Intel520240G突然掉盘了,BIOS不认,开卡也出错,哪位大神给点指导呀,谢谢了!
[root@localhost SF_Genesis-v1.7]# ./SF_Genesis -PROCESS_SSD 67:0:0:0 /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22073.12345.new.driveconfig 12345 www_123 log=/log/
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Tue 12/04/2018 01:32:24] - SF_Genesis has been invoked with the following parameters:
argv[1]: -PROCESS_SSD
argv[2]: 67:0:0:0
argv[3]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
argv[4]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22073.12345.new.driveconfig
argv[5]: 12345
argv[6]: www_123
argv[7]: log=/log/
[Tue 12/04/2018 01:32:24] - Instructing the operating system to purge any existing cached data for device: '67:0:0:0'
[Tue 12/04/2018 01:32:29] - Issuing a discovery command for device: '67:0:0:0'
[Tue 12/04/2018 01:32:34] - Discovery command completed...
[Tue 12/04/2018 01:32:34] - Waiting 5 seconds for the system to settle...
[Tue 12/04/2018 01:32:39] - Device designation string '67:0:0:0' is mapped to node '/dev/sg2'
[Tue 12/04/2018 01:32:39] - Proceeding to process SSD device with the following parameters:
DeviceName = /dev/sg2
MFP Package Filename = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
Configuration File = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22073.12345.new.driveconfig
Serial No. = 12345
World Wide Name = www_123
[Tue 12/04/2018 01:32:44] - Successfully received the IDENTIFY data from the drive...
[Tue 12/04/2018 01:32:44] - Validating Manufacturing Firmware Package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Tue 12/04/2018 01:32:44] - Successfully opened the package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Tue 12/04/2018 01:32:44] - file /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22073.12345.new.driveconfig Loaded successfully
[Tue 12/04/2018 01:33:42] - Warning: Unable to query diagnostics information to perform power management settings check
[Tue 12/04/2018 01:33:42] - B01 Power Management configuration request detected
[Tue 12/04/2018 01:33:42] - Successfully extracted *.DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22073.12345.new.driveconfig
[Tue 12/04/2018 01:33:42] - Extracted Config_ID: 1 (22073) in DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22073.12345.new.driveconfig
[Tue 12/04/2018 01:33:42] - Extracted SerialOutputControl: 0
[Tue 12/04/2018 01:33:42] - Searching for flashware image for configuration 22073
[Tue 12/04/2018 01:33:42] - Manifest found for configuration 22073
[Tue 12/04/2018 01:33:42] - Flashware image extracted: 22073_fw_cl_ccmlc_Intel_64Gb_JS29F32B08JCME2_2Q_4C_1D_S_PP_R00490_s512.vic
[Tue 12/04/2018 01:33:42] - Searching for manufacturing image for configuration 22073
[Tue 12/04/2018 01:33:42] - Manufacturing image extracted: 22073_mf_ccmlc_Intel_64Gb_JS29F32B08JCME2_2Q_4C_1D_S_PP_R00490_s512.vic
[Tue 12/04/2018 01:33:42] - Proceeding in non-ROM mode, Download feature 3...
[Tue 12/04/2018 01:34:08] - Successfully downloaded MFB to the drive...
[Tue 12/04/2018 01:34:08] - Waiting (5 sec) for the drive to settle...
[Tue 12/04/2018 01:34:18] - Successfully received the IDENTIFY data from the drive...
[Tue 12/04/2018 01:34:18] - FATAL_ERROR: Did not recieve the correct firmware revision. it is reported to be: ' S V', indicating MFB download has failed.
[Tue 12/04/2018 01:34:18] - End of Genesis manufacturing log.
[Tue 12/04/2018 01:34:18] - Exiting...
[Tue 12/04/2018 01:34:18] - Overall Result for Device: /dev/sg2 ****** FAIL ******
