查看: 1677|回复: 9
[C51] 关于赋值,百思不得解的一个问题
发表于 2024-1-5 16:37:09 | 显示全部楼层 |阅读模式
在VBA中运行这一段语句:
               tmp1 = 0
               tmp2 = 0
               tmp3 = 0
               tmp4 = 0
               Debug.Print tmp1 & "," & tmp2 & "," & tmp3 & "," & tmp4 & ""
               tmp1 = 1
               tmp2 = 2
               tmp3 = 3
               tmp4 = 4
设想输出会是
               0,0,0,0
               1,0,0,0
               1,2,0,0
               1,2,3,0
               1,2,3,4
没想到实际输出是
               0,0,0,0
               1,0,0,0
               1,2,2,0
               1,3,3,0
               1,3,3,4
根据结果看是tmp2是tmp3这两个变量是同步变化的,实在是想不通,大家测试下其它环境下有没有这种现象,分析下这个是什么原因
发表于 2024-1-5 16:51:47 | 显示全部楼层
是不是跟变量延迟还是什么的有关系,貌似有这么个设置
发表于 2024-1-5 16:59:58 | 显示全部楼层
你的设想是错的,再仔细看下代码
发表于 2024-1-5 22:11:53 | 显示全部楼层
测试一:
https://c.runoob.com/compile/5648/ 输入代码:
  1. Module Module1
  2.     Sub Main()
  3.         Console.WriteLine("Hello World!")
  4.                 Dim tmp1,tmp2,tmp3,tmp4 AS Integer
  5.                 tmp1 = 0
  6.                 tmp2 = 0
  7.                 tmp3 = 0
  8.                 tmp4 = 0
  9.                 Console.WriteLine(tmp1 & "," & tmp2 & "," & tmp3 & "," & tmp4 & "")
  10.                 tmp1 = 1
  11.                 Console.WriteLine(tmp1 & "," & tmp2 & "," & tmp3 & "," & tmp4 & "")
  12.                 tmp2 = 2
  13.                 Console.WriteLine(tmp1 & "," & tmp2 & "," & tmp3 & "," & tmp4 & "")
  14.                 tmp3 = 3
  15.                 Console.WriteLine(tmp1 & "," & tmp2 & "," & tmp3 & "," & tmp4 & "")
  16.                 tmp4 = 4
  17.                 Console.WriteLine(tmp1 & "," & tmp2 & "," & tmp3 & "," & tmp4 & "")
  18.     End Sub
  19. End Module
复制代码
输出结果:
Hello World!
0,0,0,0
1,0,0,0
1,2,0,0
1,2,3,0
1,2,3,4
符合预期。
测试二:
在本地电脑中打开Excel(版本2311)启用 开发工具,新建工作簿,在代码编辑窗口输入代码:
  1. Sub 宏2()
  2.     Dim tmp1, tmp2, tmp3, tmp4 As Integer
  3.     tmp1 = 0
  4.     tmp2 = 0
  5.     tmp3 = 0
  6.     tmp4 = 0
  7.     Debug.Print tmp1 & "," & tmp2 & "," & tmp3 & "," & tmp4 & ""
  8.     tmp1 = 1
  9.     Debug.Print tmp1 & "," & tmp2 & "," & tmp3 & "," & tmp4 & ""
  10.     tmp2 = 2
  11.     Debug.Print tmp1 & "," & tmp2 & "," & tmp3 & "," & tmp4 & ""
  12.     tmp3 = 3
  13.     Debug.Print tmp1 & "," & tmp2 & "," & tmp3 & "," & tmp4 & ""
  14.     tmp4 = 4
  15.     Debug.Print tmp1 & "," & tmp2 & "," & tmp3 & "," & tmp4 & ""
  16. End Sub
复制代码
输出结果:
0,0,0,0
1,0,0,0
1,2,0,0
1,2,3,0
1,2,3,4
符合预期。
测试三:
在WIN10虚拟机中,运行VB,新建EXE,添加按键,编辑单击事件,代码如下:
  1. Private Sub Command1_Click()
  3.     tmp1 = 0
  4.     tmp2 = 0
  5.     tmp3 = 0
  6.     tmp4 = 0
  8.     tmp1 = 1
  10.     tmp2 = 2
  12.     tmp3 = 3
  14.     tmp4 = 4
  16. End Sub
复制代码
输出结果:
0,0,0,0
1,0,0,0
1,2,0,0
1,2,3,0
1,2,3,4
符合预期。
无法复现你的输出。
建议更换编辑环境。
发表于 2024-1-6 14:17:01 | 显示全部楼层
0,0,0,0
1,0,0,0
1,2,0,0
1,2,3,0
1,2,3,4
 楼主| 发表于 2024-1-7 17:48:59 | 显示全部楼层
茶壹杯 发表于 2024-1-5 16:59
你的设想是错的,再仔细看下代码
为什么这样说呢?楼下测试代码结果是符合预期的,但是我运行就是不行,如果把tmp3改成ccc结果就符合预期了,所以才说百思不得解
 楼主| 发表于 2024-1-7 17:55:46 | 显示全部楼层
啊啊斑斑驳驳 发表于 2024-1-5 22:11
测试一:
在 https://c.runoob.com/compile/5648/ 输入代码:
输出结果:
我用的是wps表格,这个情况出现过好几次了,最后的解决办法是改变量名,本来整齐的名字在调完程序就乱了
发表于 2024-1-7 23:54:03 | 显示全部楼层
在WIN10虚拟机中,安装WPS2019 专业版 版本号:11.8.2.10912-Release,新建表格,添加宏,代码如下:
  1. Sub Macro1()
  3.     tmp1 = 0
  4.     tmp2 = 0
  5.     tmp3 = 0
  6.     tmp4 = 0
  8.     tmp1 = 1
  10.     tmp2 = 2
  12.     tmp3 = 3
  14.     tmp4 = 4
  16. End Sub
复制代码
输出结果:
0,0,0,0
1,0,0,0
1,2,0,0
1,2,3,0
1,2,3,4
符合预期。
建议卸载重装,或更新版本。
 楼主| 发表于 2024-1-8 20:26:51 | 显示全部楼层
输出 ...
这个应该不是系统的问题,我看看把这部分单独剥离出来会不会也是这样
发表于 2024-1-16 15:16:53 | 显示全部楼层
有没有不符合预期的截图,我始终不太相信
发表于 2024-1-17 08:10:54 | 显示全部楼层
南天音乐 发表于 2024-1-16 15:16
有没有不符合预期的截图,我始终不太相信
我觉得也是有截图好一点
GMT+8, 2025-8-23 04:33 , Processed in 0.093600 second(s), 8 queries , Redis On.
