查看: 719|回复: 10
[Toshiba] 大家帮忙分析一下还有救吗?KIOXIA TC10 480G刷固件成这样了
发表于 2026-3-12 22:07:52 | 显示全部楼层 |阅读模式
KIOXIA TC10 480G,期间不知怎么刷的固件成这样了,用MP Tool v2.2.85不能自动识别闪存,各位大佬,还有什么好的办法没?
问题盘的值:
2: ATA     SATAFIRM   SBRDT
Please select drive number:2
Drive: 2(ATA)
Model: SATAFIRM   SBRDTTEST
Fw   : SBSC61.2
Bank00: 0x98,0x3e,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank01: 0x98,0x3e,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank04: 0x98,0x3e,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank05: 0x98,0x3e,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank08: 0x98,0x3e,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank09: 0x98,0x3e,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank12: 0x98,0x3e,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank13: 0x98,0x3e,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Controller   : Possible PS3105 or PS3108
Flash CE     : 8
Flash Channel: 2
DRAM Size,MB : 1
Defects All Early Later
Bank00: 207 207 207
Bank01: 207 207 207
Bank04: 207 207 207
Bank05: 207 207 207
Bank08: 207 207 207
Bank09: 207 207 207
Bank12: 207 207 207
Bank13: 207 207 207
Total : 1656 1656 1656
Saved to: phison_flash_id.txt
Press any key to exit
另一块同类型好盘的值。供参考
1: KIOXIA-EXCERIA SATA SSD
Please select drive number:1
Drive: 1(USB)
Model: KIOXIA-EXCERIA SATA SSD
Fw   : SBFA1a.1
P/N  : 9498971         , SBSA7a.5
S11fw: SBFA1a.1, 2021Sep27
S11rv: A1a.1-00
Bank00: 0x98,0x3e,0x98,0x3,0x76,0xe4,0x8,0x1e - Toshiba 112L BiCS5 TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank01: 0x98,0x3e,0x98,0x3,0x76,0xe4,0x8,0x1e - Toshiba 112L BiCS5 TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank04: 0x98,0x3e,0x98,0x3,0x76,0xe4,0x8,0x1e - Toshiba 112L BiCS5 TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank05: 0x98,0x3e,0x98,0x3,0x76,0xe4,0x8,0x1e - Toshiba 112L BiCS5 TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank08: 0x98,0x3e,0x98,0x3,0x76,0xe4,0x8,0x1e - Toshiba 112L BiCS5 TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank09: 0x98,0x3e,0x98,0x3,0x76,0xe4,0x8,0x1e - Toshiba 112L BiCS5 TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank12: 0x98,0x3e,0x98,0x3,0x76,0xe4,0x8,0x1e - Toshiba 112L BiCS5 TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Bank13: 0x98,0x3e,0x98,0x3,0x76,0xe4,0x8,0x1e - Toshiba 112L BiCS5 TLC 16k 512Gb/CE 512Gb/die 2Plane/die
Controller    : PS3111
Flash CE      : 8
Flash Channel : 2
DRAM Size,MB  : 32
Flash CE Mask : [++--++-- ++--++--]
Flash Mode/Clk: 3/7 (Set 3/7)
SLC Cache     : Default
PE Cycle Limit: 570
Try to read nand parameter page...
JEDEC     : KIOXIA       TH58LKT1T25BADF      [697C]
Page size : 18336 (16384+1952)
Page/Block: 1344
Block/LUN : 3324
LUN/Chip  : 1
Bit/Cell  : 3 (TLC)
PlanAdrBit: 1 (2 plane)
MaxBBPerPlane : 130
Plane         : 2
Defects All(per plane)  Early           Later
Bank00:  11(6,5)         11(6,5)          0(0,0)
Bank01:  16(6,10)        16(6,10)         0(0,0)
Bank04:  24(15,9)        24(15,9)         0(0,0)
Bank05:  14(7,7)         14(7,7)          0(0,0)
Bank08:   7(3,4)          7(3,4)          0(0,0)
Bank09:   7(3,4)          7(3,4)          0(0,0)
Bank12: 121(87,34)      121(87,34)        0(0,0)
Bank13:  74(14,60)       74(14,60)        0(0,0)
Total : 274             274               0
Read EC..
Press any key to exit or Space to open full text report
Please share reports as text, not a sreenshot!
发表于 2026-3-13 00:59:04 | 显示全部楼层
 楼主| 发表于 2026-3-13 07:07:19 | 显示全部楼层
 楼主| 发表于 2026-3-13 08:22:13 | 显示全部楼层
 楼主| 发表于 2026-3-13 13:04:54 | 显示全部楼层
发表于 2026-3-13 18:40:20 | 显示全部楼层
发表于 2026-3-13 18:44:45 | 显示全部楼层
发表于 2026-3-13 18:47:09 | 显示全部楼层
 楼主| 发表于 2026-3-13 20:50:51 | 显示全部楼层
发表于 2026-3-13 21:05:31 | 显示全部楼层
 楼主| 发表于 2026-3-13 21:13:14 | 显示全部楼层
GMT+8, 2026-11-29 21:12 , Processed in 0.265201 second(s), 13 queries , Gzip On, Redis On.
