查看: 6871|回复: 6
[网络] CM201-2 刷固件下 TTL 请大家帮忙指点下
发表于 2020-4-12 20:23:59 | 显示全部楼层 |阅读模式
原文
https://www.mydigit.cn/forum.php ... d=139060&extra=
焊接了引脚与用ttl成功连接
但好像进去跟网上有点不一样
请大家帮忙
不按任何按键
Bootrom start
Boot Media: eMMC
Decrypt auxiliary code ...OK
Enter boot auxiliary code
Auxiliary code - v1.00
DDR code - V1.1.2 20160205
Build: Sep  7 2017 - 01:06:39
Reg Version:  v1.5.2`
Reg Time:     2018/02/25 12:35:26
Reg Name:     hi3798mv3dmm_hi3798mv300_DDR3-1866_1GB_16bitx2_4layers_cm_01.reg
Boot auxiliary code success
Bootrom success
System startup
Relocate Boot
Jump to C code
Fastboot 3.3.0 (yangyumei@wangYS) (Mar 27 2018 - 16:25:16)
Fastboot:      Version 3.3.0
Build Date:    Mar 27 2018, 16:27:48
CPU:           Hi3798Mv300
Boot Media:    eMMC
DDR Size:      1GB
Found flash memory controller hifmc100.
no found nand device.
MMC/SD controller initialization.
scan edges:2 p2f:6 f2p:8
mix set temp-phase 3
scan elemnts: startp:104 endp:93
Tuning SampleClock. mix set phase:[03/07] ele:[07/13]
MMC/SD Card:
    MID:         0x15
    Read Block:  512 Bytes
    Write Block: 512 Bytes
    Chip Size:   7456M Bytes (High Capacity)
    Chip Type:   MMC
    Version:     5.1
    Speed:       100000000Hz
    Mode:        HS400
    Voltage:     1.8V
    Bus Width:   8bit
    Boot Addr:   0 Bytes
Net:   upWarning: failed to set MAC address
, gmac0Warning: failed to set MAC address
Boot Env on eMMC
    Env Offset:          0x00400000
    Env Size:            0x00010000
    Env Range:           0x00010000
SDK Version: cmcc_v6r3c01spc012cp0001_patch5
check remote recovery button begin
count=2
mac:00:E4:00:DA:73:BD
Reserve Memory
    Start Addr:          0x3FFFE000
    Bound Addr:          0x8D80000
    Free  Addr:          0x3F1FC000
    Alloc Block:  Addr         Size
                  0x3FBFD000   0x400000
                  0x3F8FC000   0x300000
                  0x3F8F9000   0x2000
                  0x3F878000   0x80000
                  0x3F725000   0x152000
                  0x3F3A0000   0x384000
                  0x3F39C000   0x3000
                  0x3F206000   0x195000
                  0x3F1FC000   0x9000
Press Ctrl+C to stop autoboot
MMC read: dev # 0, block # 327680, count 20480 ... 20480 blocks read: OK
158197618 Bytes/s
Found Initrd at 0x04000000 (Size 344421 Bytes), align at 16384 Bytes
## Booting kernel from Legacy Image at 01ffffc0 ...
   Image Name:   Linux-3.18.24_hi3798mv2x
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    9026176 Bytes = 8.6 MiB
   Load Address: 02000000
   Entry Point:  02000000
   XIP Kernel Image ... OK
OK
ATAGS [0x00000100 - 0x00000480], 896Bytes
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
发表于 2023-9-5 06:57:10 来自手机浏览器 | 显示全部楼层
ysh259 发表于 2020-4-12 20:28
本论坛参考的教程
http://bbs.mydigit.cn/read.php?tid=2634200
刷好了吗,我的盒子ttl显示跟你的一样
发表于 2020-9-18 15:18:19 | 显示全部楼层
刷好了吗?我也是各种办法都试过,不行啊
 楼主| 发表于 2020-4-12 20:28:58 | 显示全部楼层
本论坛参考的教程
没显示root。。
显示的fastboot
也没有文中提到的命令
 楼主| 发表于 2020-4-12 20:26:20 | 显示全部楼层
请问这怎么刷阿
知识盲区阿
现在才知道读书方恨少
 楼主| 发表于 2020-4-12 20:25:25 | 显示全部楼层
命令列表
fastboot# help
?       - alias for 'help'
base    - print or set address offset
bootm   - boot application image from memory
bootp   - boot image via network using BOOTP/TFTP protocol
clear_bootf- clear Hibernate!! bootflag
cmp     - memory compare
cp      - memory copy
crc32   - checksum calculation
ddr     - ddr training function
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls   - list files in a directory (default /)
fdt     - flattened device tree utility commands
getinfo - print hardware information
go      - start application at address 'addr'
help    - print command description/usage
hibernate- Hibernate!! boot
ir      - IR command:
loadb   - load binary file over serial line (kermit mode)
loady   - load binary file over serial line (ymodem mode)
loop    - infinite loop on address range
md      - memory display
mii     - MII utility commands
mm      - memory modify (auto-incrementing address)
mmc     - MMC sub system
mmcinfo - mmcinfo <dev num>-- display MMC info
mtest   - simple RAM read/write test
mw      - memory write (fill)
nand    - NAND sub-system
nboot   - boot from NAND device
nm      - memory modify (constant address)
otp_burntoecurechipset- Burn to secure chipset, please be careful !!!
otp_getcustomerkey- otp_getcustomerkey
otp_getstbprivdata- otp_getstbprivdata
otp_gettrustzonestat- Get TEE status
otp_setstbprivdata- StbPrivData
otpreadall- read otp ,for example otpreadall
otpwrite- write otp ,for example otpwrite adddress value
ping    - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
rarpboot- boot image via network using RARP/TFTP protocol
reset   - Perform RESET of the CPU
saveenv - save environment variables to persistent storage
setenv  - set environment variables
tftp    - tftp  - download or upload image via network using TFTP protocol
unzip   - unzip a memory region
uploadx - upload binary file over serial line (xmodem mode)
usb     - USB sub-system
usbboot - boot from USB device
version - print monitor version
 楼主| 发表于 2020-4-12 20:24:52 | 显示全部楼层
按下ctrl+C
Bootrom start
Boot Media: eMMC
Bootrom success
System startup
Relocate Boot
Jump to C code
CPU:           Hi3798Mv300
Boot Media:    eMMC
DDR Size:      1GB
MMC/SD Card:
    MID:         0x15
    Chip Type:   MMC
    Version:     5.1
    Speed:       100000000Hz
    Mode:        HS400
    Voltage:     1.8V
    Bus Width:   8bit
    Boot Addr:   0 Bytes
Boot Env on eMMC
count=2
Reserve Memory
                  0x3FBFD000   0x400000
                  0x3F8FC000   0x300000
                  0x3F8F9000   0x2000
                  0x3F878000   0x80000
                  0x3F725000   0x152000
                  0x3F3A0000   0x384000
                  0x3F39C000   0x3000
                  0x3F206000   0x195000
                  0x3F1FC000   0x9000
fastboot# <INTERRUPT>
GMT+8, 2025-8-22 03:14 , Processed in 0.140400 second(s), 12 queries , Redis On.
