word_enhanced__(addr)
- #define __LPM_dword(addr) __LPM_dword_enhanced__(addr)
- #define __LPM_float(addr) __LPM_float_enhanced__(addr)
- #else
- #define __LPM(addr) __LPM_classic__(addr)
- #define __LPM_word(addr) __LPM_word_classic__(addr)
- #define __LPM_dword(addr) __LPM_dword_classic__(addr)
- #define __LPM_float(addr) __LPM_float_classic__(addr)
- #endif
- \def pgm_read_byte_near(address_short)
- Read a byte from the program space with a 16-bit (near) address.
- \note The address is a byte address.
- The address is in the program space. */
- #define pgm_read_byte_near(address_short) __LPM((uint16_t)(address_short))
- \def pgm_read_word_near(address_short)
- Read a word from the program space with a 16-bit (near) address.
- #define pgm_read_word_near(address_short) __LPM_word((uint16_t)(address_short))
- \def pgm_read_dword_near(address_short)
- Read a double word from the program space with a 16-bit (near) address.
- #define pgm_read_dword_near(address_short) \
- __LPM_dword((uint16_t)(address_short))
- \def pgm_read_float_near(address_short)
- Read a float from the program space with a 16-bit (near) address.
- #define pgm_read_float_near(address_short) \
- __LPM_float((uint16_t)(address_short))
- #if defined(RAMPZ) || defined(__DOXYGEN__)
- /* Only for devices with more than 64K of program memory.
- RAMPZ must be defined (see iom103.h, iom128.h).
- /* The classic functions are needed for ATmega103. */
- #define __ELPM_classic__(addr) \
- uint32_t __addr32 = (uint32_t)(addr); \
- __asm__ \
- "out %2, %C1" "\n\t" \
- "mov r31, %B1" "\n\t" \
- "mov r30, %A1" "\n\t" \
- "elpm" "\n\t" \
- : "r" (__addr32), \
- "I" (_SFR_IO_ADDR(RAMPZ)) \
- : "r0", "r30", "r31" \
- __result; \
- #define __ELPM_enhanced__(addr) \
- __asm__ \
- "movw r30, %1" "\n\t" \
- "elpm %0, Z+" "\n\t" \
- : "r30", "r31" \
- __result; \
- #define __ELPM_xmega__(addr) \
- __asm__ \
- "in __tmp_reg__, %2" "\n\t" \
- "out %2, __tmp_reg__" \
- : "r30", "r31" \
- __result; \
- #define __ELPM_word_classic__(addr) \
- __asm__ \
- "elpm" "\n\t" \
- "in r0, %2" "\n\t" \
- "adc r0, __zero_reg__" "\n\t" \
- "out %2, r0" "\n\t" \
- "elpm" "\n\t" \
- __result; \
- #define __ELPM_word_enhanced__(addr) \
- __asm__ \
- "elpm %A0, Z+" "\n\t" \
- "elpm %B0, Z" "\n\t" \
- : "r30", "r31" \
- __result; \
- #define __ELPM_word_xmega__(addr) \
- __asm__ \
- : "r30", "r31" \
- __result; \
- #define __ELPM_dword_classic__(addr) \
- __asm__ \
- "elpm" "\n\t" \
- "elpm" "\n\t" \
- "elpm" "\n\t" \
- "elpm" "\n\t" \
- __result; \
- #define __ELPM_dword_enhanced__(addr) \
- __asm__ \
- "elpm %B0, Z+" "\n\t" \
- "elpm %C0, Z+" "\n\t" \
- "elpm %D0, Z" "\n\t" \
- : "r30", "r31" \
- __result; \
- #define __ELPM_dword_xmega__(addr) \
- __asm__ \
- : "r30", "r31" \
- __result; \
- #define __ELPM_float_classic__(addr) \
- float __result; \
- __asm__ \
- "elpm" "\n\t" \
- "elpm" "\n\t" \
- "elpm" "\n\t" \
- "elpm" "\n\t" \
- __result; \
- #define __ELPM_float_enhanced__(addr) \
- float __result; \
- __asm__ \
- : "r30", "r31" \
- __result; \
- #define __ELPM_float_xmega__(addr) \
- float __result; \
- __asm__ \
- : "r30", "r31" \
- __result; \
- Check for architectures that implement RAMPD (avrxmega3, avrxmega5,
- avrxmega7) as they need to save/restore RAMPZ for ELPM macros so it does
- not interfere with data accesses.
- #if defined (__AVR_HAVE_RAMPD__)
- #define __ELPM(addr) __ELPM_xmega__(addr)
- #define __ELPM_word(addr) __ELPM_word_xmega__(addr)
- #define __ELPM_dword(addr) __ELPM_dword_xmega__(addr)
- #define __ELPM_float(addr) __ELPM_float_xmega__(addr)
- #else
- #define __ELPM(addr) __ELPM_enhanced__(addr)
- #define __ELPM_word(addr) __ELPM_word_enhanced__(addr)
- #define __ELPM_dword(addr) __ELPM_dword_enhanced__(addr)
- #define __ELPM_float(addr) __ELPM_float_enhanced__(addr)
- #else
- #define __ELPM(addr) __ELPM_classic__(addr)
- #define __ELPM_word(addr) __ELPM_word_classic__(addr)
- #define __ELPM_dword(addr) __ELPM_dword_classic__(addr)
- #define __ELPM_float(addr) __ELPM_float_classic__(addr)
- #endif /* __AVR_HAVE_LPMX__ */
- #endif /* __AVR_HAVE_RAMPD__ */
- \def pgm_read_byte_far(address_long)
- Read a byte from the program space with a 32-bit (far) address.
- #define pgm_read_byte_far(address_long) __ELPM((uint32_t)(address_long))
- \def pgm_read_word_far(address_long)
- Read a word from the program space with a 32-bit (far) address.
- #define pgm_read_word_far(address_long) __ELPM_word((uint32_t)(address_long))
- \def pgm_read_dword_far(address_long)
- Read a double word from the program space with a 32-bit (far) address.
- #define pgm_read_dword_far(address_long) __ELPM_dword((uint32_t)(address_long))
- \def pgm_read_float_far(address_long)
- Read a float from the program space with a 32-bit (far) address.
- #define pgm_read_float_far(address_long) __ELPM_float((uint32_t)(address_long))
- #endif /* RAMPZ or __DOXYGEN__ */
- \def pgm_read_byte(address_short)
- #define pgm_read_byte(address_short) pgm_read_byte_near(address_short)
- \def pgm_read_word(address_short)
- #define pgm_read_word(address_short) pgm_read_word_near(address_short)
- \def pgm_read_dword(address_short)
- #define pgm_read_dword(address_short) pgm_read_dword_near(address_short)
- \def pgm_read_float(address_short)
- #define pgm_read_float(address_short) pgm_read_float_near(address_short)
- \def PGM_P
- Used to declare a variable that is a pointer to a string in program
- space. */
- #ifndef PGM_P
- #define PGM_P const prog_char *
- #endif
- \def PGM_VOID_P
- Used to declare a generic pointer to an object in program space. */
- #ifndef PGM_VOID_P
- #define PGM_VOID_P const prog_void *
- #endif
- extern PGM_VOID_P memchr_P(PGM_VOID_P, int __val, size_t __len) __ATTR_CONST__;
- extern int memcmp_P(const void *, PGM_VOID_P, size_t) __ATTR_PURE__;
- extern void *memccpy_P(void *, PGM_VOID_P, int __val, size_t);
- extern void *memcpy_P(void *, PGM_VOID_P, size_t);
- extern void *memmem_P(const void *, size_t, PGM_VOID_P, size_t) __ATTR_PURE__;
- extern PGM_VOID_P memrchr_P(PGM_VOID_P, int __val, size_t __len) __ATTR_CONST__;
- extern char *strcat_P(char *, PGM_P);
- extern PGM_P strchr_P(PGM_P, int __val) __ATTR_CONST__;
- extern PGM_P strchrnul_P(PGM_P, int __val) __ATTR_CONST__;
- extern int strcmp_P(const char *, PGM_P) __ATTR_PURE__;
- extern char *strcpy_P(char *, PGM_P);
- extern int strcasecmp_P(const char *, PGM_P) __ATTR_PURE__;
- extern char *strcasestr_P(const char *, PGM_P) __ATTR_PURE__;
- extern size_t strcspn_P(const char *__s, PGM_P __reject) __ATTR_PURE__;
- extern size_t strlcat_P (char *, PGM_P, size_t );
- extern size_t strlcpy_P (char *, PGM_P, size_t );
- extern size_t strlen_P(PGM_P) __ATTR_CONST__; /* program memory can't change */
- extern size_t strnlen_P(PGM_P, size_t) __ATTR_CONST__; /* program memory can't change */
- extern int strncmp_P(const char *, PGM_P, size_t) __ATTR_PURE__;
- extern int strncasecmp_P(const char *, PGM_P, size_t) __ATTR_PURE__;
- extern char *strncat_P(char *, PGM_P, size_t);
- extern char *strncpy_P(char *, PGM_P, size_t);
- extern char *strpbrk_P(const char *__s, PGM_P __accept) __ATTR_PURE__;
- extern PGM_P strrchr_P(PGM_P, int __val) __ATTR_CONST__;
- extern char *strsep_P(char **__sp, PGM_P __delim);
- extern size_t strspn_P(const char *__s, PGM_P __accept) __ATTR_PURE__;
- extern char *strstr_P(const char *, PGM_P) __ATTR_PURE__;
- extern char *strtok_P(char *__s, PGM_P __delim);
- extern char *strtok_rP(char *__s, PGM_P __delim, char **__last);
- #endif
- #endif /* __PGMSPACE_H_ */
复制代码
