查看: 1440|回复: 12
[网络] 拆个H3C ICG2000D
发表于 2023-7-25 10:34:24 | 显示全部楼层 |阅读模式
拆个H3C ICG2000D 就是MSR2600-6  Marvell(马牌)88F6820的CPU 频率貌似文档说是1.6
Processor        : ARMv7 Processor rev 1 (v7l)
processor        : 0
BogoMIPS        : 3186.68
processor        : 1
BogoMIPS        : 3186.68
Features        : swp half thumb fastmult vfp edsp
CPU implementer        : 0x41
CPU architecture: 7
CPU variant        : 0x4
CPU part        : 0xc09
CPU revision        : 1
Cache type        : write-back
Cache clean        : read-block
Cache lockdown        : not supported
Cache format        : Harvard
I size                : 512
I assoc                : 1
I line length        : 64
I sets                : 8
D size                : 8192
D assoc                : 128
D line length        : 8
D sets                : 8
Hardware        : Marvell Armada-38x Board
Marvell Armada-38x<6>1: (null) Board - <6>1: Soc: MV88F6820 Rev 0<6>1: LE
支持的AP
  SIC-AP320       SIC-AP320
  WA2610H         WA2610H
  WA2610H-LI      WA2610H-LI
  WA2620-WiNet    WA2620-WiNet
  WA2620E-WiNet   WA2620E-WiNet
  WA4320-ACN      WA4320-ACN
  WA4320-ACN-B    WA4320-ACN-B
  WA4320-ACN-C    WA4320-ACN-C
  WA4320-ACN-D    WA4320-ACN-D
  WA4320-ACN-E    WA4320-ACN-E
  WA4320-ACN-SI   WA4320-ACN-SI
  WA4320H         WA4320H
  WA4320H-ACN     WA4320H-ACN
  WA4320H-ACN-HI  WA4320H-ACN-HI
  WA4320H-EI      WA4320H-EI
  WA4320H-SI      WA4320H-SI
  WA4320X         WA4320X
  WA4320i-ACN     WA4320i-ACN
  WA4320i-X       WA4320i-X
  WA4330-ACN      WA4330-ACN
  WA510H-WW       WA510H-WW
  WA530-WW        WA530-WW
  WA530X-WW       WA530X-WW
  WA5320          WA5320
  WA5320-C        WA5320-C
  WA5320-C-EI     WA5320-C-EI
  WA5320-C-IOT    WA5320-C-IOT
  WA5320-D        WA5320-D
  WA5320-SI       WA5320-SI
  WA5320-WiNet    WA5320-WiNet
  WA5320E         WA5320E
  WA5320E-WiNet   WA5320E-WiNet
  WA5320H         WA5320H
  WA5320H-LI      WA5320H-LI
  WA5320H-WiNet   WA5320H-WiNet
  WA5320X         WA5320X
  WA5320X-E       WA5320X-E
  WA5320X-LI      WA5320X-LI
  WA5320X-SI      WA5320X-SI
  WA5320i         WA5320i
  WA5320i-LI      WA5320i-LI
  WA536-WW        WA536-WW
  WA538-WW        WA538-WW
  WA5530          WA5530
  WA5530-LI       WA5530-LI
  WA5530-SI       WA5530-SI
  WA5530S         WA5530S
  WA560-WW        WA560-WW
  WA5620          WA5620
  WA5620i-ACN     WA5620i-ACN
  WAP711H         WAP711H
  WAP712C-HI      WAP712C-HI
  WAP712C-LI      WAP712C-LI
  WAP712E         WAP712E
  WAP712H         WAP712H
  WAP712X         WAP712X
  WAP722E-W2      WAP722E-W2
  WAP722H         WAP722H
  WAP722S-HI      WAP722S-HI
  WAP722S-W2      WAP722S-W2
  WAP722S-W2-IOT  WAP722S-W2-IOT
  WAP722X-W2      WAP722X-W2
  WAP722XS-W2     WAP722XS-W2
  WAP723-W2       WAP723-W2
参与人数 2家元 +21 收起 理由
jf201006 + 12 謝謝分享
hongo + 9 原創內容
发表于 2023-7-25 11:35:30 | 显示全部楼层
看上去很养眼,谢谢分享!
发表于 2023-7-25 11:57:10 | 显示全部楼层
板子越来越小了,集中度也越来越高了,就接口板没得办法缩
 楼主| 发表于 2023-7-25 12:14:37 | 显示全部楼层
alangxl 发表于 2023-7-25 11:57
板子越来越小了,集中度也越来越高了,就接口板没得办法缩 ...
其实类似华为的AR1200 前面接板卡 减少宽度  这货在MSR2600里面 除了最新的V9新系统的 属它转发什么的最高了
发表于 2023-7-25 12:36:36 | 显示全部楼层
马牌也做固态主控,当年还挺火的。
发表于 2023-7-25 14:04:38 | 显示全部楼层
YAORONGBAOBAO 发表于 2023-7-25 12:36
马牌也做固态主控,当年还挺火的。
然而没得玩儿
发表于 2023-7-25 14:43:37 | 显示全部楼层
yangqi5678 发表于 2023-7-25 12:14
其实类似华为的AR1200 前面接板卡 减少宽度  这货在MSR2600里面 除了最新的V9新系统的 属它转发什么的最 ...
集成度越高,性能相对应的也应该更强。
发表于 2023-7-25 15:19:09 | 显示全部楼层
看用料做工还是挺不错的,集成度也越来越高了
发表于 2023-7-25 20:28:41 | 显示全部楼层
做工还是挺不错
发表于 2023-7-26 12:32:31 | 显示全部楼层
变化还挺大
发表于 2023-7-27 15:15:39 | 显示全部楼层
全靠系统卖钱。。。。。
发表于 2023-7-29 20:21:59 | 显示全部楼层
用料做工还是挺不错的,集成度越来越高…
GMT+8, 2025-7-11 05:17 , Processed in 0.156000 second(s), 9 queries , Redis On.
