查看: 49050|回复: 11
[综合] ESP8266时钟加入DS3231
发表于 2021-3-19 09:10:54 | 显示全部楼层 |阅读模式
小白一个,跪求大佬指点。
8266+TM1637的时钟,想加入一个DS3231,让时钟掉电或断网继续走时,还请大佬不吝赐教,谢谢!
下面是时钟代码,代码来自度娘。
#include <ESP8266WiFi.h>
#include <time.h>
#include <TM1637Display.h>
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>         //https://github.com/tzapu/WiFiManager
// NTP Config
int timezone = 8 * 3600;
int dst = 0;
// Module connection pins (Digital Pins)
#define CLK D5
#define DIO D7
#define TEST_DELAY   2000
const uint8_t SEG_CONN[] = {
  SEG_A | SEG_D | SEG_E | SEG_F,                   // C
  SEG_C | SEG_D | SEG_E | SEG_G,                   // o
  SEG_C | SEG_E | SEG_G,                           // n
  SEG_C | SEG_E | SEG_G                            // n
const uint8_t SEG_PASS[] = {
  SEG_A | SEG_B | SEG_E | SEG_F | SEG_G,           // P
  SEG_A | SEG_B | SEG_C | SEG_E | SEG_F | SEG_G,   // A
  SEG_A | SEG_C | SEG_D | SEG_F | SEG_G,           // S
  SEG_A | SEG_C | SEG_D | SEG_F | SEG_G            // S
const uint8_t SEG_FAIL[] = {
  SEG_A | SEG_E | SEG_F | SEG_G,                   // F
  SEG_F | SEG_G,                                   // I
  SEG_D | SEG_F | SEG_G                            // L
const uint8_t SEG_DONE[] = {
  SEG_B | SEG_C | SEG_D | SEG_E | SEG_G,           // d
  SEG_A | SEG_B | SEG_C | SEG_D | SEG_E | SEG_F,   // O
  SEG_A | SEG_D | SEG_E | SEG_F | SEG_G            // E
TM1637Display display(CLK, DIO);
String lastTimeStr;
unsigned long lastShowColon = 0;
bool showColon = false;
bool hourcheck = false;
void setup()
  display.setBrightness(0x01);// 0x01~0x0e
  WiFiManager wifiManager;
  wifiManager.autoConnect("ClockAP");
  display.setSegments(SEG_CONN);
  while (WiFi.status() != WL_CONNECTED)
    delay(500);
  display.setSegments(SEG_PASS);
  delay(1000);
  // Get time from NTP server
  configTime(timezone, dst, "ntp1.aliyun.com");
  while (!time(nullptr))
    delay(500);
  display.setSegments(SEG_DONE);
  delay(1000);
void loop()
  uint8_t hour;
  bool hourcheck;
  time_t now = time(nullptr);
  struct tm* p_tm = localtime(&now);
  hour = p_tm->tm_hour;
  if (hour < 1)
    hourcheck = true;
  else
    hourcheck = false;
  if ((p_tm->tm_sec % 2) == 0)
    display.showNumberDecEx(hour * 100 + p_tm->tm_min, 0x40 , hourcheck);
  else
    display.showNumberDecEx(hour * 100 + p_tm->tm_min, 0x00, hourcheck );
发表于 2021-3-19 10:51:55 | 显示全部楼层
发表于 2021-3-19 11:07:18 来自手机浏览器 | 显示全部楼层
参与人数 1家元 +10 收起 理由
家睦 + 10
 楼主| 发表于 2021-3-19 11:53:40 | 显示全部楼层
发表于 2021-3-19 16:06:09 来自手机浏览器 | 显示全部楼层
发表于 2021-3-19 16:06:44 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2021-3-19 16:36:30 | 显示全部楼层
发表于 2021-3-19 18:12:16 | 显示全部楼层
发表于 2021-3-19 23:29:11 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2021-3-22 08:19:59 | 显示全部楼层
发表于 2021-3-22 13:44:41 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2021-3-27 14:46:38 | 显示全部楼层
GMT+8, 2026-8-31 04:31 , Processed in 0.109200 second(s), 10 queries , Gzip On, Redis On.
