查看: 11756|回复: 54
[C51] 12864 WIFI 全彩led点阵滚动时钟
发表于 2019-12-13 23:23:15 | 显示全部楼层 |阅读模式
最近用STC15W4K单片机做了一个全彩12864 WIFI时钟 温湿度,35MHZ刷新率53HZ~56HZ
WIFI模块  ESP8266 网页修改WIFI账号密码 一次修改 永久使用
模块化编程   带模块化菜单功能功能演示
https://v.youku.com/v_show/id_XNDM4NjI0Mzg0OA==.html?spm=a2hbt.13141534.app.5~5~5!2~5~5~5!2~5~5!2~5!2~5!2~5~5~A
大数字时钟
https://v.youku.com/v_show/id_XNDM4NjIzODEzMg==.html?spm=a2hbt.13141534.app.5~5~5!2~5~5~5!2~5~5!2~5!2~5!2~5~5!2~A
模拟时钟
https://v.youku.com/v_show/id_XNDM4NjI0MDM5Ng==.html?spm=a2hbt.13141534.app.5~5~5!2~5~5~5!2~5~5!2~5!2~5!2~5~5!3~A
多字体翻页时钟
https://v.youku.com/v_show/id_XNDM4NjIzNTc3Ng==.html?spm=a2hbt.13141534.app.5~5~5!2~5~5~5!2~5~5!2~5!2~5!2~5~5!4~A
菜单功能程序
unsigned char ProjectName[]="Menu System";   //项目名称
char Menu_index = 1;        //菜单显示与正常显示标识
char        xdata        DisplayStart  = 0;                              //显示菜单的开始位置
char         xdata        UserChoose    = 0;                                    //用户的选择
char         xdata        DisplayPoint  = 0;                                    //显示菜单的编号
char         xdata        MaxItems      = 0;                             //菜单的数量
char         xdata        Option                    = 0;           //保存用户的菜单编号
void NULL_Function(void)                                                 //空函数
void Exit();
//二级菜单
struct         MenuItem code        SysTemSet[8];              //这里不声明一下,MainMenu里不能引用
//*目录结构体定义
struct         MenuItem                                           //结构体名称
{                 unsigned char         MenuCount;                          //当前层节点数、每层菜单能显示的条目数
            unsigned char         *DisplayString;              //指向菜单标题的字符串
            unsigned char         (*Subs)();                   //指向当前状态应该执行的功能函数
            struct MenuItem         *ChildrenMenus;                    //指向当前菜单的下级菜单
            struct MenuItem         *ParentMenus;                      //指向当前菜单的上级菜单
}                MENU_NULL;
struct        MenuItem code MainMenu[4] =      //结构体主菜单
                {4,"SYSTEM SET",&NULL_Function,&SysTemSet,&MENU_NULL},
                {4,"Clock Mode",&Clock_mode_selection,&MENU_NULL,&MENU_NULL},
                {4,"Serial Port",&Uart1,&MENU_NULL,&MENU_NULL},
                {4,"About",&About,&MENU_NULL,&MENU_NULL},
WIFI模块  ESP8266部分程序
uart.setup(1, 9600, 8, uart.PARITY_NONE, uart.STOPBITS_1, 1)
print("ESP8266 WIFI time service system")
print("TX0:115200 TX   TX1:9600 D4")
--mytimer =  tmr.create()
    --mytimer1:alarm(1000, tmr.ALARM_SINGLE, function()
mytimer:alarm(10000, tmr.ALARM_SEMI, function()
--mytimer1:alarm(5000, tmr.ALARM_AUTO, function()
mytimer:start()
   if wifi.sta.getip() ~= nil then
       sntp.sync({"ntp1.aliyun.com","ntp.ntsc.ac.cn","ntp2.aliyun.com"},
         function(sec, usec, server, info)
         --print('sync', sec, usec, server,info)
          gpio.write(0, gpio.LOW)
         secs = rtctime.get()
         secs = secs + 8*3600
         time = rtctime.epoch2cal(secs)
         uart.write(1,string.format("@#%04d/%02d/%02d %02d:%02d:%02d %03d %01d",
                             time["year"],
                             time["mon"],
                             time["day"],
                             time["hour"],
                             time["min"],
                             time["sec"],
                             time["yday"],
                             time["wday"]))
         print(string.format("@#%04d/%02d/%02d %02d:%02d:%02d %03d %01d",
                             time["year"],
                             time["mon"],
                             time["day"],
                             time["hour"],
                             time["min"],
                             time["sec"],
                             time["yday"],
                             time["wday"]))
         gpio.write(0, gpio.HIGH)
       end,
       function()
        print('failed!')
       end)
      end
   end)
补充内容 (2019-12-16 11:19):
网盘链接
链接:https://pan.baidu.com/s/1ayHAhhfNTP96Dy321FVDYQ
提取码:zspz
参与人数 4家元 +100 收起 理由
慕名而来 + 20 原創內容
人艰不拆了 + 10
维超 + 20 謝謝分享
家睦 + 50
发表于 2019-12-14 07:47:23 | 显示全部楼层
发表于 2019-12-14 08:35:53 | 显示全部楼层
参与人数 1家元 +12 收起 理由
lxa0 + 12 同感!
发表于 2019-12-14 08:52:54 | 显示全部楼层
参与人数 1家元 +12 收起 理由
lxa0 + 12 同感!
发表于 2019-12-14 09:47:31 | 显示全部楼层
 楼主| 发表于 2019-12-14 09:54:36 | 显示全部楼层
 楼主| 发表于 2019-12-14 09:57:19 | 显示全部楼层
 楼主| 发表于 2019-12-14 10:59:58 | 显示全部楼层
发表于 2019-12-14 11:42:18 来自手机浏览器 | 显示全部楼层
发表于 2019-12-14 11:57:44 | 显示全部楼层
发表于 2019-12-14 13:05:55 | 显示全部楼层
 楼主| 发表于 2019-12-14 13:20:52 | 显示全部楼层
回复 支持 0 反对 1
 楼主| 发表于 2019-12-14 13:22:07 | 显示全部楼层
 楼主| 发表于 2019-12-14 13:36:43 | 显示全部楼层
发表于 2019-12-14 15:25:31 来自手机浏览器 | 显示全部楼层
发表于 2019-12-14 16:10:20 | 显示全部楼层
发表于 2019-12-14 16:29:47 | 显示全部楼层
发表于 2019-12-14 16:41:47 | 显示全部楼层
发表于 2019-12-15 11:33:15 | 显示全部楼层
发表于 2019-12-16 09:50:48 | 显示全部楼层
GMT+8, 2026-10-17 20:39 , Processed in 0.234001 second(s), 12 queries , Gzip On, Redis On.
