发表于 2025-6-11 11:27:38
显示全部楼层
厉害,可以帮忙分析一下许老师电桥的代码吗?
- //zz20130224 程序升级为V5.5版本;lcd_goto2(9)处显示位置修改,并处理末尾消隐;修正相对测量功能不能启动的问题
- //zz20130223 完善手动档的相关显示,把频率和档位显示语句放到return之前,否则显示不完善
- //zz20130222 修改图形ES(R)为字符型
- //程序基于 2004程序_3.0_全自动电桥V5.4
- // LCR表驱动程序 V2.0
- // 许剑伟 于莆田 2012.01
- #define uchar unsigned char
- #define uint unsigned int
- #define ulong unsigned long
- #include <reg52.h>
- #include <math.h>
- // 项目:LCD1602 四线驱动程序
- // 设计要点:
- // LCD1602 的运行速度慢,而单片机运行的速度快,因此容易因为速度不
- // 匹配造成调试失败。因此,调试之前应准确测试lcd_delay() 延时函数
- // 准确的延时量,如果不能满足注释中的要求,则应调整循次数。每步操
- // 作所需的延时量,按照数据手册指标指行,同时留下足够的时间余量。
- // 硬件连接:
- // 至少需要9条线,电源线2条,7条信号线。信号线详见程序中的接口定义。
- // 清注意对LCD1602对比度的调节,否则无显示。
- // 设计:许剑伟,于莆田,2010.12
- sbit lcd_RS = P2^5; //数据命令控制位,0命令1数据
- sbit lcd_RW = P2^6; //读写位,0写1读
- sbit lcd_EN = P2^7; //使能位,下降沿触发
- sbit lcd_D4 = P0^3; //数据端口D4
- sbit lcd_D5 = P0^2; //数据端口D5
- sbit lcd_D6 = P0^1; //数据端口D6
- sbit lcd_D7 = P0^0; //数据端口D7
- code char path[40]={
- 0x00,0x00,0x0e,0x11,0x11,0x0a,0x1b,0x00,
- 0x00,0x11,0x11,0x13,0x1d,0x10,0x10,0x10,
- 0x0e,0x11,0x1f,0x11,0x11,0x0e,0x00,0x00,
- 0x1C,0x10,0x1B,0x12,0x1B,0x01,0x07,0x00,
- 0x04,0x0e,0x1f,0x04,0x1f,0x0e,0x04,0x00
- };//自定义符号
- code uchar abc[][5]={
- " err"," 40"," 120"," 360"," 1080"," 1K"," 3K"," 9K"," 27K"," 10K",
- " 30K"," 90K"," 270K"," 100K"," 300K"," 900K"," 2.7M"," 13"," 4.5"," 1.5"
- code char *lcr[7] = {"2000", " 200", "20.0","2.00", " 20", " 20","2.0"};
- code char *feqc[3] = {"100Hz"," 1KHz" ,"7.8KH"};
- code char *zero[2] = {"Open zero......","Short zero...OK."};
- char binLian=0,ATA=0,ATD=0;
- char OX[8]={0,0,0,0,0,0,8,0};
- int DDS3=1, c3 = 0,c4 = 0;
- xdata char isQ=1,REL=0;
- xdata uchar menu=1,menu2=0; //菜单变量
- xdata float TR,TX; //清零数据
- xdata float RELDAT; //相对测量数据
- uint ph=0, phM=256, feq=977; //相位,phM相位步进值
- void lcd_delay(int n){ //LCD专用延时函数
- //32MHz钟频下,约循环3000次延迟1毫秒
- int i,j;
- if(n<0) { for(i=0;i< 30;i++); return; } //10us
- if(n== 0) { for(i=0;i<150;i++); return; } //50us
- for(;n;n--){ for(j=0;j<3000;j++); } //n毫秒
- void lcd_B(char f, uchar c, char t){ //控制四线式接口LCD的7个脚
- //f=0写命令字, f=1写RAM数据, f=2读地址(或读忙), f=3读RAM数据
- lcd_EN = 0;
- lcd_RS = f%2;
- lcd_RW = f/2%2;
- //移入高四位
- lcd_D4 = c & 16;
- lcd_D5 = c & 32;
- lcd_D6 = c & 64;
- lcd_D7 = c & 128;
- lcd_EN = 1; lcd_delay(-1); lcd_EN = 0; //使能脉冲
- if(f==4) { lcd_delay(t); return; }
- //移入低四位
- lcd_D4 = c & 1;
- lcd_D5 = c & 2;
- lcd_D6 = c & 4;
- lcd_D7 = c & 8;
- lcd_delay(t); //不同的命令,响应时间不同,清零命令需要2ms
- void lcd_init(){ //LCD1602 初始化
- //启动四线模式须势行9个步骤,初始化所须耗时较长,约65ms,时限不可减
- lcd_delay(20); //启动lcd之前须延时大于15ms,直到VDD大于4.5V
- lcd_B(4, 0x30, 9); //置8线模式,须延时大于4.1ms
- lcd_B(4, 0x30, 5); //置8线模式,须延时大于100us
- lcd_B(4, 0x30, 5); //置8线模式,手册中未指定延时
- lcd_B(4, 0x20, 5); //进入四线模式
- lcd_B(0, 0x28, 5); //四线模式双行显示
- lcd_B(0, 0x0C, 5); //打开显示器
- lcd_B(0, 0x80, 5); //RAM指针定位
- lcd_B(0, 0x01, 5); //启动清屏命初始化LCD
- //=========================几个功能常用函数=================================
- void lcd_cls() { lcd_B(0, 0x01+0, 2); } //清屏
- void lcd_cur0() { lcd_B(0, 0x0C+0, 0); } //隐藏光标
- void lcd_goto1(uchar x){ lcd_B(0, 0x80+x, 0); } //设置DDRAM地址,第1行x位
- void lcd_goto2(uchar x){ lcd_B(0, 0xC0+x, 0); } //设置DDRAM地址,第2行x位
- void lcd_goto3(uchar x){ lcd_B(0, 0x94+x, 0); } //设置DDRAM地址,第3行x位
- void lcd_goto4(uchar x){ lcd_B(0, 0xD4+x, 0); } //设置DDRAM地址,第4行x位
- void lcd_putc(uchar d) { lcd_B(1, 0x00+d, 0); } //字符输出
- void lcd_puts(uchar *s){ for(; *s; s++) lcd_B(1,*s,0); } //字串输出
- //==============字符显示函数====================
- void lcd_putp(float a,float b,char bo,char n, float qmin){ //带单位显示复数,n是单位下限,qmin是最小位权值(用于限定有效数字)
- code uchar dwB[] = {'p','n',1,'m',0,'k','M','G'}; //单位表
- char i,j, c=0,digW=4, h=3, fh[2]={' ','+'};
- long d,q,qm,Q=1; //最高位权
- float f,g=1,k=1;
- if(bo==2){k=2;}
- if(a<0) fh[0] = '-', a = -a;
- if(b<0) fh[1] = '-', b = -b;
- if(a>b) f = a; else f = b;
- for(i=1;i<4;i++) Q *= 10;
- for(i=0;i<3;i++){ if(f*g >= k*1000) g/=1000, c++; } //以3位为单位移动小数点,右移
- for(i=0;i<n;i++){ if(f*g < k) g*=1000, c--; } //以3位为单位移动小数点,左移
- if ((n==1)&&(c==-1)){
- digW=2; //移动1位小数点
- }else if ((n==2)&&(c==-2)){
- if(feq!=7813) {digW=2; //移动1位小数点
- }else{ digW=3; } //移动2位小数点
- }else if ((n==4)&&(c==-4)){
- for(i=1;i<digW && f*g<k*Q;i++) g*=10,h--; //继续移动小数点,使之满字
- qm = g*qmin;
- for(i=0;i<2;i++){
- if(i) d = b*g+0.5; //取出实部
- else d = a*g+0.5; //取出虚部
- if(qm) d+=qm/2, d-=d%qm;//去除小于qmin的尾数
- if(d>=Q*20) d=(d+0.5)/10, h++;
- q = Q;
- if(d>=Q*10){
- d -= Q*10;
- if(fh[i]=='-') {lcd_puts("-1");
- }else {lcd_puts(" 1");}
- }else{
- lcd_putc(fh[i]); if(bo==2)lcd_putc('0'); //显示符号
- for(j=0; j<4; j++){ //数字输出
- lcd_putc(d/q+48); //数字
- if(j==h) lcd_putc('.');//小数点
- d %= q, q /= 10;
- if(!bo||bo==2) break; //不显示虚部
- if((n!=1)&&(dwB[c+4]==0))lcd_putc(' '); else lcd_putc(dwB[c+4]);//单位
- if((n==1)&&(dwB[c+4]==0)) OX[6]=32; else OX[6]=8; //自动单位
- void lcd_putf(float a, char n, float qmin) //带单位显示浮点数,n是单位下限
- { lcd_putp(a,0,0,n,qmin); }
- void lcd_int(int a,char w){ //定宽显示正整数
- char i=0, s[5] = {' ',' ',' ',' ',' '};
- if(a<0) { a=-a; lcd_puts("-"); }
- else lcd_puts(" ");
- do{
- s[i++] = a%10+48;
- a /= 10;
- }while(a);
- for(;w;w--) lcd_putc(s[w-1]);
- //===============================延时函数===================================
- void delay(uint loop) { uint i; for(i=0;i<loop;i++); } //延时函数
- void delay2(uint k) { for(;k>0;k--) delay(10000); } //长延时,k=100大约对应1秒
- //=================================AD转换===================================
- sfr P1ASF = 0x9D; //将P1置为模拟口寄存器(使能),各位中为1的有效
- sfr ADC_CONTR = 0xBC; //A/D转换控制寄存器
- sfr ADC_res = 0xBD; //A/D转换结果寄存器
- sfr ADC_resl = 0xBE; //A/D转换结果寄存器
- void set_channel(char channel){
- P1ASF = 1<<channel;
- ADC_CONTR = channel+128; //最高位是电源开关,低3位通道选择
- delay(1); //首次打开电源应延迟,使输入稳定
- uint getAD2(){
- ADC_CONTR |= 0x08; //00001000,置ADC_START=1启动A/D 转换
- while ( !(ADC_CONTR & 0x10) ); //等待A/D转换结束(ADC_FLAG==0)
- ADC_CONTR &= 0xE7; //11100111,置ADC_FLAG=0清除结束标记, 置ADC_START=0关闭A/D 转换
- return ADC_res*4 + ADC_resl;
- //==================================EEPROW偏程==============================
- sfr IAP_data = 0xC2;
- sfr IAP_addrH = 0xC3;
- sfr IAP_addrL = 0xC4;
- sfr IAP_cmd = 0xC5;
- sfr IAP_trig = 0xC6;
- sfr IAP_contr = 0xC7;
- 写字节时,可以将原有数据中的1改为0,无法将0改为1,只能使用擦除命令将0改为1
- 应注意,擦除命令会将整个扇区擦除
- int eepEn = 0;
- void saEEP(){ //触发并EEP保护
- if(eepEn==12345) IAP_trig = 0x5A; //先送5A
- if(eepEn==12345) IAP_trig = 0xA5; //先送5A再送A5立即触发
- IAP_cmd = 0; //关闭令,保护
- IAP_contr = 0; //关EEPROM,保护
- IAP_trig = 0;
- IAP_addrL = 255; //设置读取地址的低字节,地址改变才需要设置
- IAP_addrH = 255; //设置读取地址的高字节,地址改变才需要设置
- uchar readEEP(uint k){ //读取
- IAP_addrL = k; //设置读取地址的低字节,地址改变才需要设置
- IAP_addrH = k>>8; //设置读取地址的高字节,地址改变才需要设置
- IAP_contr = 0x81; //设置等待时间,1MHz以下取7,2M以下取6,3M取5,6M取4,12M取3,20M取2,24M取1,30M取0,前导1表示许档IAP
- IAP_cmd = 1; //读取值1,写取2,擦除取3,擦除时按所在字节整个扇区撺除
- saEEP(); //触发并保护
- return IAP_data;
- void writeEEP(uint k, uchar da){ //写入
- IAP_data = da; //传入数据
- IAP_cmd = 2; //读取值1,写取2,擦除取3,擦除时按所在字节整个扇区撺除
- saEEP(); //触发并保护
- void eraseEEP(uint k){ //擦除
- IAP_cmd = 3; //读取值1,写取2,擦除取3,擦除时按所在字节整个扇区撺除
- saEEP(); //触发并保护
- xdata struct Ida{
- char zo[3];//三个频率下的零点改正值
- char j1; //相位补偿(3倍档)
- char j2; //相位补偿(10倍档)
- char J[4]; //相位补偿(V/I变换器)
- char R[4]; //下臂电阻修正(40,1k,10k,100k)
- char g1; //增益修正(3倍档)
- char g2; //增益修正(10倍档)
- char phx; //1kHz以下相位改正
- char R4b; //100k档7.8kHz频率下的幅度补偿
- char G2b; //9倍档7.8kHz频率下的幅度补偿
- char feq; //频率修正
- char ak; //AD斜率修正
- float QRs[3],QXs[3]; //短路清零数据
- float QRo[3],QXo[3]; //开路清零数据
- } cs;
- void cs_RW(char rw){
- uchar i,*p = &cs;
- const int offs=512;
- if(rw){
- delay2(20); //等待(防止掉电误识别键盘而调用本函数)
- eraseEEP(offs);
- for(i=0;i<sizeof(cs);i++) writeEEP(i+offs,p[i]);
- }else{
- for(i=0;i<sizeof(cs);i++) p[i]=readEEP(i+offs);
- //==================================LCR主程序===============================
- sfr P1M1=0x91; //P1端口设置寄存器
- sfr P1M0=0x92; //P1端口设置寄存器
- sfr P0M1=0x93; //P0端口设置寄存器
- sfr P0M0=0x94; //P0端口设置寄存器
- sfr P2M1=0x95; //P2端口设置寄存器
- sfr P2M0=0x96; //P2端口设置寄存器
- sfr P3M1=0xB1; //P3端口设置寄存器
- sfr P3M0=0xB2; //P3端口设置寄存器
- sbit spk=P2^3; //蜂鸣器
- sbit Kb=P2^4; //量程开关B
- sbit Ka=P2^2; //量程开关A
- sbit DDS2=P1^2;//移相方波输出口
- sbit K3=P1^7;
- sbit K4=P1^6;
- sbit K5=P1^5; //7.8kHz滤波开关
- sbit K6=P1^4;
- sbit K8=P2^0; //100Hz滤波开关
- sbit K32=P1^1; //32kHz发生器
- //==============低频信号DDS相关参数====================
- //PCA相关寄存器
- sfr CMOD = 0xD9; //钟源选择控制等
- sfr CH = 0xF9; //PCA的计数器
- sfr CL = 0xE9; //PCA的计数器
- sfr CCON = 0xD8; //PCA控制寄存器
- sfr CCPAM0 = 0xDA; //PCA模块0工作模式寄存器
- sfr CCPAM1 = 0xDB; //PCA模块1工作模式寄存器
- sfr CCAP0L = 0xEA; //模块0捕获寄存器低位
- sfr CCAP0H = 0xFA; //模块0捕获寄存器高位
- sfr IPH = 0xB7;
- sbit PPCA = IP^7; //PCA的中断优先级设置
- sbit CCF0 = CCON^0; //PCA的模块0中断标志
- sbit CCF1 = CCON^1; //PCA的模块1中断标志
- sbit CR = CCON^6; //PCA计数器使能
- uchar *ph8 = (char*)&ph; //ph的高8位地址
- xdata float feqX=976.6; //实际输出频率
- uchar code sinB[256]={
- //查询表中不可装载零值,否则会造成无中断产生
- 255,255,255,255,255,255,254,254,253,252,252,251,250,249,248,247,246,245,243,242,240,239,237,236,234,232,230,229,227,225,222,220,
- 218,216,214,211,209,206,204,201,199,196,194,191,188,185,183,180,177,174,171,168,165,162,159,156,153,150,147,144,140,137,134,131,
- 128,125,122,119,116,112,109,106,103,100, 97, 94, 91, 88, 85, 82, 79, 76, 73, 71, 68, 65, 62, 60, 57, 55, 52, 50, 47, 45, 42, 40,
- 38, 36, 34, 31, 29, 27, 26, 24, 22, 20, 19, 17, 16, 14, 13, 11, 10, 9, 8, 7, 6, 5, 4, 4, 3, 2, 2, 1, 1, 1, 1, 1,
- 1, 1, 1, 1, 1, 1, 2, 2, 3, 4, 4, 5, 6, 7, 8, 9, 10, 11, 13, 14, 16, 17, 19, 20, 22, 24, 26, 27, 29, 31, 34, 36,
- 38, 40, 42, 45, 47, 50, 52, 55, 57, 60, 62, 65, 68, 71, 73, 76, 79, 82, 85, 88, 91, 94, 97,100,103,106,109,112,116,119,122,125,
- 128,131,134,137,140,144,147,150,153,156,159,162,165,168,171,174,177,180,183,185,188,191,194,196,199,201,204,206,209,211,214,216,
- 218,220,222,225,227,229,230,232,234,236,237,239,240,242,243,245,246,247,248,249,250,251,252,252,253,254,254,255,255,255,255,255
- uchar code fbB[256]={ //方波DDS查询表
- 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
- 1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,
- 1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1};
- uchar chuX=0; //方波DDS初相
- //==============低频信号DDS函数====================
- void PWM_init(){ //把PCA置为PWM
- CMOD = 2; //0000 0010 计数源选择,钟源取fosc/2
- CL = CH = 0;
- CCAP0L = CCAP0H = 192; //占空比为25%
- //CCPAM0=0x42;//0100 0010,PCA的模块0设置为PWM模式,无中断
- CCPAM0=0x53;//0101 0011,PCA的模块0设置为PWM模式,有中断,下降沿中断
- PPCA = 1; //优先中断
- IPH |= 128;
- //CR = 1; //开始计数
- EA = 1; //开总中断
- void PCAinter(void) interrupt 7 {//PCA中断
- uchar x,y;
- CCF0=0; //清除中断请求,以免反复中断
- x = *ph8; //截断正弦相位累加器,取高8位
- y = x + chuX; //方波相位
- CCAP0H = sinB[x];//正弦DDS输出
- if(DDS3) { DDS2 = fbB[y]; //方波DDS输出
- }else {DDS2 = 0;}
- ph += phM; //相位累加
- K32 = ~K32;
- void setDDS(uint f){ //参考时钟是c=(fosc/2)/256=32000000/2/256=62500,频率f=c*phM/2^16
- feq = f;
- phM=f*65536.0/62500; //phM=f*2^16/62500
- feqX = 62500.0*phM/65536*(1+cs.feq/10000.0); //实际输出频率
- ph = 0; //高频时,使波形对称
- if(!f) CR=0; else CR=1;
- //相位控制函数
- xdata char xw=0; //相位
- void set90(char k){ //设置方波的相位差
- k %= 4;
- if(k<0) k += 4;
- chuX = k*64; //移相0~270度
- xw = k;
- void set902() { set90(xw+1); } //相位步进
- //==============量程控制函数====================
- xdata char rng=1; //量程
- void setRng(char k){//切换量程
- if(k>3) k=3;
- if(k<0) k=0;
- Kb = k & 2, Ka = k & 1; //40欧--100k欧
- rng = k;
- void setRng2(){ setRng( (rng+1)%4);} //量程步进
- //==============增益控制函数====================
- char curGain=1; //当前增益索引号
- void setGain(char k){ //设置电路增益
- if(k>3) k=3;
- if(k<0) k=0;
- K4 = k & 2, K6 = k & 1; //1倍--27倍
- curGain = k;
- void setGain2(){ setGain((curGain+1)%4); }
- //==============AD非线性改正与过采样=================
- uint getAD10(){ //120次采样,用reentrant申明,有的单片机无法运行
- uchar i;
- long c;
- for(i=0;i<250;i++) c += getAD2();
- return (c+12)/25;
- uint getAD10b(){ //120次采样,用reentrant申明,有的单片机无法运行
- xdata uint c = 0, c2 = 0;
- uchar i;
- for(i=0;i<250;i++){
- c += ADC_resl;
- c2 += ADC_res;
- c3 = c;
- c = ( c2*4L + c )/25;
- c3= ( c2*4L + c3 ) -c*25;
- return c;
- //==============LCR测量====================
- code float ga[4] = { 1, 3, 9, 27 }; //增益表
- code float dwR[4] = { 40, 1e3, 1e4, 1e5 }; //各档电阻表
- xdata int Vxy[12]={0,0,0,0,1,1}; //Vxy[Vx1,Vy1,Vx2,Vy2,g1,g2]
- xdata char Sxw[4]={0,1,0,1}; //保存正确相位
- xdata int Vz[24]; //LCR测量结果队
- xdata uchar tim=0,tims=0;
- xdata char pau=0; //暂停坐标自动旋转
- #define Vfull 9600
- #define gad (9600/30)
- uchar mT = 6; //测量速度,mT取值为6或12或24时,可以消除数字噪声,尾数不动,但不利于于取平均
- //==============设置频率====================
- xdata char feqK=1; //频率索引号
- void setF(char k){
- if(k==-1) k = (feqK+1)%3; //步进
- feqK = k;
- if(k==0) { setDDS(100); K5=0; K8=1; mT=12; } //置为100Hz
- if(k==1) { setDDS(977); K5=0; K8=0; mT=6; } //置为1kHz
- if(k==2) { setDDS(7813); K5=1; K8=0; mT=6; } //置为7.8125kHz
- TH1 = 150, TL1 = 171; //置为20ms
- tims = 0;
- tim = 0;
- ph = 0;
- int absMax(int a,int b){ //取两个数绝对值最大者
- if(a<0) a = -a;
- if(b<0) b = -b;
- if(b>a) a = b;
- return a;
- char yc1=0,yc2=0; //溢出标识
- char slw = 1; //降速倍率
- char chg=0; //量程切换标记
- void timerInter1(void) interrupt 3 {//T1中断,LCR数据采集
- code int y[5]={0,-15,30,24,0}; //满度用30
- code int x[5]={4900,5090,5140,5500,6120};
- char g,gb,Rb,i; int c=0,cc=0;
- tims++;
- if(tims>=mT/slw) tims = 0, tim++, c = 1;
- if(tim>=4) tim=0;
- if(pau) return;
- if(!c) return; //tim未进位触发
- c = getAD10b(); //读取电压值
- c4= c;
- cc= c3;
- c -= cs.zo[feqK];
- if(cs.ak!=0){
- for(i=0;i<4;i++){ //非线性改正
- if(c<x[i]||c>=x[i+1]) continue;
- c += cs.ak*( y[i] + (y[i+1]-y[i]) * ((int)(c-x[i])) / (x[i+1]-x[i]) ) / 30;
- break;
- Vxy[tim] = xw<2 ? c : -c; //保存当前电压
- Vxy[tim+6] = xw<2 ? cc : -cc; //保存当前电压
- Vxy[tim/2+4] = curGain; //保存当前增益
- Sxw[tim] = ( Sxw[tim]+(c<0 ? 2 : 0) )%4; //相位翻转(预测下次的相位采用值)
- if(tim==1||tim==3){ //上下臂切换
- if(tim==1) { K3=1, c = absMax(Vxy[2],Vxy[3]), g=Vxy[5]; yc2 = c>Vfull ? 1:0; }//切换到下臂
- if(tim==3) { K3=0, c = absMax(Vxy[0],Vxy[1]), g=Vxy[4]; yc1 = c>Vfull ? 1:0; }//切换到上臂
- gb=g, Rb=rng;
- if(c>Vfull){ if(g==0&&rng>0&&K3&&isQ) Rb=rng-1; gb=0; }
- else if(c<gad*1 ) gb = g+3; //增加27倍
- else if(c<gad*3 ){ gb = g+2;if(c<gad*2&&rng>=1&&rng<=2&&K3&&isQ ) { gb=0; Rb=rng+1; }} //增加9倍
- else if(c<gad*9) gb = g+1; //增加3倍
- if(gb>3) gb = 3;
- if(g==3&&rng<3&&K3&&isQ) { gb=0; Rb=rng+1; }
- if(g==0&&c<gad*1&&rng<3&&K3&&isQ) { gb=0; Rb=rng+1; }
- setRng(Rb); setGain(gb); //置量程
- if(gb!=g || Rb!=rng) slw = 2, chg++; //量程正在改变,则加速测量
- if(tim==3){ if(!chg) slw=1; chg=0; }
- set90( Sxw[ (tim+1)%4 ] ); //相位旋转
- if(tim==3){ for(i=0;i<12;i++) Vz[i+12]=Vz[i], Vz[i]=Vxy[i]; }
- void showR(char binLian, char showk){ //显示LCR
- xdata float a=0,b=0,c=0,qq=0,dd=0,e,w,L,C;
- xdata int gr=cs.R[rng], g1=cs.g1, g2=cs.g2;
- xdata int g12 = g1 + g2; //增益最大补偿
- xdata int j12 = (int)cs.j1+cs.j2; //相位最大补偿
- xdata float RELOUT;
- xdata long RELTMP;
- xdata float JD = 0, G = 0, cJD; //补偿变量
- xdata float v[4];
- xdata char ATC=0,ATE=0,d2=0,d3=1;
- xdata float LCR[3];
- //LCR计算
- if(feqK<0||feqK>2) return;
- if(feq==7813&&rng==3) gr += cs.R4b; //7.8kHz时下臂修正量
- //可控增益单元的增益修正、相位补偿量
- if(feq==7813) g2 += cs.G2b; //7.8kHz时9倍档修正量
- if(Vz[4] == 1) JD += cs.j1, G += g1;
- if(Vz[4] == 2) JD += cs.j2, G += g2;
- if(Vz[4] == 3) JD += j12, G += g12;
- if(Vz[5] == 1) JD -= cs.j1, G -= g1;
- if(Vz[5] == 2) JD -= cs.j2, G -= g2;
- if(Vz[5] == 3) JD -= j12, G -= g12;
- JD = (JD - cs.J[rng]) * feqX/7813/2000;
- if(feq==977) JD -= cs.phx/2000.0;
- cJD = 1 - JD*JD/2;
- v[0] = Vz[0]+Vz[12]+(Vz[6]+Vz[18])/25.0;
- v[1] = Vz[1]+Vz[13]+(Vz[7]+Vz[19])/25.0;
- v[2] = Vz[2]+Vz[14]+(Vz[8]+Vz[20])/25.0;
- v[3] = Vz[3]+Vz[15]+(Vz[9]+Vz[21])/25.0;
- a = (+( 1.0*v[2]*v[2] + 1.0*v[3]*v[3] )*((ga[Vz[4]] / ga[Vz[5]]) /(dwR[rng]*(1+gr/10000.0))))+(+( 1.0*v[2]*v[2] + 1.0*v[3]*v[3] )*((ga[Vz[4]] / ga[Vz[5]]) /(dwR[rng]*(1+gr/10000.0))))*G/10000; //增益补偿
- b = (-( 1.0*v[0]*v[2] + 1.0*v[1]*v[3] ))*cJD - (-( 1.0*v[2]*v[1] - 1.0*v[0]*v[3] ))*JD; //相位补偿
- c = (-( 1.0*v[0]*v[2] + 1.0*v[1]*v[3] ))*JD + (-( 1.0*v[2]*v[1] - 1.0*v[0]*v[3] ))*cJD; //相位补偿
- if(showk){
- w = 2*3.1415926*feqX;
- if((showk==5)||(showk==8)||(showk==10)||(showk==13)||(showk==15)||(showk==18)||(showk==19)){d3=0;}
- if((showk==1)||(showk==2)||(showk==3)) //校准项
- showk=0;
- lcd_puts("Z=");
- lcd_putf(c4-cs.zo[feqK],0,0);
- return;
- if(binLian){ //并联
- e = (b*b+c*c)/a;
- if(d3){
- lcd_puts("R=");
- lcd_putp(e/b, 0,2,1, 1e-4); //显示并联复阻抗,显示到毫欧
- }else{
- if((showk==10)||(showk==13)||(showk==15)||(showk==18)){
- C = -c/e/w;
- L = +e/c/w;
- if(C>-2e-12) { lcd_putp(C, 0,2,4, 1e-14); lcd_putc('F'); } //显示并联C值,显示到pF
- else { lcd_putp(L, 0,2,2, 5e-9 ); lcd_putc('H'); } //显示并联L值,显示到uH
- }else{
- lcd_putc(10);lcd_puts("=");
- lcd_putf(atan2(c,b)*180/3.1415926,0,0); //显示角度
- lcd_puts(" ");
- }else{ //串联
- e = a;
- if(d3){
- lcd_puts("R=");
- lcd_putp(b/e, c/e, 2, 1, 1e-5); lcd_putc(OX[6]); //定义欧姆符号_显示串联复阻抗,显示到毫欧
- }else{
- C = -e/c/w;
- L = +c/e/w;
- if(L<-2e-8) { lcd_putp(C, 0,2,4, 1e-14); lcd_putc('F'); } //显示C值,显示到pF
- else { lcd_putp(L, 0,2,2, 5e-9 ); lcd_putc('H'); } //显示L值,显示到uH
- }else{
- lcd_putc(10);lcd_puts("="); /////////////////////////////lcd_putc(10)相位角自定义符号
- lcd_puts(" ");
- return;
- if(binLian==20){ //测量开路残余值
- if(rng==0){
- TR += b/a, TX += c/a; //短路残余阻抗
- if(rng==3){
- a = (b*b+c*c)/a;
- TR += b/a, TX += c/a; //开路残余导抗
- return;
- if(binLian==21){ //是否应用清零
- isQ = (isQ+1)%2;
- return;
- if(isQ){ //自动手动,此处为自动 ////////////////////////////////////////////////////////////////
- if(rng==0){
- b -= cs.QRs[feqK]*a, c -= cs.QXs[feqK]*a;//短路清零
- if(rng>1){
- a = (b*b+c*c)/a;
- b -= cs.QRo[feqK]*a, c -= cs.QXo[feqK]*a; //开路清零
- a = (b*b+c*c)/a;
- if(ATA!=0){
- if(ATD==0) { if(rng>1)ATE=1;else ATE=0; } //置为100Hz
- if(ATD==1) { ATE=1; } //置为1kHz
- if(ATD==2) { ATE=0; } //置为7.8125kHz
- }else { if(rng>1)ATE=1;else ATE=0; }
- if(feq==100) LCR[0]=2e3,LCR[1]=2e-1,LCR[2]=2e7,d2=1;
- if(feq==977) LCR[0]=2e2,LCR[1]=2e-2,LCR[2]=2e7,d2=2;
- if(feq==7813) LCR[0]=2e1,LCR[1]=2e-3,LCR[2]=2e6,d2=3;
- if(ATE){ //并联
- e = (b*b+c*c)/a;
- C = -c/e/w;
- L = +e/c/w;
- if(C>-2e-12) { ATC=1; }
- else { ATC=2; }
- if(fabs(e/b)<fabs(e/c)) { ATC=3; }
- }else{ //串联
- e = a;
- C = -e/c/w;
- L = +c/e/w;
- if(L<-2e-8) { ATC=1; }
- else { ATC=2; }
- if(fabs(b/e)>fabs(c/e)) { ATC=3; }
- qq = fabs(c/b); //计算Q
- if(!b||qq>999) qq = 999;
- dd = fabs(b/c); //计算D
- if(!c||dd>=10) dd = 9.999;
- if(ATA!=0){ATC=ATA;}
- lcd_goto1(0);
- if(ATC==0){
- }else if(ATC==1){
- if(ATE){ //并联
- lcd_puts("Cp");
- if(C>-2e-12) {
- if(fabs(C)<LCR[1]) {lcd_putp(C, 0,2,4, 1e-14); lcd_putc('F'); //显示并联C值,显示到pF
- }else{lcd_puts(" C>");lcd_puts(lcr[d2]);lcd_puts("mF");}
- else { lcd_puts(" ---OL---"); }
- }else{ //串联
- lcd_puts("Cs");
- if(L<-2e-8) {
- if(fabs(C)<LCR[1]) {lcd_putp(C, 0,2,4, 1e-14); lcd_putc('F'); //显示串联C值,显示到pF
- }else if(ATC==2){
- if(ATE){ //并联
- lcd_puts("Lp");
- if(C>-2e-12) { lcd_puts(" ---OL---"); }
- else {
- if(fabs(L)<LCR[0]) { lcd_putp(L, 0,2,2, 5e-9 ); lcd_putc('H'); //显示并联L值,显示到uH
- }else{lcd_puts(" L>");lcd_puts(lcr[d2-1]);lcd_puts(" H");}
- }else{ //串联
- lcd_puts("Ls");
- if(L<-2e-8) { lcd_puts(" ---OL---"); }
- else {
- if(fabs(L)<LCR[0]) { lcd_putp(L, 0,2,2, 5e-9 ); lcd_putc('H'); //显示串联L值,显示到uH
- }else if(ATC==3){
- if(ATE){ //并联
- lcd_puts("Rp");
- if(fabs(e/b)<LCR[2]) { lcd_putp(e/b, 0,2,1, 1e-4); lcd_putc(OX[6]);} //显示电阻
- else { lcd_puts(" R>");lcd_puts(lcr[d2+3]);lcd_puts(" M");lcd_putc(OX[6]); }
- }else{ //串联
- lcd_puts("Rs");
- if(fabs(b/e)<LCR[2]) { lcd_putp(b/e, 0,2,1, 1e-4); lcd_putc(OX[6]);} //显示电阻
- lcd_goto2(0);
- lcd_puts("Q=");
- lcd_putf(qq,0,0); //显示Q
- lcd_goto3(0);
- lcd_puts("D=");
- lcd_putf(dd,0,0); //显示D
- lcd_goto4(0);
- if(REL) {
- lcd_putc(4);lcd_puts("=");
- if(ATC==0){
- }else if(ATC==1){if(RELDAT==0){RELDAT=C;RELOUT=0;}else{RELOUT=(C-RELDAT)/RELDAT*100.0;}
- }else if(ATC==2){if(RELDAT==0){RELDAT=L;RELOUT=0;}else{RELOUT=(L-RELDAT)/RELDAT*100.0;}
- }else if(ATC==3){
- if(ATE){ //并联
- if(RELDAT==0){RELDAT=e/b;RELOUT=0;}else{RELOUT=((e/b)-RELDAT)/RELDAT*100.0;}
- }else{ //串联
- if(RELDAT==0){RELDAT=b/e;RELOUT=0;}else{RELOUT=((b/e)-RELDAT)/RELDAT*100.0;}
- if(RELOUT<-99.9)RELOUT=-100;
- if(RELOUT>99.9)RELOUT=100;
- if (fabs(RELOUT)==100){
- if (RELOUT>99.9) lcd_puts(" OL %"); else lcd_puts("- OL %");
- }else{
- RELTMP=RELOUT*1000+0.5;
- lcd_putf(RELTMP/1000.0,0,0); lcd_puts("%");
- if(!ATA){ATA=ATC;}
- }else{
- RELDAT=0;
- lcd_putc(10);lcd_putc('=');
- lcd_putf(atan2(c,b)*180/3.1415926,0,0);lcd_puts(" "); //显示角度
- lcd_goto2(9); ///////////////////////////////////////////////
- if(ATC==3){
- if(ATE){ //并联
- lcd_puts(" Xp");
- if(fabs(e/c)<LCR[2]) { lcd_putf(e/c, 1, 1e-4); lcd_putc(OX[6]);} //显示电阻
- else { lcd_puts(" X>");lcd_puts(lcr[d2+3]);lcd_puts("M");lcd_putc(OX[6]);}//lcd_puts(" "); }
- }else{ //串联
- lcd_puts(" Xs");
- if(fabs(c/e)<LCR[2]) { lcd_putp(c/e, b/e, 0, 1, 1e-4); lcd_putc(OX[6]);} //显示电阻
- }else{
- if(ATE){ //并联
- lcd_puts(" RP");
- if(fabs(e/b)<LCR[2]) {lcd_putf(e/b, 1, 1e-4); lcd_putc(OX[6]);} //显示电阻
- else { lcd_puts(" R>");lcd_puts(lcr[d2+3]);lcd_puts("M");lcd_putc(OX[6]);}//lcd_puts(" "); }
- }else{ //串联
- lcd_puts("ESR");//lcd_putc(11); //lcd_putc(11)是自定义的es(R)图形
- //lcd_putc('R');
- if(fabs(b/e)<LCR[2]) { lcd_putp(b/e, c/e, 0, 1, 1e-4); lcd_putc(OX[6]);} //显示电阻
- lcd_goto1(11);
- if(ATA==0||ATD==0){
- if(ATA==0) lcd_puts(" AUTO ");
- if(ATA==1) lcd_puts(" AUTO-C ");
- if(ATA==2) lcd_puts(" AUTO-L ");
- if(ATA==3) lcd_puts(" AUTO-R ");
- }else{
- if(ATE) lcd_puts(" P "); else lcd_puts(" S ");
- if(feq==100) lcd_putc('A');
- if(feq==977) lcd_putc('B');
- if(feq==7813) lcd_putc('C');
- lcd_putc(rng+49); //显示量程
- lcd_goto3(9);
- lcd_puts(" ");
- if(Vz[4]!=0&&rng==0) {for(OX[5]=0;OX[5]<5;OX[5]++){ lcd_putc(abc[16+Vz[4]][OX[5]]); }lcd_putc(8);}
- else {for(OX[5]=0;OX[5]<5;OX[5]++){ lcd_putc(abc[rng*4+Vz[5]+1][OX[5]]); }lcd_putc(8);}
- lcd_goto4(10);
- if(feq==100) lcd_puts(" 100Hz ");
- if(feq==977) lcd_puts(" 1KHz ");
- if(feq==7813) lcd_puts(" 7.8KHz ");
- //lcd_goto2(19);lcd_puts(" ");
- }else{ //以下为手动
- //显示量程信息
- lcd_goto4(0); //第四行显示
- if(isQ) lcd_puts("Auto/"); else lcd_puts("Hand/"); //显示自动手动
- if(binLian) lcd_puts("p"); else lcd_puts("s"); //显示串联并联
- lcd_puts(" ");
- lcd_goto4(7);//第四行显示频率
- if(feq==7813) lcd_puts("7.8KHz ");
- lcd_goto4(14); ////////////////////////////////////zz
- if(rng==0) {lcd_puts("40");lcd_putc(244);lcd_puts(" ");} //////zz
- if(rng==1) {lcd_puts("1K");lcd_putc(244);lcd_puts(" ");} //////zz
- if(rng==2) {lcd_puts("10K");lcd_putc(244);lcd_puts(" ");} //////zz
- if(rng==3) {lcd_puts("100K");lcd_putc(244);} ///////////////////zz
- if(!isQ){ //手动
- if(yc1&&rng!=3){ lcd_goto1(2); lcd_puts(" Overflow,high ");lcd_goto2(2); lcd_puts(" ");} //未知高阻溢出
- if(yc2&&rng!=0){ lcd_goto1(2); lcd_puts(" Overflow,low ");lcd_goto2(2); lcd_puts(" ");} //未知低阻溢出
- if(yc1||yc2){ lcd_goto2(2); lcd_puts(" ");lcd_goto3(2); lcd_puts(" "); return; }
- //电学量显示 if(!a) { lcd_cls(); lcd_puts("DIV 0"); return; }
- if(binLian){ //并联
- e = (b*b+c*c)/a;
- lcd_goto1(0); lcd_puts("R=");
- lcd_putf(e/b, 1, 1e-4); //显示并联复阻抗,显示到毫欧
- lcd_putc(OX[6]);
- lcd_putf(e/c, 1, 1e-4); //显示并联复阻抗,显示到毫欧
- lcd_putc(OX[6]);lcd_puts(" ");
- C = -c/e/w;
- L = +e/c/w;
- lcd_goto2(0);
- if(C>-2e-12) {lcd_puts("C="); lcd_putp(C, 0,2,4, 1e-14); lcd_putc('F'); } //显示并联C值,显示到pF
- else {lcd_puts("L="); lcd_putp(L, 0,2,2, 5e-9 ); lcd_putc('H'); } //显示并联L值,显示到uH
- lcd_puts(" ");
- }else{ //串联
- e = a;
- lcd_goto1(0); lcd_puts("R="); //////////////////////////////////////////////////////////////////////
- lcd_putp(b/e, c/e, 1, 1, 1e-4); lcd_putc(OX[6]); //定义欧姆符号_显示串联复阻抗,显示到毫欧
- lcd_puts(" ");
- C = -e/c/w;
- L = +c/e/w;
- lcd_goto2(0);
- if(L<-2e-8) {lcd_puts("C="); lcd_putp(C, 0,2,4, 1e-14); lcd_putc('F'); } //显示C值,显示到pF
- else {lcd_puts("L="); lcd_putp(L, 0,2,2, 5e-9 ); lcd_putc('H'); } //显示L值,显示到uH
- lcd_puts(" ");
- lcd_goto3(0); //跳转第三行
- lcd_puts("Q="); //显示标识
- lcd_putf(qq,0,0); //显示Q//lcd_putf(c,0,0); //显示Q
- lcd_puts(" ");
- lcd_puts(" ");
- lcd_goto1(17);
- if((feq==7813)&&(rng==0)&&(!binLian)&&(!isQ)&&(L<-2e-8)){lcd_puts("ESR");}//else{lcd_puts(" ");}//lcd_goto1(19);lcd_puts(" ");} ///zz
- // lcd_goto4(14);
- // if(Vz[4]!=0&&rng==0) {for(OX[5]=0;OX[5]<5;OX[5]++){ lcd_putc(abc[16+Vz[4]][OX[5]]); }lcd_putc(8);}
- // else {for(OX[5]=0;OX[5]<5;OX[5]++){ lcd_putc(abc[rng*4+Vz[5]+1][OX[5]]); }lcd_putc(8);}
- //void timerInter(void) interrupt 1 {}//T0中断
- main(){
- uchar i=0,s=0,key=0;
- uchar dispN=0; //显示扫描索引
- uchar spkN=0; //蜂鸣器发声时长
- uint nn=0;
- int kn=0;
- char mo=0; //编辑显示开关
- lcd_init(); //初始化LCD
- lcd_cur0(); //隐藏光标
- lcd_B(0, 0x40, 0); //定义欧姆符号_设置CGRAM地址,写指令
- for(i=0;i<40;i++)lcd_B(1, 0x00+path[i], 0); //定义欧姆符号_把数据送入CGRAM地址内
- lcd_goto1(0);//定义欧姆符号_光标定位
- lcd_puts("LCR 3.0");
- lcd_goto2(0);
- lcd_puts("XJW Putian,2012");
- delay2(500); //启动延时
- eepEn= 12345;
- cs_RW(0); //读EEPROM
- TCON=0, TMOD=0x12; //将T0置为自动重装定时器,T1置为定时器
- TH1 = 0, TL1 = 0;
- TR1=1; //T1开始计数
- TR0=0; //T0暂停计数
- ET1=1; //T1开中断
- ET0=1; //T1开中断
- EA=1; //开总中断
- //PT0=1; //设置优先级
- set_channel(0); //设置AD转换通道
- P2M0 = 0xFF; //P2.01234567置为推勉输出
- P1M0 = 0xFE; //P1.1234567置为推换口
- P1M1 = 0x01; //P1.0置为高阻抗
- P2 = 0x0F;
- PWM_init(); //DDS初始化
- set90(2); //初始设置相位
- setRng(1); //初始设置量程
- setGain(1); //初始设置增益
- setF(1); //DDS初始设置为1kHz
- while(1){
- //显示disp
- //1键-X,2键-R,3键-L,4键-C,5键-Q,6键-F,7键-Rng,8键-Menu
- nn++;
- //扫描键盘
- key = ~P3;
- if(key&&kn<255) kn++; else kn=0;
- for(i=0;key;i++) key/=2; key=i;
- if(menu==7&&key<3){
- if(kn==4) spkN=10,kn=-14; else key=0; //校准数值加速
- }else{
- if(kn==4) spkN=10; else key=0; //当按下一定时间后key才有效。spkN发声时长设置
- //菜单系统
- if(key==8){//菜单键
- lcd_cls(); lcd_puts(" LCR Set Options");
- lcd_goto2(0); lcd_puts(" Exit:X Ver:5.5");
- menu=0; key=0; mo=0; pau=0;
- for(i=0;i<3;i++)OX[i]=3.1415;
- delay(10000);
- if(menu>=1 && menu<=3){
- if(key==7) setRng2(); //量程步进
- if(key==6) setF(-1); //设置频率
- delay(10000);
- if(menu==0){ //显示量程和菜单
- if(key) lcd_cls();
- if(key>=1 && key<=7) {menu = key, menu2 = 0;if (key==1)isQ=1;}
- key = 0;
- DDS3 = 1;
- delay(10000);
- } //1键-X,2键-R,3键-L,4键-C,5键-Q,6键-F,7键-Rng,8键-Menu
- if(menu==1){ //LCR测量
- if(key==1) if(isQ){ ATA++;ATD=0;REL=0;if(ATA>3){ATA=0;}}else{binLian = (binLian+1)%2;} //L/C/R 模式
- if(key==2) if(isQ){ ATD++;REL=0;if(ATD>2){ATD=0;}} //串并联测量模式选择
- if(key==3) {showR(21,0);REL=0;} //自动手动切换
- if(key==4) {
- if((rng==3)||(rng==0)){
- lcd_cls();if(rng==3){lcd_puts(zero[0]);}else{lcd_puts(zero[1]);}delay2(100);
- for(i=0;i<3;i++){
- lcd_goto2(2);
- if(feq==100) delay2(150);
- lcd_puts(feqc[feqK]);lcd_goto2(9);lcd_puts(" ");
- delay2(100);
- TR = 0, TX = 0;
- for(s=0;s<4;s++){lcd_goto2(9);lcd_putc(51-s);if(feq==100){delay2(150);}else{delay2(75);}showR(20,0);}
- if(rng==3){
- cs.QRo[feqK] = TR/4.0, cs.QXo[feqK] = TX/4.0; //开路残余导抗
- if(rng==0){
- cs.QRs[feqK] = TR/4.0, cs.QXs[feqK] = TX/4.0; //短路残余阻抗
- setF(-1);
- cs_RW(1);
- lcd_goto1(0);if(rng==3){lcd_puts(zero[0]);}else{lcd_puts(zero[1]);}delay2(100);
- REL=0;
- } //清零
- OX[7]++;
- if(OX[7]>15){OX[7]=0;showR(binLian,0);}
- delay(12000);
- if(key==5) {REL = (REL+1)%2;spkN=0;}
- if(menu==2){
- lcd_goto1(0);
- lcd_puts("up:"); lcd_putc(Vxy[4]+48);
- lcd_puts(" dw:"); lcd_putc(Vxy[5]+48);
- delay(10000);
- if(menu==3){ //手动调试
- pau = 1;
- if(key==1) setGain2();//增益控制
- if(key==2) { };
- if(key==3) K3=~K3; //切换上下臂
- if(key==4) set902(); //相位旋转
- lcd_goto1(0);
- lcd_puts(" xw="); lcd_putc(xw+48); //相位索引号
- lcd_puts(" K3="); lcd_putc(K3?49:48); //K3状态
- lcd_puts(" Ga="); lcd_putc(curGain+48); //增益索引号
- lcd_goto2(0);
- if(nn%32==0) lcd_int(getAD10(),5);
- delay(10000);
- if(menu>=4 && menu<=5){
- delay(10000);
- if(menu==6){ //频率修正
- if(key==1) cs.feq += 1; //X键增
- if(key==2) cs.feq -= 1; //R键减
- if(key==3) { cs_RW(1); setF(feqK); } //L键保存
- if(OX[0]!=cs.feq){ lcd_cls();OX[0]=cs.feq;
- lcd_goto1(0); lcd_puts("Feq correct");
- lcd_goto2(0); lcd_putf(cs.feq,0,0);}
- delay(10000);
- if(menu==7){ //校准
- code char *csR[19] = {
- "Z0 :000", "Z1 :000", "Z2 :000",
- "R1 : 40", "R1X: 40",
- "ak : 25",
- "R2 : 1k", "R2X: 1k",
- "R3 :10k", "R3X:10k",
- "R4 :.1M", "R4b:.1M", "R4X:.1M",
- "G1 : 3k", "G1X: 3k",
- "G2 : 9k", "G2b: 9k", "G2X: 9k",
- "phX: 1k"
- char *p,bc=1, feqD=1,rngD=1;
- static char kc=0;
- isQ = 0;
- lcd_goto2(5);
- if(menu2==0) p = cs.zo+0, feqD=0, rngD=0; //100Hz零点校准,接入20k欧电阻 //Z0 77
- if(menu2==1) p = cs.zo+1, feqD=1, rngD=0; //1kHz零点校准,接入20k欧电阻 //Z1 74
- if(menu2==2) p = cs.zo+2, feqD=2, rngD=0; //7.8kHz零点校准,接入20k欧电阻 //Z2 44
- if(menu2==3) p = cs.R+0, bc=2, feqD=1, rngD=0; //VI变换器模值校准,接入40欧 //R1 20
- if(menu2==4) p = cs.J+0, feqD=2, rngD=0; //40R相位 //R1X 0
- if(menu2==5) p = &cs.ak, feqD=1, rngD=0; //AD校准 //ak 0
- if(menu2==6) p = cs.R+1, bc=2, feqD=1, rngD=1; //VI变换器模值校准,接入1k欧 //R2 0
- if(menu2==7) p = cs.J+1, feqD=2, rngD=1; //1k相位 //R2X -2
- if(menu2==8) p = cs.R+2, bc=2, feqD=1, rngD=2; //VI变换器模值校准,接入10k欧 //R3 2
- if(menu2==9) p = cs.J+2, feqD=2, rngD=2; //10k相位 //R3X -6(2)
- if(menu2==10) p = cs.R+3, bc=2, feqD=1, rngD=3; //VI变换器模值校准,接入100k欧 //R4 24
- if(menu2==11) p = &cs.R4b,bc=2, feqD=2, rngD=3; //7.8kHz频率100k档幅度校准 //R4b 28
- if(menu2==12) p = cs.J+3, feqD=2, rngD=3; //100k相位 //R4X 29
- if(menu2==13) p = &cs.g1, bc=2, feqD=1, rngD=1; //运放3倍增益校准,接入3.3k欧电阻 //G1 -2
- if(menu2==14) p = &cs.j1, feqD=2, rngD=1; //3倍档相位 G1X 32
- if(menu2==15) p = &cs.g2, bc=2, feqD=1, rngD=1; //运放9倍增益校准,接入10k欧电阻 //G2 -10
- if(menu2==16) p = &cs.G2b,bc=2, feqD=2, rngD=1; //7.8kHz频率9倍档幅度校准 //G2b 2
- if(menu2==17) p = &cs.j2, feqD=2, rngD=1; //9倍档相位 //G2X 24(34)
- if(menu2==18) p = &cs.phx, feqD=1, rngD=1; //1kHz以下相位校准,接入1k欧电阻 //phx 0
- if(menu2<3) DDS3=0; else DDS3=1;
- if(key==1) *p += bc ; //X键增
- if(key==2) *p -= bc ; //R键减
- if(key==4) *p = 0; //C键清除
- if(key==5) { if(menu2==0) menu2=18; else menu2--; mo=0; }
- if(key==6) { if(menu2==18)menu2=0; else menu2++; mo=0; }
- if(key==7) mo = (mo+1)%2;
- if(key==4){ //恢复到默认值
- if(++kc==5){
- kc = 0;
- cs.j1 = 32, cs.j2 = 24;
- cs.g1 = -2, cs.g2 = -10;
- cs.zo[0] = 76;
- cs.zo[1] = 78;
- cs.zo[2] = 78;
- cs.J[0] = 0,cs.J[1] = -2, cs.J[2] = -6, cs.J[3] = 29;
- cs.R[0] = 20,cs.R[1] = 0,cs.R[2] = 2,cs.R[3] = 24;
- cs.R4b = 28, cs.G2b = 2,cs.phx = cs.feq = 0;
- cs.ak = 0;
- for(i=0;i<3;i++) cs.QRs[i] = cs.QXs[i] = cs.QRo[i] = cs.QXo[i] = 0;
- else { if(key) kc=0; }
- //显示
- if(mo){
- OX[1]=3.1415;OX[2]=3.1415;
- if(feqD!=feqK) setF(feqD);
- if(rngD!=rng) setRng(rngD);
- if(menu2>=3&&menu2<=7) showR(0,0);
- else showR(1,0);
- }else{
- if(menu2>=3&&menu2<=7) showR(0,menu2+1);
- else showR(1,menu2+1);
- if(OX[1]!=*p||OX[2]!=menu2){ OX[1]=*p;OX[2]=menu2;
- lcd_cls();
- lcd_goto1(0); lcd_puts(csR[menu2]);lcd_puts(" X:+ R:-"); //输出参数名称
- lcd_goto2(0); lcd_int(*p,3); //输出参数值
- delay(10000);
- if (menu!=7){
- if(spkN) spkN--, spk=0; else spk=1; //键盘发声
- }//while end
复制代码 |
