查看: 2325|回复: 8
[SandForce] 金士顿sf2281原8贴板子没问题,又贴了八个相同的颗粒上去共16,报错
发表于 2021-6-22 23:02:43 | 显示全部楼层 |阅读模式
<?xml version = "1.0"?>
<Genesis_Log>
    <Log_Body>
Overall Summary:
                Start Time: Tue, 06/22/2021 @ 07:55:55
                  End Time: Tue, 06/22/2021 @ 07:56:18
             OverallResult: FAIL
                  ExitCode: (0x10090012:SF_GENESIS_IDENTIFY_ERROR)
Environment Settings:
          Input Parameters:
                  argv[1]: -PROCESS_SSD
                  argv[2]: 3:0:0:0
                  argv[3]: /home/1234/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
                  argv[4]: /home/1234/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/33206.123456.driveconfig
                  argv[5]: 12345
                  argv[6]: www_123
                  argv[7]: log=/home/1234/ssd/ssd.log
                  Log File: SF_Genesis_Main_Log__Tue_06.22.2021_07.55.55.log
                  Hostname: localhost.localdomain
           Host IP Address: 127.0.0.1
               Port Number: 2
                DeviceName: /dev/sg2
        SF_Genesis Version: v1.7.0.01020130612-fc14-32bit
   SF_Core Library Version: v1.7.1.20130612-fc14-32bit
         SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
                   WWN OUI: UNKNOWN
              WWN UniqueID: UNKNOWN
                Serial No.: UNKNOWN
                 Model No.: UNKNOWN
         Firmware Revision: UNKNOWN
              ROM Revision: UNKNOWN
            NAND Page Size: UNKNOWN
     Number Of Chip Enable: UNKNOWN
           Logical Sectors: UNKNOWN
                   NAND ID: UNKNOWN
        Flash Manufacturer: UNKNOWN
              Flash Device: UNKNOWN
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Tue 06/22/2021 07:55:55] - SF_Genesis has been invoked with the following parameters:
                      argv[2]: 3:0:0:0
                      argv[5]: 12345
                      argv[6]: www_123
[Tue 06/22/2021 07:55:55] - Instructing the operating system to purge any existing cached data for device: '3:0:0:0'
[Tue 06/22/2021 07:56:00] - Issuing a discovery command for device: '3:0:0:0'
[Tue 06/22/2021 07:56:06] - Discovery command completed...
[Tue 06/22/2021 07:56:06] - Waiting 5 seconds for the system to settle...
[Tue 06/22/2021 07:56:11] - Device designation string '3:0:0:0' is mapped to node '/dev/sg2'
[Tue 06/22/2021 07:56:11] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = /home/1234/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/FW_PPRO_6_0_A_Release.1134440.release.123456.mfp
      Configuration File = /home/1234/ssd/mpt/FW_PPRO_6_0_A_Release.1134440.release--123456/Configuration_Files/33206.123456.driveconfig
              Serial No. = 12345
         World Wide Name = www_123
[Tue 06/22/2021 07:56:18] - FATAL_ERROR: Could not get the IDENTIFY data from the drive... (0x12000005:SF_SG_HOST_ABORT_ERROR)
[Tue 06/22/2021 07:56:18] - End of Genesis manufacturing log.
[Tue 06/22/2021 07:56:18] - Exiting...
    </Log_Body>
    <Overall_Summary>
        <Start_Time> Tue, 06/22/2021 @ 07:55:55 </Start_Time>
        <End_Time> Tue, 06/22/2021 @ 07:56:18 </End_Time>
        <Overall_Result> FAIL </Overall_Result>
        <Exit_Code> (0x10090012:SF_GENESIS_IDENTIFY_ERROR) </Exit_Code>
    </Overall_Summary>
    <Environment_Settings>
        <Input_Parameters>
                  argv[2]: 3:0:0:0
                  argv[5]: 12345
                  argv[6]: www_123
        </Input_Parameters>
        <Log_File> SF_Genesis_Main_Log__Tue_06.22.2021_07.55.55.log </Log_File>
        <Hostname> localhost.localdomain </Hostname>
        <Host_IP_Address> 127.0.0.1 </Host_IP_Address>
        <Port_Number> 2 </Port_Number>
        <Device_Name> /dev/sg2 </Device_Name>
        <SF_Genesis_Version> v1.7.0.01020130612-fc14-32bit </SF_Genesis_Version>
        <SF_Core_Library_Version> v1.7.1.20130612-fc14-32bit </SF_Core_Library_Version>
        <SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
    </Environment_Settings>
    <Post_Processing_Device_Info>
        <WWN_OUI> UNKNOWN </WWN_OUI>
        <WWN_UniqueID> UNKNOWN </WWN_UniqueID>
        <Serial_Number> UNKNOWN </Serial_Number>
        <Model_Number> UNKNOWN </Model_Number>
        <Firmware_Revision> UNKNOWN </Firmware_Revision>
        <ROM_Revision> UNKNOWN </ROM_Revision>
        <NAND_Page_Size> UNKNOWN </NAND_Page_Size>
        <Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
        <Logical_Sectors> UNKNOWN </Logical_Sectors>
        <NAND_ID> UNKNOWN </NAND_ID>
        <Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
        <Flash_Device> UNKNOWN </Flash_Device>
    </Post_Processing_Device_Info>
</Genesis_Log>
[Tue 06/22/2021 07:56:18] - Overall Result for Device: /dev/sg2 ****** FAIL ******
 楼主| 发表于 2021-6-22 23:11:45 | 显示全部楼层
主控面,字数补丁
 楼主| 发表于 2021-6-22 23:25:31 | 显示全部楼层
很神奇的是另一个8贴板子之前开卡正常 拆了4个颗粒,剩四个,报同样的错
发表于 2021-6-24 08:33:55 | 显示全部楼层
你这个焊工不是太好,这种闪存很讲究焊工,不能开路也不能连锡!!放大镜伺候
 楼主| 发表于 2021-6-24 11:32:18 来自手机浏览器 | 显示全部楼层
wzcgx 发表于 2021-6-24 08:33
你这个焊工不是太好,这种闪存很讲究焊工,不能开路也不能连锡!!放大镜伺候 ...
可是为什么另一个好板子八个拆四个剩下四个不动 剩的四个刚好是4贴顺序 开卡报一样的错 拆下的焊盘已经清理干净了
发表于 2021-6-24 15:53:26 | 显示全部楼层
拆了就不是用原来的ID开了,因为容量变成原来一半了,要重新换ID开
 楼主| 发表于 2021-6-24 16:42:18 来自手机浏览器 | 显示全部楼层
id是肯定换了的
发表于 2021-6-25 08:39:51 | 显示全部楼层
颗粒位置是很重要的,拆下的是圈中的四颗粒
 楼主| 发表于 2021-6-26 10:13:33 来自手机浏览器 | 显示全部楼层
没有问题 拆的就是这四个
GMT+8, 2025-5-9 07:42 , Processed in 0.296401 second(s), 11 queries , Redis On.
