查看: 6454|回复: 13
CM311-3-YST(1G+8G)-晨星MSO9385 TTL线刷命令不能识别请教一下
发表于 2024-1-29 18:27:08 | 显示全部楼层 |阅读模式
CM311-3-YST(1G+8G)-晨星MSO9385 TTL线刷输入三个命令
第一,第二正常执行
第三个命令(avbab disable-verity)不能识别
请教大神帮助看一下什么原因,谢谢
以下是开机代码:
*********u16CZ*****************
00000001
*********u16DO*****************
00000001
*********_3padInitTbl*****************
20082900
*********Load OneBin Pad address:*****************
20082900
EMMC
Relocation Offset is: 015FF000
[AT][MB][start ub][0]
U-Boot 2011.06-00000-g575ae8d-dirty (Sep 01 2021 - 17:23:07)
[Mboot] ===== sw IR Config Register =====
[Mboot] ===== Attach IR Interrupt  ======
Function = SYSOpen, Line = 794, current resource pri_shm content is: 0
Function = SYSOpen, Line = 813, [SYS INFO] OPEN INSTANCE...
create instance at 2D7F8358 with private size 108 bytes at 2D7F83A0
[MIU INFO] miu opencreate instance at 2D7F8410 with private size 88 bytes at 2D7F8458
create instance at 2D7F84B8 with private size 44 bytes at 2D7F8500
uboot held at [2D5DDF60~2E900000],size=013220A0
DRAM:  233 MiB
Now running in RAM - U-Boot at: 2DE00000
eMMC: HS200 200MHz
eMMC 7.12 GB [E3FFF8h]
SAR5=ON
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MAC:  0xAC: 0xBB: 0x61: 0xD7:0xCF: 0x45
create instance at 2D808968 with private size 44 bytes at 2D8089B0
[AT][MBoot][Driver Init][0]
mmc change mount : tvconfig
Size of file "/config/sys.ini" from mmc device 0 partition tvconfig: 1809 bytes
Loading file "/config/sys.ini" at offset 0x0 from mmc device 0 partition tvconfig
1809 bytes read
sizeof( sys ini script ) --------> 1809 bytes
set platform=mi to bootargs OK
customer_ini_path env value --> /vendor/tvconfig/config/model/Customer_1.ini
Half model.ini path --> /vendor/tvconfig/config/model/Customer_1.ini
** File not found /vendor/tvconfig/config/model/Customer_1.ini
[ERROR] vfs_getsize:420: ext4filesize mmc fail, try again!
[ERROR] vfs_getsize:424: ext4filesize mmc fail
[ERROR] loadscript:867: No enough buffer or path fail(/vendor/tvconfig/config/model/Customer_1.ini) :
[src/MsUtility.c] [loadscript]
filter /tvconfig/config/model/Customer_1.ini, and find file again!!
** File not found /tvconfig/config/model/Customer_1.ini
[ERROR] loadscript:867: No enough buffer or path fail(/tvconfig/config/model/Customer_1.ini) :
Full model.ini  path --> /vendor/tvconfig/config/model/Customer_1.ini
** File not found /vendor/vendor/tvconfig/config/model/Customer_1.ini
[ERROR] loadscript:867: No enough buffer or path fail(/vendor/vendor/tvconfig/config/model/Customer_1.ini) :
filter /config, and find file again!!
mmc change mount : system
** File not found system/media/boot0.jpg
[ERROR] prepare_nand_dbtable:1055: /system/system/media/boot0.jpg do not exist !
** File not found 2D5DCDF4
gRGBWPath=
gstDbtable.dbdata[E_DB_RGBW].Size=0x0
MPOOL size : 0x200000
Size of file "/config/panel/DACOUT_1080P_60.ini" from mmc device 0 partition tvconfig: 6006 bytes
Loading file "/config/panel/DACOUT_1080P_60.ini" at offset 0x0 from mmc device 0 partition tvconfig
6006 bytes read
sizeof( panel ini script ) --------> 6006 bytes
u32PeriodPWM = 0
u32DutyPWM = 0x0
** File not found 2D5DD104
[ERROR] loadscript:867: No enough buffer or path fail() :
[ERROR] vfs_getsize:393: filedir is a null pointer
[ERROR] Load_BoardSetting_ToFlash:2111: parse_board_ini fail !!
set resolution info to bootargs
Size of file "/config/dfbrc.ini" from mmc device 0 partition tvconfig: 1464 bytes
Loading file "/config/dfbrc.ini" at offset 0x0 from mmc device 0 partition tvconfig
1464 bytes read
sizeof( dfb ini script ) --------> 1464 bytes
logo -> [1]
Size of file "/config/ir_config.ini" from mmc device 0 partition tvconfig: 9236 bytes
Loading file "/config/ir_config.ini" at offset 0x0 from mmc device 0 partition tvconfig
9236 bytes read
sizeof( ir_config ini script ) --------> 9236 bytes
section = MIR_Mstar
section = MIR_ChinaMobile
section = MIR_ChinaUnicom
section = MIR_ChinaTelecom
section = MIR_ChinaMobile_00FF
9236 bytes read
section = PIR_ChinaMobile_00FF
section = PIR_ChinaMobile_2014
** File not found 2D5DD214
[ERROR] Load_RGBWBinToFlash:2715: vfs_getsize error:  !
3 blocks written: OK
Writing to MMC(0)... 128 blocks written: OK
done
Changelist:     00112233
============= set bootargs ===============
[Mboot] ===== zjj.... before shezhi ipaddr ===AC:BB:61:D7:CF:45==17
============= after bootargs ===============
[ERROR] set_bootargs_cfg:940: New bootargs( NewArgLen : 1260) has exceeded the env_size( CONFIG_SYS_CBSIZE :1024 )
set_bootargs_cfg failed !
[ERROR] set_security_cfg:1112: set SECURITY=ON/OFF to bootargs fail
WDT is not Enable !!!setenv WDT_ENABLE 1 to enable it.
Hit any key to stop autoboot:  0
C2P#
C2P#
C2P#
C2P#
C2P#
补充内容 (2024-3-4 11:18):
应该是 CM311-3S-YST(1G+8G)-晨星MSO9385安卓4.4.2
发表于 2024-1-29 19:31:25 | 显示全部楼层
 楼主| 发表于 2024-1-29 19:53:46 | 显示全部楼层
 楼主| 发表于 2024-1-29 21:22:12 | 显示全部楼层
 楼主| 发表于 2024-1-29 23:33:31 | 显示全部楼层
发表于 2024-2-5 23:57:53 | 显示全部楼层
 楼主| 发表于 2024-2-19 16:07:44 | 显示全部楼层
发表于 2024-2-20 16:57:03 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2024-2-20 19:31:48 | 显示全部楼层
发表于 2024-4-3 18:02:56 | 显示全部楼层
回复 支持 0 反对 1
 楼主| 发表于 2024-4-17 22:38:16 | 显示全部楼层
 楼主| 发表于 2024-4-17 22:40:54 | 显示全部楼层
发表于 2024-5-26 19:05:45 | 显示全部楼层
发表于 2025-6-11 12:34:00 | 显示全部楼层
GMT+8, 2026-7-7 23:39 , Processed in 0.296400 second(s), 11 queries , Gzip On, Redis On.
