发表于 2023-10-24 16:56:08
显示全部楼层
Hello friends, this is my first time posting, I don’t speak Chinese well, sorry :)
I have an RD6012P power supply which is very nice but it heats up very quickly and has a loud fan that is constantly on.
I checked it with a thermal imaging camera, and the parts that generated the most heat were the main converter tube and the large inductor. I have installed a larger heat sink on the tube and would like to install an inductor with a higher current rating but I don't know its inductance and current rating. Maybe someone has measured the inductance value of the main inductor?
朋友们好,这是我第一次发帖,我的中文说得不好,对不起:)
我有一个RD6012P电源,它很好,但它加热得很快,而且有一个一直开着的大风扇。
我用热成像相机检查了一下,产生热量最多的部件是主换流管和大电感器。我在管子上安装了一个更大的散热器,想安装一个额定电流更高的电感器,但我不知道它的电感和额定电流。也许有人测量过主电感器的电感值?
6012电源最大电流不能超过12A,我不知道你一般用多少电流,6012会在大电流的时侯产生大量的热并开启风扇,并产生声音。建议你如果用大电流,采用更高规格的6024
The maximum current of 6012 power supply cannot exceed 12A. I don't know how much current you usually use. 6012 will generate a large amount of heat and turn on the fan during high current, and produce sound. I suggest that if you use high current, use a higher specification 6024
