废品站淘来的剃须刀,老板说降速严重不要了,我花了 49 块钱拿回来,赌一把能不能救活。拆之前先通了个电,现象和老板说的一致,心里大概有数了。
底部有两颗防拆螺丝,还好手头有对应的批头,拧下来之后整机就能分解开了。拆开之后发现内部比想象中干净,没有明显的进水和腐蚀痕迹,这点比较让人放心。
PCB 布局挺紧凑的,几个大电容是固态电容,电源部分用了常见电源管理 IC,整体设计还算正规。板子边缘做了倒角处理,没有毛刺,安装孔附近也做了加固,细节上能看出一点用心。
通电试了一下,现象和描述的一致,确实会降速严重,而且不是偶发,基本上每次都会出现。先测了一下待机电压,发现 5V 这一路不太对,估计问题就出在供电上。
逐个测了一遍,问题出在降速严重上,元件本身没坏,是引脚那边接触不良。拆下来重新上锡,顺便把周边几个疑似虚焊的点也补了一遍,防患于未然。
顺手把散热硅脂也换了,这玩意儿时间长了容易干,影响散热,换了之后温度明显低了不少。原来的硅脂已经硬得像块饼干,难怪会降速严重,散热不好元件寿命肯定受影响。
复测的时候特意多跑了一会儿,温度、电压、电流都记录了一下,各项指标都在正常范围。相比修之前,待机功耗还降了一点,估计是之前那个坏件拖累了整体效率。
整体拆解体验还行,螺丝不多、卡扣好拆,内部还行,值得一拆。拆机过程中最大的感受就是,很多所谓的“坏了”,其实只是降速严重这种小问题,稍微动动手就能解决。
顺便问问大家,这种问题你们一般怎么处理?是直接换件还是先补焊试试?评论区聊聊。
https://www.51sole.com/b2b/sides358964793.html
https://www.51sole.com/b2b/sides358964841.html
https://www.51sole.com/b2b/sides358964849.html
https://www.51sole.com/b2b/sides358964913.html
https://www.51sole.com/b2b/sides358964979.html
https://www.51sole.com/b2b/sides358965010.html
https://www.51sole.com/b2b/sides358965042.html
https://www.51sole.com/b2b/sides358965079.html
https://www.51sole.com/b2b/sides358965185.html
https://www.51sole.com/b2b/sides358965201.html
https://www.51sole.com/b2b/sides358965261.html
https://www.51sole.com/b2b/sides358965365.html
https://www.51sole.com/b2b/sides358965370.html
https://www.51sole.com/b2b/sides358965371.html
https://www.51sole.com/b2b/sides358965418.html
https://www.51sole.com/b2b/sides358965549.html
https://www.51sole.com/b2b/sides358965567.html
https://www.51sole.com/b2b/sides358965637.html
https://www.51sole.com/b2b/sides358965652.html
https://www.51sole.com/b2b/sides358965724.html
https://www.51sole.com/b2b/sides358965725.html
https://www.51sole.com/b2b/sides358965790.html
https://www.51sole.com/b2b/sides358965827.html
https://www.51sole.com/b2b/sides358965900.html
https://www.51sole.com/b2b/sides358965962.html
https://www.51sole.com/b2b/sides358965964.html
https://www.51sole.com/b2b/sides358966007.html
https://www.51sole.com/b2b/sides358966071.html
https://www.51sole.com/b2b/sides358966107.html
https://www.51sole.com/b2b/sides358966117.html
https://www.51sole.com/b2b/sides358966223.html
https://www.51sole.com/b2b/sides358966260.html
https://www.51sole.com/b2b/sides358966314.html
https://www.51sole.com/b2b/sides358966358.html
https://www.51sole.com/b2b/sides358966390.html
https://www.51sole.com/b2b/sides358966422.html
https://www.51sole.com/b2b/sides358966430.html
https://www.51sole.com/b2b/sides358966488.html
https://www.51sole.com/b2b/sides358966500.html
https://www.51sole.com/b2b/sides358966528.html
https://www.51sole.com/b2b/sides358966597.html
https://www.51sole.com/b2b/sides358966602.html
https://www.51sole.com/b2b/sides358966629.html
https://www.51sole.com/b2b/sides358966634.html
https://www.51sole.com/b2b/sides358966718.html
https://www.51sole.com/b2b/sides358966726.html
https://www.51sole.com/b2b/sides358966744.html
https://www.51sole.com/b2b/sides358966779.html
https://www.51sole.com/b2b/sides358966804.html
https://www.51sole.com/b2b/sides358966819.html
https://www.51sole.com/b2b/sides358966832.html
https://www.51sole.com/b2b/sides358966858.html
https://www.51sole.com/b2b/sides358966892.html
https://www.51sole.com/b2b/sides358966919.html
https://www.51sole.com/b2b/sides358966936.html
https://www.51sole.com/b2b/sides358966948.html
https://www.51sole.com/b2b/sides358966984.html
https://www.51sole.com/b2b/sides358967012.html
https://www.51sole.com/b2b/sides358967035.html
https://www.51sole.com/b2b/sides358967036.html
https://www.51sole.com/b2b/sides358967070.html
https://www.51sole.com/b2b/sides358967114.html
https://www.51sole.com/b2b/sides358967118.html
https://www.51sole.com/b2b/sides358967133.html
https://www.51sole.com/b2b/sides358967162.html
https://www.51sole.com/b2b/sides358967202.html
https://www.51sole.com/b2b/sides358967210.html
https://www.51sole.com/b2b/sides358967224.html
https://www.51sole.com/b2b/sides358967245.html
https://www.51sole.com/b2b/sides358967275.html
https://www.51sole.com/b2b/sides358967296.html
https://www.51sole.com/b2b/sides358967320.html
https://www.51sole.com/b2b/sides358967335.html
https://www.51sole.com/b2b/sides358967385.html
https://www.51sole.com/b2b/sides358967466.html
https://www.51sole.com/b2b/sides358967474.html
https://www.51sole.com/b2b/sides358967520.html
https://www.51sole.com/b2b/sides358967539.html
https://www.51sole.com/b2b/sides358967614.html
https://www.51sole.com/b2b/sides358967640.html
https://www.51sole.com/b2b/sides358967662.html
https://www.51sole.com/b2b/sides358967699.html
https://www.51sole.com/b2b/sides358967789.html
https://www.51sole.com/b2b/sides358967827.html
https://www.51sole.com/b2b/sides358967828.html
https://www.51sole.com/b2b/sides358967881.html
https://www.51sole.com/b2b/sides358967952.html
https://www.51sole.com/b2b/sides358967979.html
https://www.51sole.com/b2b/sides358967996.html
https://www.51sole.com/b2b/sides358968094.html
https://www.51sole.com/b2b/sides358968114.html
https://www.51sole.com/b2b/sides358968150.html
https://www.51sole.com/b2b/sides358968158.html
https://www.51sole.com/b2b/sides358968255.html
https://www.51sole.com/b2b/sides358968260.html
https://www.51sole.com/b2b/sides358968329.html
https://www.51sole.com/b2b/sides358968411.html
https://www.51sole.com/b2b/sides358968421.html
https://www.51sole.com/b2b/sides358968439.html
https://www.51sole.com/b2b/sides358968561.html
https://www.51sole.com/b2b/sides358968587.html
https://www.51sole.com/b2b/sides358968614.html
https://www.51sole.com/b2b/sides358968716.html
https://www.51sole.com/b2b/sides358968726.html
https://www.51sole.com/b2b/sides358968751.html
https://www.51sole.com/b2b/sides358968791.html
https://www.51sole.com/b2b/sides358968863.html
https://www.51sole.com/b2b/sides358968900.html
https://www.51sole.com/b2b/sides358968943.html
https://www.51sole.com/b2b/sides358968972.html
https://www.51sole.com/b2b/sides358968977.html
https://www.51sole.com/b2b/sides358969025.html
https://www.51sole.com/b2b/sides358969068.html
https://www.51sole.com/b2b/sides358969071.html
https://www.51sole.com/b2b/sides358969117.html
https://www.51sole.com/b2b/sides358969130.html
https://www.51sole.com/b2b/sides358969159.html
https://www.51sole.com/b2b/sides358969170.html
https://www.51sole.com/b2b/sides358969205.html
https://www.51sole.com/b2b/sides358969221.html
https://www.51sole.com/b2b/sides358969238.html
https://www.51sole.com/b2b/sides358969246.html
https://www.51sole.com/b2b/sides358969289.html
https://www.51sole.com/b2b/sides358969303.html
https://www.51sole.com/b2b/sides358969305.html
https://www.51sole.com/b2b/sides358969353.html
https://www.51sole.com/b2b/sides358969355.html
https://www.51sole.com/b2b/sides358969359.html
https://www.51sole.com/b2b/sides358969363.html
https://www.51sole.com/b2b/sides358969421.html
https://www.51sole.com/b2b/sides358969428.html
https://www.51sole.com/b2b/sides358969431.html
https://www.51sole.com/b2b/sides358969435.html
https://www.51sole.com/b2b/sides358969476.html
https://www.51sole.com/b2b/sides358969493.html
https://www.51sole.com/b2b/sides358969507.html
https://www.51sole.com/b2b/sides358969517.html
https://www.51sole.com/b2b/sides358969554.html
https://www.51sole.com/b2b/sides358969567.html
https://www.51sole.com/b2b/sides358969590.html
https://www.51sole.com/b2b/sides358969601.html
https://www.51sole.com/b2b/sides358969642.html
https://www.51sole.com/b2b/sides358969660.html
https://www.51sole.com/b2b/sides358969665.html
https://www.51sole.com/b2b/sides358969671.html
https://www.51sole.com/b2b/sides358969711.html
https://www.51sole.com/b2b/sides358969733.html
https://www.51sole.com/b2b/sides358969762.html
https://www.51sole.com/b2b/sides358969822.html
https://www.51sole.com/b2b/sides358969847.html
https://www.51sole.com/b2b/sides358969887.html
https://www.51sole.com/b2b/sides358969897.html
https://www.51sole.com/b2b/sides358969942.html
https://www.51sole.com/b2b/sides358970008.html
https://www.51sole.com/b2b/sides358970009.html
https://www.51sole.com/b2b/sides358970015.html
https://www.51sole.com/b2b/sides358970051.html
https://www.51sole.com/b2b/sides358970122.html
https://www.51sole.com/b2b/sides358970143.html
https://www.51sole.com/b2b/sides358970147.html
https://www.51sole.com/b2b/sides358970177.html
https://www.51sole.com/b2b/sides358970236.html
https://www.51sole.com/b2b/sides358970274.html
https://www.51sole.com/b2b/sides358970295.html
https://www.51sole.com/b2b/sides358970353.html
https://www.51sole.com/b2b/sides358970358.html
https://www.51sole.com/b2b/sides358970410.html
https://www.51sole.com/b2b/sides358970421.html
https://www.51sole.com/b2b/sides358970467.html
https://www.51sole.com/b2b/sides358970492.html
https://www.51sole.com/b2b/sides358970550.html
https://www.51sole.com/b2b/sides358970555.html
https://www.51sole.com/b2b/sides358970599.html
https://www.51sole.com/b2b/sides358970651.html
https://www.51sole.com/b2b/sides358970711.html
https://www.51sole.com/b2b/sides358970727.html
https://www.51sole.com/b2b/sides358970752.html
https://www.51sole.com/b2b/sides358970830.html
https://www.51sole.com/b2b/sides358970874.html
https://www.51sole.com/b2b/sides358970908.html
https://www.51sole.com/b2b/sides358970910.html
https://www.51sole.com/b2b/sides358971012.html
https://www.51sole.com/b2b/sides358971042.html
https://www.51sole.com/b2b/sides358971061.html
https://www.51sole.com/b2b/sides358971078.html
https://www.51sole.com/b2b/sides358971184.html
https://www.51sole.com/b2b/sides358971201.html
https://www.51sole.com/b2b/sides358971206.html
https://www.51sole.com/b2b/sides358971246.html
https://www.51sole.com/b2b/sides358971343.html
https://www.51sole.com/b2b/sides358971344.html
https://www.51sole.com/b2b/sides358971351.html
https://www.51sole.com/b2b/sides358971405.html
https://www.51sole.com/b2b/sides358971471.html
https://www.51sole.com/b2b/sides358971482.html
https://www.51sole.com/b2b/sides358971492.html
https://www.51sole.com/b2b/sides358971553.html
https://www.51sole.com/b2b/sides358971602.html
https://www.51sole.com/b2b/sides358971615.html
https://www.51sole.com/b2b/sides358971641.html
https://www.51sole.com/b2b/sides358971682.html
https://www.51sole.com/b2b/sides358971711.html
https://www.51sole.com/b2b/sides358971731.html
https://www.51sole.com/b2b/sides358971766.html
https://www.51sole.com/b2b/sides358971802.html
https://www.51sole.com/b2b/sides358971816.html
https://www.51sole.com/b2b/sides358971836.html
https://www.51sole.com/b2b/sides358971923.html
https://www.51sole.com/b2b/sides358971929.html
https://www.51sole.com/b2b/sides358971949.html
https://www.51sole.com/b2b/sides358972013.html
https://www.51sole.com/b2b/sides358972038.html
https://www.51sole.com/b2b/sides358972049.html
https://www.51sole.com/b2b/sides358972117.html
https://www.51sole.com/b2b/sides358972159.html
https://www.51sole.com/b2b/sides358972160.html
https://www.51sole.com/b2b/sides358972213.html
https://www.51sole.com/b2b/sides358972252.html
https://www.51sole.com/b2b/sides358972299.html
https://www.51sole.com/b2b/sides358972347.html
https://www.51sole.com/b2b/sides358972401.html
https://www.51sole.com/b2b/sides358972465.html
https://www.51sole.com/b2b/sides358972474.html
https://www.51sole.com/b2b/sides358972507.html
https://www.51sole.com/b2b/sides358972569.html
https://www.51sole.com/b2b/sides358972595.html
https://www.51sole.com/b2b/sides358972606.html
https://www.51sole.com/b2b/sides358972731.html
https://www.51sole.com/b2b/sides358972770.html
https://www.51sole.com/b2b/sides358972873.html
https://www.51sole.com/b2b/sides358972938.html
https://www.51sole.com/b2b/sides358972999.html
https://www.51sole.com/b2b/sides358973007.html
https://www.51sole.com/b2b/sides358973145.html
https://www.51sole.com/b2b/sides358973151.html
https://www.51sole.com/b2b/sides358973215.html
https://www.51sole.com/b2b/sides358973301.html
https://www.51sole.com/b2b/sides358973323.html
https://www.51sole.com/b2b/sides358973395.html
https://www.51sole.com/b2b/sides358973408.html
https://www.51sole.com/b2b/sides358973479.html
https://www.51sole.com/b2b/sides358973543.html
https://www.51sole.com/b2b/sides358973613.html
https://www.51sole.com/b2b/sides358973623.html
https://www.51sole.com/b2b/sides358973697.html
https://www.51sole.com/b2b/sides358973762.html
https://www.51sole.com/b2b/sides358973796.html
https://www.51sole.com/b2b/sides358973803.html
https://www.51sole.com/b2b/sides358973858.html
https://www.51sole.com/b2b/sides358973934.html
https://www.51sole.com/b2b/sides358973963.html
https://www.51sole.com/b2b/sides358974043.html
https://www.51sole.com/b2b/sides358974124.html
https://www.51sole.com/b2b/sides358974150.html
https://www.51sole.com/b2b/sides358974188.html
https://www.51sole.com/b2b/sides358974273.html
https://www.51sole.com/b2b/sides358974284.html
https://www.51sole.com/b2b/sides358974324.html
https://www.51sole.com/b2b/sides358974384.html
https://www.51sole.com/b2b/sides358974392.html
https://www.51sole.com/b2b/sides358974400.html
https://www.51sole.com/b2b/sides358974434.html
https://www.51sole.com/b2b/sides358974489.html
https://www.51sole.com/b2b/sides358974525.html
https://www.51sole.com/b2b/sides358974571.html
https://www.51sole.com/b2b/sides358974575.html
https://www.51sole.com/b2b/sides358974605.html
https://www.51sole.com/b2b/sides358974632.html
https://www.51sole.com/b2b/sides358974676.html
https://www.51sole.com/b2b/sides358974696.html
https://www.51sole.com/b2b/sides358974705.html
https://www.51sole.com/b2b/sides358974706.html
https://www.51sole.com/b2b/sides358974803.html
https://www.51sole.com/b2b/sides358974805.html
https://www.51sole.com/b2b/sides358974812.html
https://www.51sole.com/b2b/sides358974846.html
https://www.51sole.com/b2b/sides358974903.html
https://www.51sole.com/b2b/sides358974916.html
https://www.51sole.com/b2b/sides358974937.html
https://www.51sole.com/b2b/sides358974975.html
https://www.51sole.com/b2b/sides358974982.html
https://www.51sole.com/b2b/sides358974987.html
https://www.51sole.com/b2b/sides358975003.html
https://www.51sole.com/b2b/sides358975061.html
https://www.51sole.com/b2b/sides358975075.html
