查看: 638|回复: 9
[Phison] PS5008-E8这么烫的吗?!
发表于 2026-5-21 00:42:52 | 显示全部楼层 |阅读模式
先上个检测报告证明我不是来水贴的——
v0.183a
OS: 6.1 build 7601 Service Pack 1
Drive: 1(NVME)
Scsi    : 1
Model   : LITEON T11 128 P
Fw      : LTNFW1.0
LBA Size: 512
Firmware lock supported [01 01]- Drive locked
P/N     : 511-171031055
F/W     : E8SM11.B
Bank00: 0x98,0x3c,0x98,0xb3,0x76,0x72,0x8,0xe - Toshiba 64L BiCS TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank08: 0x98,0x3c,0x98,0xb3,0x76,0x72,0x8,0xe - Toshiba 64L BiCS TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank16: 0x98,0x3c,0x98,0xb3,0x76,0x72,0x8,0xe - Toshiba 64L BiCS TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Bank24: 0x98,0x3c,0x98,0xb3,0x76,0x72,0x8,0xe - Toshiba 64L BiCS TLC 16k 256Gb/CE 256Gb/die 2Plane/die
Controller    : PS5008-E8
CPU Clk       : 400
Flash CE      : 4
Flash Channel : 4
Interleave    : 1
Flash CE Mask : [+------- +------- +------- +-------]
Flash Clk,MT  : 534
Block per CE  : 2956
Page per Block: 768
Bit Per Cell  : 3(TLC)
DRAM Size,MB  : 256
DRAM Clock,MHz: 400
Defects Early Read Prog Erase
Bank00:   25    0    0    0
Bank01:   53    0    0    0
Bank02:   54    0    0    0
Bank03:   36    0    0    0
Total :  168    0    0    0
最近入夏,把这个拿出来放在NAS里,发现待机50多度,读写八九十,而此时读写速度仅有400MB/S左右(位于PCI-E 2.0 1X速率下),温度实在是太夸张了,颗粒和主控摸起来跟火球一样,这温度正常么?
看标签功率不低,3.3V 2.5A这样,我自己的SN550都没这么热,也不知道哪里出问题了
顺便问问2263XT功耗、温度如何,想搬颗粒了
发表于 2026-5-21 02:17:34 | 显示全部楼层
发表于 2026-5-21 07:14:59 来自手机浏览器 | 显示全部楼层
发表于 2026-5-21 08:17:50 | 显示全部楼层
 楼主| 发表于 2026-5-21 10:28:36 | 显示全部楼层
 楼主| 发表于 2026-5-21 10:34:45 | 显示全部楼层
 楼主| 发表于 2026-5-21 10:36:38 | 显示全部楼层
发表于 2026-9-30 10:06:44 | 显示全部楼层
发表于 2026-9-30 14:34:57 | 显示全部楼层
发表于 2026-10-1 12:29:22 | 显示全部楼层
GMT+8, 2026-10-16 03:53 , Processed in 0.156000 second(s), 10 queries , Gzip On, Redis On.
