发表于 2024-3-12 16:07:25
显示全部楼层
- https://remember.the-aero.org/aero/paq/diagf10.htm
复制代码
没有软驱……还是供起来比较好
THIS SOFTPAQ IS ESSENTIAL FOR THE COMPAQ CONTURA AERO!!!
IT CREATES A SETUP AND DIAGNOSTIC PARTITION ON THE HARDDISK, THAT GIVES YOU ACCESS TO THE BIOS-CONFIGURATION, TO SYSTEM-INFORMATION AND TO SELF-TESTS OF ALL HARDWARE.
IT HAS TO BE INSTALLED BEFORE ANY OTHER SOFTWARE. IT HAS TO BE INSTALLED ON A CLEAN HARDDISK, NO PARTITIONS ARE ALLOWED.
WHEN INSTALLED YOU GET ACCESS TO SETUP BY TYPING "F10" AFTER BOOTING WHILE THE CURSOR IS BLINKING IN THE UPPER RIGHT CORNER OF THE SCREEN.
ALTERNATIVELY YOU CAN RUN THE SETUP AND DIAGNOSTICS SOFTWARE FROM A FLOPPY. |
