Day: (15 \ 6 \ 2025) Time: ( 9:41:49) TesterNumber:1
[ConfigID]
ID=98 3C 98 B3 76 E3-BICS4
[SN Set]
SN_Set=1
SN_Type=255
SN_Len=12
SN_Start=000000000001
SN_End=999999999999
SN_Mask=############
[Other]
SATA_SSC_Enable=0
[StationName]
01=EraseAll
02=RDT
03=RDTResult
04=MP
[ConfigID]
[SN Set]
SN_Set=1
SN_Type=255
SN_Len=12
SN_End=999999999999
[Other]
SATA_SSC_Enable=0
[StationName]
01=EraseAll
02=RDT
03=RDTResult
04=MP
05=ReMP
06=ICT
07=UpdateFW
08=ScanBad
[General Info]
TestStationSel=3
TestStation=F1
WorkingNo=00000000
ModelName=ndysy ssd
SerialNum=000000000001
MaxCurrent=400
[Flash Info]
Flh_Type=TLC_16K
Flh_MakeCode=Toshiba
Flh_ID=98 3c 98 b3 76 e3
Flh_Capacity=524288
Flh_CapacitySel=0
Flh_Number=16
Flh_NumberSel=0
Flash Clock=100
Flash Interface=3
[Device Info]
SATASpeed=2
ControllerType=SSD-3111SB
ICFWVersion=SBFQ61L3
3111SBISP_CodeVersion=Q61L3
3111SBISP_MPBINCode=.\Bin\SBFQ61L3.BIN
3111SBISP_RDTBINCode=.\Bin\SBSC61.2.BIN
SSD Size=2.5"
[Options]
DDRSize=32
Enable_Set_Custom_SMART_Temperature=0
Set_LBTOEB=10
Smart_Table=0
DisableSmartC7=1
EnableSmartC3=1
SLCPoolSizeSel=0
Disable_DIPM_Support=1
Use Partial Size=1
DEVSLP_Enable=1
Put_Thermal_Sensor=0
Skip_Check_RDDebugPage=1
PretestType=1
PMASetting=42035
ScanBad_CheckByDie=1
[InfoBlock]
Byte_290=E8
Byte_291=03
[EraseAll]
Do_Erase_First=1
Type=09
[Log]
Use Partial Size, 512 GB -> 480 GB.
[ Success ] Modify InfoBlock OK.
[ Info ] MP AP: V2.06_x02(China), MAC Address: , ISP FW: SBFQ61L3.BIN, Station:F1T
[ Success ] Check Device State OK.
[ Success ] Check IO State OK- Total take 0.022 sec.
[ Success ] Check ICVer. OK.
[ Success ] AES VUC Process OK.
[ Success ] ISP Program PRAM OK.
[ Success ] eFuse Info
UART : Enable
JTAG : Enable
Trim good die : 01
Get Controller ID : 1A_0F_09_01_10_09_04
Trim good die : 01
Y Coordination : 1a
X Coordination : 0f
Wafer ID : 09
Lot ID 4 : 01
Lot ID 3 : 10
Lot ID 2 : 09
Lot ID 1 : 04
CTL Version : 03
[ Success ] Check eFuse OK.
[ Success ] Verify param.ini with Device Info OK.
Scan_Flash_SDLL:
DiePerFlash=1, SectorPerPage=32
Ch=0~1, Bank=0~7
FlashMode : 3 FlashClock : 5 FlashODT : 0 Flash(NAND)Drive : 0 PadODTEnable : 0 PadODT : 0
PADDriveEnable : 0 ALEPads : 0 CLEPads : 0 WEPads : 0 REPads : 0 FRDYPads : 0
WPPads : 0 DQSPads : 0 DataPads : 0 CEPads : 0 ScanRound : 0 Scan Interval : 50
Scan_LDPC_Error_Bit : 0x03FF
BitMask : 0 SlewRateEnable : 0 SlewRate : 0 EnableOverClocking : 0
Set Scan Window Criteria : 50
Duty Range : 0~0
Duty : 0 Bank : 0 Die : 0
CH 0 Read-Min : 0 Read-Max : 324 Write-Min : 2 Write-Max : 327
CH 1 Read-Min : 0 Read-Max : 330 Write-Min : 1 Write-Max : 331
Duty : 0 Bank : 1 Die : 0
CH 0 Read-Min : 0 Read-Max : 334 Write-Min : 2 Write-Max : 328
CH 1 Read-Min : 0 Read-Max : 333 Write-Min : 1 Write-Max : 330
Duty : 0 Bank : 2 Die : 0
CH 0 Read-Min : 0 Read-Max : 328 Write-Min : 2 Write-Max : 328
CH 1 Read-Min : 0 Read-Max : 332 Write-Min : 1 Write-Max : 329
Duty : 0 Bank : 3 Die : 0
CH 0 Read-Min : 0 Read-Max : 330 Write-Min : 2 Write-Max : 329
Duty : 0 Bank : 4 Die : 0
CH 0 Read-Min : 0 Read-Max : 329 Write-Min : 2 Write-Max : 329
CH 1 Read-Min : 0 Read-Max : 335 Write-Min : 1 Write-Max : 329
Duty : 0 Bank : 5 Die : 0
CH 0 Read-Min : 0 Read-Max : 330 Write-Min : 2 Write-Max : 327
CH 1 Read-Min : 0 Read-Max : 335 Write-Min : 1 Write-Max : 327
Duty : 0 Bank : 6 Die : 0
CH 0 Read-Min : 0 Read-Max : 327 Write-Min : 2 Write-Max : 325
CH 1 Read-Min : 0 Read-Max : 331 Write-Min : 1 Write-Max : 328
Duty : 0 Bank : 7 Die : 0
CH 0 Read-Min : 0 Read-Max : 331 Write-Min : 2 Write-Max : 325
CH 1 Read-Min : 0 Read-Max : 333 Write-Min : 1 Write-Max : 331
CH0 Read :
Duty_0: CH_0: Read_Min : 0 Read_Max : 324 (Range : 325)
CH1 Read :
Duty_0: CH_1: Read_Min : 0 Read_Max : 330 (Range : 331)
CH0 Write :
Duty_0: CH_0: Write_Min : 2 Write_Max : 325 (Range : 324)
CH1 Write :
Duty_0: CH_1: Write_Min : 1 Write_Max : 327 (Range : 327)
Find Read Max Duty :Ch_0 Duty_0 Ch_1 Duty_0
[Windows]:
Duty_0 CH_0: Read Window=0xa2, Write Window=0xa3
Duty_0 CH_0: HW_Rd=0xaa, HW_Wr=0xac
ScanValueRe[0] = 0x8008 ScanValueWr[0] = 0x8009
Duty_0: Bank_0: Die_0: Read Win=0xa2(Min=0x0, Max=0x144)
Write_Win=0xa4(Min=0x2, Max=0x147)
Duty_0: Bank_1: Die_0: Read Win=0xa7(Min=0x0, Max=0x14e)
Write_Win=0xa5(Min=0x2, Max=0x148)
Duty_0: Bank_2: Die_0: Read Win=0xa4(Min=0x0, Max=0x148)
Duty_0: Bank_3: Die_0: Read Win=0xa5(Min=0x0, Max=0x14a)
Write_Win=0xa5(Min=0x2, Max=0x149)
Duty_0: Bank_4: Die_0: Read Win=0xa4(Min=0x0, Max=0x149)
Duty_0: Bank_5: Die_0: Read Win=0xa5(Min=0x0, Max=0x14a)
Duty_0: Bank_6: Die_0: Read Win=0xa3(Min=0x0, Max=0x147)
Write_Win=0xa3(Min=0x2, Max=0x145)
Duty_0: Bank_7: Die_0: Read Win=0xa5(Min=0x0, Max=0x14b)
Duty_0 CH_1: Read Window=0xa5, Write Window=0xa4
Duty_0 CH_1: HW_Rd=0xaa, HW_Wr=0xac
ScanValueRe[1] = 0x8005 ScanValueWr[1] = 0x8008
Duty_0: Bank_0: Die_0: Read Win=0xa5(Min=0x0, Max=0x14a)
Write_Win=0xa6(Min=0x1, Max=0x14b)
Duty_0: Bank_1: Die_0: Read Win=0xa6(Min=0x0, Max=0x14d)
Write_Win=0xa5(Min=0x1, Max=0x14a)
Duty_0: Bank_2: Die_0: Read Win=0xa6(Min=0x0, Max=0x14c)
Write_Win=0xa5(Min=0x1, Max=0x149)
Duty_0: Bank_4: Die_0: Read Win=0xa7(Min=0x0, Max=0x14f)
Duty_0: Bank_5: Die_0: Read Win=0xa7(Min=0x0, Max=0x14f)
Write_Win=0xa4(Min=0x1, Max=0x147)
Duty_0: Bank_6: Die_0: Read Win=0xa5(Min=0x0, Max=0x14b)
Write_Win=0xa4(Min=0x1, Max=0x148)
Duty_0: Bank_7: Die_0: Read Win=0xa6(Min=0x0, Max=0x14d)
[ Success ] Scan Window Process OK- Total take 10.728 sec.
[ Fail ] Error Message : Not Running on Flash Code now- SBRM02.0
Error Code : I_B67
AP Command : [a1]-[8]-[e]-[0]-[1]-[0]-[0]-[0]-[e0]-[ec]-[0]-[0]
OS LastError : [ 0 ]
05=ReMP
06=ICT
07=UpdateFW
08=ScanBad
[General Info]
TestStationSel=3
TestStation=F1
WorkingNo=00000000
ModelName=ndysy ssd
MaxCurrent=400
[Flash Info]
Flh_Type=TLC_16K
Flh_Capacity=524288
Flh_CapacitySel=0
Flh_Number=16
Flh_NumberSel=0
Flash Clock=100
Flash Interface=3
[Device Info]
SATASpeed=2
SSD Size=2.5"
[Options]
DDRSize=32
Set_LBTOEB=10
Smart_Table=0
DisableSmartC7=1
EnableSmartC3=1
SLCPoolSizeSel=0
Use Partial Size=1
DEVSLP_Enable=1
PretestType=1
PMASetting=42035
[InfoBlock]
Byte_290=E8
Byte_291=03
[EraseAll]
Do_Erase_First=1
Type=09
[Log]
UART : Enable
JTAG : Enable
Trim good die : 01
Trim good die : 01
Y Coordination : 1a
X Coordination : 0f
Wafer ID : 09
Lot ID 4 : 01
Lot ID 3 : 10
Lot ID 2 : 09
Lot ID 1 : 04
CTL Version : 03
Scan_Flash_SDLL:
Ch=0~1, Bank=0~7
Duty Range : 0~0
CH0 Read :
CH1 Read :
CH0 Write :
CH1 Write :
[Windows]:
Error Code : I_B67
看看那里的问题
