查看: 3795|回复: 5
[SandForce] SM2241开卡求助
发表于 2020-6-22 23:00:52 | 显示全部楼层 |阅读模式
ADATA SP900 搬板开卡失败 请问FLASH编号1234是怎么对应的?
开卡失败记录如下.我是应该拆掉FLASH 4 还是补焊? 3片的话能开吗?
给二奶机做系统用,不存资料。
[root@localhost SF_Genesis-v1.7]# ./2281 -PROCESS_SSD 2:0:0:0 /root/Desktop/sf2281/60A/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp /root/Desktop/sf2281/60A/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/31039.12345.driveconfig 2F4620061732 5707C181001FC553 log=/root/Desktop/sf2281/60A
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Tue 06/23/2020 06:32:20] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 2:0:0:0
                      argv[3]: /root/Desktop/sf2281/60A/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
                      argv[4]: /root/Desktop/sf2281/60A/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/31039.12345.driveconfig
                      argv[5]: 2F4620061732
                      argv[6]: 5707C181001FC553
                      argv[7]: log=/root/Desktop/sf2281/60A
[Tue 06/23/2020 06:32:20] - Instructing the operating system to purge any existing cached data for device: '2:0:0:0'
[Tue 06/23/2020 06:32:25] - Issuing a discovery command for device: '2:0:0:0'
[Tue 06/23/2020 06:32:31] - Discovery command completed...
[Tue 06/23/2020 06:32:31] - Waiting 5 seconds for the system to settle...
[Tue 06/23/2020 06:32:36] - Device designation string '2:0:0:0' is mapped to node '/dev/sg1'
[Tue 06/23/2020 06:32:36] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg1
    MFP Package Filename = /root/Desktop/sf2281/60A/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
      Configuration File = /root/Desktop/sf2281/60A/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/31039.12345.driveconfig
              Serial No. = 2F4620061732
         World Wide Name = 5707C181001FC553
[Tue 06/23/2020 06:32:36] - Successfully received the IDENTIFY data from the drive...
[Tue 06/23/2020 06:32:36] - Validating Manufacturing Firmware Package: /root/Desktop/sf2281/60A/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Tue 06/23/2020 06:32:36] - Successfully opened the package: /root/Desktop/sf2281/60A/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Tue 06/23/2020 06:32:36] - file  /root/Desktop/sf2281/60A/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/31039.12345.driveconfig Loaded successfully
[Tue 06/23/2020 06:32:36] - Warning:  Unable to query diagnostics information to perform power management settings check
[Tue 06/23/2020 06:32:36] - B01 Power Management configuration request detected
[Tue 06/23/2020 06:32:36] - Successfully extracted *.DriveConfig file: /root/Desktop/sf2281/60A/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/31039.12345.driveconfig
[Tue 06/23/2020 06:32:36] - Extracted Config_ID: 1 (31039) in DriveConfig file: /root/Desktop/sf2281/60A/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/31039.12345.driveconfig
[Tue 06/23/2020 06:32:36] - Extracted SerialOutputControl: 0
[Tue 06/23/2020 06:32:36] - Searching for flashware image for configuration 31039
[Tue 06/23/2020 06:32:36] - Manifest found for configuration 31039
[Tue 06/23/2020 06:32:36] - Flashware image extracted: 31039_fw_cl_mlc_Micron_128Gb_33bit_MT29F128G08CBECB_1Q_1C_1D_PP_R02897_s512.vic
[Tue 06/23/2020 06:32:36] - Searching for manufacturing image for configuration 31039
[Tue 06/23/2020 06:32:36] - Manufacturing image extracted: 31039_mf_mlc_Micron_128Gb_33bit_MT29F128G08CBECB_1Q_1C_1D_PP_R02897_s512.vic
[Tue 06/23/2020 06:32:36] - Proceeding in ROM mode, download feature 3...
[Tue 06/23/2020 06:32:37] - Successfully downloaded MFB to the drive...
[Tue 06/23/2020 06:32:37] - Waiting (5 sec) for the drive to settle...
[Tue 06/23/2020 06:32:42] - Successfully received the IDENTIFY data from the drive...
[Tue 06/23/2020 06:32:42] - Firmware revision reported to be: '60AABBM0'.  This indicates MFB download was successful.
[Tue 06/23/2020 06:32:42] - Successfully enabled SMART capabilities...
[Tue 06/23/2020 06:32:44] - Successfully issued a diagnostic unlock...
[Tue 06/23/2020 06:32:45] - Performing the flash test of block 0 (0x0000)...
[Tue 06/23/2020 06:32:46] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 1
        Chip Enabled Count: 1
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
  Total Number of test results: 4
            Number of failures: 1
         Number of Passed with warnings: 0
      No. Passed without warnings: 3
[Tue 06/23/2020 06:32:46] - End of Genesis manufacturing log.
[Tue 06/23/2020 06:32:46] - Exiting...
[Tue 06/23/2020 06:32:46] - Overall Result for Device: /dev/sg1 ****** FAIL ******
发表于 2020-6-23 21:29:46 | 显示全部楼层
这个应该是sf2241主控吧
 楼主| 发表于 2020-6-23 21:35:30 | 显示全部楼层
zhao6866933 发表于 2020-6-23 21:29
这个应该是sf2241主控吧
是的 SF2241
发表于 2020-6-24 08:09:19 | 显示全部楼层
图中左边看第一片
发表于 2020-6-25 15:45:06 | 显示全部楼层
主要考虑连锡问题
发表于 2020-8-24 17:23:11 | 显示全部楼层
0x0374 | N4,N5,N6,N8,N10         这代表什么意思呢,按前面解释是n8和n10是plane0和1的坏块超过限制,那4,6,8,10一起组合代表啥?
GMT+8, 2025-7-26 21:57 , Processed in 0.296400 second(s), 11 queries , Redis On.
