查看: 7086|回复: 17
[Arduino] esp8266+DHT11+ILI9341绘制图形温湿度计
发表于 2019-8-26 12:28:44 来自手机浏览器 | 显示全部楼层 |阅读模式
之前用的是0.96寸的oled单色屏
U8g2库驱动刷新率很满意但屏幕太小了
这2.2寸彩色lcd拿到手后折腾了一个晚上都无法用
后来发现是Arduino UNO R3引脚电平与这个lcd不匹配
改用esp8266后一次驱动成功
由于是彩色屏所以改用Ucglib库
屏幕大了分辨率高的效果真的很好
遗憾的是刷新率不理想
接线:
VCC -> 3.3V
GND -> GND
CS -> D8
RESET -> D2
DC/RS -> D1
SDI/MOSI -> D7
SCK -> D5
LED -> 3.3V或PWM控制亮度
  1. #include "Ucglib.h"
  2. #include <dht11.h>
  3. #define DHT11PIN D6 //DHT11 data接D6引脚
  4. #include <SPI.h>
  5. dht11 DHT11;
  6. Ucglib_ILI9341_18x240x320_HWSPI ucg(/*cd=*/ D1, /*cs=*/ D8, /*reset=*/ D2);
  7. //左边仪表
  8. void draw(int value) {
  9.   int cx = 76;  //圆心x
  10.   int cy = 120;  //圆心y
  11.   int cr = 75;  //圆半径r
  12.   float angle;  //数值转换指针偏转角度
  13.   float rad;  //指针偏转角度转换弧度
  14.
  15.   //仪表指针及轨迹
  16.   for(float i=0;i<=value;i+=0.25)
  17.   {
  18.     angle = 150+i*2.4;
  19.     rad = angle/180*PI;
  20.     if(i<value)
  21.     {
  22.       ucg.setColor(0,255,255);
  23.       ucg.drawLine(cx+(cr-5)*cos(rad),cy+(cr-5)*sin(rad),cx+cr*cos(rad),cy+cr*sin(rad));
  24.     }
  25.     else
  26.     {
  27.       ucg.setColor(0,255,255);
  28.       ucg.drawLine(cx+(cr-70)*cos(rad),cy+(cr-70)*sin(rad),cx+cr*cos(rad),cy+cr*sin(rad));
  29.     }
  30.   }
  31.   //仪表中心小圆
  32.   ucg.setColor(0,255,255);
  33.   ucg.drawDisc(cx,cy,(cr-70),UCG_DRAW_ALL);
  34.   //仪表刻度
  35.   for(int i=0;i<=100;i+=2.5){
  36.     angle = 150+i*2.4;
  37.     rad = angle/180*PI;
  38.     if(i==0 ||i==20 ||i==40 ||i==60 ||i==80 ||i==100)
  39.     {
  40.       //刻度线
  41.       ucg.setColor(255,255,255);
  42.       ucg.drawLine(cx+(cr-15)*cos(rad),cy+(cr-15)*sin(rad),cx+cr*cos(rad),cy+cr*sin(rad));
  43.       //刻度数值
  44.       ucg.setColor(255,255,255);
  45.       ucg.setFont(ucg_font_ncenR14_tr);
  46.       ucg.setPrintPos((cx-8)+(cr-30)*cos(rad),(cy+5)+(cr-30)*sin(rad));
  47.       ucg.print(i);
  48.     }
  49.     else if(i==10 ||i==30 ||i==50 ||i==70 ||i==90)
  50.     {
  51.       //刻度线
  52.       ucg.setColor(255,255,255);
  53.       ucg.drawLine(cx+(cr-15)*cos(rad),cy+(cr-15)*sin(rad),cx+cr*cos(rad),cy+cr*sin(rad));
  54.     }
  55.     else
  56.     {
  57.       //刻度线
  58.       ucg.setColor(255,255,255);
  59.       ucg.drawLine(cx+(cr-10)*cos(rad),cy+(cr-10)*sin(rad),cx+cr*cos(rad),cy+cr*sin(rad));
  60.     }
  61.   }
  62.
  63.   //仪表外圆
  64.   ucg.setColor(255,255,255);
  65.   ucg.drawCircle(cx,cy,cr,UCG_DRAW_ALL);
  66. }
  67. //右边仪表
  68. void draw2(int value) {
  69.   int cx = 244;  //圆心x
  70.   int cy = 120;  //圆心y
  71.   int cr = 75;  //圆半径r
  72.   float angle;  //数值转换指针偏转角度
  73.   float rad;  //指针偏转角度转换弧度
  74.
  75.   //仪表指针及轨迹
  76.   for(float i=0;i<=value;i+=0.25)
  77.   {
  78.     angle = 150+i*4.8;
  79.     rad = angle/180*PI;
  80.     if(i<value)
  81.     {
  82.       ucg.setColor(255,0,0);
  83.       ucg.drawLine(cx+(cr-5)*cos(rad),cy+(cr-5)*sin(rad),cx+cr*cos(rad),cy+cr*sin(rad));
  84.     }
  85.     else
  86.     {
  87.       ucg.setColor(255,0,0);
  88.       ucg.drawLine(cx+(cr-70)*cos(rad),cy+(cr-70)*sin(rad),cx+cr*cos(rad),cy+cr*sin(rad));
  89.     }
  90.   }
  91.   //仪表中心小圆
  92.   ucg.setColor(255,0,0);
  93.   ucg.drawDisc(cx,cy,(cr-70),UCG_DRAW_ALL);
  94.
  95.   //仪表刻度
  96.   for(int i=0;i<=50;i+=1){
  97.     angle = i*4.8+150;
  98.     rad = angle/180*PI;
  99.     if(i==0 ||i==10 ||i==20 ||i==30 ||i==40 ||i==50)
  100.     {
  101.       //刻度线
  102.       ucg.setColor(255,255,255);
  103.       ucg.drawLine(cx+(cr-15)*cos(rad),cy+(cr-15)*sin(rad),cx+cr*cos(rad),cy+cr*sin(rad));
  104.       //刻度数值
  105.       ucg.setColor(255,255,255);
  106.       ucg.setFont(ucg_font_ncenR14_tr);
  107.       ucg.setPrintPos((cx-8)+(cr-30)*cos(rad),(cy+5)+(cr-30)*sin(rad));
  108.       ucg.print(i);
  109.     }
  110.     else if(i==5 ||i==15 ||i==25 ||i==35 ||i==45)
  111.     {
  112.       //刻度线
  113.       ucg.setColor(255,255,255);
  114.       ucg.drawLine(cx+(cr-10)*cos(rad),cy+(cr-10)*sin(rad),cx+cr*cos(rad),cy+cr*sin(rad));
  115.     }
  116.     else
  117.     {
  118.       //刻度线
  119.       ucg.setColor(255,255,255);
  120.       ucg.drawLine(cx+(cr-5)*cos(rad),cy+(cr-5)*sin(rad),cx+cr*cos(rad),cy+cr*sin(rad));
  121.     }
  122.   }
  123.
  124.   //仪表外圆
  125.   ucg.setColor(255,255,255);
  126.   ucg.drawCircle(cx,cy,cr,UCG_DRAW_ALL);
  127. }
  128. void setup(void) {
  129.   pinMode(DHT11PIN,OUTPUT);
  130.   delay(1000);
  131.   ucg.begin(UCG_FONT_MODE_TRANSPARENT); //字体透明模式
  132.   ucg.setRotate90();  //屏幕旋转90度
  133. }
  134. void loop(void) {
  135.   int chk = DHT11.read(DHT11PIN);                 //将读取到的值赋给chk
  136.   int tem=(float)DHT11.temperature;               //将温度值赋值给tem
  137.   int hum=(float)DHT11.humidity;                  //将湿度值赋值给hum
  138.   ucg.clearScreen();  //清屏
  139.   draw(hum);
  140.   draw2(tem);
  141.   delay(10000); //10秒刷新一次
  142. }
复制代码
参与人数 1家元 +40 收起 理由
家睦 + 40
发表于 2019-8-26 21:08:16 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2019-8-26 21:16:08 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2019-8-26 22:23:52 | 显示全部楼层
发表于 2019-8-26 23:33:03 | 显示全部楼层
发表于 2019-8-27 10:14:01 | 显示全部楼层
 楼主| 发表于 2019-8-27 12:11:58 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2019-8-27 12:16:49 来自手机浏览器 | 显示全部楼层
发表于 2019-8-27 20:17:57 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2019-8-28 09:54:18 来自手机浏览器 | 显示全部楼层
发表于 2019-8-28 18:35:36 来自手机浏览器 | 显示全部楼层
发表于 2019-8-29 11:07:23 | 显示全部楼层
 楼主| 发表于 2019-8-29 15:11:55 来自手机浏览器 | 显示全部楼层
发表于 2019-9-6 09:50:52 | 显示全部楼层
 楼主| 发表于 2019-9-6 15:05:33 来自手机浏览器 | 显示全部楼层
发表于 2020-4-24 21:14:27 | 显示全部楼层
发表于 2021-1-7 10:21:54 | 显示全部楼层
发表于 2021-1-7 10:58:02 | 显示全部楼层
GMT+8, 2026-11-21 17:35 , Processed in 0.280800 second(s), 13 queries , Gzip On, Redis On.
