多年前测试过红外遥控,用 HX1838+库 很简单的,虽然空调还是有些折腾,但是没需求就没仔细看。
近期有个遥控的需求,把蓝牙调通之后,随便看看红外,万一老板看上某个红外遥控器的颜值呢。。。
HX1838我有很多,但不在手边。顺手把之前转速计的普通红外收发小模块插上。
AI一通操作,约3.2kHz采样率读取IO电平,串口输出254个0或者1
我当然知道有很多成熟的方法读红外信号,不过偏爱这种用 “0、1的个数” 等效于 “高低电平时长” 的方式(这个方法 DHT11 DHT22 DS18B20 也适用,WS2812也是这原理,不过频率高很多),这样的 0、1串 有示波器和逻辑分析仪的直观。(虽然有,但是小制作能不用就不用)
以前肉眼数,现在AI去数就行了
- 000000000000000000000000000011111111111111001100100110010011001001100111110011111011111101111110111111011111101111110111111011001111100110111111011001101100100110010011111001100111110011111001111100111110011111001111111111111111111111111111111111111
- 000000000000000000000000000011111111111111001101100110110011011001101111110111111011111101111110111111011111101111110111111011001111100110111110011001001100100110010011111101100111110011111001111100111110011111001111111111111111111111111111111111111
- 000000000000000000000000000011111111111111001100100110110011011001101111110111111011111101111110111111011111101111110111110011001111100100110011011001001100100110011111001111100111110011111001111100111110011111001111111111111111111111111111111111111
- 000000000000000000000000000011111111111111001100100110010011001001100111110111111011111101111110111111011111101111110111111011001111100100110010011001001100100110011111001111100111110011111001111100111110011111001111111111111111111111111111111111111
- 000000000000000000000000000011111111111111001100100110010011001001101111110111111011111101111110111111011111101111110111111011001001111100110010011111001100100110011111001001111100111110011001111100111110011111001111111111111111111111111111111111111
- 000000000000000000000000000011111111111111001100100110010011001001100111110011111011111101111110111111011111101111110111111011001101111110111110011111001111100110010011001111100100110010011001111100111110011111001111111111111111111111111111111111111
- 000000000000000000000000000011111111111111001100100110010011011001101111110111111011111101111110111111011111101111100111110011001001111100111110011111001111100110010011001111100100110010011001111100111110111111011111111111111111111111111111111111111
- 000000000000000000000000000011111111111111001100100110010011011001101111110111111011111101111110111111011111101111100111110011001001111100110010011111001100100110011111001001111100111110011001111100111110011111011111111111111111111111111111111111111
复制代码
一通教育之后,AI终于识别到这正是 NEC 编码。随便试试闲置的几个遥控器,都有键码输出。
基本上故事到这里就该结束了。。。
但是突然想起,用的并不是HX1838,一颗普通红外接收管而已。
过程自始至终都没考虑载波这个问题,但遥控器是电器配套的,肯定有载波的。。。问题是去哪了? 。。。答案。。。百度有。
