查看: 3623|回复: 7
[Realtek] [Realtek] 瑞昱RTL9210B芯片的固态硬盘盒升级固件v1.29.12加v1.28.17版本解决LDE问题
发表于 2022-9-15 19:16:13 | 显示全部楼层 |阅读模式
  瑞昱RTL9210B芯片的固态硬盘盒升级固件v1.29.12加v1.28.17版本解决刷机后LED不显示,弹出设备LED不灭,无硬盘显示空盘符问题。实测LED显示正常,弹出后LED灯灭,无硬盘不显示盘符。
方案:去掉 ;SUSPEND_LED_OFF = 0x1前面的;解决LED弹出显示问题
         去掉 DIS_SHOW_EMPTY_DISK = 0x1前面的;解决无硬盘显示显示空盘符问题
参考文献: https://blog.csdn.net/m0_55207244/article/details/124491389
                 https://www.mydigit.cn/forum.php ... 9E%E6%98%B1RTL9210B
                 https://wenku.baidu.com/view/614db7e7650e52ea54189803.html
配置文件
~~~~~~~~ 移动硬盘 ~~~~~~~~
复制代码
;Configure Start
;=================FW Configure=================
VID = 0xbda
PID = 0x9210
MANUFACTURE = "Realtek"
PRODUCT = "USB 3.2 Gen2x1 Storage Device"
;"0123" for Dec, "0x0123" for Hex, max 12 digits
SERIAL = "221010010023"
DISK_HOTPLUG = 0x0
PINMUX1 = 0x0
PINMUX2 = 0x0
U2_MAXPWR = 0xfa
U3_MAXPWR = 0x70
ASPMDIS = 0x0
;10 minutes of idle time will disable disk power
;DISK_IPS_THRES = 10
;EN_UPS = 0x0
;PD = 0x0
LED = 0x2
;CUSTOMIZED_LED is 15 bytes
;CUSTOMIZED_LED = 22 00
;FORCE_SATA_NORMAL_DMA = 0x0
UART_DBG_PIN = 5
;FINGER_PRINT_EN = n
;=================Tool Configure=================
;DISCONN_FORCE_USB2 = n
FORMAT_DISK = n
;INC_SERIAL = y
;PARTITION: GPT, MBR
PARTITION = "MBR"
;FORMAT: NTFS, exFAT
FORMAT = "NTFS"
;LABEL max allowed - characters
LABEL = "My USB"
发表于 2022-9-26 06:15:37 来自手机浏览器 | 显示全部楼层
发表于 2022-9-26 08:51:40 | 显示全部楼层
发表于 2022-10-2 14:37:42 来自手机浏览器 | 显示全部楼层
发表于 2022-10-3 10:51:57 | 显示全部楼层
发表于 2022-10-4 23:09:17 | 显示全部楼层
发表于 2023-11-14 16:54:45 | 显示全部楼层
GMT+8, 2026-10-24 00:15 , Processed in 0.156000 second(s), 9 queries , Gzip On, Redis On.
