查看: 415|回复: 11
openipc最新版出bug了,又连不上海康录像机了
发表于 2026-8-25 21:49:59 | 显示全部楼层 |阅读模式
openipc最新版出bug了,又连不上海康录像机了,故障是???
[code]2026/8/25 20:57:06 openipc后门 syslog.info syslogd started: BusyBox v1.36.1
2026/8/25 20:57:06 openipc后门 kern.notice kernel: klogd started: BusyBox v1.36.1 (2026-08-23 03:59:19 UTC)
2026/8/25 20:57:06 openipc后门 kern.info kernel: Booting Linux on physical CPU 0x0
2026/8/25 20:57:06 openipc后门 kern.notice kernel: Linux version 4.9.84 (runner@runnervm76f27) (buildroot-gcc-13.3.0) #2 PREEMPT Sun Aug 23 04:02:31 UTC 2026
2026/8/25 20:57:06 openipc后门 kern.info kernel: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c53c7d
2026/8/25 20:57:06 openipc后门 kern.info kernel: CPU: div instructions available: patching division code
2026/8/25 20:57:06 openipc后门 kern.info kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
2026/8/25 20:57:06 openipc后门 kern.err kernel: early_atags_to_fdt() success
2026/8/25 20:57:06 openipc后门 kern.info kernel: OF: fdt:Machine model: INFINITY6B0 SSC009A-S01A QFN88
2026/8/25 20:57:06 openipc后门 kern.debug kernel: cma: early_cma(2M)
2026/8/25 20:57:06 openipc后门 kern.err kernel: LXmem is 0x3fe0000 PHYS_OFFSET is 0x20000000
2026/8/25 20:57:06 openipc后门 kern.err kernel: Add mem start 0x20000000 size 0x3fe0000!!!!
2026/8/25 20:57:06 openipc后门 kern.err kernel: LX_MEM  = 0x20000000, 0x3fe0000
2026/8/25 20:57:06 openipc后门 kern.err kernel: LX_MEM2 = 0x0, 0x0
2026/8/25 20:57:06 openipc后门 kern.err kernel: LX_MEM3 = 0x0, 0x0
2026/8/25 20:57:06 openipc后门 kern.err kernel: EMAC_LEN= 0x0
2026/8/25 20:57:06 openipc后门 kern.err kernel: DRAM_LEN= 0x0
2026/8/25 20:57:06 openipc后门 kern.err kernel: deal_with_reserve_mma_heap memblock_reserve success mma_config[0].reserved_start=
2026/8/25 20:57:06 openipc后门 kern.err kernel: 0x21fe0000
2026/8/25 20:57:06 openipc后门 kern.debug kernel: cma: dma_contiguous_reserve(limit ffffffff)
2026/8/25 20:57:06 openipc后门 kern.debug kernel: cma: dma_contiguous_reserve: reserving 2 MiB for global area
2026/8/25 20:57:06 openipc后门 kern.debug kernel: cma: cma_declare_contiguous(size 0x00200000, base 0x00000000, limit 0xffffffff alignment 0x00000000)
2026/8/25 20:57:06 openipc后门 kern.info kernel: cma: Reserved 2 MiB at 0x21c00000
2026/8/25 20:57:06 openipc后门 kern.info kernel: Memory policy: Data cache writeback
2026/8/25 20:57:06 openipc后门 kern.debug kernel: On node 0 totalpages: 16352
2026/8/25 20:57:06 openipc后门 kern.debug kernel: free_area_init_node: node 0, pgdat c0402274, node_mem_map c1f56000
2026/8/25 20:57:06 openipc后门 kern.debug kernel:   Normal zone: 128 pages used for memmap
2026/8/25 20:57:06 openipc后门 kern.debug kernel:   Normal zone: 0 pages reserved
2026/8/25 20:57:06 openipc后门 kern.debug kernel:   Normal zone: 16352 pages, LIFO batch:3
2026/8/25 20:57:06 openipc后门 kern.info kernel: CPU: All CPU(s) started in SVC mode.
2026/8/25 20:57:06 openipc后门 kern.debug kernel: pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
2026/8/25 20:57:06 openipc后门 kern.debug kernel: pcpu-alloc: [0] 0
2026/8/25 20:57:06 openipc后门 kern.info kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16224
2026/8/25 20:57:06 openipc后门 kern.notice kernel: Kernel command line: console=ttyS0,115200 panic=20 root=/dev/mtdblock3 init=/init mtdparts=NOR_FLASH:256k(boot),64k(env),2048k(kernel),5120k(rootfs),-(rootfs_data) LX_MEM=0x3FE0000 mma_heap=mma_heap_name0,miu=0,sz=0x2000000 cma=
2026/8/25 20:57:06 openipc后门 kern.info kernel: PID hash table entries: 256 (order: -2, 1024 bytes)
2026/8/25 20:57:06 openipc后门 kern.info kernel: Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
2026/8/25 20:57:06 openipc后门 kern.info kernel: Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
2026/8/25 20:57:06 openipc后门 kern.info kernel: Memory: 25584K/65408K available (2385K kernel code, 227K rwdata, 1196K rodata, 128K init, 145K bss, 37776K reserved, 2048K cma-reserved)
2026/8/25 20:57:06 openipc后门 kern.notice kernel: Virtual kernel memory layout:
2026/8/25 20:57:06 openipc后门 kern.notice kernel:     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
2026/8/25 20:57:06 openipc后门 kern.notice kernel:     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
2026/8/25 20:57:06 openipc后门 kern.notice kernel:     vmalloc : 0xc4000000 - 0xff800000   ( 952 MB)
2026/8/25 20:57:06 openipc后门 kern.notice kernel:     lowmem  : 0xc0000000 - 0xc3fe0000   (  63 MB)
2026/8/25 20:57:06 openipc后门 kern.notice kernel:     modules : 0xbf800000 - 0xc0000000   (   8 MB)
2026/8/25 20:57:06 openipc后门 kern.notice kernel:       .text : 0xc0008000 - 0xc025c7f0   (2386 kB)
2026/8/25 20:57:06 openipc后门 kern.notice kernel:       .init : 0xc03aa000 - 0xc03ca000   ( 128 kB)
2026/8/25 20:57:06 openipc后门 kern.notice kernel:       .data : 0xc03ca000 - 0xc0402e78   ( 228 kB)
2026/8/25 20:57:06 openipc后门 kern.notice kernel:        .bss : 0xc0404000 - 0xc0428438   ( 146 kB)
2026/8/25 20:57:06 openipc后门 kern.info kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
2026/8/25 20:57:06 openipc后门 kern.info kernel: Preemptible hierarchical RCU implementation.
参与人数 1家元 +6 收起 理由
暗影男爵 + 6 歡迎探討
 楼主| 发表于 2026-8-27 17:35:38 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2026-8-28 00:03:36 | 显示全部楼层
 楼主| 发表于 2026-8-29 04:05:21 来自手机浏览器 | 显示全部楼层
发表于 2026-9-3 20:29:01 | 显示全部楼层
 楼主| 发表于 2026-9-3 21:50:05 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2026-9-3 21:50:55 来自手机浏览器 | 显示全部楼层
发表于 2026-9-4 07:53:00 | 显示全部楼层
发表于 2026-9-4 07:54:38 | 显示全部楼层
 楼主| 发表于 2026-9-5 16:16:54 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2026-9-5 16:17:21 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2026-9-6 10:02:07 | 显示全部楼层
GMT+8, 2026-10-25 09:02 , Processed in 0.140401 second(s), 6 queries , Gzip On, Redis On.
