查看: 14434|回复: 23
三贱客 FAST FAC1200R V7双频路由器拆解
发表于 2019-8-1 12:16:27 | 显示全部楼层 |阅读模式
论坛只有早期V2版本的拆机,看看去年的V7成什么样子了
两颗螺丝,全卡扣,感觉比TP WR840/2N用的模具要好拆(840的模具硬,而且卡扣极为牢固,空间小)
拉近点
主SOC MT7628DBN(WDR5620也是这个了,最早出现在水星D128上),5G常见的MT7612E
启动LOG,GD25Q16B 2M SPI NOR FLASH,MT7628DBN内置16M闪存(比7628KN要大),保留了PCIe接入5G PHY
  1. [DBG] sel_fine_tmp=00000006, sel_mst_fine=00000007,fg_dly_adj=00000007
  2. [DBG] sel_fine_tmp=00000004, sel_mst_fine=00000007,fg_dly_adj=00000005
  3. [04020C0C][04020C09][85870000][23244446][00232447]
  4. DU Setting Cal Done
  5. U-Boot 1.1.3 (Apr 27 2018 - 14:25:28)
  6. Board: Ralink APSoC DRAM:  16 MB
  7. relocate_code Pointer at: 80fc0000
  8. Software System Reset Occurred
  9. flash manufacture id: c8, device id 40 15
  10. find flash: GD25Q16B
  11. *** Warning - bad CRC, using default environment
  12. icache: sets:512, ways:4, linesz:32 ,total:65536
  13. dcache: sets:256, ways:4, linesz:32 ,total:32768
  14. RESET MT7628 PHY!!!!!!
  15. Please choose the operation or press ctrl + c to stop auto boot:
  16.    1: Load system code to SDRAM via TFTP.
  17.    2: Load system code then write to Flash via TFTP.
  18.    3: Boot system code via Flash (default).
  19.    9: Load Boot Loader code then write to Flash via TFTP.                          0
  20. 3: System Boot system code via Flash.
  21. ## Booting image at bc015200 ...
  22. addr:0xbc015200
  23. RALINK_GPIOMODE = 54050404
  24. RALINK_GPIOMODE = 54040404
  25. ***** Xtal 40MHz *****
  26. start PCIe register access
  27. RALINK_RSTCTRL = 2400000
  28. RALINK_CLKCFG1 = fdbfffc0
  29. *************** MT7628 PCIe RC mode *************
  30. PCIE0 enabled
  31. Port 0 N_FTS = 1b105000
  32. init_rt2880pci done
  33. Scan busNo=0, devNo=0 funNo=0.
  34. PCI-E setup device 0x801, 0x14C3.
  35. PCIe DEV 0x801 VENDOR 0x14C3 isn't work properly.
  36. PCI-E setup bridge done.
  37. **************************************pci_scan_bridge****************************************
  38. **************************************pci_scan_bridge****************************************
  39. Scan busNo=1, devNo=0 funNo=0.
  40. PCI-E setup device 0x7662, 0x14C3.
  41. PCIe DEV 0x7662 VENDOR 0x14C3 isn't work properly.
  42. PCIe DEV 0x7662 VENDOR 0x14C3 isn't work properly.
  43. PCIe DEV 0x7662 VENDOR 0x14C3 isn't work properly.
  44. PCIe DEV 0x7662 VENDOR 0x14C3 isn't work properly.
  45. PCI-E setup nprmal device done.
  46. Scan busNo=1, devNo=1 funNo=0
  47. Scan busNo=0, devNo=1 funNo=0.
  48. BAR0 at slot 0 = 0
  49. bus=0x0, slot = 0x0
  50. res[0]->start = 0
  51. res[0]->end = 7fffffff
  52. res[1]->start = 20200000
  53. res[1]->end = 2020ffff
  54. res[2]->start = 0
  55. res[2]->end = 0
  56. res[3]->start = 0
  57. res[3]->end = 0
  58. res[4]->start = 0
  59. res[4]->end = 0
  60. res[5]->start = 0
  61. res[5]->end = 0
  62. bus=0x1, slot = 0x0
  63. res[0]->start = 0
  64. res[0]->end = fffff
  65. res[1]->start = 0
  66. res[1]->end = 0
  67. res[2]->start = 0
  68. res[2]->end = 0
  69. res[3]->start = 0
  70. res[3]->end = 0
  71. res[4]->start = 0
  72. res[4]->end = 0
  73. res[5]->start = 0
  74. res[5]->end = 0
  75. RALINK_REG_GPIOMODE:0X55040414
  76. RALINK_REG_GPIOMODE2:0X5550555
  77. Before exit sysClkConnect!
  78. In sysClkEnable!
  79. Before exit sysClkEnable!
  80. Attmacthi7ng6 i2nt8erEfanced lLo0o..a. ddo neu
  81. nitNum=0
  82. Waitting for RX_DMA_BUSY status Start... done
  83. ==> netpool_mangement.c
  84. Init netpool for mtk network now
  85. netpool_mangement.c(): malloc for clConfig[0] with size(4748832)!
  86. pNetPool[0]=0x80e7f3d0!
  87. <== netpool_mangement.c
  88. Count=1,netpool=80e7f3d0
  89. Tx_Ring addr: 0xa09a4ae0!!!
  90. Rx_Ring addr: 0xa09a3e20!!!
  91. mt7628EndLoad unitNum=1
  92.                                       Version2.0
  93.                             Software Platform for PNE2.2
  94.               Copyright(C) 2001-2011 by TP-LINK TECHNOLOGIES CO., LTD.
  95.                       Creation date: Aug  6 2018, 20:46:56
  96. # RALINK_REG_GPIOMODE2:0X10001
  97. miniFs.c(2442): Install minifs driver successed.
  98. Flash ID = 0x0.
  99. Flash UID 0x305538373818559250FFFFFFFFFFFFFF
  100. set mii port 4 value 0x00003300
  101. add net default: gateway 169.254.11.96
  102. change net 169.254.11.0
  103. change net 0.0.0.0
  104. delete net 0.0.0.0
  105. add net default: gateway 172.16.1.1
  106. ===========5g ssid TP_LINK-263404
  107. ==> netpool_mangement.c
  108. mtk netPool has been init before
  109. Count=2,netpool=80e7f3d0
  110. First phase! the return iniString=rai!
  111. The initString info:
  112.         phyNum=0!
  113.         devNum=0!
  114.         infType=5!
  115.         irqNum=25!
  116.         devType=0!
  117.         privSize=0!
  118.         csrAddr=0x7fffffff!
  119.         devName=rai!
  120. Update memory base to 803d866000000001 from bar: 14
  121. Found PCI-E device(0x14c3:0x7662) 1:0.0
  122.             Vendor Id : 0x000014C3
  123.             Device Id : 0x00007662
  124.             bar 0     : 0x20000004
  125.             bar 1     : 0x00000000
  126.             map 0     : 0xC0000000
  127.             map 1     : 0x00000000
  128. hal_vec = 54, base address = 20000004
  129. csr_addr = 0x20000000
  130. === pAd = 805437e0, size = 935440 ===
  131. <-- RTMPAllocTxRxRingMemory, Status=0
  132. <-- RTMPAllocAdapterBlock, Status=0
  133. pAd->CSRBaseAddress =0x20000000, csr_addr=0x20000000!
  134. device_id =0x7612
  135. pAd->ChipID=76120044
  136. RTMPInitPCIeDevice 1
  137. ==>../rlt_wifi/mac/ral_nmac.c(): OnOff:1, Reset= 1, pAd->WlanFunCtrl:0x0, Reg-WlanFunCtrl=0x20a
  138. RTMPInitPCIeDevice 2
  139. RTMPInitPCIeDevice 3
  140. ../rlt_wifi/common/eeprom.c::e2p_type=0, inf_Type=5
  141. ../rlt_wifi/common/eeprom.c::e2p_dafault=1
  142. NVM is efuse and the information is too less to bring up the interface
  143. Force to use Flash mode
  144. NVM is FLASH mode (pAd->flash_offset = 0x40000)
  145. Error opening profile "/etc/Wireless/RT2860AP/RT2860AP.dat"
  146. ../rlt_wifi/common/cmm_cfg.c : invalid length (0)
  147. cfg_mode=14
  148. cfg_mode=14
  149. wmode_band_equal(): Band Not Equal!
  150. APSDCapable[0]=0
  151. APSDCapable[1]=0
  152. APSDCapable[2]=0
  153. APSDCapable[3]=0
  154. APSDCapable[4]=0
  155. APSDCapable[5]=0
  156. APSDCapable[6]=0
  157. APSDCapable[7]=0
  158. APSDCapable[8]=0
  159. APSDCapable[9]=0
  160. APSDCapable[10]=0
  161. APSDCapable[11]=0
  162. APSDCapable[12]=0
  163. APSDCapable[13]=0
  164. APSDCapable[14]=0
  165. APSDCapable[15]=0
  166. default ApCliAPSDCapable[0]=0
  167. Key2Str is Invalid key length(0) or Type(0)
  168. Key3Str is Invalid key length(0) or Type(0)
  169. Key4Str is Invalid key length(0) or Type(0)
  170. The primary RSNIE: 805911b5, len = 8
  171. 0x0000 : 01 00 00 0f ac 02 00 00
  172. The primary RSNIE: 805911b5, len = 20
  173. 0x0000 : 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f
  174. 0x0010 : ac 02 00 00
  175. 7f:11:eb:28:28:d4:ee:70:8f:be:d9:eb:5a:a4:67:87:
  176. 2b:db:5b:cd:19:b9:94:0d:1f:51:4b:b8:4b:79:8f:08:
  177. ThermalProHigh_En=1, ThermalProHigh_TempTh=112
  178. ThermalProLow_En=1, ThermalProLow_TempTh=102
  179. 1. Phy Mode = 49
  180. ../rlt_wifi/common/eeprom.c::e2p_type=2, inf_Type=5
  181. NVM is FLASH mode (pAd->flash_offset = 0x40000)
  182. ==> netpool_mangement.c
  183. mtk netPool has been init before
  184. Count=3,netpool=80e7f3d0
  185. rai: at CSR addr 0x20000000
  186. ../rlt_wifi/os/vxworks/rt_vxworks.c 3374 pAd=805437e0MBSS_Init pAd->ApCfg.BssidNum=1
  187. availableNum(0) devInitStr =0:5:0:1024:4:0:apclii
  188. tp_feature_steering_attach initialized tp steering timer.
  189. Start Entry Listw algea tnim eri(pser iocd:a60l0)e
  190. sts
  191. erw-la-ni-f_-st5arGt_ upsdatteo_tpim
  192. ta-rt- w-la-ni5f Gup dastet taimrert
  193. St
  194. Scteferg i_n m2Go
  195. de=14
  196. cfg_mode=14
  197. wmode_band_equal(): Band Equal!
  198. Stop Swtelera inn _5G5
  199. bl= =sisisdE nacblae l1 evadpE
  200. 0 e
  201. DNS proxy flush 010110ac/00000000
  202. IGMP extern IP 230110ac
  203. <<<<<load fw image method 1
  204. <<<<<<<<<<<<< try 1
  205. <<<<<<<<<<<<< OS_LOAD_CODE_FROM_BIN_2G will load file: /fw/mtk/WIFI_RAM_CODE_MT7628_e2.bin
  206. <<<<<<<<<<<<< OS_LOAD_CODE_FROM_BIN_2G load file: /fw/mtk/WIFI_RAM_CODE_MT7628_e2.bin size: 63984(0xf9f0)
  207. FW Version:_e2_mp
  208. FW Build Date:20160524163352
  209. -->rt28xx_open!pEndObj=8037dc5c pAd=805437e0
  210. init irq success!
  211. load rom patch from /lib/firmware//fw/mtk/mt7662_patch_e3_hdr_v0.0.2_P69.bin
  212. <<<<<<<<<<<<< try 1
  213. <<<<<<<<<<<<< oooooo! will load file: /fw/mtk/mt7662_patch_e3_hdr_v0.0.2_P69.bin
  214. <<<<<<<<<<<<< oooooo! will load file: /fw/mtk/mt7662_patch_e3_hdr_v0.0.2_P69.bin
  215. <<<<<<<<<<<<< OS_LOAD_CODE_FROM_BIN load file: /fw/mtk/mt7662_patch_e3_hdr_v0.0.2_P69.bin size: 26350(0x66ee)
  216. build time =
  217. 20141115060606a
  218. rom patch for E3 IC
  219. platform =
  220. ALPS
  221. hw/sw version =
  222. ▒▒
  223. patch version =
  224. <<<<<load rom patch finish 0
  225. load fw image from /lib/firmware//fw/mtk/MT7662_E3_v1.9_20160711.bin
  226. <<<<<<<<<<<<< try 1
  227. <<<<<<<<<<<<< oooooo! will load file: /fw/mtk/MT7662_E3_v1.9_20160711.bin
  228. <<<<<<<<<<<<< oooooo! will load file: /fw/mtk/MT7662_E3_v1.9_20160711.bin
  229. <<<<<<<<<<<<< OS_LOAD_CODE_FROM_BIN load file: /fw/mtk/MT7662_E3_v1.9_20160711.bin size: 81984(0x14040)
  230. FW Version:0.0.00 Build:1
  231. Build Time:201607111443____
  232. fw for E3 IC
  233. --> rtmp_nv_init
  234. wlan_5G is caled
  235. <<<<<load fw image finish 0
  236. RX[0] DESC a051e140 size = 4096
  237. RX[1] DESC a051d120 size = 4096
  238. --> rtmp_nv_init
  239. wlan_5G is caled
  240. ../rlt_wifi/chips/mt76x2.c:illegal channel (167)
  241. ../rlt_wifi/chips/mt76x2.c:illegal channel (167)
  242. ../rlt_wifi/chips/mt76x2.c:illegal channel (169)
  243. ../rlt_wifi/chips/mt76x2.c:illegal channel (169)
  244. ../rlt_wifi/chips/mt76x2.c:illegal channel (171)
  245. ../rlt_wifi/chips/mt76x2.c:illegal channel (171)
  246. ../rlt_wifi/chips/mt76x2.c:illegal channel (173)
  247. ../rlt_wifi/chips/mt76x2.c:illegal channel (173)
  248. Country Region from e2p = ffff
  249. ../rlt_wifi/chips/mt76x2.c:: is_temp_tx_alc=0, temp_tx_alc_enable=0
  250. ../rlt_wifi/chips/mt76x2.c:: is_ePA_mode=0, ePA_type=3
  251. ../rlt_wifi/chips/mt76x2.c:: [5G band] high_temp_slope=0, low_temp_slope=0
  252. ../rlt_wifi/chips/mt76x2.c:: [2G band] high_temp_slope=0, low_temp_slope=0
  253. ../rlt_wifi/chips/mt76x2.c:: [5G band] tc_lower_bound=0, tc_upper_bound=0
  254. ../rlt_wifi/chips/mt76x2.c:: [2G band] tc_lower_bound=0, tc_upper_bound=0
  255. ../rlt_wifi/chips/mt76x2.c::LNA type=0x11, BLNAGain=0x0, ALNAGain0=0xffffff81, ALNAGain1=0x0, ALNAGain2=0x0
  256. 2. Phy Mode = 49
  257. 3. Phy Mode = 49
  258. ../rlt_wifi/mcu/mcu_and.c
  259. 0x1300 = 00064300
  260. MAX_LEN_CFG =3e3640     2
  261. ../rlt_wifi/common/rtmp_init.c: primary/secondary ant 0/1
  262. ../rlt_wifi/mcu/mcu_and.c:cr_type(2)
  263. ../rlt_wifi/ate/common/rt_ate.c(): MT76x2 hook !
  264. [url=home.php?mod=space&uid=2281032]@@@[/url] BuildChannel # 36 :: Pwr0 = 33, Pwr1 =33, Flags = c0, RemainingTimeForUse=0
  265. @@@ BuildChannel # 40 :: Pwr0 = 33, Pwr1 =33, Flags = c0, RemainingTimeForUse=0
  266. @@@ BuildChannel # 44 :: Pwr0 = 33, Pwr1 =33, Flags = c0, RemainingTimeForUse=0
  267. @@@ BuildChannel # 48 :: Pwr0 = 33, Pwr1 =33, Flags = c0, RemainingTimeForUse=0
  268. @@@ BuildChannel # 149 :: Pwr0 = 33, Pwr1 =33, Flags = c0, RemainingTimeForUse=0
  269. @@@ BuildChannel # 153 :: Pwr0 = 33, Pwr1 =33, Flags = c0, RemainingTimeForUse=0
  270. @@@ BuildChannel # 157 :: Pwr0 = 33, Pwr1 =33, Flags = c0, RemainingTimeForUse=0
  271. @@@ BuildChannel # 161 :: Pwr0 = 33, Pwr1 =33, Flags = c, RemainingTimeForUse=0
  272. @@@ BuildChannel # 165 :: Pwr0 = 33, Pwr1 =33, Flags = 0, RemainingTimeForUse=0
  273. RTMPSetPhyMode: channel is out of range, use first channel=0
  274. MCS Set = ff ff 00 00 01
  275. TX0 power compensation = 0x38
  276. TX1 power compensation = 0x38
  277.         WTBL Segment 1 info:
  278.                 MemBaseAddr/FID:0x28000/0
  279.                 EntrySize/Cnt:32/128
  280.         WTBL Segment 2 info:
  281.                 MemBaseAddr/FID:0x40000/0
  282.                 EntrySize/Cnt:64/128
  283.         WTBL Segment 3 info:
  284.                 MemBaseAddr/FID:0x42000/64
  285.                 EntrySize/Cnt:64/128
  286.         WTBL Segment 4 info:
  287.                 MemBaseAddr/FID:0x44000/128
  288.                 EntrySize/Cnt:32/128
  289. ===============qadInit_2G===============
  290. ../rlt_wifi/chips/mt76x2.c():rf_bw=2, ext_ch=1, PrimCh=149, HT-CentCh=151, VHT-CentCh=155
  291. ../rlt_wifi/ap/ap.c(): AP Set CentralFreq at 155(Prim=149, HT-CentCh=151, VHT-CentCh=155, BBP_BW=2)
  292. ../rlt_wifi/chips/mt76x2.c(channel = 155)
  293. Steer is not enabled, skip start
  294. Main bssid = f4:6a:92:88:4f:d2
  295. ../rlt_wifi/chips/mt76x2.c:original agc_vga0 = 0x5c, agc_vga1 = 0x5c
  296. ../rlt_wifi/chips/mt76x2.c:updated agc_vga0 = 0x5c, agc_vga1 = 0x5c
  297. ../rlt_wifi/chips/mt76x2.c:original hi_lna0 = 0x27, hi_lna1 = 0x27
  298. ../rlt_wifi/chips/mt76x2.c:updated hi_lna0 = 0x27, hi_lna1 = 0x27
  299. original vga value(chain0) = 5c
  300. original vga value(chain1) = 5c
  301. <==== rt28xx_init, Status=0
  302. ../rlt_wifi/common/rtmp_init_inf.c(1):Check if PDMA is idle!
  303. ../rlt_wifi/common/rtmp_init_inf.c(2):Check if PDMA is idle!
  304. ../rlt_wifi/chips/mt76x2.c():rf_bw=2, ext_ch=1, PrimCh=149, HT-CentCh=151, VHT-CentCh=155
  305. ../rlt_wifi/ap/ap.c(): AP Set CentralFreq at 155(Prim=149, HT-CentCh=151, VHT-CentCh=155, BBP_BW=2)
  306. ../rlt_wifi/chips/mt76x2.c(channel = 155)
  307. Steer is not enabled, skip start
复制代码
只是不知道为什么linux kernel TFTP下载到内存中启动不起来
  1. Please choose the operation:
  2.    1: Load system code to SDRAM via TFTP.
  3.    2: Load system code then write to Flash via TFTP.
  4.    3: Boot system code via Flash (default).
  5.    4: Entr boot command line interface.
  6.    7: Load Boot Loader code then write to Flash via Serial.
  7.    9: Load Boot Loader code then write to Flash via TFTP.
  8.  4
  9. You choosed 1
  10.  0
  11. raspi_read: from:40028 len:6
  12.
  13. 1: System Load Linux to SDRAM via TFTP.
  14. Please Input new ones /or Ctrl-C to discard
  15.     Input device IP (10.10.10.123) ==:10.10.10.123
  16.     Input server IP (10.10.10.3) ==:10.10.10.3
  17.     Input Linux Kernel filename (vmlinux-wrtnode.uImage) ==:vmlinux-wrtnode.uImage
  18. netboot_common, argc= 3
  19. NetTxPacket = 0x81FE5940
  20. KSEG1ADDR(NetTxPacket) = 0xA1FE5940
  21. NetLoop,call eth_halt !
  22. NetLoop,call eth_init !
  23. Trying Eth0 (10/100-M)
  24. Waitting for RX_DMA_BUSY status Start... done
  25. ETH_STATE_ACTIVE!!
  26. TFTP from server 10.10.10.3; our IP address is 10.10.10.123
  27. Filename 'vmlinux-wrtnode.uImage'.
  28. TIMEOUT_COUNT=10,Load address: 0x80a00000
  29. Loading: *Got ARP REPLY, set server/gtwy eth addr (80:fa:5b:00:89:43)
  30. Got it
  31. #################################################################
  32.      #################################################################
  33.      #################################################################
  34.      ###########
  35. done
  36. Bytes transferred = 1052580 (100fa4 hex)
  37. NetBootFileXferSize= 00100fa4
  38. Automatic boot of image at addr 0x80A00000 ...
  39. ## Booting image at 80a00000 ...
复制代码
然后就停了,难道tp的uboot精简掉了Linux uimage支持?知道的大佬麻烦传授下经验:lol:
参与人数 2家元 +35 收起 理由
qianjiakun + 5
家睦 + 30
发表于 2019-8-1 12:45:33 | 显示全部楼层
还行,2m不够用
发表于 2019-8-1 13:20:22 | 显示全部楼层
缩成狗,绝对不会自用这种东西。
 楼主| 发表于 2019-8-1 19:04:51 | 显示全部楼层
Hexoxg 发表于 2019-8-1 12:45
还行,2m不够用
内存16M不知道有没有什么搞头,linux不知道精简后放得进不进
 楼主| 发表于 2019-8-1 19:05:41 | 显示全部楼层
whf20 发表于 2019-8-1 13:20
缩成狗,绝对不会自用这种东西。
你如果单纯图用的话,这东西就失去意义了,看的就是TP的缩水大法
发表于 2019-8-1 23:37:34 | 显示全部楼层
缩成这样,当AP可以凑合用
发表于 2019-8-2 10:49:04 | 显示全部楼层
双频做到16MB的运行内存也是独一家啊!独门秘籍!
 楼主| 发表于 2019-8-2 10:51:19 | 显示全部楼层
我很期待TP能不能把7612E的驱动塞到MT76x8KN的8MB RAM内存空间里:lol:
 楼主| 发表于 2019-8-2 10:52:31 | 显示全部楼层
lipengbo 发表于 2019-8-1 23:37
缩成这样,当AP可以凑合用
ralink这颗580Mhz的MIPS 24Kc的软转发能力还是很可以的,百兆跑满问题真的不大
发表于 2019-8-2 11:24:15 | 显示全部楼层
以后像交换芯片一样,不需要ram
发表于 2019-12-14 09:19:28 | 显示全部楼层
楼主我有个迅捷1200M 千兆版 2.1  不知如何查看log
 楼主| 发表于 2020-2-29 20:12:29 | 显示全部楼层
TTL用万用表测
发表于 2020-3-7 14:24:33 | 显示全部楼层
楼主有没有编程器固件发一个,谢谢!
发表于 2020-3-10 23:45:22 来自手机浏览器 | 显示全部楼层
wdr6300 v9.0 一样的内存大小!7628an 2m闪存
发表于 2020-3-11 10:30:21 | 显示全部楼层
外面的盒子这么大,板这么小,利于散热:lol:
 楼主| 发表于 2020-3-12 09:32:15 | 显示全部楼层
静默无痕 发表于 2020-3-7 14:24
楼主有没有编程器固件发一个,谢谢!
放老家电脑了,有空回去发你
 楼主| 发表于 2020-3-12 09:34:27 | 显示全部楼层
这个是MT762xD系列的,D是集成闪存的7628D有7628DAN和7628DBN两个版本,一个64M,一个16M,水星的BN 16M vxworks缩水专用的,你那个7628AN是很早的产物了,7628KN同时代的东西
 楼主| 发表于 2020-3-12 09:34:58 | 显示全部楼层
都市砍柴人 发表于 2020-3-11 10:30
外面的盒子这么大,板这么小,利于散热
卖塑料天线啊,这才是消费者感知点
发表于 2020-3-12 21:38:50 | 显示全部楼层
配置比这个好点,这个是水星,单频的。https://www.mydigit.cn/forum.php ... d=119404&extra=
拆机图楼下
 楼主| 发表于 2020-3-14 18:04:19 | 显示全部楼层
wuren 发表于 2020-3-12 21:38
配置比这个好点,这个是水星,单频的。https://www.mydigit.cn/forum.php?mod=viewthread&tid=119404&extra ...
7628kn好早的东西了,做ap还不错
GMT+8, 2025-9-10 13:13 , Processed in 0.358801 second(s), 14 queries , Gzip On, Redis On.
