查看: 1745|回复: 8
[家电] 拆一台不知名的网络机顶盒TTTV BOX,有人知道这款是啥型号的吗?
发表于 2024-5-27 08:24:44 | 显示全部楼层 |阅读模式
直接上图吧,啥也不说了,只知道是H618方案,2+128   隐约能看见有个X96,但搜到的X96都和这个不一样
参与人数 1家元 +12 收起 理由
nokia5320 + 12
发表于 2024-5-27 13:39:38 | 显示全部楼层
128g江波龙的硬盘不错,运存似乎也可以
发表于 2024-5-27 14:19:45 | 显示全部楼层
2+128这容量可不小
 楼主| 发表于 2024-5-27 17:52:33 | 显示全部楼层
[89]HELLO! BOOT0 is starting!
[92]BOOT0 commit : 4b34f2890a
[95]set pll start
[97]periph0 has been enabled
[100]set pll end
[103]unknow PMU
[105]unknow PMU
[109]PMU: AXP1530
[114]dram return write ok
[116]board init ok
[118]enable_jtag
[120]DRAM BOOT DRIVE INFO: V0.651
[123]the chip id is 0x2000
[126]chip id check OK
[148]DRAM_VCC set to 1500 mv
[151]DRAM CLK =648 MHZ
[153]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[162]Actual DRAM SIZE =2048 M
[165]DRAM SIZE =2048 MBytes, para1 = 30fb, para2 = 8000000, dram_tpr13 = 6041
[178]DRAM simple test OK.
[180]rtc standby flag is 0x0, super standby flag is 0x0
[186]dram size =2048
[189]Use rtc to store dram tuning para
[192]card no is 2
[194]sdcard 2 line count 8
[197][mmc]: mmc driver ver 2021-10-12 13:56
[201][mmc]: b mmc 2 bias 4
[209][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
[215][mmc]: ***Try MMC card 2***
[240][mmc]: RMCA OK!
[243][mmc]: MMC 5.1
[245][mmc]: HSSDR52/SDR25 8 bit
[248][mmc]: 50000000 Hz
[250][mmc]: 118000 MB
[252][mmc]: ***SD/MMC 2 init OK!!!***
[327]Loading boot-pkg Succeed(index=0).
[331][mmc]: b mmc 2 bias 4
[334]Entry_name        = u-boot
[342]Entry_name        = monitor
[346]Entry_name        = dtbo
[349]Entry_name        = optee
[353]Entry_name        = dtb
[356]tunning data addr:0x4a0003e8
[359]Jump to second Boot.
NOTICE:  BL3-1: v1.0(debug):54937d5
NOTICE:  BL3-1: Built : 17:44:59, 2021-12-13
NOTICE:  BL3-1 commit: 8
NOTICE:  cpuidle init version V2.0
NOTICE:  secure os exist
MESSAGE: [0x0] TEE-CORE: OP-TEE version: 81ab7a47 #1 2020年 05月 06日 星期三 02:40:04 UTC arm
NOTICE:  BL3-1: Preparing for EL3 exit to normal world
NOTICE:  BL3-1: Next image address = 0x4a000000
NOTICE:  BL3-1: Next image spsr = 0x1d3
U-Boot 2018.07 (Mar 09 2024 - 09:57:06 +0000) Allwinner Technology
[00.423]CPU:   Allwinner Family
[00.426]Model: sun50iw9
I2C:   ready
[00.434]DRAM:  2 GiB
[00.439]Relocation Offset is: 75ecd000
[00.474]secure enable bit: 0
[00.477]smc_tee_inform_fdt failed with: ffffffff
[00.481]pmu_axp152_probe pmic_bus_read fail
[00.485]PMU: AXP1530
FDT ERROR:fdt_get_regulator_name:get property handle twi-supply error:FDT_ERR_INTERNAL
[00.499]CPU=1416 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
[00.505]gic: sec monitor mode
sunxi flash map init
SPI ALL:   ready
[00.523]flash init start
[00.525]workmode = 0,storage type = 2
[00.529][mmc]: mmc driver ver uboot2018:2023-03-21 09:51:00
[00.534][mmc]: get sdc_type fail and use default host:tm4.
[00.540][mmc]: get clk_mmc_name string failed
[00.544][mmc]: get pll0 string failed
[00.547][mmc]: get pll1 string failed
[00.551][mmc]: get pll2 string failed
[00.554][mmc]: SUNXI SDMMC Controller Version:0x40502
[00.578][mmc]: Best spd md: 4-HS400, freq: 3-100000000, Bus width: 8
[00.584]sunxi flash init ok
[00.586]drv_disp_init
[00.590]handle_num : 7
erase secure storage failed
[00.617]sunxi_secure_storage_exit err: secure storage has not been inited
fdt get node offset faill: lcd1
[00.633]handle_num : 4
of_clk_get: index is error,reset it.
[00.644]handle_num : 2
[00.649]drv_disp_init finish
[00.671]Loading Environment from SUNXI_FLASH... OK
[00.677]boot_gui_init:start
FAT: Misaligned buffer address (bbe48ad0)
hdmi hpd out, force open?
[00.836]set disp.fb0_rot_used fail. using defval=0
[00.841]set disp.fb0_rot_degree fail. using defval=0
[00.846]boot_gui_init:finish
[00.853]bmp_name=bootlogo.bmp size 3686456
secure storage read widevine fail
[00.887]secure storage read widevine fail with:-1
secure storage read ec_key fail
[00.894]secure storage read ec_key fail with:-1
[00.899]usb burn from boot
delay time 0
weak:otg_phy_config
[00.912]usb prepare ok
[01.215]overtime
[01.219]do_burn_from_boot usb : no usb exist
List file under ULI/factory
** Unrecognized filesystem type **
[01.234]update part info
[01.250]update bootcmd
[01.253]change working_fdt 0xbbe7ce50 to 0xbbe4ac90
disable nand error: FDT_ERR_BADPATH
[01.261][mmc]: get sunxi-mmc2 string failed
[01.280]update dts
Hit any key to stop autoboot:  0
Android's image name: arm64
ERROR: reserving fdt memory region failed (addr=bbf21000 size=384000)
[01.608]Starting kernel ...
[01.611][mmc]: mmc exit start
[01.628][mmc]: mmc 2 exit ok
[    0.000000][    T0] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000][    T0] Linux version 5.4.125 (xml@xml-server) (Android (7485623, based on r416183b1) clang version 12.0.7 (https://android.googlesource.com/toolchain/llvm-project c935d99d7cf2016289302412d708641d52d2f7ee), LLD 12.0.7 (/buildbot/src/android/llvm-r416183/out/llvm-project/lld c935d99d7cf2016289302412d708641d52d2f7ee)) #13 SMP PREEMPT Wed Mar 6 22:10:36 CST 2024
[    0.000000][    T0] Machine model: sun50iw9
[    0.000000][    T0] earlycon: uart8250 at MMIO32 0x0000000005000000 (options '')
[    0.000000][    T0] printk: bootconsole [uart8250] enabled
[    0.000000][    T0] cma: Reserved 8 MiB at 0x00000000bf800000
[    0.000000][    T0] On node 0 totalpages: 524288
[    0.000000][    T0]   DMA32 zone: 8192 pages used for memmap
[    0.000000][    T0]   DMA32 zone: 0 pages reserved
[    0.000000][    T0]   DMA32 zone: 524288 pages, LIFO batch:63
[    0.000000][    T0] psci: probing for conduit method from DT.
[    0.000000][    T0] psci: PSCIv1.0 detected in firmware.
[    0.000000][    T0] psci: Using standard PSCI v0.2 function IDs
[    0.000000][    T0] psci: Trusted OS migration not required
[    0.000000][    T0] psci: SMC Calling Convention v1.0
[    0.000000][    T0] percpu: Embedded 22 pages/cpu s49944 r8192 d31976 u90112
[    0.000000][    T0] pcpu-alloc: s49944 r8192 d31976 u90112 alloc=22*4096
[    0.000000][    T0] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000][    T0] Detected VIPT I-cache on CPU0
[    0.000000][    T0] CPU features: detected: ARM erratum 845719
[    0.000000][    T0] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000][    T0] Kernel command line: earlycon=uart8250,mmio32,0x05000000 clk_ignore_unused initcall_debug=0 console=ttyAS0,115200 loglevel=8 root=/dev/mmcblk0p4 init=/init cma=8M snum=2c00142895a408c1dd1 mac_addr=90:0E:B3:66:FA:40 wifi_mac= bt_mac= specialstr= gpt=1 androidboot.force_normal_boot=1 androidboot.slot_suffix=_a androidboot.vbmeta.avb_vers] usbcore: registered new interface driver ums-sddr55
[    1.320269][    T1] usbcore: registered new interface driver ums-usbat
[    1.327491][    T1] usbcore: registered new interface driver usbserial_generic
[    1.335435][    T1] usbserial: USB Serial support registered for generic
[    1.342816][    T1] usbcore: registered new interface driver option
[    1.349090][    T1] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.357516][    T1] usbcore: registered new interface driver pl2303
[    1.363790][    T1] usbserial: USB Serial support registered for pl2303
[    1.371069][    T1] usbcore: registered new interface driver qcserial
[    1.378150][    T1] usbserial: USB Serial support registered for Qualcomm USB modem
[    1.386577][    T1] usbcore: registered new interface driver quatech2
[    1.393673][    T1] usbserial: USB Serial support registered for Quatech 2nd gen USB to Serial Driver
[    1.403965][    T1] usbcore: registered new interface driver xpad
[    1.410675][    T1] usbcore: registered new interface driver usb_acecad
[    1.417956][    T1] usbcore: registered new interface driver aiptek
[    1.424856][    T1] usbcore: registered new interface driver gtco
[    1.430969][    T1] usbcore: registered new interface driver hanwang
[    1.437963][    T1] usbcore: registered new interface driver kbtab
[    1.444941][    T1] axp2101_pek: axp2101-pek can not register without irq
[    1.451733][    T1] axp2101-pek: probe of axp2101-pek.0 failed with error -22
[    1.459775][    T1] sunxi-rtc 7000000.rtc: reset_control_get() failed
[    1.466876][    T1] sunxi-rtc 7000000.rtc: Fail to get clock 'rtc-spi'
[    1.473403][    T1] sunxi-rtc 7000000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
[    1.484207][    T1] sunxi-rtc 7000000.rtc: registered as rtc1
[    1.490526][    T1] sunxi-rtc 7000000.rtc: sunxi rtc probed
[    1.496821][    T1] i2c /dev entries driver
[    1.501622][    T1] IR NEC protocol handler initialized
[    1.507358][    T1] IR RC5(x/sz) protocol handler initialized
[    1.513433][    T1] uvcvideo: Unable to create debugfs directory
[    1.520060][    T1] usbcore: registered new interface driver uvcvideo
[    1.527128][    T1] USB Video Class driver (1.1.1)
[    1.532394][    T1] sunxi cedar version 1.1
[    1.537062][    T1] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[    1.543952][    T1] VE: install start!!!
[    1.543952][    T1]
[    1.550735][    T1] VE: cedar-ve the get irq is 20
[    1.550735][    T1]
[    1.558468][    T1] VE: install end!!!
[    1.558468][    T1]
[    1.564462][    T1] sunxi-cedar soc@3000000:ve1@1c0e000: Adding to iommu group 0
[    1.571863][    T1] VE: device ve1 just use to add iommu master
[    1.578365][    T1] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.587952][    T1] device-mapper: uevent: version 1.0.3
[    1.593948][    T1] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
[    1.604861][    T1] hidraw: raw HID events driver (C) Jiri Kosina
[    1.613387][    T1] usbcore: registered new interface driver usbhid
[    1.619863][    T1] usbhid: USB HID core driver
[    1.625023][    T1] ashmem: initialized
[    1.629800][    T1] optee: probing for conduit method from DT.
[    1.635646][    T1] optee: revision 2.5
[    1.636079][    T1] optee: initialized driver
[    1.645080][    T1] drm_base=0x40000000
[    1.649287][    T1] drm_size=0x0
[    1.652826][    T1] tee_base=0x2000000
[    1.657387][    T1] usbcore: registered new interface driver snd-usb-audio
[    1.665275][    T1] netem: version 1.3
[    1.669389][    T1] u32 classifier
[    1.673119][    T1]     input device check on
[    1.677896][    T1]     Actions configured
[    1.682933][    T1] xt_time: kernel timezone is -0000
[    1.688083][    T1] ipip: IPv4 and MPLS over IPv4 tunneling driver
[    1.695209][    T1] gre: GRE over IPv4 demultiplexor driver
[    1.701121][    T1] ip_gre: GRE over IPv4 tunneling driver
[    1.707860][    T1] IPv4 over IPsec tunneling driver
[    1.713774][    T1] Initializing XFRM netlink socket
[    1.719125][    T1] IPsec XFRM device driver
[    1.724093][    T1] NET: Registered protocol family 10
[    1.730852][    T1] Segment Routing with IPv6
[    1.735287][    T1] mip6: Mobile IPv6
[    1.739390][    T1] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.746946][    T1] ip6_gre: GRE over IPv6 tunneling driver
[    1.753204][    T1] NET: Registered protocol family 17
[    1.758863][    T1] NET: Registered protocol family 15
[    1.764271][    T1] Bluetooth: RFCOMM TTY layer initialized
[    1.770136][    T1] Bluetooth: RFCOMM socket layer initialized
[    1.776542][    T1] Bluetooth: RFCOMM ver 1.11
[    1.781001][    T1] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.787786][    T1] Bluetooth: HIDP socket layer initialized
[    1.793740][    T1] l2tp_core: L2TP core driver, V2.0
[    1.798793][    T1] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    1.804283][    T1] tipc: Activated (version 2.0.0)
[    1.809433][    T1] NET: Registered protocol family 30
[    1.815124][    T1] tipc: Started in single node mode
[    1.821185][    T1] registered taskstats version 1
[    1.826448][    T1] Loading compiled-in X.509 certificates
[    1.832488][    T1] Key type ._fscrypt registered
[    1.837190][    T1] Key type .fscrypt registered
[    1.842255][    T1] Key type fscrypt-provisioning registered
[    1.849122][    T1] HDMI 2.0 driver init start!
[    1.853662][    T1] boot_hdmi=false
[    1.858355][    T1] Can not find the node of esm
[    1.863385][    T1] ERROR: pinctrl_get for HDMI2.0 DDC fail
[    1.869579][    T1] Get hdmi_power0:aldo1
[    1.873717][    T1] (NULL device *): deviceless supply aldo1 not found, using dummy regulator
[    1.882606][    T1] Get hdmi_power1:dcdc1
[    1.887007][    T1] (NULL device *): deviceless supply dcdc1 not found, using dummy regulator
[    1.897795][    T1] hdmi_cec_init
[    1.902184][    T1] HDMI2.0 module init end
[    1.907102][    T1] tv_probe()1574 - of_property_read_string tv_power failed!
[    1.915394][    T1] tv probe finished!
[    2.510983][   T34] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x4 cs:0x101 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
[    2.890960][    C0] random: fast init done
[    3.535081][   T34] [DISP] de_rtmx_mgr_apply,line:456:
[    3.535083][   T34] ctx->output.hdr_type=0
[    3.545217][   T34] [DISP] de_rtmx_mgr_apply,line:474:
[    3.545219][   T34] ctx->output.hdr_type=0
[    3.579056][   T34] [DISP] disp_device_attached_and_enable,line:235:
[    3.579059][   T34] attached ok, mgr0<-->dev0
[    3.590204][   T34] [DISP] disp_device_attached_and_enable,line:248:
[    3.590209][   T34] type:4,mode:10,fmt:rgb,bits:8bits,eotf:4,cs:257 dvi_hdmi:2, range:2 scan:0 ratio:8
[    3.613808][   T32] sun50iw9-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
[    3.622895][   T32] sun50iw9-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-pc not found, using dummy regulator
[    3.634424][   T32] sunxi-mmc 4022000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.20 2021-12-17 11:02)
[    3.643962][   T32] sunxi-mmc 4022000.sdmmc: ***ctl-spec-caps*** 308
[    3.652099][   T32] sunxi-mmc 4022000.sdmmc: No vdmmc regulator found
[    3.659163][   T32] sunxi-mmc 4022000.sdmmc: No vd33sw regulator found
[    3.666335][   T32] sunxi-mmc 4022000.sdmmc: No vd18sw regulator found
[    3.672858][   T32] sunxi-mmc 4022000.sdmmc: No vq33sw regulator found
[    3.680012][   T32] sunxi-mmc 4022000.sdmmc: No vq18sw regulator found
[    3.686856][   T32] sunxi-mmc 4022000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[    3.696530][   T32] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 23 width 1 timing LEGACY(SDR12) dt B
[    3.720823][   T32] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[    3.745614][   T32] sunxi-mmc 4022000.sdmmc: detmode:alway in(non removable)
[    3.754084][   T32] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.20 2021-12-17 11:02)
[    3.764497][   T32] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[    3.771316][  T128] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[    3.784998][   T32] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[    3.791455][  T128] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[    3.803571][   T32] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[    3.810984][   T32] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[    3.816425][  T128] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[    3.828179][   T32] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 23 width 1 timing LEGACY(SDR12) dt B
[    3.839847][   T32] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[    3.860075][   T32] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[    3.885111][   T32] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
[    3.891256][  T128] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[    3.903458][  T128] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[    3.916111][   T32] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.20 2021-12-17 11:02)
[    3.926575][   T32] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[    3.933219][  T131] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    3.945437][   T32] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[    3.952494][  T128] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[    3.964625][   T32] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[    3.971790][   T32] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[    3.979006][   T32] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[    3.986183][   T32] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[    3.992750][   T32] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[    4.002161][   T32] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 23 width 1 timing LEGACY(SDR12) dt B
[    4.026445][   T32] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[    4.039632][  T128] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[    4.051269][   T32] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[    4.059028][   T32] sun50iw9-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-ph not found, using dummy regulator
[    4.070724][   T32] uart uart0: get regulator failed
[    4.075806][   T32] uart uart0: uart0 supply uart not found, using dummy regulator
[    4.083808][   T32] uart uart0: uart0 error to get fifo size property
[    4.090938][   T32] uart0: ttyAS0 at MMIO 0x5000000 (irq = 43, base_baud = 1500000) is a SUNXI
[    4.100376][   T32] sw_console_setup()1807 - console setup baud 115200 parity n bits 8, flow n
[    4.109586][  T128] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    4.119225][  T128] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    4.129191][   T32] printk: console [ttyAS0] enabled
[    4.139742][  T128] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    4.160510][   T32] printk: bootconsole [uart8250] disabled
[    4.172820][  T128] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
[    4.193916][   T32] uart uart1: get regulator failed
[    4.194176][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
[    4.199453][   T32] uart uart1: uart1 supply uart not found, using dummy regulator
[    4.215671][   T32] uart1: ttyAS1 at MMIO 0x5000400 (irq = 44, base_baud = 1500000) is a SUNXI
[    4.216351][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
[    4.225308][  T128] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 8 timing LEGACY(SDR12) dt B
[    4.245231][  T131] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[    4.258107][   T32] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
[    4.268354][  T128] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 8 timing MMC-HS200 dt B
[    4.280310][  T131] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[    4.292910][   T32] hym8563 probe
[    4.296869][    C0] sunxi-i2c sunxi-i2c2: drv-mode: Timeout when sending 9th SCL clk
[    4.305546][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[    4.305593][   T32] sunxi-i2c sunxi-i2c2: drv-mode: xfer failed (dev addr:0x51)
[    4.321244][  T128] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 100000000Hz bm PP pm ON vdd 23 width 8 timing MMC-HS200 dt B
[    4.322064][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[    4.333603][   T32] rtc-hym8563 2-0051: could not init device, -22
[    4.347899][  T128] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 100000000Hz bm PP pm ON vdd 23 width 8 timing MMC-HS(SDR20) dt B
[    4.348721][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[    4.360578][  T128] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 52000000Hz bm PP pm ON vdd 23 width 8 timing MMC-HS(SDR20) dt B
[    4.380734][   T32] rtc-hym8563: probe of 2-0051 failed with error -22
[    4.381391][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[    4.388064][   T32] sunxi-i2c sunxi-i2c2: probe success
[    4.401406][  T131] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    4.414385][   T32] sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA0
[    4.424327][   T32] sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA1
[    4.434288][   T32] sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA2
[    4.444191][  T128] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 23 width 8 timing MMC-HS400 dt B
[    4.456441][  T128] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 100000000Hz bm PP pm ON vdd 23 width 8 timing MMC-HS400 dt B
[    4.468700][   T32] sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA3
[    4.478647][   T32] sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA4
[    4.488577][   T32] sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA5
[    4.498512][   T32] sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA6
[    4.508457][   T32] sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA7
[    4.518385][  T128] mmc0: new HS400 MMC card at address 0001
[    4.524871][   T32] sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA8
[    4.535283][  T128] mmcblk0: mmc0:0001 A3A562 115 GiB
[    4.541458][  T128] mmcblk0boot0: mmc0:0001 A3A562 partition 1 4.00 MiB
[    4.549280][  T128] mmcblk0boot1: mmc0:0001 A3A562 partition 2 4.00 MiB
[    4.556671][   T32] sun50iw9-pinctrl 300b000.pinctrl: unsupported function io_disabled on pin PA9
[    4.566759][  T128] mmcblk0rpmb: mmc0:0001 A3A562 partition 3 16.0 MiB, chardev (242:0)
[    4.576612][   T32] sun50iw9-pinctrl 300b000.pinctrl: 300b000.pinctrl supply vcc-pa not found, using dummy regulator
[    4.588785][   T32] sunxi gmac driver's version: 1.0.0
[    4.594708][   T32] gmac-power0: NULL
[    4.598859][   T32] gmac-power1: NULL
[    4.602992][   T32] gmac-power2: NULL
[    4.607352][  T128]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26
[    4.621438][   T32] sunxi_ir_startup: get ir protocol failed
[    4.621618][   T32] Registered IR keymap rc_map_sunxi
[    4.633743][   T32] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
[    4.643248][   T32] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
[    4.658261][   T32] dig_led_tm1628_dev_probe
[    4.663043][   T32] get clk_pin..............
[    4.667915][   T32] get dio_pin..............
[    4.672796][   T32] get stb_pin..............
[    4.677674][   T32] dig_led_tm1628 dig_led_tm1628: [dig_led_tm1628_dev_probe] clk_pin=71
[    4.686723][   T32] dig_led_tm1628 dig_led_tm1628: [dig_led_tm1628_dev_probe] dio_pin=66
[    4.695758][   T32] dig_led_tm1628 dig_led_tm1628: [dig_led_tm1628_dev_probe] stb_pin=76
[    4.704801][   T32] dig_led_tm1628 dig_led_tm1628: [dig_led_tm1628_setup_dt] dig_led_tm1628_setup_dt
[    4.715010][   T32] sun50iw9-pinctrl 300b000.pinctrl: pin PC7 already requested by dig_led_tm1628; cannot claim for 300b000.pinctrl:71
[    4.728534][   T32] sun50iw9-pinctrl 300b000.pinctrl: pin-71 (300b000.pinctrl:71) status -22
[    4.737969][   T32] dig_led_tm1628 dig_led_tm1628: [dig_led_tm1628_setup_dt] clk_pin request failed(-22)
[    4.748556][   T32] dig_led_tm1628 dig_led_tm1628: [dig_led_tm1628_setup_dt] clk_pin(71)
[    4.757616][   T32] sun50iw9-pinctrl 300b000.pinctrl: pin PC2 already requested by dig_led_tm1628; cannot claim for 300b000.pinctrl:66
[    4.771147][   T32] sun50iw9-pinctrl 300b000.pinctrl: pin-66 (300b000.pinctrl:66) status -22
[    4.780580][   T32] dig_led_tm1628 dig_led_tm1628: [dig_led_tm1628_setup_dt] dio_pin request failed(-22)
[    4.791175][   T32] dig_led_tm1628 dig_led_tm1628: [dig_led_tm1628_setup_dt] dio_pin(66)
[    4.800218][   T32] sun50iw9-pinctrl 300b000.pinctrl: pin PC12 already requested by dig_led_tm1628; cannot claim for 300b000.pinctrl:76
[    4.813831][   T32] sun50iw9-pinctrl 300b000.pinctrl: pin-76 (300b000.pinctrl:76) status -22
[    4.823252][   T32] dig_led_tm1628 dig_led_tm1628: [dig_led_tm1628_setup_dt] stb_pin request failed(-22)
[    4.833876][   T32] dig_led_tm1628 dig_led_tm1628: [dig_led_tm1628_setup_dt] stb_pin(76)
[    4.842893][   T32] tm1628 clean buf
[    4.894843][   T32] failed to get network led pin assign
[    4.900807][   T32] failed to get gpio_sdcard_reused assign
[    4.907047][   T32] gpio_pin_1(233) gpio_is_valid
[    4.912385][   T32] gpio_pin_2(229) gpio_is_valid
[    4.917910][   T32] gpio: 233, name: PH9, ret = 0
[    4.923287][   T32] gpio: 229, name: PH5, ret = 0
[    4.928619][   T32] gpio-sunxi probe success
[    4.935278][   T32] energy_model: pd0: hertz/watts ratio non-monotonically decreasing: em_cap_state 1 >= em_cap_state0
[    4.947245][   T32] energy_model: Created perf domain 0-3
[    4.965252][    T1] [sound  145][COMMON snd_sunxi_pa_pin_init] pa_pin_max get failed, default 0
[    4.975649][    T1] [sound 1022][SPDIF snd_sunxi_dts_params_init] playback_cma : 128
[    4.984486][    T1] [sound 1023][SPDIF snd_sunxi_dts_params_init] capture_cma  : 128
[    4.993177][    T1] [sound 1024][SPDIF snd_sunxi_dts_params_init] tx_fifo_size : 128
[    5.001859][    T1] [sound 1025][SPDIF snd_sunxi_dts_params_init] rx_fifo_size : 64
[    5.012487][    T1] sunxi-snd-mach soc@3000000:codec_mach: 5096000.codec <-> soc@3000000:codec_plat mapping ok
[    5.024998][    T1] sunxi-snd-mach soc@3000000:spdif_mach: snd-soc-dummy-dai <-> 5093000.spdif_plat mapping ok
[    5.036948][    T1] sunxi-snd-mach soc@3000000:ahub_dam_mach: snd-soc-dummy-dai <-> 5097000.ahub_dam_plat mapping ok
[    5.049564][    T1] sunxi-snd-mach soc@3000000:ahub1_mach: snd-soc-dummy-dai <-> soc@3000000:ahub1_plat mapping ok
[    5.062254][    T1] sunxi-snd-mach soc@3000000:ahub2_mach: snd-soc-dummy-dai <-> soc@3000000:ahub2_plat mapping ok
[    5.074652][    T1] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    5.085497][    T1] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    5.093696][   T32] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    5.094931][    T1] clk: Not disabling unused clocks
[    5.104145][   T32] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[    5.109810][    T1] get_key_map_info()187 - Failed to find "oe" in dts.
[    5.126775][    C0] sunxi-i2c sunxi-i2c5: SLA+W has been transmitted; ACK not received
[    5.135720][    T1] sunxi-i2c sunxi-i2c5: engine-mode: xfer failed(dev addr:0x10)
[    5.144249][    C0] sunxi-i2c sunxi-i2c2: drv-mode: Timeout when sending 9th SCL clk
[    5.152989][    T1] sunxi-i2c sunxi-i2c2: drv-mode: xfer failed (dev addr:0x10)
[    5.161216][    T1] of_property_read_string ac200.tv_regulator_name fail
[    5.168726][    T1] [ac200] get ave_regulator_name failed!
[    5.175086][    T1] [ac200] pwm enable
[    5.179303][    T1] ALSA device list:
[    5.183408][    T1]   #0: audiocodec
[    5.187414][    T1]   #1: sndspdif
[    5.191222][    T1]   #2: ahubdam
[    5.194943][    T1]   #3: ahubhdmi
[    5.198746][    T1]   #4: ahubi2s2
[    5.202577][    T1] alloc_fd: slot 0 not NULL!
[    5.208151][    T1] Freeing unused kernel memory: 1088K
[    5.214062][    T1] Kernel init done
[    5.218073][    T1] Run /init as init process
[    5.271028][  T124] hdmi_hpd_sys_config_release
[    5.295104][    T1] init: init first stage started!
[    5.300705][    T1] init: Unable to open /lib/modules, skipping module loading.
[    5.309188][    T1] init: Copied ramdisk prop to /second_stage_resources/system/etc/ramdisk/build.prop
[    5.319928][    T1] init: Switching root to '/first_stage_ramdisk'
[    5.327656][    T1] init: [libfs_mgr]ReadFstabFromDt(): failed to read fstab from dt
[    5.338764][    T1] init: Using Android DT directory /proc/device-tree/firmware/android/
[    5.369883][    T1] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
[    5.379954][    T1] init: [libfs_mgr]Filesystem on /dev/block/by-name/metadata was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x46
[    5.396190][    T1] EXT4-fs (mmcblk0p19): Ignoring removed nomblk_io_submit option
[    5.409172][    T1] EXT4-fs (mmcblk0p19): recovery complete
[    5.415589][    T1] EXT4-fs (mmcblk0p19): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[    5.428451][    T1] init: [libfs_mgr]check_fs(): mount(/dev/block/by-name/metadata,/metadata,ext4)=0: Success
[    5.440894][    T1] init: [libfs_mgr]check_fs(): unmount(/metadata) succeeded
[    5.450818][  T148] random: e2fsck: uninitialized urandom read (40 bytes read)
[    5.459953][    T1] e2fsck: e2fsck 1.45.4 (23-Sep-2019)
[    5.465856][    T1] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[    5.473201][    T1] e2fsck: Pass 2: Checking directory structure
[    5.479947][    T1] e2fsck: Pass 3: Checking directory connectivity
[    5.486989][    T1] e2fsck: Pass 4: Checking reference counts
[    5.493438][    T1] e2fsck: Pass 5: Checking group summary information
[    5.500762][    T1] e2fsck: /dev/block/by-name/metadata: 29/4096 files (0.0% non-contiguous), 1190/4096 blocks
[    5.520315][    T1] EXT4-fs (mmcblk0p19): mounted filesystem with ordered data mode. Opts: errors=panic
[    5.535196][    T1] random: init: uninitialized urandom read (16 bytes read)
[    5.544245][    T1] random: init: uninitialized urandom read (16 bytes read)
[    5.558476][    T1] EXT4-fs (dm-0): mounted filesystem without journal. Opts: barrier=1
[    5.573414][    T1] EXT4-fs (dm-1): mounted filesystem without journal. Opts: barrier=1
[    5.585229][    T1] EXT4-fs (dm-3): mounted filesystem without journal. Opts: barrier=1
[    5.597381][    T1] EXT4-fs (dm-2): mounted filesystem without journal. Opts: barrier=1
[    5.611925][    T1] newfs_msdos: executing /system/bin/newfs_msdos failed: No such file or directory
[    5.622255][    T1] newfs_msdos: newfs_msdos terminated by exit(255)
[    5.622255][    T1]
[    5.637107][    T1] SELinux: Unable to set superblock options before the security server is initialized
[    5.679277][    T1] printk: init: 27 output lines suppressed due to ratelimiting
[    5.839571][    T1] init: DM_DEV_STATUS failed for system_ext_a: No such device or address
[    5.848908][    T1] init: Could not update logical partition
[    5.855344][    T1] init: Opening SELinux policy
[    5.869425][    T1] init: Loading SELinux policy
[    5.894295][    T1] SELinux:  Permission nlmsg_getneigh in class netlink_route_socket not defined in policy.
[    5.905723][    T1] SELinux: the above unknown classes and permissions will be denied
[    5.914564][    T1] SELinux:  policy capability network_peer_controls=1
[    5.921981][    T1] SELinux:  policy capability open_perms=1
[    5.928326][    T1] SELinux:  policy capability extended_socket_class=1
[    5.935775][    T1] SELinux:  policy capability always_check_network=0
[    5.943101][    T1] SELinux:  policy capability cgroup_seclabel=0
[    5.949937][    T1] SELinux:  policy capability nnp_nosuid_transition=1
[    5.992159][   T35] audit: type=1403 audit(5.880:2): auid=4294967295 ses=4294967295 lsm=selinux res=1
[    6.010487][    T1] selinux: SELinux: Loaded file_contexts
[    6.016660][    T1] selinux:
[    6.097129][    T1] init: init second stage started!
[    6.171428][    T1] init: Using Android DT directory /proc/device-tree/firmware/android/
[    6.187218][    T1] init: Overriding previous property 'persist.sys.usb.config':'none' with new value 'adb'
[    6.199138][    T1] init: Overriding previous property 'persist.sys.usb.config':'adb' with new value 'none'
[    6.210222][    T1] init: Couldn't load property file '/vendor/default.prop': open() failed: No such file or directory: No such file or directory
[    6.231221][    T1] init: Couldn't load property file '/odm_dlkm/etc/build.prop': open() failed: No such file or directory: No such file or directory
[    6.248261][    T1] init: Couldn't load property file '/oem/build.prop': open() failed: No such file or directory: No such file or directory
[    6.263244][    T1] init: Could not set 'ro.boot.dynamic_partitions' to 'true' while loading .prop filesRead-only property was already set
[    6.277213][    T1] init: Could not set 'ro.boot.dynamic_partitions_retrofit' to 'true' while loading .prop filesRead-only property was already set
[    6.293347][    T1] init: Setting product property ro.product.brand to 'Allwinner' (from ro.product.product.brand)
[    6.415446][    T1] cgroup1: Unknown subsys name 'blkio'
[    6.424838][    T1] cgroup1: Unknown subsys name 'memory'
[    6.635484][  T165] ueventd: ueventd started!
[    6.645100][  T165] selinux: SELinux: Loaded file_contexts
[    6.651268][  T165] selinux:
[    6.654941][  T165] ueventd: Parsing file /system/etc/ueventd.rc...
[    6.662446][  T165] ueventd: Added '/vendor/etc/ueventd.rc' to import list
[    6.670235][  T165] ueventd: Added '/odm/etc/ueventd.rc' to import list
[    6.678373][  T165] ueventd: Parsing file /vendor/etc/ueventd.rc...
[    6.685627][  T165] ueventd: Unable to read config file '/vendor/etc/ueventd.rc': open() failed: No such file or directory
[    6.698209][  T165] ueventd: Parsing file /odm/etc/ueventd.rc...
[    6.705137][  T165] ueventd: Unable to read config file '/odm/etc/ueventd.rc': open() failed: No such file or directory
[    6.827683][  T162] sunxi-rfkill soc@3000000:rfkill: module version: v1.0.9
[    6.835564][  T162] sunxi-rfkill soc@3000000:rfkill: pinctrl_lookup_state(default) failed! return ffffffffffffffed
[    6.847287][  T162] sunxi-rfkill soc@3000000:rfkill: get gpio chip_en failed
[    6.855213][  T162] sunxi-rfkill soc@3000000:rfkill: get gpio power_en failed
[    6.911918][  T162] sunxi-rfkill soc@3000000:rfkill: wlan_busnum (1)
[    6.919206][  T162] sunxi-rfkill soc@3000000:rfkill: Missing wlan_power.
[    6.926779][  T162] sunxi-rfkill soc@3000000:rfkill: wlan_regon gpio=210 assert=1
[    6.935261][  T162] sunxi-rfkill soc@3000000:rfkill: wlan_hostwake gpio=207 assert=1
[    6.943970][  T162] sunxi-rfkill soc@3000000:rfkill: wakeup source is enabled
[    6.952307][  T162] sunxi-rfkill soc@3000000:rfkill: Missing bt_power.
[    6.959851][  T162] sunxi-rfkill soc@3000000:rfkill: bt_rst gpio=211 assert=0
[    7.100863][    T1] Registered swp emulation handler
[    7.179228][  T175] logd.auditd: start
[    7.184188][  T175] logd.klogd: 7073249544
console:/ $ [    7.218419][    T1] fsck.f2fs: Info: Fix the reported corruption.
[    7.225529][    T1] fsck.f2fs:       Info: No support kernel version!
[    7.232455][    T1] fsck.f2fs: Info: Segments per section = 1
[    7.238970][    T1] fsck.f2fs: Info: Sections per zone = 1
[    7.245200][    T1] fsck.f2fs: Info: sector size = 512
[    7.251010][    T1] fsck.f2fs: Info: total sectors = 24853471 (12135 MB)
[    7.258568][    T1] fsck.f2fs: Info: MKFS version
[    7.263867][    T1] fsck.f2fs:   "5.4.125"
[    7.268483][    T1] fsck.f2fs: Info: FSCK version
[    7.273783][    T1] fsck.f2fs:   from "5.4.125"
[    7.366626][    T1] F2FS-fs (mmcblk0p26): Using encoding defined by superblock: utf8-12.1.0 with flags 0x0
[    7.378482][    T1] F2FS-fs (mmcblk0p26): Reduce reserved blocks for root = 118743
[    7.458542][    T1] F2FS-fs (mmcblk0p26): Mounted with checkpoint version = 3e537743
[    7.472464][    T1] EXT4-fs (mmcblk0p25): Ignoring removed nomblk_io_submit option
[    7.472475][  T191] type=1400 audit(7.360:3): avc: denied { mounton } for comm="init" path="/vcache" dev="dm-0" ino=3452 scontext=u:r:init:s0 tcontext=u:object_r:vcache_file:s0 tclass=dir permissive=1
[    7.497171][    T1] EXT4-fs (mmcblk0p25): recovery complete
[    7.507512][    T1] EXT4-fs (mmcblk0p25): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[    7.548151][  T191] type=1400 audit(7.436:4): avc: denied { read } for comm="e2fsck" name="mmcblk0p25" dev="tmpfs" ino=1245 scontext=u:r:fsck:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=1
[    7.569308][  T191] type=1400 audit(7.436:5): avc: denied { open } for comm="e2fsck" path="/dev/block/mmcblk0p25" dev="tmpfs" ino=1245 scontext=u:r:fsck:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=1
[    7.591376][  T191] type=1400 audit(7.436:6): avc: denied { write } for comm="e2fsck" name="mmcblk0p25" dev="tmpfs" ino=1245 scontext=u:r:fsck:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=1
[    7.612439][  T191] type=1400 audit(7.436:7): avc: denied { ioctl } for comm="e2fsck" path="/dev/block/mmcblk0p25" dev="tmpfs" ino=1245 ioctlcmd=0x127c scontext=u:r:fsck:s0 tcontext=u:object_r:block_device:s0 tclass=blk_file permissive=1
[   10.447854][    T1] EXT4-fs (mmcblk0p25): Ignoring removed nomblk_io_submit option
[   10.461896][    T1] EXT4-fs (mmcblk0p25): mounted filesystem with ordered data mode. Opts: barrier=1,data=ordered,nomblk_io_submit,noauto_da_alloc,errors=panic
[   10.639545][  T162] mali_kbase: loading out-of-tree module taints kernel.
[   10.683748][  T162] mali 1800000.gpu: Regulators probed: 0
[   10.689953][  T162] mali 1800000.gpu: Clocks probed: 2
[   10.695915][  T162] mali 1800000.gpu: [950mv-600MHz] bak[950mv-600MHz] inde_power:0 idle:1 dvfs:1
[   10.706006][  T162] mali 1800000.gpu: GPU identified as 0x3 arch 7.0.9 r0p0 status 0
[   10.714789][  T162] mali 1800000.gpu: No memory group manager is configured
[   10.723228][  T162] mali 1800000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[   10.736750][  T162] mali 1800000.gpu: Probed as mali0
[   12.190948][    C2] random: crng init done
[   12.195558][    C2] random: 7 urandom warning(s) missed due to ratelimiting
[   12.243444][    T1] init: Service 'exec 6 (/system/bin/vdc keymaster earlyBootEnded)' (pid 221) exited with status 0 waiting took 1.454000 seconds
[   12.258253][    T1] init: Sending signal 9 to service 'exec 6 (/system/bin/vdc keymaster earlyBootEnded)' (pid 221) process group...
[   12.272004][    T1] libprocessgroup: Successfully killed process cgroup uid 1000 pid 221 in 0ms
[   12.282261][    T1] init: Not setting encryption policy on: /data/apex
[   12.290670][    T1] init: Inferred action different from explicit one, expected 0 but got 2
[   12.300637][    T1] init: Inferred action different from explicit one, expected 0 but got 3
[   12.310302][    T1] init: Inferred action different from explicit one, expected 0 but got 2
[   12.320720][    T1] init: starting service 'apexd'...
[   12.346397][    T1] init: Not setting encryption policy on: /data/preloads
[   12.355432][    T1] init: Not setting encryption policy on: /data/data
[   12.358580][  T226] apexd: This device does not support updatable APEX. Exiting
[   12.371089][  T226] apexd: Marking APEXd as activated
[   12.471733][  T229] vdc: Waited 0ms for vold
[   12.671365][  T235] apexd: This device does not support updatable APEX. Exiting
[   12.679718][  T235] apexd: Marking APEXd as ready
[   12.715414][  T162] init: Top-level directory needs encryption action, eg mkdir /data/audio_d <mode> <uid> <gid> encryption=Require
[   12.729356][  T191] type=1400 audit(12.616:8): avc: denied { getattr } for comm="init" path="/data/audio_d" dev="mmcblk0p26" ino=199 scontext=u:r:vendor_init:s0 tcontext=u:object_r:audio_rw_data_file:s0 tclass=dir permissive=1
[   12.785397][  T188] logd: logd reinit
[   12.790725][  T188] logd: FrameworkListener: read() failed (Connection reset by peer)
[   13.229755][  T241] update_verifier: Started with arg 1: nonencrypted
[   13.237519][  T241] cutils-trace: Error opening trace file: No such file or directory (2)
[   13.249139][  T241] update_verifier: Booting slot 0: isSlotMarkedSuccessful=1
[   13.257249][  T241] update_verifier: Leaving update_verifier.
[   13.540351][  T261] healthd: No battery devices found
[   13.564472][  T261] healthd: battery none chg=
Gatekeeper_TA_CreateEntryPoint
[   13.620100][  T162] file system registered
[   13.635655][  T191] type=1400 audit(13.524:9): avc: denied { read write } for comm="pqd" name="disp_firmware" dev="mmcblk0p26" ino=226 scontext=u:r:pqd:s0 tcontext=u:object_r:system_data_root_file:s0 tclass=file permissive=1
[   13.658685][  T191] type=1400 audit(13.524:10): avc: denied { open } for comm="pqd" path="/data/disp_firmware" dev="mmcblk0p26" ino=226 scontext=u:r:pqd:s0 tcontext=u:object_r:system_data_root_file:s0 tclass=file permissive=1
[   13.661307][  T162] sunxi-rfkill soc@3000000:rfkill: block state already is 1
[   13.681481][  T191] type=1400 audit(13.524:11): avc: denied { map } for comm="pqd" path="/data/disp_firmware" dev="mmcblk0p26" ino=226 scontext=u:r:pqd:s0 tcontext=u:object_r:system_data_root_file:s0 tclass=file permissive=1
[   13.815757][    T1] FAT-fs (mmcblk0p24): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   13.915545][  T191] type=1400 audit(13.800:12): avc: denied { write search } for comm="preloaddata" name="tmp" dev="mmcblk0p26" ino=85 scontext=u:r:toolbox:s0 tcontext=u:object_r:shell_data_file:s0 tclass=dir permissive=1
[   13.940458][  T191] type=1400 audit(13.800:13): avc: denied { getattr } for comm="preloaddata" path="/data/local/tmp" dev="mmcblk0p26" ino=85 scontext=u:r:toolbox:s0 tcontext=u:object_r:shell_data_file:s0 tclass=dir permissive=1
[   14.222291][  T191] type=1400 audit(14.108:14): avc: denied { search } for comm="EventThread" name="extcon" dev="sysfs" ino=18241 scontext=u:r:hal_tv_cec_default:s0 tcontext=u:object_r:sysfs_extcon:s0 tclass=dir permissive=1
[   14.255842][  T191] type=1400 audit(14.108:15): avc: denied { read } for comm="EventThread" name="u:object_r:default_prop:s0" dev="tmpfs" ino=2657 scontext=u:r:hal_tv_cec_default:s0 tcontext=u:object_r:default_prop:s0 tclass=file permissive=1
[   14.392748][  T343] sunxi-rfkill soc@3000000:rfkill: wlan power on success
[   14.587291][  T343] misc sunxi-wlan: start scan device on bus_index: 1
[   14.610308][   T36] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 23 width 1 timing LEGACY(SDR12) dt B
[   14.646982][   T36] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[   14.687952][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
[   14.696419][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
[   14.699897][  T373] read descriptors
[   14.709102][   T36] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[   14.739271][  T373] read strings
[   14.744647][   T36] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[   14.773307][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[   14.775559][  T336] input: sunxi-ir-uinput as /devices/virtual/input/input1
[   14.789521][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[   14.797892][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[   14.806237][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[   14.813798][   T36] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   16.632073][  T343] sunxi-rfkill soc@3000000:rfkill: wlan power off success
[   16.640382][  T343] misc sunxi-wlan: start scan device on bus_index: 1
[   16.648784][   T32] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 23 width 1 timing LEGACY(SDR12) dt B
[   16.674976][   T32] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[   16.693026][  T343] sunxi-rfkill soc@3000000:rfkill: wlan power on success
[   16.719842][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
[   16.728279][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
[   16.735935][   T32] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[   16.751948][   T32] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[   16.766741][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[   16.775143][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[   16.783518][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[   16.791883][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[   16.799809][   T32] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   16.811914][  T343] misc sunxi-wlan: start scan device on bus_index: 1
[   16.820701][   T32] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 23 width 1 timing LEGACY(SDR12) dt B
[   16.845620][   T32] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[   16.871585][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
[   16.880030][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 52, RTO !!
[   16.887645][   T32] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[   16.903316][   T32] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 23 width 1 timing LEGACY(SDR12) dt B
[   16.918268][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[   16.926627][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[   16.934974][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[   16.943339][    C0] sunxi-mmc 4021000.sdmmc: smc 2 p1 err, cmd 5, RTO !!
[   16.950906][   T32] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
 楼主| 发表于 2024-5-27 18:01:19 | 显示全部楼层
[95]set pll start
[100]set pll end
[103]unknow PMU
[105]unknow PMU
[109]PMU: AXP1530
[116]board init ok
[118]enable_jtag
[192]card no is 2
[243][mmc]: MMC 5.1
I2C:   ready
[00.434]DRAM:  2 GiB
SPI ALL:   ready
delay time 0
weak:otg_phy_config
[01.215]overtime
[01.280]update dts
到这里怎么停不下来啊
用的SecureCRT 9.3+CH340
波特率115200
分别用以下模式测试均结果相同:
DTR(勾选)
RTS(勾选)
Xon(勾选)
发表于 2024-6-4 16:17:48 | 显示全部楼层
这种配置的盒子基本都是pcdn用的,看电视和cdn互不影响,配置应该假不了,假了就没收益了。至于收益,大概率归中间商。背面的内存颗粒有磨损,像是拆机颗粒。
 楼主| 发表于 2024-6-9 16:44:49 | 显示全部楼层
链接:https://pan.baidu.com/s/1LOq7zWUrpMb3CA8s5A1SoA
提取码:6t0n
刷机固件来了
发表于 2024-6-9 19:57:46 来自手机浏览器 | 显示全部楼层
出的话,多少出?
 楼主| 发表于 2024-6-12 17:51:21 | 显示全部楼层
自己用了啊,出啥啊
GMT+8, 2025-7-19 13:25 , Processed in 0.234000 second(s), 11 queries , Redis On.
