查看: 3239|回复: 3
武汉电信中兴F450 V4.0光猫的超级密码有没有人破解了的
发表于 2021-8-18 22:00:37 | 显示全部楼层 |阅读模式
不想开盖接串口看打印信息,有没有破解了网页或者telnet或者ssh的坛友?
 楼主| 发表于 2021-8-19 11:58:21 | 显示全部楼层
开盖了,串口打到启动系统就不打印了。
Boot SPI NAND
start read bootheader
start read secondboot
secure boot
CBC decrypt OK!
CBC decrypt OK!
verify OK!
Jump
rate is 1066M
value = 0x12
7smux:3f7ffffa:3ffffeff:19ff0555:6be1b
7s vid 67
vid is 67
ddr size 10000000
two plane
secure uboot
verify OK!
backup header!!
Jump
U-Boot 2013.04 (Oct 25 2020 - 20:57:17)
CPU  : ZX279127S@A9,1000MHZ
Board: ZXIC zx279127sevb
127s product_vid = 67
DRAM:  256 MiB
,10000000,50000000
cpuid=27912710
127s pinmux: 177770c0  3dd7  3fffc555  11ef7f
mtk reset,66,53
bootsel=3
NAND:
Manu ID: 0x2c, Chip ID: 0x24 (Micron SPI NAND MT29F2G01ABAGDWB  256MiB 3,3V)
256 MiB
<nand_read_skip_bad_,422>!mtdpart=0x1,offset=0x0,mtdpartoffset=0x180000,mtdPartsize=0x80000,length=0x20000
In:    serial
Out:   serial
Err:   serial
clk_pll env is not setted, core clk won't change
Net:   enter ref_clk_set.. mode = 0 .
enter pll_cfg_fractional
ref_clk_set success!
gpon serdes init
addr 0x9400002c before value is 11000013
addr 0x9400004c after value is 11003ff3
eth0
sec mode!
Hit 1 to upgrade software version
Hit any key to stop autoboot:  0
addr=3600000
addr=5c00000
select=0x0
search=0x2
<nand_read_skip_bad_,422>!mtdpart=0x6,offset=0x0,mtdpartoffset=0x200000,mtdPartsize=0x200000,length=0x1000
tmp=0x00000000, value=0
select=0x0
search=0x2
search->result[0].entry=3600240
<nand_read_skip_bad_,422>!mtdpart=0x2,offset=0x0,mtdpartoffset=0x3600000,mtdPartsize=0x2600000,length=0x1c80000
RSA Verify OK
---mtdparts_init--current_mtd_partnum=0-
dev id: type = 2, num = 0, size = 0xffffffff, mtd_id = single part
part  : name = rootfs0, size = 0x01c60000, offset = 0x03620000
part  : name = rootfs1, size = 0x01c60000, offset = 0x05c20000
--- jffs2_part_info: partition number 0 for device nand0 (single part)
jffs2_part_info:rootfs0,3620000
### JFFS2 loading '0uImage' to 0x44000000
Scanning JFFS2 FS: ................. done.
### JFFS2 load complete: 2757087 bytes loaded to 0x44000000
<nand_read_skip_bad_,422>!mtdpart=0x0,offset=0x0,mtdpartoffset=0x0,mtdPartsize=0x180000,length=0x80000
lseek=0x42077800
cmdline=U-Boot V3.0.0P1N5 20201025212423
output gpio:56, value=1, 0
output gpio:57, value=1, 0
output gpio:58, value=1, 0
output gpio:59, value=1, 0
## Booting kernel from Legacy Image at 44000000 ...
   Image Name:   Linux Kernel Image
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2757023 Bytes = 2.6 MiB
   Load Address: 40008000
   Entry Point:  40008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
|-->setup versioninfo tag...
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
发表于 2021-8-22 22:22:22 | 显示全部楼层
打10000直接要,我也是武汉电信
 楼主| 发表于 2021-8-23 23:21:58 来自手机浏览器 | 显示全部楼层
leonz 发表于 2021-8-22 22:22
打10000直接要,我也是武汉电信
客服不给。花10元到淘宝查了。
GMT+8, 2025-5-16 23:37 , Processed in 0.234000 second(s), 11 queries , Redis On.
