求助卡下面一步了,求哪位大神指导下。我换过转接卡了 还是不行,一定要USB2.0吗?
<?xml version = "1.0"?>
<Genesis_Log>
<Log_Body>
Overall Summary:
Start Time: Fri, 10/04/2019 @ 13:02:22
End Time: Fri, 10/04/2019 @ 13:04:32
OverallResult: FAIL
ExitCode: (0x10090009:SF_GENESIS_CDU_ERROR)
Environment Settings:
Input Parameters:
argv[1]: -PROCESS_SSD
argv[2]: 18:0:0:0
argv[3]: /home/Mac/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
argv[4]: /home/Mac/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/28041.123456.driveconfig
argv[5]: 2F2720020239
argv[6]: 28041
argv[7]: LOG=/home/Mac/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/2F2720020239_localhost.localdomain_DATETIMESTAMP_18.0.0.0_PROCESS_SSD_RESULT.log
argv[8]: -TCG_OPAL=/home/Mac/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/28041.123456.driveconfig
Log File: /home/Mac/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/2F2720020239_localhost.localdomain_DATETIMESTAMP_18.0.0.0_PROCESS_SSD_RESULT.log
Hostname: localhost.localdomain
Host IP Address: 127.0.0.1
Port Number: 1
DeviceName: /dev/sg1
SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
SF_Core Library Version: v1.7.1.20130612-fc14-32bit
SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
WWN OUI: UNKNOWN
WWN UniqueID: UNKNOWN
Serial No.: UNKNOWN
Model No.: UNKNOWN
Firmware Revision: UNKNOWN
ROM Revision: UNKNOWN
NAND Page Size: UNKNOWN
Number Of Chip Enable: UNKNOWN
Logical Sectors: UNKNOWN
NAND ID: UNKNOWN
Flash Manufacturer: UNKNOWN
Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Fri 10/04/2019 13:02:22] - SF_Genesis has been invoked with the following parameters:
argv[2]: 18:0:0:0
argv[6]: 28041
[Fri 10/04/2019 13:02:22] - Instructing the operating system to purge any existing cached data for device: '18:0:0:0'
[Fri 10/04/2019 13:02:27] - Issuing a discovery command for device: '18:0:0:0'
[Fri 10/04/2019 13:02:32] - Discovery command completed...
[Fri 10/04/2019 13:02:32] - Waiting 5 seconds for the system to settle...
[Fri 10/04/2019 13:02:37] - Device designation string '18:0:0:0' is mapped to node '/dev/sg1'
[Fri 10/04/2019 13:02:37] - Proceeding to process SSD device with the following parameters:
DeviceName = /dev/sg1
MFP Package Filename = /home/Mac/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
Configuration File = /home/Mac/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/28041.123456.driveconfig
Serial No. = 2F2720020239
World Wide Name = 28041
[Fri 10/04/2019 13:02:37] - Successfully received the IDENTIFY data from the drive...
[Fri 10/04/2019 13:02:37] - Validating Manufacturing Firmware Package: /home/Mac/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Fri 10/04/2019 13:02:37] - Successfully opened the package: /home/Mac/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
[Fri 10/04/2019 13:02:37] - file /home/Mac/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/28041.123456.driveconfig Loaded successfully
[Fri 10/04/2019 13:02:43] - Warning: Unable to query diagnostics information to perform power management settings check
[Fri 10/04/2019 13:02:43] - B01 Power Management configuration request detected
[Fri 10/04/2019 13:02:43] - Successfully extracted *.DriveConfig file: /home/Mac/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/28041.123456.driveconfig
[Fri 10/04/2019 13:02:43] - Extracted Config_ID: 1 (28041) in DriveConfig file: /home/Mac/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/28041.123456.driveconfig
[Fri 10/04/2019 13:02:43] - Extracted SerialOutputControl: 0
[Fri 10/04/2019 13:02:43] - Searching for flashware image for configuration 28041
[Fri 10/04/2019 13:02:43] - Manifest found for configuration 28041
[Fri 10/04/2019 13:02:43] - Flashware image extracted: 28041_fw_cl_mlc_MIC_64Gb_MT29F64G08CBABBWP_1Q_2C_1D_S_PP_R01365_s512.vic
[Fri 10/04/2019 13:02:43] - Searching for manufacturing image for configuration 28041
[Fri 10/04/2019 13:02:43] - Manufacturing image extracted: 28041_mf_mlc_MIC_64Gb_MT29F64G08CBABBWP_1Q_2C_1D_S_PP_R01365_s512.vic
[Fri 10/04/2019 13:02:43] - Proceeding in ROM mode, download feature 3...
[Fri 10/04/2019 13:02:44] - Successfully downloaded MFB to the drive...
[Fri 10/04/2019 13:02:44] - Waiting (5 sec) for the drive to settle...
[Fri 10/04/2019 13:02:49] - Successfully received the IDENTIFY data from the drive...
[Fri 10/04/2019 13:02:49] - Firmware revision reported to be: '60AABBM0'. This indicates MFB download was successful.
[Fri 10/04/2019 13:02:49] - Successfully enabled SMART capabilities...
[Fri 10/04/2019 13:02:51] - Successfully issued a diagnostic unlock...
[Fri 10/04/2019 13:02:52] - Performing the flash test of block 0 (0x0000)...
[Fri 10/04/2019 13:02:54] - Flash Test Results:
Flash Test Parameters:
Block Count: 0
Page Count: 1
Bus Count: 1
Chip Enabled Count: 2
Die Count: 1
Lane Count: 4
Plane Count: 2
Results Notes:
N1 - At least one page tested and passed with no bit errors.
N2 - No test data available. Test may have aborted, or failed during the testing.
N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
N4 - At least one erased page tested had bit error rate greater than half the correction power.
N5 - Walking zeros test failed.
N6 - Walking ones test failed.
N7 - Block contained factory bad block markings and testing was skipped.
N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
N9 - Block in plane 0 was marked as a factory bad block.
N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
N11 - Block in plane 1 was marked as a factory bad block.
| Bus | CE | Die | Lane | Value | Result Notes | Overall |
| 0 | 0 | 0 | 0 | 0x0001 | N1 | PASS |
| 0 | 0 | 0 | 1 | 0x0001 | N1 | PASS |
| 0 | 0 | 0 | 2 | 0x0001 | N1 | PASS |
| 0 | 0 | 0 | 3 | 0x0001 | N1 | PASS |
| 0 | 1 | 0 | 0 | 0x0001 | N1 | PASS |
| 0 | 1 | 0 | 1 | 0x0023 | N1,N3,N5 | WARNING |
| 0 | 1 | 0 | 2 | 0x0001 | N1 | PASS |
| 0 | 1 | 0 | 3 | 0x0001 | N1 | PASS |
Total Number of test results: 8
Number of failures: 0
Number of Passed with warnings: 1
No. Passed without warnings: 7
[Fri 10/04/2019 13:02:54] - Performing the FORMAT Command with the following parameters:
MemoryWearCycleCapability = 0
CurrentPE_CycleCount = 0
LifeInSeconds = 0
LogicalCapacity = 125045424
SectorSize = 512
SectorAlignmentOffset = 0
ExpectedMemoryID = 25644 (0x642C)
ExpectedNumDies = 0
SerialOutputControl = 0
Time[8] = 0x0000000000000000
MiscFlag_Erase_R_Block = 0
MiscFlag_PanicHandlingEnabled = 0
MiscFlag_PanicOnSATA_Error = 0
MiscFlag_WriteThrottlingTestMode = 0
MiscFlag_DisableUserBandECCX = 1
L_PageSize = 0
E_PageSize = 0
ErrorCorrectionPower = 0
ConfigDeviceReadDisturbCount = 0
ConfigDeviceReadDisturbCountLow = 0
ExtraOptions_0_1 = 0
[Fri 10/04/2019 13:04:30] - FORMAT command completed...
[Fri 10/04/2019 13:04:30] - Waiting (2 sec) for the drive to settle...
[Fri 10/04/2019 13:04:32] - Setting up the stamp information through CDU command...
[Fri 10/04/2019 13:04:32] - FATAL_ERROR: Could not perform the ReadDriveConfigUnique() operation on the drive... (0x00100001:SF_SATA_DEVICE_NOT_PRESENT_ERROR)
[Fri 10/04/2019 13:04:32] - End of Genesis manufacturing log.
[Fri 10/04/2019 13:04:32] - Exiting...
</Log_Body>
<Overall_Summary>
<Start_Time> Fri, 10/04/2019 @ 13:02:22 </Start_Time>
<End_Time> Fri, 10/04/2019 @ 13:04:32 </End_Time>
<Overall_Result> FAIL </Overall_Result>
<Exit_Code> (0x10090009:SF_GENESIS_CDU_ERROR) </Exit_Code>
</Overall_Summary>
<Environment_Settings>
<Input_Parameters>
argv[2]: 18:0:0:0
argv[6]: 28041
</Input_Parameters>
<Log_File> /home/Mac/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/2F2720020239_localhost.localdomain_DATETIMESTAMP_18.0.0.0_PROCESS_SSD_RESULT.log </Log_File>
<Hostname> localhost.localdomain </Hostname>
<Host_IP_Address> 127.0.0.1 </Host_IP_Address>
<Port_Number> 1 </Port_Number>
<Device_Name> /dev/sg1 </Device_Name>
<SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
<SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
<SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
</Environment_Settings>
<Post_Processing_Device_Info>
<WWN_OUI> UNKNOWN </WWN_OUI>
<WWN_UniqueID> UNKNOWN </WWN_UniqueID>
<Serial_Number> UNKNOWN </Serial_Number>
<Model_Number> UNKNOWN </Model_Number>
<Firmware_Revision> UNKNOWN </Firmware_Revision>
<ROM_Revision> UNKNOWN </ROM_Revision>
<NAND_Page_Size> UNKNOWN </NAND_Page_Size>
<Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
<Logical_Sectors> UNKNOWN </Logical_Sectors>
<NAND_ID> UNKNOWN </NAND_ID>
<Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
<Flash_Device> UNKNOWN </Flash_Device>
</Post_Processing_Device_Info>
</Genesis_Log>
[Fri 10/04/2019 13:04:32] - Overall Result for Device: /dev/sg1 ****** FAIL ******
是不是我哪里写错了。
