楼主 |
发表于 2024-8-9 15:59:09
显示全部楼层
Day: ( 9 \ 8 \ 2024) Time: (15:58:26) TesterNumber:1
[ConfigID]
ID=89 D4 0C 32 AA 00-N18
[SN Set]
SN_Set=0
SN_Type=3
SN_Len=12
SN_Start=PS3111PS3111
SN_End=PS3111PS3111
SN_Mask=PS3111PS3111
[Other]
SATA_SSC_Enable=0
[StationName]
01=EraseAll
02=RDT
03=RDTResult
04=MP
05=ReMP
06=ICT
07=UpdateFW
08=ScanBad
[InfoBlock_2]
Byte_290=E8
Byte_291=03
Byte_222=08
[General Info]
TestStationSel=3
TestStation=F1
WorkingNo=PS3111
ModelName=PS3111
SerialNum=PS3111PS3111
MaxCurrent=400
[Flash Info]
Flh_Type=QLC
Flh_MakeCode=Intel
Flh_ID=89 d4 0c 32 aa 00
Flh_Capacity=557056
Flh_CapacitySel=35
Flh_Number=4
Flh_NumberSel=4
Flash Clock=100
Flash Interface=3
[Device Info]
SATASpeed=3
ControllerType=SSD-3111SB
ICFWVersion=SBFGK1.3
3111SBISP_CodeVersion=GK1.3
3111SBISP_MPBINCode=.\Bin\SBFGK1.3.BIN
3111SBISP_RDTBINCode=.\Bin\SBSCK1.2.BIN
SSD Size=2.5"
[Options]
DDRSize=32
Enable_Set_Custom_SMART_Temperature=0
Smart_Table=0
SLCPoolSizeSel=1
SLCPoolSize=0
Disable_DIPM_Support=1
Put_Thermal_Sensor=0
Skip_Check_RDDebugPage=1
PretestType=0
PMASetting=42035
[InfoBlock]
Byte_136=00
Byte_137=00
Byte_138=40
Byte_139=00
Byte_203=01
[EraseAll]
Do_Erase_First=1
Type=01
[Log]
[ Success ] Modify InfoBlock OK.
[ Success ] AES VUC Process OK.
[ Info ] MP AP: V2.06_x02(China), MAC Address: , ISP FW: SBFGK1.3.BIN, Station:F1T
[ Success ] Check Device State OK.
[ Success ] Check IO State OK- Total take 0.000 sec.
[ Success ] Check ICVer. OK.
[ Success ] Verify param.ini with Device Info OK.
Start Scan Bad Block Progress ...
Die Size = 128 GB
(FW)Max_badblock_perplane = 49 (Setting)Max_badblock_perplane = 0
Get Max Bad block number per Plane= 49
FlashNumber=4, MaxBad_perPlane/Die=49
CENo_0/Die_0-> Early Bad Count: Plane0=8, Plane1=8, Plane2=3, Plane3=7
CENo_4/Die_0-> Early Bad Count: Plane0=4, Plane1=5, Plane2=3, Plane3=4
CENo_8/Die_0-> Early Bad Count: Plane0=5, Plane1=7, Plane2=2, Plane3=5
CENo_12/Die_0-> Early Bad Count: Plane0=5, Plane1=8, Plane2=4, Plane3=6
[ Success ] Scan Bad Process OK.
Do PreFormat:
Smart_Table = 0
- Total take 0.442 sec.
[ Fail ] Error Message : Issue PreFormat-WriteInfoBlock Command Failed !!!
Error Code : F_H07
AP Command : [a1]-[a]-[6]-[8]-[2]-[0]-[10]-[2]-[a0]-[31]-[0]-[0]
OS LastError : [ 0 ]
ATA Reg:[4][2][12][1][7][51]
[ Error End ] Time: (15:58:32)
Fail Mapping : 0000000000000100 Fail CE: 8,CE0,CE8,CE9,CE10, CE=0x01, Error Case=0x00
