查看: 536|回复: 7
[Realtek] Realtek RTS5735 +29R08T2AOCQH1 无法量产
发表于 2025-11-1 15:14:48 | 显示全部楼层 |阅读模式
用RTS573任一量产工具提示需要18A,但18A打开了没有对应闪存选项,随便选了一个后量产后到最后一步失败变成0gb。
现在盘是可以认的,但多次量产还是无法成功,请问有对应的量产支持该flash型号吗?还是我量产的方法有问题。
量产工具来自(除了RTS5735还有其他):
https://github.com/18930395823/MPTOOLS/tree/main/Realtek/RTS5735(RM1135)
rtl_flash id查询信息:
  1. v0.16a
  2. Drive: 0(ATA)
  3. OS: 10.0 build 19044
  4. Model: Samsung SSD 870 EVO 1TB
  5. Fw   : SVT01B6Q
  6. Size : 953869 MB [1000.2 GB]
  7. FwStr: [REALTEK_RL6643ZD0R3G5A_p_tN18AV5.16]
  8. Controller: Realtek RTS5735
  9. ATA: Get FWI failed! Error: 0x51
  10. ATA: Get FID failed! Error: 0x51
  11. Bank04: 0x89,0xd4,0xc,0x32,0xaa,0x0,0x0,0x0 - Intel 64L(N18A) QLC 1024Gb/CE 1024Gb/die
  12. Bank05: 0x89,0xd4,0xc,0x32,0xaa,0x0,0x0,0x0 - Intel 64L(N18A) QLC 1024Gb/CE 1024Gb/die
  13. Bank06: 0x89,0xd4,0xc,0x32,0xaa,0x0,0x0,0x0 - Intel 64L(N18A) QLC 1024Gb/CE 1024Gb/die
  14. Bank07: 0x89,0xd4,0xc,0x32,0xaa,0x0,0x0,0x0 - Intel 64L(N18A) QLC 1024Gb/CE 1024Gb/die
  15. Bank12: 0x89,0xd4,0xc,0x32,0xaa,0x0,0x0,0x0 - Intel 64L(N18A) QLC 1024Gb/CE 1024Gb/die
  16. Bank13: 0x89,0xd4,0xc,0x32,0xaa,0x0,0x0,0x0 - Intel 64L(N18A) QLC 1024Gb/CE 1024Gb/die
  17. Bank14: 0x89,0xd4,0xc,0x32,0xaa,0x0,0x0,0x0 - Intel 64L(N18A) QLC 1024Gb/CE 1024Gb/die
  18. Bank15: 0x89,0xd4,0xc,0x32,0xaa,0x0,0x0,0x0 - Intel 64L(N18A) QLC 1024Gb/CE 1024Gb/die
  19. Flash CE Mask : [----++++ ----++++]
  20. Fabric Bad block list (bank0 only):
  21. Later Bad block list (bank0 only):
  22. Bank0 BB (Fabric+Later): 0 (0+0)
复制代码
闪存芯片看起来是
29R08T2AOCQH1 但查ID是PF29F08T2AOCQH1
但用flashMaster 查看
https://fm-us.xfjportal.com/#/decode?pn=PF29F08T2AOCQH1
  1. 料号:PF29F08T2AOCQH1,厂商:英特尔,类型:NAND,容量:8Tb
  2. 位宽:x8,单元:QLC,制程:3D2 64L,代:1
  3. 同步:是,异步:是,片选:8,通道:2,Die:8,R/B:4
  4. 电压:Vcc: 3.3V, VccQ: 1.8V/1.2V
  5. 封装:BGA
  6. 控制器:SM2259XT, MAS0902, MAS1102, CBM2199E
  7. 注释:
  8. 更多信息:晶圆: 否, 无铅: 是
  9. 闪存ID:89D40C32AA00
  10. 由 FlashMaster 强力驱动 https://nand.gq
复制代码
发表于 2025-11-1 16:56:15 | 显示全部楼层
 楼主| 发表于 2025-11-1 22:52:49 | 显示全部楼层
发表于 2025-11-2 06:15:13 | 显示全部楼层
 楼主| 发表于 2025-11-5 16:20:01 | 显示全部楼层
 楼主| 发表于 2025-11-5 17:47:17 | 显示全部楼层
 楼主| 发表于 2025-11-11 14:13:25 | 显示全部楼层
 楼主| 发表于 2025-11-12 12:40:25 | 显示全部楼层
发表于 2025-11-12 13:16:23 | 显示全部楼层
GMT+8, 2026-5-11 19:36 , Processed in 0.374400 second(s), 12 queries , Gzip On, Redis On.
