查看: 5872|回复: 6
求助:MIUI TV 微投 ROOT
发表于 2021-2-5 22:17:34 | 显示全部楼层 |阅读模式
各位大神好!
我有一台便携LED投影仪,系统是MIUI TV1.3.67. 现在想ROOT系统,去广告。
已拆机,接好TTL线。 现在碰到的问题是日志打印完毕,不能输入命令。见下面日志:
Me2 不能进入命令:
接TTL后通电开机,直到所有日志打印完毕 ,不能输入任务命令,
如下打印日志:
GXTVBB:BL1:ee57c+:7a1241;FEAT:EDFC318C;POC:3;RCY:0;EMMC:0;READ:0;CHK:0;
no sdio debug board detected
TE: 68146
BL2 Built : 17:57:38, Apr  1 2016.
gxtvbb gb30adc1 - xiaobo.gu@droid05
bbcykyo run in pwm_init
bbcykyo run in pwm_a_1 init finish
bbcykyo run in pwm_d init finish
set vcck to 1100 mv
bbcykyo pwm_set_voltage
set vddee to 1100 mv pwm_d
set vddee to  mv
set AO 2/4 low,3/5 high
set AO 10 input
Board ID = 12
CPU clk: 1536MHz
DDR channel: DDR0+1 two channel @ 720MHz
DDR0: 1024MB-2T-11
DDR1: 1024MB-2T-11
DataBus test pass!
AddrBus test pass!
-s
Load fip header from eMMC, src: 0x0000c000, des: 0x01400000, size: 0x00004000
Load bl30 from eMMC, src: 0x00010000, des: 0x01000000, size: 0x0000d460
Sending bl30......................................................OK.
Run bl30...
Load bl31 from eMMC, src: 0x00020000, des: 0x101b0000, size: 0x00013140
l30: check_permit, count is 1
bl30: check_permit: ok!
efuse_pw_en: 0x3
Load bl33 from eMMC, src: 0x00034000, des: 0x01000000, size: 0x000f1310
[Image: gxtvb_v1.1.3109-f651ed3 2016-05-05 19:38:44 xing.xu@droid05]
efuse_setup() 223: OPS=0x12
bl30: check_permit, count is 1
chipid: ef be ad de d f0 ad ba ef be ad de not ES chip
[0.210922 Inits done]
secure task start!
high task start!
low task start!
low task NOTICE:  BL3-1: v1.0(debug):d1ef098
NOTICE:  BL3-1: Built : 10:34:39, Mar 22 2016
INFO:    BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x1000000
INFO:    BL3-1: Next image spsr = 0x3c9
U-Boot 2015.01-g12a85c2 (Mar 20 2018 - 11:39:29), Build: jenkins-Me2_release-415
DRAM:  2 GiB
Relocation Offset is: 76e81000
register usb cfg[0][1] = 0000000077f62fd0
aml_i2c_init g_aml_i2c_plat_num: 1
aml_i2c_init 1 init.
===========power on turn off led light=====
set A06 to high
set A011 to high
###### bbcykyo reset c788 #####gpio: pin GPIOAO_5 (gpio 127) value is 1
gpio: pin GPIOAO_13 (gpio 135) value is 0
gpio: pin GPIOY_2 (gpio 34) value is 1
gpio: pin GPIOZ_13 (gpio 86) value is 1
gpio: pin GPIOZ_14 (gpio 87) value is 1
MMC:   aml_priv->desc_buf = 0x0000000073e81f40
aml_priv->desc_buf = 0x0000000073e83f50
SDIO Port B: 0, SDIO Port C: 1
emmc/sd response timeout, cmd8, status=0x3ff2800
emmc/sd response timeout, cmd55, status=0x3ff2800
[mmc_init] mmc init success
mmc read lba=0x14000, blocks=0x400
      Amlogic multi-dtb tool
      Single dtb detected
start dts,buffer=0000000073e86630,dt_addr=0000000073e86630
parts: 14
00:      logo   0000000000400000 1
01:  recovery   0000000001000000 1
02:     param   0000000002000000 2
03:     crypt   0000000001000000 1
04:      misc   0000000001000000 1
05:      boot   0000000001400000 1
06:    system   0000000040000000 1
07:     cache   0000000010000000 2
08:  cri_data   0000000000800000 2
09:    tvinfo   0000000000a00000 4
10:     panic   0000000000400000 4
11:   persist   0000000000800000 4
12:    backup   0000000024000000 4
13:      data   ffffffffffffffff 4
get_dtb_struct: Get emmc dtb OK!
overide_emmc_partition_table: overide cache
[mmc_get_partition_table] skip partition cache.
Partition table get from SPL is :
        name                        offset              size              flag
   0: bootloader                         0            400000                  0
   1: reserved                     2400000           4000000                  0
   2: cache                        6c00000          10000000                  2
   3: env                         17400000            800000                  0
   4: logo                        18400000            400000                  1
   5: recovery                    19000000           1000000                  1
   6: param                       1a800000           2000000                  2
   7: crypt                       1d000000           1000000                  1
   8: misc                        1e800000           1000000                  1
   9: boot                        20000000           1400000                  1
  10: system                      21c00000          40000000                  1
  11: cri_data                    62400000            800000                  2
  12: tvinfo                      63400000            a00000                  4
  13: panic                       64600000            400000                  4
  14: persist                     65200000            800000                  4
  15: backup                      66200000          24000000                  4
  16: data                        8aa00000         320a00000                  4
mmc read lba=0x12000, blocks=0x2
mmc read lba=0x12002, blocks=0x2
mmc_read_partition_tbl: mmc read partition OK!
eMMC/TSD partition table have been checked OK!
mmc env offset: 0x17400000
In:    serial
Out:   serial
Err:   serial
##env version is V1.1.16
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
read emmc dtb
      Single dtb detected
vpu: clk_level in dts: 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
hardware_version: 0
panel_detect: panel_id = 0, panel_type = lvds_0
Saving Environment to aml-storage...
Writing to MMC(1)... done
lcd: no lcd_debug_print flag
lcd: no lcd_debug_test flag
lcd: detect mode: tv, key_valid: 0
lcd: load config from dts
lcd: use panel_type=lvds_0
lcd: set phy vswing=3, preemphasis=0
lcd: bl: status disabled
lcd: bl: name: default, method: 5
vpp: vpp_init
### batteryout =disable
### set GPIOAO_13 low
Net:
set A06 to high
set A011 to high
###### bbcykyo reset c788 #####No ethernet found.
efuse_pw_en: 0x3
WARNING! efuse bits is disabled
Enable A53 JTAG to EE
wipe_data=successful
wipe_cache=successful
upgrade_step=2
[OSD]load fb addr from dts
[OSD]fb_addr for logo: 0x3d851000
[CANVAS]addr=0x3d851000 width=3840, height=2160
lcd: enable: OPD30, lvds, 1920x1080@60.0Hz
lcd: tv driver init(ver: 20170810)
lcd: lcd_pll_wait_lock: pll_lock=1, wait_loop=1
lcd: set pll spread spectrum: 2, +/-0.5%
amlkey_init() enter!
[EFUSE_MSG]keynum is 4
[KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[mac] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet
gpio: pin GPIOAO_3 (gpio 125) value is 1
(Re)start USB...
USB0:   USB3.0 XHCI init start
Register 5000140 NbrPorts 5
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
** Bad device usb 0 **
InUsbBurn
[MSG]sof
Set Addr 7
Get DT cfg
Get DT cfg
Get DT cfg
set CFG
waitIdentifyTime(751) > timeout(750)
enter_systemoff
start down_fw_bcm
gpio: pin GPIOX_17 (gpio 111) value is 0
gpio: pin GPIOX_17 (gpio 111) value is 1
change module baud rate to: 2000000
try change host baud rate to: 2000000
try change host baud rate to: 115200
down_fw_bcm ok
INFO:    PSCI Affinity Map:
INFO:      AffInst: Level 0, MPID 0x0, State ON
INFO:      AffInst: Level 0, MPID 0x1, State OFF
INFO:      AffInst: Level 0, MPID 0x2, State OFF
INFO:      AffInst: Level 0, MPID 0x3, State OFF
bl31 reboot reason: 0x101
system cmd  0.
process command 00000006
bl30 enter suspend!
store restore gp0 pll
cpu clk suspend rate 1536000000
process command 00000001
power_off_projon
enter detect key
08915c0000000000host_wake enter high
exit_reason:0x04
cfg15 3b00000
cfg15 43b00000
TE: 68145
set vcck to 1100 mv
set vddee to  mv
set AO 10 input
Board ID = 12
CPU clk: 1536MHz
DDR0: 1024MB-2T-11
DDR1: 1024MB-2T-11
DataBus test pass!
AddrBus test pass!
-s
Run bl30...
Load bl31 from eMMC, src: 0x00020000, des: 0x1010b000, size: 0x00013140
efuse_pw_en: 0x3
secure task start!
high task start!
low task start!
DRAM:  2 GiB
set A06 to high
set A011 to high
      Single dtb detected
parts: 14
In:    serial
Out:   serial
Err:   serial
read emmc dtb
      Single dtb detected
hardware_version: 0
vpp: vpp_init
Net:
set A06 to high
set A011 to high
efuse_pw_en: 0x3
upgrade_step=2
gpio: pin GPIOAO_13 (gpio 135) value is 1
spicc: sys_clk=167000000, div=5
*******c788 init start************
start initializing c788!
##### ifh=2199,ifv=1125
B10_DDR3OCDDOP = 0x1E
B10_DDR3OCDDON = 0x1D
##set_projector_source write 0x05 0------
##set led enable write 0x01b 7------
*******c788 init end************
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
ee_gate_off ...
## Booting Android Image at 0x01080000 ...
reloc_addr =73f06880
copy done
      Single dtb detected
load dtb from 0x1000000 ......
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x01080000, end = 0x021a5460
   Loading Ramdisk to 73dc5000, end 73e6ef9d ... OK
   Loading Device Tree to 000000001ffef000, end 000000001ffff7a0 ... OK
fdt_instaboot: no instaboot image
Starting kernel ...
 楼主| 发表于 2021-2-5 22:19:02 | 显示全部楼层
uboot time: 3145015 us
[    0.000000@0] Initializing cgroup subsys cpu
[    0.000000@0] Initializing cgroup subsys cpuacct
[    0.000000@0] Linux version 3.14.29-301837-g757fff5 (jenkins@c3-mitv-bsp-build03.bj) (gcc version 4.9.2 20140904 (prerelease) (crosstool-NG linaro-1.13.1-4.9-2014.09 - Linaro GCC 4.9-2014.09) ) #1 SMP PREEMPT Tue Mar 20 11:44:37 CST 2018
[    0.000000@0] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000@0] no prop version_code
[    0.000000@0] bootconsole [earlycon0] enabled
[    0.000000@0] fdt Reserved memory table:
[    0.000000@0]                  linux,di: 0x0000000078d00000 - 0x000000007c000000  (51 MiB)
[    0.000000@0] DI: DI reserved memory: created CMA memory pool at 0x0000000078d00000, size 51 MiB
[    0.000000@0]               linux,demod: 0x0000000078700000 - 0x0000000078d00000  (6 MiB)
[    0.000000@0]               linux,ppmgr: 0x0000000078700000 - 0x0000000078700000  (0 MiB)
[    0.000000@0]        linux,codec_mm_cma: 0x0000000067c00000 - 0x0000000073c00000  (192 MiB)
[    0.000000@0] cma: cma_init_reserved_mem: base_pfn 67c00 count 49152 normal 71c00
[    0.000000@0]   linux,codec_mm_reserved: 0x0000000074600000 - 0x0000000078700000  (65 MiB)
[    0.000000@0]           linux,vdin1_cma: 0x0000000066800000 - 0x0000000067c00000  (20 MiB)
[    0.000000@0] cma: cma_init_reserved_mem: base_pfn 66800 count 5120 normal 67c00
[    0.000000@0] fdt Reserved memory total:  401 MiB
[    0.000000@0] cma: cma_init_reserved_mem: base_pfn 65800 count 4096 normal 66800
[    0.000000@0] cma: Reserved 16 MiB at 65800000
[    0.000000@0] psci: probing function IDs from device-tree
[    0.000000@0] PERCPU: Embedded 12 pages/cpu @ffffffc074597000 s19392 r8192 d21568 u49152
[    0.000000@0] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 512312
[    0.000000@0] Kernel command line: rootfstype=ramfs init=/init console=ttyS0,115200 no_console_suspend earlyprintk=aml-uart,0xc81004c0 androidboot.selinux=disabled logo=osd1,loaded,0x3b000000 vout=1080p60hz,enable panel_type=lvds_0 hdmitx= osd_reverse=n video_reverse=n jtag=apao ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 androidboot.firstboot=0 display_orient= androidboot.hardware=amlogic ???w androidboot.panel_type=0 androidboot.mi.panel_size=120 androidboot.mi.panel_vendor=GF androidboot.mi.panel_resolution=1920x1080 androidboot.mi.panel_buildin=true androidboot.mi.panel_3d_attribute=1 androidboot.hardware_version=0 androidboot.console_enable= aux_codec= androidboot.btmac=10:d0:7a:12:42:33 display_brightness=200
[    0.000000@0] logo: osd1
[    0.000000@0] logo: loaded
[    0.000000@0] logo: 0x3b000000
[    0.000000@0] vout_serve: 1080p60hz
[    0.000000@0] vout_serve: enable: 1
[    0.000000@0] lcd: panel_type: lvds_0
[    0.000000@0] codec:vpp_axis_reverse: bootargs is n
[    0.000000@0] jtag: apao
[    0.000000@0] display_orient_setup 0
[    0.000000@0] display_brightness_setup 200
[    0.000000@0] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000@0] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000@0] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000@0] Memory: 1598836K/2077696K available (11024K kernel code, 1197K rwdata, 4124K rodata, 1202K init, 4405K bss, 478860K reserved)
[    0.000000@0] Virtual kernel memory layout:
[    0.000000@0]     vmalloc : 0xffffff8000000000 - 0xffffff807fff0000   (  2047 MB)
[    0.000000@0]     vmemmap : 0xffffff8080000000 - 0xffffff8081c00000   (    28 MB)
[    0.000000@0]     modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
[    0.000000@0]     memory  : 0xffffffc000000000 - 0xffffffc080000000   (  2048 MB)
[    0.000000@0]       .init : 0xffffffc001f4d000 - 0xffffffc002079bc0   (  1203 kB)
[    0.000000@0]       .text : 0xffffffc001080000 - 0xffffffc001f4c274   ( 15153 kB)
[    0.000000@0]       .data : 0xffffffc00207a000 - 0xffffffc0021a5460   (  1198 kB)
[    0.000000@0] PM: Registered nosave memory: [mem 0x01080000-0x01f4bfff]
[    0.000000@0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000@0] Preemptible hierarchical RCU implementation.
[    0.000000@0]        RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000@0] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000@0] NR_IRQS:64 nr_irqs:64 0
[    0.000000@0] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000003@0] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 2863311519744ns
[    0.008492@0] Console: colour dummy device 80x25
[    0.012870@0] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.023448@0] pid_max: default: 32768 minimum: 301
[    0.028324@0] Security Framework initialized
[    0.032561@0] SELinux:  Initializing.
[    0.036297@0] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.043143@0] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.056323@0] Initializing cgroup subsys debug
[    0.056359@0] Initializing cgroup subsys freezer
[    0.059863@0] ftrace: allocating 37981 entries in 149 pages
[    0.101191@0] /cpus/cpu@0: Missing clock-frequency property
[    0.101232@0] /cpus/cpu@1: Missing clock-frequency property
[    0.106812@0] /cpus/cpu@2: Missing clock-frequency property
[    0.112434@0] /cpus/cpu@3: Missing clock-frequency property
[    0.118013@0] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[    0.166384@0] ftrace: Allocated trace_printk buffers
[    0.168317@0] Meson chip version = RevB (20:B - 12:0)
[    0.186819@1] CPU1: Booted secondary processor
[    0.206803@2] CPU2: Booted secondary processor
[    0.226803@3] CPU3: Booted secondary processor
[    0.226862@0] Brought up 4 CPUs
[    0.237824@0] SMP: Total of 4 processors activated.
[    0.243252@0] devtmpfs: initialized
[    0.254414@0] instabooting: 0
[    0.261001@0] cma: cma_activate_area(): 0x67c00-0x73c00 count: 49152 normal: 71c00
[    0.263304@0] cma: cma_activate_area(): 0x66800-0x67c00 count: 5120 normal: 67c00
[    0.270822@0] cma: cma_activate_area(): 0x65800-0x66800 count: 4096 normal: 66800
[    0.278149@0] pinctrl core: initialized pinctrl subsystem
[    0.284072@0] regulator-dummy: no parameters
[    0.288451@0] NET: Registered protocol family 16
[    0.294949@0] ramoops: using module parameters
[    0.297345@0] console [pstore-1] enabled
[    0.300832@0] pstore: Registered ramoops as persistent store backend
[    0.307232@0] ramoops: attached 0x100000@0x7300000, ecc: 0/0
[    0.313815@0] aml_vdac_init: module init
[    0.316978@0] register canvas platform driver
[    0.321297@0] register rdma platform driver
[    0.327749@0] vdso: 2 pages (1 code, 1 data) at base ffffffc002084000
[    0.331931@0] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.339014@0] DMA: preallocated 256 KiB pool for atomic allocations
[    0.346417@0] software IO TLB [mem 0x62800000-0x62c00000] (4MB) mapped at [ffffffc062800000-ffffffc062bfffff]
[    0.355170@0] Serial: AMBA PL011 UART driver
[    0.359851@0] aml_i2c version: 20140813
[    0.363494@0] i2c-core: driver [pmu4] using legacy resume method
[    0.369481@0] codec_mm:codec_mm_module_init
[    0.373612@0] c788_init enter
[    0.376702@0] aml_watch_point_probe, in
[    0.380718@0] gxbb_mpll_clk: register mpll_clk_out0 success done
[    0.386410@0] gxbb_mpll_clk: register mpll_clk_out1 success done
[    0.392455@0] gxbb_mpll_clk: register mpll_clk_out2 success done
[    0.398687@0] clk_sys: register PLL sys_pll success done
[    0.403865@0] clkrate [ xtal         ] : 24000000Hz
[    0.408107@0] clkrate [ 32Khz        ] : 32000Hz
[    0.412221@0] clkrate [ clk81        ] : 166666666Hz
[    0.416689@0] clkrate [ fixed_pll    ] : 2000000000Hz
[    0.421582@0] clkrate [ fclk_div2    ] : 1000000000Hz
[    0.426482@0] clkrate [ fclk_div3    ] : 666666000Hz
[    0.431301@0] clkrate [ fclk_div4    ] : 500000000Hz
[    0.436107@0] clkrate [ fclk_div5    ] : 400000000Hz
[    0.440923@0] clkrate [ fclk_div7    ] : 285714000Hz
[    0.445760@0] gxbbtv clock initialization complete
[    0.450725@0] clkmsr: msr_clk_reg0=ffffff800002e75c,msr_clk_reg2=ffffff800003a764 msr_clk_reg2=ffffff800003c15c
[    0.462711@0] aml_iomap: amlogic iomap probe done
[    0.465712@0] pinmux-gxtvbb c1109880.pinmux: Init pinux probe!
[    0.472538@0] pinmux-gxtvbb c1109880.pinmux: Probed amlogic pinctrl driver
[    0.478899@0] aml-i2c c1108500.i2c: add adapter aml_i2c_adap1(ffffffc062d800e0)
[    0.485788@0] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xbc)
[    0.493602@0] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xbc)
[    0.501764@0] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xbc)
[    0.509701@0] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xbc)
lo[    0.519244@0] codec_mm has 2 memory regions
[    0.522137@0] codec_mm codec_mm.17: assigned reserved memory node linux,codec_mm_cma ok
[    0.530192@0] codec_mm codec_mm.17: assigned reserved memory node linux,codec_mm_reserved ok
[    0.538733@0] codec_mm has 2 memory regions
[    0.542874@0] codec_mm codec_mm.17: assigned reserved memory node linux,codec_mm_cma ok
[    0.550912@0] codec_mm codec_mm.17: assigned reserved memory node linux,codec_mm_reserved ok
[    0.561237@0] vpu: driver version: v02
[    0.563178@0] vpu: load vpu_clk: 666667000Hz(7)
[    0.567784@0] vpu: vpu_probe OK
[    0.572529@0] canvas_probe reg=00000000c8838000,size=400
[    0.576223@0] canvas maped reg_base =ffffff800009a000
[    0.584706@0] rdma_probe
[    0.584988@0] lcd: detect mode: tv, fr_auto_policy: 0, key_valid: 0
[    0.590108@0] lcd: status: 1
[    0.593013@0] vout_notify: vout_register_server
[    0.597547@0] lcd: lcd_get_config from dts
[    0.601663@0] lcd: error: failed to get range_setting
[    0.606742@0] lcd: set phy vswing=3, preemphasis=0
[    0.611567@0] desc->test = 0
[    0.614432@0] chip->test=0
[    0.617156@0] gpio_test= 0
[    0.619883@0] lcd: OPD30, lvds, 8bit, 1920x1080
[    0.624416@0] lcd: error: failed to get range_setting
[    0.629493@0] lcd: set phy vswing=3, preemphasis=0
[    0.634308@0] lcd: OPD30, lvds, 8bit, 1280x720
[    0.638758@0] lcd: lcd_vmode_init mode: 1080p60hz
[    0.643619@0] lcd: lcd_probe
[    0.881910@0] bio: create slab <bio-0> at 0
[    0.882744@0] SCSI subsystem initialized
[    0.884997@0] usbcore: registered new interface driver usbfs
[    0.890239@0] usbcore: registered new interface driver hub
[    0.895770@0] usbcore: registered new device driver usb
[    0.901409@0] Linux video capture interface: v2.00
[    0.905903@0] pps_core: LinuxPPS API ver. 1 registered
[    0.910893@0] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.920344@0] PTP clock support registered
[    0.924904@0] hdmitx: system: amhdmitx_init
[    0.928566@0] hdmitx: system: Ver: 2014May6
[    0.933037@0] vout_serve: vout_init_module
[    0.936935@0] vout_notify: set_current_vmode lcd_vout_server 32826
[    0.943104@0] lcd: lcd_vmode_is_supported vmode = 58, lcd_vmode = 3(1080p)
[    0.950007@0] lcd: lcd_set_current_vmode , lqm lcd_changed = 0
[    0.955877@0] vout_serve: vinfo mode is: 1080p60hz
[    0.960678@0] vout_serve: init mode 1080p60hz
[    0.965130@0] vout_serve: create vout attribute OK
[    0.969873@0] vout_serve: meson_vout_probe OK
[    0.974414@0] logo: logo_init
[    0.977295@0] osd_rdma: osd_rdma_init: rmda_table p=0x65841000,op=0x65841000 , v=0xffffff80000a9000
[    0.986702@0] spicc c1108d80.spicc: master is unqueued, this is deprecated
[    0.993307@0] spicc c1108d80.spicc: cs_num=1
[    0.997527@0] spicc c1108d80.spicc: cs[0]=221
[    1.002124@0] Advanced Linux Sound Architecture Driver Initialized.
[    1.008719@0] Bluetooth: Core ver 2.18
[    1.012025@0] NET: Registered protocol family 31
[    1.016594@0] Bluetooth: HCI device and connection manager initialized
[    1.023170@0] Bluetooth: HCI socket layer initialized
[    1.028239@0] Bluetooth: L2CAP socket layer initialized
[    1.033505@0] Bluetooth: SCO socket layer initialized
[    1.038875@0] cfg80211: Calling CRDA to update world regulatory domain
[    1.045240@0] NetLabel: Initializing
[    1.048704@0] NetLabel:  domain hash size = 128
[    1.053252@0] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.058460@0] NetLabel:  unlabeled traffic allowed by default
[    1.066854@0] Switched to clocksource arch_sys_counter
[    1.111854@0] [amlatvdemod..]aml_atvdemod_init.
[    1.111974@0] NET: Registered protocol family 2
[    1.115784@0] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.122924@0] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    1.129863@0] TCP: Hash tables configured (established 16384 bind 16384)
[    1.136439@0] TCP: reno registered
[    1.139794@0] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    1.146032@0] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    1.152829@0] NET: Registered protocol family 1
[    1.157421@0] RPC: Registered named UNIX socket transport module.
[    1.163330@0] RPC: Registered udp transport module.
[    1.168228@0] RPC: Registered tcp transport module.
[    1.173120@0] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.180237@0] pwm: probe ok
[    1.182727@0] (NULL device *): [wifi_dev_probe] wifi_dev_probe
[    1.188462@0] interrupt_pin_inverse = 0;
[    1.192379@0] power_on_pin_OD = 1;
[    1.195786@0] aml_wifi wifi.36: [wifi_dev_probe] no power_on_pin2
[    1.201949@0] aml_wifi wifi.36: [pwm_double_channel_conf_dt] pwm phandle val=31;pwm-channel1=2;pwm-channel2=10
[    1.211995@0] aml_wifi wifi.36: [pwm_double_channel_conf_dt] pwm_config1[0] = 30541
[    1.219678@0] aml_wifi wifi.36: [pwm_double_channel_conf_dt] pwm_config2[0] = 30518
[    1.227380@0] aml_wifi wifi.36: [pwm_double_channel_conf_dt] pwm_config1[1] = 15270
[    1.235071@0] aml_wifi wifi.36: [pwm_double_channel_conf_dt] pwm_config2[1] = 15259
[    1.242781@0] aml_wifi wifi.36: [pwm_double_channel_conf_dt] pwm_config1[2] = 6
[    1.250128@0] aml_wifi wifi.36: [pwm_double_channel_conf_dt] pwm_config2[2] = 9
[    1.257492@0] aml_wifi wifi.36: [pwm_double_channel_conf_dt] wifi pwm dt ok
[    1.264487@0] aml_wifi wifi.36: [pwm_double_channel_conf] wifi pwm conf ok
[    1.271432@0] aml_wifi wifi.36: [wifi_dev_probe] dhd_static_buf setup
[    1.277911@0] Wifi: bcmdhd_init_wlan_mem: bcmdhd_init_wlan_mem: WIFI MEM Allocated
[    1.285471@0] aml_wifi wifi.36: [wifi_dev_probe] interrupt_pin=160
[    1.291694@0] aml_wifi wifi.36: [wifi_dev_probe] irq_num=100, irq_trigger_type=0
[    1.299127@0] aml_wifi wifi.36: [wifi_dev_probe] power_on_pin=157
[    1.305250@0] aml_wifi wifi.36: [wifi_dev_probe] clock_32k_pin=0
[    1.311295@0] aml_wifi wifi.36: [wifi_dev_probe] power_on_pin_level=1
[    1.318018@0] aml_wifi wifi.36: [wifi_setup_dt] wifi_setup_dt
[    1.323537@0] desc->test = 0
[    1.326424@0] chip->test=0
[    1.329145@0] gpio_test= 0
[    1.331867@0] aml_wifi wifi.36: [wifi_setup_dt] interrupt_pin(160)
[    1.338066@0] desc->test = 0
[    1.340951@0] chip->test=0
[    1.343658@0] gpio_test= 0
[    1.346379@0] aml_wifi wifi.36: [wifi_setup_dt] power_on_pin(157)
[    1.352766@0] Unpacking initramfs...
[    1.375290@0] Freeing initrd memory: 676K (ffffffc073dc5000 - ffffffc073e6e000)
[    1.381271@0] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    1.383496@0] audit: initializing netlink subsys (disabled)
[    1.389101@0] audit: type=2000 audit(1.230:1): initialized
[    1.395199@0] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    1.408298@0] VFS: Disk quotas dquot_6.5.2
[    1.408522@0] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.416770@0] Registering sdcardfs 0.1
[    1.418158@0] NFS: Registering the id_resolver key type
[    1.422513@0] Key type id_resolver registered
[    1.426896@0] Key type id_legacy registered
[    1.431473@0] jffs2: version 2.2. (NAND) (SUMMARY)  ? 2001-2006 Red Hat, Inc.
[    1.439027@0] fuse init (API version 7.22)
[    1.442988@0] msgmni has been set to 3188
[    1.448016@0] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    1.454078@0] io scheduler noop registered
[    1.458214@0] io scheduler deadline registered
[    1.462817@0] io scheduler cfq registered (default)
[    1.519796@0] meson-rng c8834000.rng: hwrng registered
[    1.522757@0] loop: module loaded
[    1.523251@0] zram: Created 1 device(s) ...
[    1.527737@0] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.534007@0] tun: Universal TUN/TAP device driver, 1.6
[    1.538820@0] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.546307@0] desc->test = 0
[    1.548087@0] chip->test=0
[    1.550791@0] gpio_test= 0
[    1.556708@0] libphy: stmmac: probed
[    1.557098@0] eth0: No PHY found
[    1.586955@0] stmmac_pltfr_probe: main driver probe failed
[    1.587227@0] PPP generic driver version 2.4.2
[    1.591591@0] PPP BSD Compression module registered
[    1.596244@0] PPP Deflate Compression module registered
[    1.601521@0] PPP MPPE Compression module registered
[    1.606484@0] NET: Registered protocol family 24
[    1.611286@0] usbcore: registered new interface driver catc
[    1.616797@0] usbcore: registered new interface driver kaweth
[    1.622501@0] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    1.630191@0] usbcore: registered new interface driver pegasus
[    1.636041@0] usbcore: registered new interface driver rtl8150
[    1.641920@0] usbcore: registered new interface driver r8152
[    1.647528@0] hso: /home/work/data/jenkins/workspace/Me2_release/common/drivers/net/usb/hso.c: Option Wireless
[    1.657688@0] usbcore: registered new interface driver hso
[    1.663170@0] usbcore: registered new interface driver asix
[    1.668775@0] usbcore: registered new interface driver ax88179_178a
[    1.675069@0] usbcore: registered new interface driver cdc_ether
[    1.681109@0] usbcore: registered new interface driver cdc_eem
[    1.686974@0] usbcore: registered new interface driver dm9601
[    1.692745@0] usbcore: registered new interface driver sr9700
[    1.698530@0] usbcore: registered new interface driver CoreChips
[    1.704576@0] usbcore: registered new interface driver smsc75xx
[    1.710524@0] usbcore: registered new interface driver smsc95xx
[    1.716454@0] usbcore: registered new interface driver gl620a
[    1.722240@0] usbcore: registered new interface driver net1080
[    1.728107@0] usbcore: registered new interface driver plusb
[    1.733777@0] usbcore: registered new interface driver rndis_host
[    1.739913@0] usbcore: registered new interface driver cdc_subset
[    1.746035@0] usbcore: registered new interface driver zaurus
[    1.751811@0] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    1.759442@0] usbcore: registered new interface driver int51x1
[    1.765284@0] usbcore: registered new interface driver cdc_phonet
[    1.771410@0] usbcore: registered new interface driver kalmia
[    1.777191@0] usbcore: registered new interface driver ipheth
[    1.782965@0] usbcore: registered new interface driver sierra_net
[    1.789091@0] usbcore: registered new interface driver cx82310_eth
[    1.795307@0] usbcore: registered new interface driver cdc_ncm
[    1.801161@0] usbcore: registered new interface driver huawei_cdc_ncm
[    1.807643@0] usbcore: registered new interface driver lg-vl600
[    1.813578@0] usbcore: registered new interface driver qmi_wwan
[    1.819535@0] usbcore: registered new interface driver cdc_mbim
[    1.825688@0] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.832152@0] ehci-h20ahb: H20AHB-EHCI Host Controller driver
[    1.838127@0] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.844554@0] usbcore: registered new interface driver cdc_acm
[    1.850185@0] aml_wifi wifi.36: [wifi_dt_timer] wifi_dt_timer()
[    1.856134@0] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.864435@0] usbcore: registered new interface driver cdc_wdm
[    1.870301@0] usbcore: registered new interface driver usb-storage
[    1.876595@0] usbcore: registered new interface driver usbserial
[    1.882536@0] usbcore: registered new interface driver cp210x
[    1.888305@0] usbserial: USB Serial support registered for cp210x
[    1.894568@0] amlogic-usb2 d0078000.usb2phy: USB2 phy probe:phy_mem:0xd0078000, iomap phy_base:0xffffff80000dc000
[    1.904867@0] amlogic-usb3 d0078080.usb3phy: USB3 phy probe:phy_mem:0xd0078080, iomap phy_base:0xffffff80000de080
[    1.915830@0] mousedev: PS/2 mouse device common for all mice
[    1.921173@0] usbcore: registered new interface driver xpad
[    1.926582@0] i2c /dev entries driver
[    1.930365@0] usbcore: registered new interface driver uvcvideo
[    1.936006@0] USB Video Class driver (1.1.1)
[    1.941283@0] device-mapper: ioctl: 4.27.0-ioctl (2013-10-30) initialised: dm-devel@redhat.com
[    1.949036@0] Bluetooth: HCI UART driver ver 2.2
[    1.953598@0] Bluetooth: HCI H4 protocol initialized
[    1.959304@0] hidraw: raw HID events driver (C) Jiri Kosina
[    1.964794@0] usbcore: registered new interface driver usbhid
[    1.969967@0] usbhid: USB HID core driver
[    1.974558@0] ashmem: initialized
[    1.977469@0] logger: created 256K log 'log_main'
[    1.982165@0] logger: created 256K log 'log_events'
[    1.987078@0] logger: created 256K log 'log_radio'
[    1.991894@0] logger: created 256K log 'log_system'
[    1.997745@0] meson_uart c81004c0.serial: ==uart0 reg addr = ffffff80000ea4c0
[    2.003839@0] c81004c0.serial: ttyS0 at MMIO 0xc81004c0 (irq = 225, base_baud = 1500000) is a meson_uart
[    2.018874@0] meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 0 to 115200
[    2.021500@0] console [ttyS0] enabled
[    2.028752@0] bootconsole [earlycon0] disabled
[    2.037860@0] meson_uart c11084dc.serial: ==uart1 reg addr = ffffff80000ec4dc
[    2.044541@0] c11084dc.serial: ttyS1 at MMIO 0xc11084dc (irq = 107, base_baud = 1500000) is a meson_uart
[    2.054156@0] meson_uart c1108700.serial: ==uart2 reg addr = ffffff80000ee700
[    2.061020@0] c1108700.serial: ttyS2 at MMIO 0xc1108700 (irq = 125, base_baud = 1500000) is a meson_uart
[    2.070615@0] meson_uart c11084c0.serial: ==uart3 reg addr = ffffff80000fa4c0
[    2.077493@0] c11084c0.serial: ttyS3 at MMIO 0xc11084c0 (irq = 58, base_baud = 1500000) is a meson_uart
[    2.087157@0] meson-gpu-clkgen c883c000.gpu_clk: clock dvfs table size is 6
[    2.093729@0] meson-gpu-clkgen c883c000.gpu_clk: 0:clk_freq= 125000000,
[    2.100249@0] meson-gpu-clkgen c883c000.gpu_clk: clk_parent=fclk_div4,voltage=1150,
[    2.107845@0] meson-gpu-clkgen c883c000.gpu_clk: keep_count=5, threshod=<30 120>
[    2.115162@0] meson-gpu-clkgen c883c000.gpu_clk: 1:clk_freq= 250000000,
[    2.121723@0] meson-gpu-clkgen c883c000.gpu_clk: clk_parent=fclk_div4,voltage=1150,
[    2.129317@0] meson-gpu-clkgen c883c000.gpu_clk: keep_count=5, threshod=<80 170>
[    2.136638@0] meson-gpu-clkgen c883c000.gpu_clk: 2:clk_freq= 285714000,
[    2.143202@0] meson-gpu-clkgen c883c000.gpu_clk: clk_parent=fclk_div7,voltage=1150,
[    2.150790@0] meson-gpu-clkgen c883c000.gpu_clk: keep_count=5, threshod=<100 190>
[    2.158209@0] meson-gpu-clkgen c883c000.gpu_clk: 3:clk_freq= 400000000,
[    2.164756@0] meson-gpu-clkgen c883c000.gpu_clk: clk_parent=fclk_div5,voltage=1150,
[    2.172352@0] meson-gpu-clkgen c883c000.gpu_clk: keep_count=5, threshod=<152 207>
[    2.179772@0] meson-gpu-clkgen c883c000.gpu_clk: 4:clk_freq= 500000000,
[    2.186318@0] meson-gpu-clkgen c883c000.gpu_clk: clk_parent=fclk_div4,voltage=1150,
[    2.193917@0] meson-gpu-clkgen c883c000.gpu_clk: keep_count=5, threshod=<180 220>
[    2.201351@0] meson-gpu-clkgen c883c000.gpu_clk: 5:clk_freq= 666666000,
[    2.207894@0] meson-gpu-clkgen c883c000.gpu_clk: clk_parent=fclk_div3,voltage=1150,
[    2.215472@0] meson-gpu-clkgen c883c000.gpu_clk: keep_count=5, threshod=<210 236>
[    2.223201@0] hdmitx: system: hdmitx_hdcp_init
[    2.227296@0] hdmitx: system: exit for null device of hdmitx!
[    2.232978@0] ESM HLD: Initializing...
[    2.236689@0] ESM HLD: Exit for null device of hdmitx!
[    2.242144@0] aml_vrtc rtc.3: rtc core: registered aml_vrtc as rtc0
[    2.248284@0] dlp34xx_probe dlp34xx type is 0
[    2.252299@0] dlp34xx_dt_parse ...
[    2.255672@0] desc->test = 0
[    2.258526@0] chip->test=0
[    2.261189@0] gpio_test= 0
[    2.263868@0] dlp34xx_dt_parse pwr_num 128
[    2.267917@0] desc->test = 0
[    2.270758@0] chip->test=0
[    2.273434@0] gpio_test= 0
[    2.276114@0] desc->test = 0
[    2.278955@0] chip->test=0
[    2.281629@0] gpio_test= 0
[    2.284308@0] desc->test = 0
[    2.287149@0] chip->test=0
[    2.289819@0] gpio_test= 0
[    2.293164@0] check controller chip id 9.
[    2.297315@0] check dmd device id 0x60,0xd,0x0,0x73.
[    2.302101@0] check system software version 0x1050001.
[    2.307186@0] check flash build version 0x1050001.
[    2.315508@0] pro_device_t find projector brightness bri_hightlight level 255(r:700,g:1020,b:900,x:2865,y:3115),limit(0 0 0 39 0 86 77 77)
[    2.323382@0] pro_device_t find projector brightness bri_normal level 200(r:688,g:920,b:800,x:2865,y:3115),limit(0 0 0 50 0 99 90 90)pro_device_t find projector brightness bri_powersave level 100(r:481,g:645,b:56,x:2865,y:3115),limit(0 0 0 0 0 0 0 0)
[    2.345474@0] dlp34xx_chip_init projector ffffffc0626a8018
[    2.351064@0] projector_ext_ld_enable() enable:1
[    2.856861@0] projector_init_display dlp3438
[    2.859657@0] projector_set_keystone_enable set angle enable 1.
[    2.904834@0] projector_init_display init brightness 200
[    2.904856@0] projector_write_brightness brightness change to 200
[    2.911818@0] spi spi0.0: cs_gpio=221,mode=2, speed=10000000
[    2.916139@0] desc->test = 0
[    2.918991@0] chip->test=0
[    2.921666@0] gpio_test= 0
[    2.924483@0] c788 spi0.0: cs_gpio=221,mode=2, speed=10000000
[    2.930032@0] desc->test = 0
[    2.932963@0] register_warp_dev
[    2.935981@0] register_warp_dev major_num = 242
[    2.941003@0] i2c-core: driver [dlp34xx] using legacy suspend method
[    2.946758@0] i2c-core: driver [dlp34xx] using legacy resume method
[    2.953072@0] secmon has 1 memory regions
[    2.956976@0] secmon: share in base: 0xffffff800010e000, share out base: 0xffffff800011a000
[    2.965222@0] secmon: phy_in_base: 0x100fe000, phy_out_base: 0x100ff000
[    2.971779@0] secmon secmon.5: assigned reserved memory node linux,secmon ok
[    2.978765@0] secmon: probe done
[    2.982215@0] storage: storage in base: 0xffffff8001600000
[    2.987388@0] storage: storage out base: 0xffffff8001680000
[    2.992905@0] storage: storage block base: 0xffffff8001700000
[    2.998598@0] storage: probe done!
[    3.002384@0] aml_sd_emmc_probe: line 3466
[    3.006014@0] mmc driver version: 1.07, 2015-01-21: fix a bug in tuning which caused eMMC data CRC error
[    3.015594@0] aml_sd_emmc_reg_init 1128
[    3.019264@0] get property:                ocr_avail, value:0x00200080
[    3.025686@0] get property:                    f_min, value:300000
[    3.031807@0] get property:                    f_max, value:200000000
[    3.038192@0] get property:             max_req_size, value:0x00020000
[    3.044658@0] get property:                  pinname, str:emmc
[    3.050439@0] get property:                card_type, value:1
[    3.056125@0] get property:                 tx_phase, value:1
[    3.061831@0] get property:                gpio_dat3, str:
[    3.067256@0] get property:                 hw_reset, str:
[    3.072709@0] emmc:pdata->caps = c0000d47
[    3.076658@0] emmc:pdata->caps2 = 60
[    3.080198@0] storage 1, boot 1
[    3.083292@0] get_storage_dev return 1
[    3.126868@0] [aml_sd_emmc_probe] aml_sd_emmc_probe() success!
[    3.127063@0] desc->test = 0
[    3.129901@0] chip->test=0
[    3.132580@0] gpio_test= 0
[    3.136871@0] aml_sd_emmc_probe: line 3466
[    3.141381@0] desc->test = 0
[    3.142148@0] chip->test=0
[    3.144824@0] gpio_test= 0
[    3.147596@2] aml_sd_emmc_reg_init 1128
[    3.151367@2] get property:                ocr_avail, value:0x00200080
[    3.153574@0] desc->test = 0
[    3.153575@0] chip->test=0
[    3.153578@0] gpio_test= 0
[    3.166008@2] get property:                    f_min, value:400000
[    3.172116@2] get property:                    f_max, value:200000000
[    3.178472@2] get property:             max_req_size, value:0x00020000
[    3.184932@2] get property:                  pinname, str:sd
[    3.190560@3] get property:                card_type, value:3
[    3.196252@3] sd:pdata->caps = 4010f
[    3.199804@3] sd:pdata->caps2 = 0
[    3.221440@2] emmc: BKOPS_EN bit is not set
[    3.227720@2] emmc: trying cali 0-th time(s)
[    3.236866@0] [aml_sd_emmc_probe] aml_sd_emmc_probe() success!
[    3.237319@0] ion_dev has 1 memory regions
[    3.245179@0] fb: osd_init_module
[    3.245277@0] fb: viu vsync irq: 35
[    3.247848@0] fb: failed to init reserved memory
[    3.252415@0] fb: osd_probe vinfo:ffffffc0021238c8
[    3.257157@0] fb: init fbdev bpp is:32
[    3.273953@2] emmc: delay[0]= 2200 padding= 4, bidx=2
[    3.273973@2] emmc: delay[1]= 1800 padding= 1, bidx=1
[    3.274158@0] fb: osd probe OK
[    3.274335@0] ge2d: ge2d_init_module
[    3.274344@0] ge2d: ge2d_dev major:241
[    3.274671@0] ge2d: ge2d clock is 400 MHZ
[    3.274675@0] ge2d: ge2d: pdev=ffffffc062dc6600, irq=182, rstc=0IffO:    pkf 50
INclk=f  dfk 662ccNFO:    end set4743@0] ge2d: mapped phy: 0xd0160000
[    3.274749@0] ge2d: ge2d start monitor
[    3.274791@1] ge2d: ge2d workqueue monitor start
[    3.274936@0] sysled: module init
[    3.275206@0] pwmled: module init
[    3.275252@0] codec:Amlogic A/V streaming port init
[    3.276822@0] codec:get gate demux control ok ffffffc061ec0b80
[    3.276827@0] codec:get gate parser_top control ok ffffffc061ec0c00
[    3.276831@0] codec:get gate vpu_intr control ok ffffffc061ec0c80
[    3.276836@0] codec:get gate vdec control ok ffffffc061ec0d00
[    3.277438@0] codec:[tsync_pcr_init]init success.
[    3.277441@0] codec:amvideocap_init_module
[    3.277513@0] codec:amvideocap_probe,amvideocap
[    3.277517@0] codec:use cma buf.
[    3.277518@0] codec:amvideocap_dev_register
[    3.278896@0] amvenc_avc_probe -- reserved memory config fail.
[    3.278899@0] amvenc_avc - cma memory pool size: 40 MB
[    3.278926@0] encode_wq_init.
[    3.278932@0] encode start monitor.
[    3.278987@1] encode workqueue monitor start.
[    3.279379@0] jpegenc module init
[    3.279568@0] codec:picdec_driver_probe called.
[    3.279571@0] picdec has 1 memory regions
[    3.279616@0] codec:picdec_driver_probe done.
[    3.280561@0] codec:create_ge2d_work_queue video task ok
[    3.280936@0] rdma_register, rdma_table_addr ffffff80003a9000 rdma_table_addr_phy 65848000 reg_buf ffffffc062168000
[    3.280938@0] rdma_register success, handle 1 table_size 32768
[    3.280940@0] video_rdma:rdma_init video rdma handle = 1.
[    3.280951@0] codec:register clk_set_setting cpu[32]
[    3.281270@0] DI: di_module_init ok.
[    3.281275@0] DI: di_module_init: major 235
[    3.281625@0] DI: di_probe
[    3.281805@0] deinterlace has 1 memory regions
[    3.281866@0] deinterlace deinterlace.24: assigned reserved memory node linux,di ok
[    3.281893@0] di_irq:78,timerc_irq:38
[    3.281931@0] rdma_register, rdma_table_addr ffffff8000159000 rdma_table_addr_phy 65846000 reg_buf ffffffc0620a2000
[    3.281934@0] rdma_register success, handle 2 table_size 8192
[    3.281935@0] DI: di_probe allocate rdma channel 2.
[    3.281939@0] DI: DI hw version 2.
[    3.281953@0] 0x000000db:Y=db,U=0,V=0
[    3.281954@0] 0x000000dc:Y=dc,U=0,V=0
[    3.281957@0] 0x000000dd:Y=dd,U=0,V=0
[    3.281958@0] 0x000000de:Y=de,U=0,V=0
[    3.281960@0] 0x000000df:Y=df,U=0,V=0
[    3.281962@0] 0x000000e0:Y=e0,U=0,V=0
[    3.281963@0] 0x000000e1:Y=e1,U=0,V=0
[    3.281965@0] 0x000000e2:Y=e2,U=0,V=0
[    3.281966@0] 0x000000e3:Y=e3,U=0,V=0
[    3.281968@0] 0x000000f0:Y=f0,U=0,V=0
[    3.281972@0] 0x000000f1:Y=f1,U=0,V=0
[    3.281973@0] 0x000000f2:Y=f2,U=0,V=0
[    3.281975@0] 0x000000f3:Y=f3,U=0,V=0
[    3.281976@0] 0x000000f4:Y=f4,U=0,V=0
[    3.281978@0] 0x000000f5:Y=f5,U=0,V=0
[    3.281980@0] 0x000000f6:Y=f6,U=0,V=0
[    3.281983@0] 0x000000f7:Y=f7,U=0,V=0
[    3.281984@0] 0x000000f8:Y=f8,U=0,V=0
[    3.281986@0] 0x000000f9:Y=f9,U=0,V=0
[    3.281988@0] 0x000000fa:Y=fa,U=0,V=0
[    3.281989@0] 0x000000fb:Y=fb,U=0,V=0
[    3.281991@0] 0x000000fc:Y=fc,U=0,V=0
[    3.282119@0] DI: di_probe here.
[    3.282415@0] efuse efuse.9:  open efuse clk gate error!!
[    3.282437@0] efusekeynum: 4
[    3.282448@0] efusekeyname:             mac  offset:     0   size:     6
[    3.282454@0] efusekeyname:          mac_bt  offset:     6   size:     6
[    3.282459@0] efusekeyname:        mac_wifi  offset:    12   size:     6
[    3.282465@0] efusekeyname:            usid  offset:    18   size:    16
[    3.282676@0] efuse efuse.9: probe OK!
[    3.282904@0] key unify config unifykey-num is 21
[    3.282967@0] key unify fact unifykey-num is 21
[    3.282971@0] aml_unifykeys_probe:1199=============unifykey_devno:e900000
[    3.283187@0] unifykey: device unifykeys created ok
[    3.283282@0] aml_unifykeys_init done!
[    3.283283@0] PPMGRDRV: warn: ppmgr module init func called
[    3.283338@0] PPMGRDRV: err: ppmgr_driver_probe called
[    3.283340@0] ppmgr has 1 memory regions
[    3.283365@0] PPMGRDRV: info: ppmgr_dev major:232
[    3.283590@0] PPMGRDRV: info: ppmgr_probe done
[    3.283834@0] amlogic rfkill init
[    3.283885@0] enter bt_probe of_node
[    3.283888@0] not get gpio_reset
[    3.283904@0] power on valid level is high
[    3.283904@0] desc->test = 0
[    3.283907@0] chip->test=0
[    3.283916@0] gpio_test= 0
[    3.284352@0] ionvideo-000: V4L2 device registered as video13
[    3.284354@0] ionvid: info: Video Technology Magazine Ion Video
[    3.284355@0] ionvid: info: Capture Board ver 1.0 successfully loaded
[    3.284365@0] audio_dsp: [dsp]register dsp to char divece(257)
[    3.285014@0] amaudio: amaudio: driver amaudio succuess!
[    3.285833@0] amaudio2: amaudio2: driver amaudio2 succuess!
[    3.285988@0] amlkaraoke init success!
[    3.286163@0] amlvid:err: amlvideo_init called
[    3.286163@0] amlvid:err: amlvideo_create_instance called
[    3.286166@0] amlvid:err: v4l2_dev.name=:amlvideo-000
[    3.286304@0] amlvideo-000: V4L2 device registered as video10
[    3.286388@0] amlvideo2 probe called
[    3.286557@0] amlvideo2_create_node
[    3.286557@0] amlvideo2: V4L2 device registered as video11
[    3.286845@0] amlvideo2: V4L2 device registered as video12
[    3.287297@0] vdin_drv_init: major 231
[    3.287505@0] rdma_register, rdma_table_addr ffffff800013e000 rdma_table_addr_phy 65850000 reg_buf ffffffc061f29a00
[    3.287507@0] rdma_register success, handle 4 table_size 512
[    3.287509@0] vdin_drv_probe:vdin.0 rdma hanld 4.
[    3.287662@0]
[    3.287662@0]  vdin memory resource undefined!!
[    3.287667@0] vdin0 cma_mem_size = 160 MB
[    3.287671@0] vdin0 irq: 115 rdma irq: 2
[    3.287733@0] vdin_drv_probe: fclk_div5 is 400 MHZ
[    3.287761@0] vdin_drv_probe: vdin[0] clock is 50 MHZ
[    3.287942@0] vdin_drv_probe: driver initialized ok
[    3.287967@0] rdma_register, rdma_table_addr ffffff800015c000 rdma_table_addr_phy 65851000 reg_buf ffffffc061f2a200
[    3.287969@0] rdma_register success, handle 5 table_size 512
[    3.287971@0] vdin_drv_probe:vdin.1 rdma hanld 5.
[    3.288097@0] vdin1 has 1 memory regions
[    3.288150@0] vdin vdin1.27: assigned reserved memory node linux,vdin1_cma ok
[    3.288151@0]
[    3.288151@0]  vdin memory resource done.
[    3.288156@0] vdin1 cma_mem_size = 20 MB
[    3.288159@0] vdin1 irq: 117 rdma irq: 4
[    3.288178@0] vdin_drv_probe: fclk_div5 is 400 MHZ
[    3.288183@0] vdin_drv_probe: vdin[1] clock is 50 MHZ
[    3.288309@0] vdin_drv_probe: driver initialized ok
[    3.288450@0] vdin_drv_init: vdin driver init done
[    3.288456@0] tvafe_drv_init: major 230
[    3.288749@0] tvafe: can't get memory resource
[    3.288752@0] tvafe cma_mem_size = 8 MB
[    3.288776@0] tvafe_drv_probe:tvafe start get  ioremap .
[    3.288779@0] tvafe_probe reg=00000000c8842000,size=2000
[    3.288789@0] tvafe_drv_probe: tvafe maped reg_base =ffffff800016c000, size=2000
[    3.288801@0] tvafe: driver probe ok
[    3.288906@0] tvafe: tvafe_init.
[    3.289219@0] [RX]-hdmirx: Mapped PHY: 0xc0800000
[    3.289237@0] [RX]-hdmirx: Mapped PHY: 0xc883c000
[    3.289240@0] [RX]-hdmirx: Mapped PHY: 0xd0076000
[    3.289243@0] [RX]-hdmirx: Mapped PHY: 0xc883e000
[    3.289245@0] [RX]-hdmirx: Mapped PHY: 0xda83e000
[    3.289248@0] [RX]-hdmirx: Mapped PHY: 0xc8834400
[    3.290486@0] [RX]-hdmirx: Mapped PHY: 0xda846000
[    3.290666@0] [RX]-hdevpd irq: 0, 88
[    3.291008@0] [RX]-hdmirx: pinmux:ffffffc06253c200, name:hdmirx_pins
[    3.291029@0] hdmirx_probe: xtal_clk is 24 MHZ
[    3.291042@0] hdmirx_probe: fclk_div5_clk is 400 MHZ
[    3.291049@0] hdmirx_probe: modet_clk is 24 MHZ
[    3.291072@0] hdmirx_probe: cfg_clk is 133 MHZ
[    3.291082@0] hdmirx_probe: audmeas_clk is 200 MHZ
[    3.291432@0] [RX]-port map:0x3120
[    3.291435@0] [RX]-bfe:0x1
[    3.291436@0] [RX]-aft:0x10
[    3.291437@0] [RX]-port 0 phy:16
[    3.291438@0] [RX]-bfe:0x2
[    3.291439@0] [RX]-aft:0x20
[    3.291441@0] [RX]-port 2 phy:32
[    3.291442@0] [RX]-bfe:0x3
[    3.291443@0] [RX]-aft:0x30
[    3.291444@0] [RX]-port 1 phy:48
[    3.291451@0] [RX]-edid update end
[    3.298385@0] [RX]-hdmirx_phy_init  0 Done!
[    3.302865@0] [RX]-hdcp22 == 1
[    3.302873@0] [RX]-hdmirx_hw_probe Done!
[    3.302875@0] [RX]-hdmirx: driver probe ok
[    3.303037@0] [RX]-hdmirx: hdmirx_init.
[    3.303039@0] ESM HLD: Initializing...
[    3.303041@0] ESM HLD: Registering device range 'esm_rx'...
[    3.303049@0] ESM HLD: Device range 'esm_rx' has been registered.
[    3.303052@0] ESM HLD: Creating class /sys/class/elliptic_rx...
[    3.303121@0] ESM HLD: The class /sys/class/elliptic_rx has been created.
[    3.303123@0] ESM HLD: Creating device 'esm_rx'...
[    3.303262@0] ESM HLD: Device 'esm_rx' has been created.
[    3.303264@0] ESM HLD: Done initializing the HLD driver.
[    3.303504@0] [viuin..]viuin_init_module viuin module init
[    3.303859@0] [viuin..]viuin_probe probe ok.
[    3.303923@0] module init
[    3.304034@0]
[    3.304034@0]  VECM probe start
[    3.304470@0] aml_vecm_probe: ok
[    3.304900@0] saradc c8100600.saradc: initialized by BL30
[    3.304911@0] saradc c8100600.saradc: calibration start:
[    3.304952@0] saradc c8100600.saradc: nominal=0, value=0
[    3.304992@0] saradc c8100600.saradc: nominal=256, value=248
[    3.305032@0] saradc c8100600.saradc: nominal=512, value=505
[    3.305072@0] saradc c8100600.saradc: nominal=768, value=761
[    3.305112@0] saradc c8100600.saradc: nominal=1023, value=1019
[    3.305115@0] saradc c8100600.saradc: calibration end: coef=4088
[    3.305120@0] saradc c8100600.saradc: saradc_probe fail to get sub-woofer!
[    3.305228@0] remote: Driver init
[    3.305265@0] remote: platform_data g_remote_ao_offset=580
[    3.305268@0] remote: platform_data irq =228
[    3.305297@0] remote: set drvdata completed
[    3.305306@0] remote: device_create_file completed
[    3.305582@0] input: aml_keypad as /devices/meson-remote.11/input/input0
[    3.305865@0] remote: input_register_device completed
[    3.305889@0] remote: set_remote_mode[78]
[    3.305920@0] remote: remote config major:227
[    3.306091@0] remote: physical address:0x615a0000
[    3.306429@0] gpio-key gpio_keypad.29: gpio_key: 0 name(power) pin()
[    3.306433@0] gpio-key gpio_keypad.29: amlogic_gpio_name_map_num pin 0!::
[    3.306448@0] gpio-key gpio_keypad.29: gpio_key: 0 power(127)
[    3.306452@0] desc->test = 0
[    3.306454@0] chip->test=0
[    3.306464@0] gpio_test= 0
[    3.306488@0] gpio-key gpio_keypad.29: start setup_timer
[    3.306496@0] gpio-key gpio_keypad.29: power key(116) registed.
[    3.306647@0] input: gpio_keypad as /devices/gpio_keypad.29/input/input1
[    3.306770@0] gpio-key gpio_keypad.29: gpio keypad register input device completed.
[    3.306777@0] input input1: gpio keypad major:226
[    3.306907@0] [RX]-hdmirx_set_hpd, port:0, val:0
[    3.306911@0] [RX]-hdmirx_set_hpd, port:1, val:0
[    3.306914@0] [RX]-hdmirx_set_hpd, port:2, val:0
[    3.307942@0] Sensor: lsm303d_init
[    3.308135@0] Sensor: stk8313_init
[    3.308204@0] Sensor: stk831x_init
[    3.308270@0] Sensor: mxc622x_acc_init
[    3.308340@0] Sensor: mxc6255xc_acc_init
[    3.308473@0] Sensor: l3gd20_gyr_init
[    3.309258@0] i2c-core: driver [bma2x2] using legacy suspend method
[    3.309259@0] i2c-core: driver [bma2x2] using legacy resume method
[    3.309509@0] aml dvb init
[    3.309783@0] Amlogic Demod DVB-T/C DebugIF Init
[    3.310045@0] Amlogic Demod DVB-T/C DebugIF Init ok----------------
[    3.310217@0] g751_module_init ....
[    3.310277@0] g751_probe ...
[    3.311052@0] jtag: module init
[    3.311420@0] defendkey: driver init
[    3.311967@0] input: cec_input as /devices/virtual/input/input2
[    3.313193@0] surround: _gpio_tbl_initial, get dongle-en pin error
[    3.313196@0] surround: _gpio_tbl_initial, get i2s01-amp-en pin error
[    3.313198@0] surround: _gpio_tbl_initial, get i2s01-kok-en pin error
[    3.313201@0] surround: _gpio_tbl_initial, get i2s45-en pin error
[    3.313203@0] surround: _gpio_tbl_initial, get i2sin-en pin error
[    3.313205@0] surround: _gpio_tbl_initial, get data-surr-en pin error
[    3.313207@0] surround: _gpio_tbl_initial, get data-mic-en pin error
[    3.313216@0] surround: _gpio_cfg_initial, 1-0-1-1-1-1-1
[    3.313218@0] surround: _gpio_cfg_initial, 0-0-1-0-1-0-1
[    3.313220@0] surround: _gpio_cfg_initial, 0-0-1-0-1-0-1
[    3.313223@0] surround: _gpio_cfg_initial, 0-1-0-1-0-1-0
[    3.313235@0] desc->test = 0
[    3.313237@0] chip->test=0
[    3.313245@0] gpio_test= 0
[    3.313264@0] surround: surround_ctrl_probe, register gpio ctrl driver for xiaomi surround dongle success
[    3.313710@0] usbcore: registered new interface driver snd-usb-audio
[    3.314630@0] aml_pmu4_codec pmu4.49: aml_pmu4_audio_codec_probe
[    3.314642@0] desc->test = 0
[    3.314644@0] chip->test=0
[    3.314650@0] gpio_test= 0
[    3.314658@0] aml_pmu4_audio_codec_probe flags:0
[    3.314667@0] pmu4: can't find block_enable
[    3.314669@0] pmu4: can't find audio_config
[    3.314671@0] pmu4: can't find lineout_config
[    3.314673@0] pmu4: [reg: 0x02] 0xBCFF(block_enable)
[    3.314674@0] pmu4: [reg: 0x04] 0x3400(audio_config)
[    3.314676@0] pmu4: [reg: 0x06] 0x2929(name_in_dts)
[    3.314677@0] pmu4: [reg: 0x08] 0x5050(name_in_dts)
[    3.314679@0] pmu4: [reg: 0x0A] 0x0000(name_in_dts)
[    3.314681@0] pmu4: [reg: 0x0C] 0xFFFF(name_in_dts)
[    3.314682@0] pmu4: [reg: 0x0E] 0x4242(lineout_config)
[    3.317157@0] [RX]-port map:0x3120
[    3.317159@0] [RX]-bfe:0x1
[    3.317160@0] [RX]-aft:0x10
[    3.317162@0] [RX]-port 0 phy:16
[    3.317163@0] [RX]-bfe:0x2
[    3.317164@0] [RX]-aft:0x20
[    3.317166@0] [RX]-port 2 phy:32
[    3.317167@0] [RX]-bfe:0x3
[    3.317168@0] [RX]-aft:0x30
[    3.317169@0] [RX]-port 1 phy:48
[    3.317175@0] [RX]-edid update end
[    3.317485@0] aml_spdif_pinmux_init
[    3.317494@0] desc->test = 0
[    3.317496@0] chip->test=0
[    3.317502@0] gpio_test= 0
[    3.317514@0] aml_spdif_select_enable_pin flags:1
[    3.317517@0] aml spdif outpin_active_low:1
[    3.317922@0] aml_g9tv: aux name = tas5717
[    3.317929@0] aml_g9tv: tas5717:this audio codec is disabled!
[    3.317932@0] aml_g9tv: powerup_codecs_in_initializtion fail to get codecs pdn pin from dts!
[    3.318198@0] aml_g9tv: enter aml_asoc_init
[    3.318578@0] aml_snd_card_g9tv aml_g9tv_snd.50: dummy <-> I2S.41 mapping ok
[    3.318873@0] aml_snd_card_g9tv aml_g9tv_snd.50: dit-hifi <-> SPDIF.42 mapping ok
[    3.318947@0] aml_snd_card_g9tv aml_g9tv_snd.50: pcm2bt-pcm <-> PCM.43 mapping ok
[    3.320394@0] desc->test = 0
[    3.320397@0] chip->test=0
[    3.320404@0] gpio_test= 0
[    3.320408@0] aml_g9tv: aml_g9tv_pinmux_init, make avmute gpio high!
[    3.396872@0] [RX]-hotplg-b
[    3.396872@0] input input1: key 116 up
[    3.436856@0] hdmirx_set_hpd, port:0, val:1
[    3.436860@0] [RX]-hdmirx_set_hpd, port:1, val:1
[    3.436862@0] [RX]-hdmirx_set_hpd, port:2, val:1
[    4.610537@2] emmc: delay[2]= 1600 padding= 2, bidx=1
[    4.615500@2] emmc: delay[3]= 1800 padding= 1, bidx=1
[    4.620509@2] emmc: delay[4]= 2200 padding= 4, bidx=2
[    4.625502@2] emmc: delay[5]= 1800 padding= 1, bidx=1
[    4.630510@2] emmc: delay[6]= 2200 padding= 4, bidx=2
[    4.635507@2] emmc: delay[7]= 1800 padding= 1, bidx=1
[    4.640514@2] emmc: calibration result @ 0: max(2200), min(1600)
[    4.646462@2] emmc: line_delay =0x20202320, max_cal_result =2200
[    4.652417@2] emmc: base_index_max 2, base_index_min 1
[    4.657510@2] emmc: clk 200000000 SDR mode tuning start
[    4.668296@2] emmc: rx_tuning_result[0] = 10
[    4.668316@2] emmc: rx_tuning_result[1] = 10
[    4.671158@2] emmc: rx_tuning_result[2] = 10
[    4.675380@2] emmc: rx_tuning_result[3] = 10
[    4.679613@2] emmc: rx_tuning_result[4] = 10
[    4.683832@2] emmc: rx_tuning_result[8] = 10
[    4.688067@2] emmc: rx_tuning_result[9] = 10
[    4.692285@2] emmc: rx_tuning_result[10] = 10
[    4.696597@2] emmc: rx_tuning_result[11] = 10
[    4.700917@2] emmc: rx_tuning_result[12] = 10
[    4.705225@2] emmc: rx_tuning_result[13] = 10
[    4.709540@2] emmc: rx_tuning_result[14] = 10
[    4.713847@2] emmc: rx_tuning_result[15] = 10
[    4.718165@2] emmc: rx_tuning_result[16] = 10
[    4.722472@2] emmc: rx_tuning_result[17] = 10
[    4.726785@2] emmc: rx_tuning_result[18] = 10
[    4.731102@2] emmc: rx_tuning_result[19] = 10
[    4.735411@2] emmc: rx_tuning_result[20] = 10
[    4.739727@2] emmc: rx_tuning_result[21] = 10
[    4.744035@2] emmc: rx_tuning_result[22] = 10
[    4.748352@2] emmc: rx_tuning_result[23] = 10
[    4.752660@2] emmc: rx_tuning_result[24] = 10
[    4.756978@2] emmc: best_win_start =8, best_win_size =22
[    4.762234@2] emmc: rx_phase = 2, rx_delay = 9,
[    4.766549@2] emmc: gclock =0x1902645, gdelay=0x20202320, gadjust=0x0
[    4.773909@2] emmc: new HS200 MMC card at address 0001
[    4.778199@2] emmc: clock 200000000, 8-bit-bus-width
 楼主| 发表于 2021-2-5 22:19:34 | 显示全部楼层
[    4.783665@0] mmcblk0: emmc:0001 016G70 14.6 GiB
[    4.788154@0] mmcblk0boot0: emmc:0001 016G70 partition 1 4.00 MiB
[    4.794183@0] mmcblk0boot1: emmc:0001 016G70 partition 2 4.00 MiB
[    4.800221@0] mmcblk0rpmb: emmc:0001 016G70 partition 3 4.00 MiB
[    4.807244@1]  mmcblk0: unknown partition table
[    4.811706@2] [mmc_read_partition_tbl] mmc read partition OK!
[    4.816229@2] add_emmc_partition
[    4.819610@0] [mmcblk0p01]           bootloader  offset 0x000000000000, size 0x000000400000
[    4.827965@0] [mmcblk0p02]             reserved  offset 0x000002400000, size 0x000004000000
[    4.836282@0] [mmcblk0p03]                cache  offset 0x000006c00000, size 0x000010000000
[    4.844690@0] [mmcblk0p04]                  env  offset 0x000017400000, size 0x000000800000
[    4.853051@0] [mmcblk0p05]                 logo  offset 0x000018400000, size 0x000000400000
[    4.861419@0] [mmcblk0p06]             recovery  offset 0x000019000000, size 0x000001000000
[    4.869778@0] [mmcblk0p07]                param  offset 0x00001a800000, size 0x000002000000
[    4.878153@0] [mmcblk0p08]                crypt  offset 0x00001d000000, size 0x000001000000
[    4.886473@0] [mmcblk0p09]                 misc  offset 0x00001e800000, size 0x000001000000
[    4.894885@0] [mmcblk0p10]                 boot  offset 0x000020000000, size 0x000001400000
[    4.903241@0] [mmcblk0p11]               system  offset 0x000021c00000, size 0x000040000000
[    4.911629@0] [mmcblk0p12]             cri_data  offset 0x000062400000, size 0x000000800000
[    4.919966@0] [mmcblk0p13]               tvinfo  offset 0x000063400000, size 0x000000a00000
[    4.928354@0] [mmcblk0p14]                panic  offset 0x000064600000, size 0x000000400000
[    4.936671@0] [mmcblk0p15]              persist  offset 0x000065200000, size 0x000000800000
[    4.945085@0] [mmcblk0p16]               backup  offset 0x000066200000, size 0x000024000000
[    4.953436@0] [mmcblk0p17]                 data  offset 0x00008aa00000, size 0x000320a00000
[    4.961717@0] card key: card_blk_probe.
[    4.965441@0] emmc_key_init:524 emmc key lba_start:0x12020,lba_end:0x12220
[    4.972276@0] emmc key: emmc_key_init:549 ok.
[    4.976581@0] amlmmc_dtb_init: register dtb chardev
[    4.981433@0] amlmmc_dtb_init: register dtb chardev OK[    4.986381@0] Exit aml_emmc_partition_ops OK.
[    4.992269@0]  mmcblk0boot1: unknown partition table
[    4.996927@0]  mmcblk0boot0: unknown partition table
[    5.000636@0] clear_emmc_wait_flag
[    5.327081@0] GACT probability NOT on
[    5.327108@0] Mirror/redirect action on
[    5.328906@0] u32 classifier
[    5.331753@0]     Actions configured
[    5.335293@0] Netfilter messages via NETLINK v0.30.
[    5.340190@0] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    5.346766@0] ctnetlink v0.93: registering with nfnetlink.
[    5.352278@1] xt_time: kernel timezone is -0000
[    5.356319@1] ipip: IPv4 over IPv4 tunneling driver
[    5.361689@1] ip_tables: (C) 2000-2006 Netfilter Core Team
[    5.366606@1] arp_tables: (C) 2002 David S. Miller
[    5.371323@1] TCP: cubic registered
[    5.374704@1] Initializing XFRM netlink socket
[    5.379848@1] NET: Registered protocol family 10
[    5.384408@1] mip6: Mobile IPv6
[    5.386797@1] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    5.392506@1] sit: IPv6 over IPv4 tunneling driver
[    5.398104@1] NET: Registered protocol family 17
[    5.401640@1] NET: Registered protocol family 15
[    5.406267@1] Bridge firewalling registered
[    5.410409@1] Bluetooth: RFCOMM TTY layer initialized
[    5.415340@1] Bluetooth: RFCOMM socket layer initialized
[    5.420670@1] Bluetooth: RFCOMM ver 1.11
[    5.424478@1] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    5.429912@1] Bluetooth: BNEP filters: protocol multicast
[    5.435256@1] Bluetooth: BNEP socket layer initialized
[    5.440351@1] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    5.446384@1] Bluetooth: HIDP socket layer initialized
[    5.451520@1] l2tp_core: L2TP core driver, V2.0
[    5.455957@1] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    5.460873@1] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[    5.466579@1] l2tp_netlink: L2TP netlink interface
[    5.471340@1] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[    5.477364@1] l2tp_debugfs: L2TP debugfs support
[    5.481913@1] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[    5.488503@1] NET: Registered protocol family 35
[    5.493097@1] Key type dns_resolver registered
[    5.499833@1] Registering SWP/SWPB emulation handler
[    5.502917@1] regulator-dummy: disabling
[    5.506513@1] aml_vrtc rtc.3: setting system clock to 2015-01-01 00:00:09 UTC (1420070409)
[    5.515728@1] cpufreq-scpi cpufreq-meson.8: enter  cpufreq
[    5.519912@1] cpufreq-scpi cpufreq-meson.8: probe  cpufreq okay
[    5.526916@0] gxbb_pm: enter meson_pm_probe!
[    5.529993@0] gxbb_pm: wakeup_reason: unknown
[    5.534297@0] gxbb_pm: meson_pm_probe done
[    5.538762@0] thermal_zone_bind_cooling_device soc_thermal:1 thermal-cpufreq-0
[    5.545682@0] cpucore_cooling_register, max_cpu_core_num:4
[    5.551293@0] thermal_zone_bind_cooling_device soc_thermal:1 thermal-cpucore-0
[    5.573431@0] aml_istbt_dev_ready NULL
[    5.573493@X    5.578546@0] meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 115200 to 115200
[    5.581869@0] Freeing unused kernel memory: 1200K (ffffffc001f4d000 - ffffffc002079000)
[    5.606989@1] init: init started!
[    5.608222@2] init: init second stage started!
[    5.609526@2] init: waitpid failed: No child processes
[    5.614305@2] init: (Loading properties from /default.prop took 0.00s.)
[    5.622064@2] init: (Parsing /init.environ.rc took 0.00s.)
[    5.626357@2] init: (Parsing /init.usb.rc took 0.00s.)
[    5.631562@2] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[    5.637173@2] init: (Parsing /init.zygote32.rc took 0.00s.)
[    5.642715@2] init: (Parsing /init.trace.rc took 0.00s.)
[    5.648533@2] init: /init.amlogic.rc: 433: invalid command 'e2fsck'
[    5.654651@2] init: (Parsing init.amlogic.usb.rc took 0.00s.)
[    5.659814@2] init: (Parsing init.amlogic.board.rc took 0.01s.)
[    5.665689@2] init: could not import file 'init.amlogic.wifi.rc' from '/init.amlogic.rc'
[    5.673722@2] init: could not import file 'init.mtk.rc' from '/init.amlogic.rc'
[    5.680944@2] init: (Parsing /init.amlogic.rc took 0.03s.)
[    5.686369@2] init: (Parsing /init.rc took 0.07s.)
[    5.691388@2] init: Starting service 'ueventd'...
[    5.697222@0] ueventd: ueventd started!
[    5.867W    5.868427@2] meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 115200 to 115200
[    5.896108@2] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: (null)
[    5.898886@2] fs_mgr: __mount(source=/dev/block/system,target=/system,type=ext4)=0
[    5.907350@2] EXT4-fs (mmcblk0p17): Ignoring removed nomblk_io_submit option
[    5.916495@2] EXT4-fs (mmcblk0p17): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[    5.924573@2] fs_mgr: check_fs(): mount(/dev/block/data,/data,ext4)=0: Success
[    5.968044@3] fs_mgr: check_fs(): unmount(/data) succeeded
[    5.968837@3] fs_mgr: Running /system/bin/e2fsck on /dev/block/data
[    6.032927@3] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    6.032927@3]
[    6.033669@3] e2fsck: /dev/block/data: clean, 2034/820928 files, 469392/3279360 blocks
[    6.033669@3]
[    6.044114@3] EXT4-fs (mmcblk0p17): Ignoring removed nomblk_io_submit option
[    6.053165@3] EXT4-fs (mmcblk0p17): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submit,errors=remount-ro,discard
[    6.062502@3] fs_mgr: __mount(source=/dev/block/data,target=/data,type=ext4)=0
[    6.070520@3] EXT4-fs (mmcblk0p3): Ignoring removed nomblk_io_submit option
[    6.079282@3] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[    6.087168@3] fs_mgr: check_fs(): mount(/dev/block/cache,/cache,ext4)=0: Success
[    6.127906@2] fs_mgr: check_fs(): unmount(/cache) succeeded
[    6.127960@2] fs_mgr: Running /system/bin/e2fsck on /dev/block/cache
[    6.152166@2] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    6.152166@2]
[    6.152903@2] e2fsck: /dev/block/cache: clean, 13/16384 files, 2091/65536 blocks
[    6.152903@2]
[    6.162898@2] EXT4-fs (mmcblk0p3): Ignoring removed nomblk_io_submit option
[    6.171647@2] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submit,errors=remount-ro
[    6.180362@2] fs_mgr: __mount(source=/dev/block/cache,target=/cache,type=ext4)=0
[    6.188756@2] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[    6.197528@2] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[    6.205358@2] fs_mgr: check_fs(): mount(/dev/block/tvinfo,/tvinfo,ext4)=0: Success
[    6.267917@3] fs_mgr: check_fs(): unmount(/tvinfo) succeeded
[    6.267967@3] fs_mgr: Running /system/bin/e2fsck on /dev/block/tvinfo
[    6.290912@3] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    6.290912@3]
[    6.291644@3] e2fsck: /dev/block/tvinfo: clean, 12/640 files, 1078/2560 blocks
[    6.291644@3]
[    6.301379@3] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[    6.310296@3] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submit,errors=remount-ro
[    6.319111@3] fs_mgr: __mount(source=/dev/block/tvinfo,target=/tvinfo,type=ext4)=0
[    6.327403@3] EXT4-fs (mmcblk0p15): Ignoring removed nomblk_io_submit option
[    6.336220@3] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[    6.344287@3] fs_mgr: check_fs(): mount(/dev/block/persist,/persist,ext4)=0: Success
[    6.407904@3] fs_mgr: check_fs(): unmount(/persist) succeeded
[    6.408031@3] fs_mgr: Running /system/bin/e2fsck on /dev/block/persist
[    6.431166@3] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    6.431166@3]
[    6.431899@3] e2fsck: /dev/block/persist: clean, 14/512 files, 1073/2048 blocks
[    6.431899@3]
[    6.441723@3] EXT4-fs (mmcblk0p15): Ignoring removed nomblk_io_submit option
[    6.450518@3] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Opts: nodelalloc,nomblk_io_submit,errors=remount-ro
[    6.459475@3] fs_mgr: __mount(source=/dev/block/persist,target=/persist,type=ext4)=0
[    6.467924@3] EXT4-fs (mmcblk0p7): Ignoring removed nomblk_io_submit option
[    6.476743@3] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[    6.484616@3] fs_mgr: check_fs(): mount(/dev/block/param,/param,ext4)=0: Success
[    6.547903@3] fs_mgr: check_fs(): unmount(/param) succeeded
[    6.547955@3] fs_mgr: Running /system/bin/e2fsck on /dev/block/param
[    6.570955@3] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[    6.570955@3]
[    6.571692@3] e2fsck: /dev/block/param: clean, 17/2048 files, 1555/8192 blocks
[    6.571692@3]
[    6.581440@3] EXT4-fs (mmcblk0p7): Ignoring removed nomblk_io_submit option
[    6.590181@3] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[    6.598059@3] fs_mgr: __mount(source=/dev/block/param,target=/param,type=ext4)=0
[    6.664113@0] logd.auditd: start
[    6.664177@0] logd.klogd: 6507314044
[    6.739148@2] mali d00c0000.t83x: Continuing without Mali regulator control
[    6.740481@2] mali d00c0000.t83x: Continuing without Mali clock control
[    6.747067@2] mali d00c0000.t83x: set min pp to default 1
[    6.752368@2] mali d00c0000.t83x: set min clk default to 0
[    6.757880@2] mali d00c0000.t83x: dvfs table is 5
[    6.762460@2] mali d00c0000.t83x: dvfs table addr ffffffc0621f6a18, ele size=48
[    6.769713@2] mali d00c0000.t83x: max clk set 3
[    6.774189@2] mali d00c0000.t83x: turbo clk set to 4
[    6.779113@2] mali d00c0000.t83x: default clk set to 1
[    6.784263@2] mali_plat=ffffffbffc0439b0
[    6.788555@2] thermal_zone_bind_cooling_device soc_thermal:1 thermal-gpufreq-0
gpu cooling register okay with err=0
[    6.798760@2] thermal_zone_bind_cooling_device soc_thermal:1 thermal-gpucore-0
gpu core cooling register okay with err=0
[    6.809828@2] gpu_power_main, 63
[    6.812886@2] hrtimer: interrupt took 14750 ns
[    6.817579@2] mali d00c0000.t83x: GPU identified as 0x0830 r1p0 status 0
[    6.824867@1] mali d00c0000.t83x: Probed as mali0
[    6.836100@1] tfat: module license 'Commercial. For support email exfat-support@tuxera.com' taints kernel.
[    6.840125@1] Disabling lock debugging due to kernel taint
[    6.847873@1] Tuxera FAT 12/16/32 driver version 3017.7.24.1 [Flags: R/W MODULE].
[    6.852952@1] Built against headers 3.14.29 #1 SMP PREEMPT Wed Jan 31 16:27:11 CST 2018 arm64
[    6.861412@1] Running on kernel 3.14.29 #1 SMP PREEMPT Tue Mar 20 11:44:37 CST 2018 aarch64
[    6.881148@1] Tuxera NTFS driver 3015.1.29 [Flags: R/W MODULE].
[    6.888449@1] Tuxera exFAT driver version 3015.1.29 [Flags: R/W MODULE].
[    6.889510@1] Built against headers 3.14.29 #1 SMP PREEMPT Wed Jan 31 16:27:11 CST 2018 arm64
[    6.897974@1] Running on kernel 3.14.29 #1 SMP PREEMPT Tue Mar 20 11:44:37 CST 2018 aarch64
[    6.906242@1] WARNING: Running kernel does not match configured kernel headers the driver was built with!  The driver needs to be rebuilt with the correct kernel headers!
[    6.933569@1] init: /recovery not specified in fstab
[    6.955407@1] init: Failed to reload policy
[    6.993141@1] init: cannot find '/sbin/healthd', disabling 'healthd'
[    7.007623@0] logd.daemon: reinit
[    7.009457@1] amlkey_init() enter!
[    7.009490@1] amlkey_init() storagekey_info.buffer=ffffff8001700000, storagekey_info.size = 40000!
[    7.019641@2] emmc_key_read:426, read ok
[    7.022096@2] vfm_map_store:rm default
[    7.025778@2] vfm_map_store:add default decoder ppmgr deinterlace amvideo
[    7.032069@2] init: property_set("ro.radio.noril", "true" failed
[    7.039333@2] lcd: set pll spread spectrum: 3, +/-0.9%
[    7.045396@3] dig: dig start!
[    7.388070@3] fb: afbc: 1
[    7.388136@3] fb: use ion buffer for fb memory
[    7.389490@3] fb: OSD0 as afbcd mode
[    7.393230@3] meson-fb meson-fb.14: create ion_client ffffffc062d43300, handle=ffffffc0613262c0
[    7.401943@3] meson-fb meson-fb.14: ion memory(0): created fb at 0x000000007c000000, size 8 MiB
[    7.410304@3] fb:  0, phy: 0x000000007c000000, vir:0xffffff8008d7f000, size=8300K
[    7.410304@3]
[    7.419508@3] meson-fb meson-fb.14: create ion_client ffffffc062d43300, handle=ffffffc0613263c0
[    7.427970@3] meson-fb meson-fb.14: ion memory(0): created fb at 0x000000007c81b000, size 8 MiB
[    7.436563@3] fb:  0, phy: 0x000000007c81b000, vir:0xffffff800959b000, size=8300K
[    7.436563@3]
[    7.445774@3] meson-fb meson-fb.14: create ion_client ffffffc062d43300, handle=ffffffc061326400
[    7.454264@3] meson-fb meson-fb.14: ion memory(0): created fb at 0x000000007d036000, size 8 MiB
[    7.462880@3] fb:  0, phy: 0x000000007d036000, vir:0xffffff8009db7000, size=8300K
[    7.462880@3]
[    7.471931@3] fb: Frame buffer memory assigned at
[    7.476414@3] fb:  0, phy: 0x000000007c000000, vir:0xffffff8008d7f000, size=8300K
[    7.476414@3]
[    7.485650@3] fb:  0, phy: 0x000000007c000000, vir:0xffffff8008d7f000, size=8300K
[    7.485650@3]
[    7.494701@3] fb:  0, phy: 0x000000007c81b000, vir:0xffffff800959b000, size=8300K
[    7.494701@3]
[    7.503760@3] fb:  0, phy: 0x000000007d036000, vir:0xffffff8009db7000, size=8300K
[    7.503760@3]
[    7.512818@3] fb: ---------------clear fb0 memory ffffff8008d7f000
[    7.521308@3] fb: ---------------clear fb0 memory ffffff8008d7f000
[    7.527419@3] fb: ---------------clear fb0 memory ffffff800959b000
[    7.533544@3] fb: ---------------clear fb0 memory ffffff8009db7000
[    7.539684@3] fb: osd[0] canvas.idx =0x40
[    7.541272@3] fb: osd[0] canvas.addr=0x7c000000
[    7.545757@3] fb: osd[0] canvas.width=7680
[    7.549814@3] fb: osd[0] canvas.height=3240
[    7.553948@3] fb: osd[0] frame.width=1920
[    7.557932@3] fb: osd[0] frame.height=1080
[    7.606101@3] fb: use ion buffer for fb memory
[    7.606234@3] meson-fb meson-fb.14: create ion_client ffffffc062d43300, handle=ffffffc06125d180
[    7.613683@3] meson-fb meson-fb.14: ion memory(1): created fb at 0x000000007d851000, size 1 MiB
[    7.622184@3] fb: Frame buffer memory assigned at
[    7.626650@3] fb:  1, phy: 0x000000007d851000, vir:0xffffff800a5d3000, size=1024K
[    7.626650@3]
[    7.766791@0] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    7.766839@0] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    7.774864@0] xhci-hcd xhci-hcd.0.auto: irq 62, io mem 0xc9000000
[    7.780747@0] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    7.787534@0] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.794890@0] usb usb1: Product: xHCI Host Controller
[    7.799866@0] usb usb1: Manufacturer: Linux 3.14.29 xhci-hcd
[    7.805446@0] usb usb1: SerialNumber: xhci-hcd.0.auto
[    7.811506@1] hub 1-0:1.0: USB hub found
[    7.814353@1] hub 1-0:1.0: 4 ports detected
[    7.818759@1] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    7.824092@1] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    7.831951@1] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    7.838777@1] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.846070@1] usb usb2: Product: xHCI Host Controller
[    7.851081@1] usb usb2: Manufacturer: Linux 3.14.29 xhci-hcd
[    7.856678@1] usb usb2: SerialNumber: xhci-hcd.0.auto
[    7.862524@1] hub 2-0:1.0: USB hub found
[    7.865586@1] hub 2-0:1.0: 1 port detected
[    7.870820@1] init: property 'ro.usb.vendor.string' doesn't exist while expanding '${ro.usb.vendor.string}'
[    7.879312@1] init: cannot expand '${ro.usb.vendor.string}' while writing to '/sys/class/android_usb/android0/f_mass_storage/vendor_string'
[    7.892020@1] init: property 'ro.usb.product.string' doesn't exist while expanding '${ro.usb.product.string}'
[    7.901553@1] init: cannot expand '${ro.usb.product.string}' while writing to '/sys/class/android_usb/android0/f_mass_storage/product_string'
[    7.915264@1] SysRq : Changing Loglevel
[    7.917922@1] Loglevel set to 4
[    7.924732@1] init: cannot find '/system/bin/sensord', disabling 'sensord'
[    7.940214@1] init: cannot find '/system/xbin/perfprofd', disabling 'perfprofd'
[    7.942597@1] init: cannot find '/system/bin/instabootserver', disabling 'instaboot'
[    7.987680@0] android_usb: Cannot enable 'adb' (-22)
[    8.100260@1] init: property_set("ro.ubootenv.varible.prefix", "ubootenv.var" failed
[    8.389559@1]  key_unify_init() already inited!
[    8.389680@1] name: hdcp22_rx_fw, size 1128
[    8.852888@1] pgd = ffffffc06111c000
[    8.852913@1] [00000018] *pgd=0000000000000000
[    9.942228@1]  key_unify_init() already inited!
[    9.942323@1] name: hdcp14_rx, size 348
[   16.991117@0] alloc_rdev: cannot get rdev because rdev_buf unused rdev_buf_size 0 alloc_size 3680, call kzalloc
[   16.996460@2] alloc_rdev: save ffffffc056c99000 3680 to rdev_buf
[   20.885992@3] vfm_map_store:rm default
[   20.886115@3] vfm_map_store:add default decoder amlvideo deinterlace amvideo
[   21.060056@0] dig: isBootCompleted:1!
[   21.060947@0] dig: setDataRoCount count:0!
[   21.092303@2] PROJECTOR_RGB_CURRENT_SET 200
[   21.093884@2] android_usb: Cannot enable 'adb' (-22)
[   36.115123@3] vfm_map_store:rm default
[   36.115198@3] vfm_map_store:add default decoder ppmgr deinterlace amvideo
------------------------------------------分割线----------------------------------------------------------------------------------------------------
 楼主| 发表于 2021-2-5 22:20:13 | 显示全部楼层
如果开机打印日志时,按回车键中断后,是可以输入命令的,输入help命令,查看并没有可以进入system分区的命令。日志如下:
GXTVBB:BL1:ee57c+:7a1241;FEAT:EDFC318C;POC:3;RCY:0;EMMC:0;READ:0;CHK:0;
no sdio debug board detected
TE: 68417
BL2 Built : 17:57:38, Apr  1 2016.
gxtvbb gb30adc1 - xiaobo.gu@droid05
bbcykyo run in pwm_init
bbcykyo run in pwm_a_1 init finish
bbcykyo run in pwm_d init finish
set vcck to 1100 mv
bbcykyo pwm_set_voltage
set vddee to 1100 mv pwm_d
set vddee to  mv
set AO 2/4 low,3/5 high
set AO 10 input
Board ID = 12
CPU clk: 1536MHz
DDR channel: DDR0+1 two channel @ 720MHz
DDR0: 1024MB-2T-11
DDR1: 1024MB-2T-11
DataBus test pass!
AddrBus test pass!
-s
Load fip header from eMMC, src: 0x0000c000, des: 0x01400000, size: 0x00004000
Load bl30 from eMMC, src: 0x00010000, des: 0x01000000, size: 0x0000d460
Sending bl30......................................................OK.
Run bl30...
Load bl31 from eMMC, src: 0x00020000, des: 0x101b0000, size: 0x00013140
l30: check_permit, count is 1
bl30: check_permit: ok!
efuse_pw_en: 0x3
Load bl33 from eMMC, src: 0x00034000, des: 0x01000000, size: 0x000f1310
[Image: gxtvb_v1.1.3109-f651ed3 2016-05-05 19:38:44 xing.xu@droid05]
efuse_setup() 223: OPS=0x12
bl30: check_permit, count is 1
chipid: ef be ad de d f0 ad ba ef be ad de not ES chip
[0.211194 Inits done]
secure task start!
high task start!
low task start!
low task NOTICE:  BL3-1: v1.0(debug):d1ef098
NOTICE:  BL3-1: Built : 10:34:39, Mar 22 2016
INFO:    BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x1000000
INFO:    BL3-1: Next image spsr = 0x3c9
U-Boot 2015.01-g12a85c2 (Mar 20 2018 - 11:39:29), Build: jenkins-Me2_release-415
DRAM:  2 GiB
Relocation Offset is: 76e81000
register usb cfg[0][1] = 0000000077f62fd0
aml_i2c_init g_aml_i2c_plat_num: 1
aml_i2c_init 1 init.
===========power on turn off led light=====
set A06 to high
set A011 to high
###### bbcykyo reset c788 #####gpio: pin GPIOAO_5 (gpio 127) value is 1
gpio: pin GPIOAO_13 (gpio 135) value is 0
gpio: pin GPIOY_2 (gpio 34) value is 1
gpio: pin GPIOZ_13 (gpio 86) value is 1
gpio: pin GPIOZ_14 (gpio 87) value is 1
MMC:   aml_priv->desc_buf = 0x0000000073e81f40
aml_priv->desc_buf = 0x0000000073e83f50
SDIO Port B: 0, SDIO Port C: 1
emmc/sd response timeout, cmd8, status=0x3ff2800
emmc/sd response timeout, cmd55, status=0x3ff2800
[mmc_init] mmc init success
mmc read lba=0x14000, blocks=0x400
      Amlogic multi-dtb tool
      Single dtb detected
start dts,buffer=0000000073e86630,dt_addr=0000000073e86630
parts: 14
00:      logo   0000000000400000 1
01:  recovery   0000000001000000 1
02:     param   0000000002000000 2
03:     crypt   0000000001000000 1
04:      misc   0000000001000000 1
05:      boot   0000000001400000 1
06:    system   0000000040000000 1
07:     cache   0000000010000000 2
08:  cri_data   0000000000800000 2
09:    tvinfo   0000000000a00000 4
10:     panic   0000000000400000 4
11:   persist   0000000000800000 4
12:    backup   0000000024000000 4
13:      data   ffffffffffffffff 4
get_dtb_struct: Get emmc dtb OK!
overide_emmc_partition_table: overide cache
[mmc_get_partition_table] skip partition cache.
Partition table get from SPL is :
        name                        offset              size              flag
   0: bootloader                         0            400000                  0
   1: reserved                     2400000           4000000                  0
   2: cache                        6c00000          10000000                  2
   3: env                         17400000            800000                  0
   4: logo                        18400000            400000                  1
   5: recovery                    19000000           1000000                  1
   6: param                       1a800000           2000000                  2
   7: crypt                       1d000000           1000000                  1
   8: misc                        1e800000           1000000                  1
   9: boot                        20000000           1400000                  1
  10: system                      21c00000          40000000                  1
  11: cri_data                    62400000            800000                  2
  12: tvinfo                      63400000            a00000                  4
  13: panic                       64600000            400000                  4
  14: persist                     65200000            800000                  4
  15: backup                      66200000          24000000                  4
  16: data                        8aa00000         320a00000                  4
mmc read lba=0x12000, blocks=0x2
mmc read lba=0x12002, blocks=0x2
mmc_read_partition_tbl: mmc read partition OK!
eMMC/TSD partition table have been checked OK!
mmc env offset: 0x17400000
In:    serial
Out:   serial
Err:   serial
##env version is V1.1.16
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
read emmc dtb
      Single dtb detected
vpu: clk_level in dts: 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
hardware_version: 0
panel_detect: panel_id = 0, panel_type = lvds_0
Saving Environment to aml-storage...
Writing to MMC(1)... done
lcd: no lcd_debug_print flag
lcd: no lcd_debug_test flag
lcd: detect mode: tv, key_valid: 0
lcd: load config from dts
lcd: use panel_type=lvds_0
lcd: bl: status disabled
lcd: bl: name: default, method: 5
vpp: vpp_init
### batteryout =disable
### set GPIOAO_13 low
Net:
set A06 to high
set A011 to high
###### bbcykyo reset c788 #####No ethernet found.
efuse_pw_en: 0x3
WARNING! efuse bits is disabled
Enable A53 JTAG to EE
wipe_data=successful
wipe_cache=successful
upgrade_step=2
[OSD]load fb addr from dts
[OSD]fb_addr for logo: 0x3d851000
[CANVAS]addr=0x3d851000 width=3840, height=2160
lcd: enable: OPD30, lvds, 1920x1080@60.0Hz
lcd: tv driver init(ver: 20170810)
lcd: lcd_pll_wait_lock: pll_lock=1, wait_loop=1
lcd: set pll spread spectrum: 2, +/-0.5%
[EFUSE_MSG]keynum is 4
[KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[mac] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet
gpio: pin GPIOAO_3 (gpio 125) value is 1
(Re)start USB...
USB0:   USB3.0 XHCI init start
Register 5000140 NbrPorts 5
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
** Bad device usb 0 **
InUsbBurn
[MSG]sof
Set Addr 9
Get DT cfg
Get DT cfg
Get DT cfg
set CFG
waitIdentifyTime(751) > timeout(750)
enter_systemoff
start down_fw_bcm
gpio: pin GPIOX_17 (gpio 111) value is 0
gpio: pin GPIOX_17 (gpio 111) value is 1
change module baud rate to: 2000000
try change host baud rate to: 2000000
try change host baud rate to: 115200
down_fw_bcm ok
INFO:    PSCI Affinity Map:
INFO:      AffInst: Level 0, MPID 0x0, State ON
INFO:      AffInst: Level 0, MPID 0x1, State OFF
INFO:      AffInst: Level 0, MPID 0x2, State OFF
INFO:      AffInst: Level 0, MPID 0x3, State OFF
bl31 reboot reason: 0x101
system cmd  0.
process command 00000006
bl30 enter suspend!
store restore gp0 pll
cpu clk suspend rate 1536000000
process command 00000001
power_off_projon
enter detect key
08915c0000000000host_wake enter high
exit_reason:0x04
cfg15 3b00000
cfg15 43b00000
TE: 71612
set vcck to 1100 mv
set vddee to  mv
set AO 10 input
Board ID = 12
CPU clk: 1536MHz
DDR0: 1024MB-2T-11
DDR1: 1024MB-2T-11
DataBus test pass!
AddrBus test pass!
-s
Run bl30...
Load bl31 from eMMC, src: 0x00020000, des: 0x10100b00, size: 0x00013140
efuse_pw_en: 0x3
[0.214387 Inits done]
secure task start!
high task start!
low task start!
DRAM:  2 GiB
set A06 to high
set A011 to high
      Single dtb detected
parts: 14
In:    serial
Out:   serial
Err:   serial
read emmc dtb
      Single dtb detected
hardware_version: 0
vpp: vpp_init
Net:
set A06 to high
set A011 to high
efuse_pw_en: 0x3
upgrade_step=2
gpio: pin GPIOAO_13 (gpio 135) value is 1
spicc: sys_clk=167000000, div=5
*******c788 init start************
start initializing c788!
##### ifh=2199,ifv=1125
B10_DDR3OCDDOP = 0x1F
B10_DDR3OCDDON = 0x1E
##set_projector_source write 0x05 0------
##set led enable write 0x01b 7------
*******c788 init end************
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
gxtvbb_p451_v1_me2#
gxtvbb_p451_v1_me2#
gxtvbb_p451_v1_me2#
gxtvbb_p451_v1_me2#df
Unknown command 'df' - try 'help'
gxtvbb_p451_v1_me2#ls
Unknown command 'ls' - try 'help'
gxtvbb_p451_v1_me2#su
Unknown command 'su' - try 'help'
gxtvbb_p451_v1_me2#help
?       - alias for 'help'
aml_sysrecovery- Burning with amlogic format package from partition sysrecovery
amlmmc  - AMLMMC sub system
autoscr - run script from memory
base    - print or set address offset
bmp     - manipulate BMP image data
booti   - boot arm64 Linux Image image from memory
bootm   - boot application image from memory
bootp   - boot image via network using BOOTP/TFTP protocol
c788_init- c788 init
cbusreg - cbus register read/write
clkmsr  - measure PLL clock
cmp     - memory compare
cp      - memory copy
crc32   - checksum calculation
dcache  - enable or disable data cache
ddrtest - DDR test function
defenv_reserv- reserve some specified envs after defaulting env
dhcp    - boot image via network using DHCP/TFTP protocol
down_fw_bcm- download fw to BT module, run down_fw_bcm directly.
echo    - echo args to console
efuse   - efuse read/write data commands
efuse_user- efuse user space read write ops
emmc    - EMMC sub system
env     - environment handling commands
exit    - exit script
false   - do nothing, unsuccessfully
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls   - list files in a directory (default /)
fatsize - determine a file's size
fdt     - flattened device tree utility commands
get_rebootmode- get reboot mode
go      - start application at address 'addr'
gpio    - query and control gpio pins
hardware_version_init- Init hardware version from GPIO pin configuration
help    - print command description/usage
i2c     - I2C sub-system
icache  - enable or disable instruction cache
imgread - Read the image from internal flash with actual size
irkey   - irkey key_value1 key_value2 time_value
itest   - return true/false on integer compare
jtagoff - disable jtag
jtagon  - enable jtag
keyman  - Unify key ops interfaces based dts cfg
keyunify- key unify sub-system
lcd     - lcd sub-system
loop    - infinite loop on address range
macreg  - ethernet mac register read/write/dump
md      - memory display
mm      - memory modify (auto-incrementing address)
mmc     - MMC sub system
mmcinfo - display MMC info
mw      - memory write (fill)
mwm     - mw mask function
nm      - memory modify (constant address)
open_scp_log- print SCP messgage
osd     - osd sub-system
panel_detect- Detect panel type from GPIO pin configuration
phyreg  - ethernet phy register read/write/dump
ping    - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
rarpboot- boot image via network using RARP/TFTP protocol
read_temp- cpu temp-system
reboot  - set reboot mode and reboot system
reset   - Perform RESET of the CPU
run     - run commands in an environment variable
saveenv - save environment variables to persistent storage
sdc_burn- Burning with amlogic format package in sdmmc
sdc_update- Burning a partition with image file in sdmmc card
set_trim_base- cpu temp-system
set_usb_boot- set usb boot mode
setenv  - set environment variables
sf      - SPI flash sub-system
showvar - print local hushshell variables
silent  - silent
sleep   - delay execution for some time
store   - STORE sub-system
systemoff- system off
temp_triming- cpu temp-system
test    - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
true    - do nothing, successfully
unpackimg- un pack logo image into pictures
update  - Enter v2 usbburning mode
usb     - USB sub-system
usb_burn- Burning with amlogic format package in usb
usb_update- Burning a partition with image file in usb host
usbboot - boot from USB device
version - print monitor, compiler and linker version
vout    - VOUT sub-system
vpu     - vpu sub-system
wipeisb - wipeisb
write_trim- cpu temp-system
write_version- cpu temp-system
gxtvbb_p451_v1_me2#
发表于 2021-2-7 05:36:43 来自手机浏览器 | 显示全部楼层
帮顶一下,好看,不懂
发表于 2022-8-11 21:45:39 | 显示全部楼层
一样的情况
按键没有任何反应
发表于 2025-7-9 04:25:22 | 显示全部楼层
感谢楼主提供分享
GMT+8, 2025-8-31 05:31 , Processed in 0.218401 second(s), 10 queries , Redis On.
