查看: 4005|回复: 12
兆能M2 变砖求救
发表于 2024-8-3 03:48:21 | 显示全部楼层 |阅读模式
改了512内存  识别了  然后刷了过度包,也启动了,然后刷了CDT也识别到512了,然后又刷了暗云大佬的分区文件和uboot,然后就没有然后了  进不了uboot  通电只有电源灯,TTL跑码如下,求大佬指点怎么救砖。
Format: Log Type - Time(microsec) - Message - Optional Info
Log Type: B - Since Boot(Power On Reset),  D - Delta,  S - Statistic
S - QC_IMAGE_VERSION_STRING=BOOT.XF.0.3-00086-IPQ60xxLZB-1
S - IMAGE_VARIANT_STRING=IPQ6018LA
S - OEM_IMAGE_VERSION_STRING=crm-ubuntu200
S - Boot Interface: NAND
S - Secure Boot: Off
S - Boot Config @ 0x000a602c = 0x000002e5
S - JTAG ID @ 0x000a607c = 0x001390e1
S - OEM ID @ 0x000a6080 = 0x00000000
S - Serial Number @ 0x000a4128 = 0x499e6b6f
S - OEM Config Row 0 @ 0x000a4188 = 0x0000000000000000
S - OEM Config Row 1 @ 0x000a4190 = 0x0000000000000000
S - Feature Config Row 0 @ 0x000a4130 = 0x0000800018200021
S - Feature Config Row 1 @ 0x000a4138 = 0x02c3e83783000009
S - PBL Patch Ver: 1
S - I-cache: On
S - D-cache: On
B -      3413 - PBL, Start
B -       592 - bootable_media_detect_entry, Start
B -      4339 - bootable_media_detect_success, Start
B -      5207 - elf_loader_entry, Start
B -      5380 - auth_hash_seg_entry, Start
B -      7847 - auth_hash_seg_exit, Start
B -      8342 - elf_segs_hash_verify_entry, Start
B -    103758 - elf_segs_hash_verify_exit, Start
B -    107953 - auth_xbl_sec_hash_seg_entry, Start
B -    108098 - auth_xbl_sec_hash_seg_exit, Start
B -    114647 - xbl_sec_segs_hash_verify_entry, Start
B -    114647 - xbl_sec_segs_hash_verify_exit, Start
B -    115576 - PBL, End
B -     97478 - SBL1, Start
B -    237259 - GCC [RstStat:0x0, RstDbg:0x600000] WDog Stat : 0x4
B -    239669 - clock_init, Start
D -      2775 - clock_init, Delta
B -    248178 - boot_flash_init, Start
D -     30439 - boot_flash_init, Delta
B -    281881 - sbl1_ddr_set_default_params, Start
D -       274 - sbl1_ddr_set_default_params, Delta
B -    288499 - boot_config_data_table_init, Start
D -      4788 - boot_config_data_table_init, Delta - (575 Bytes)
B -    298351 - CDT Version:2,Platform ID:8,Major ID:3,Minor ID:2,Subtype:0
B -    303170 - Image Load, Start
D -      6618 - OEM_MISC Image Loaded, Delta - (0 Bytes)
B -    312503 - Image Load, Start
D -      5063 - PMIC Image Loaded, Delta - (0
发表于 2024-8-3 08:17:39 | 显示全部楼层
发表于 2024-8-3 08:45:18 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2024-8-3 11:44:41 | 显示全部楼层
 楼主| 发表于 2024-8-3 11:47:51 | 显示全部楼层
 楼主| 发表于 2024-8-3 11:53:31 | 显示全部楼层
发表于 2024-8-3 19:44:05 | 显示全部楼层
发表于 2024-8-4 03:53:14 来自手机浏览器 | 显示全部楼层
发表于 2024-8-18 09:23:30 来自手机浏览器 | 显示全部楼层
发表于 2024-12-9 11:11:41 来自手机浏览器 | 显示全部楼层
发表于 2025-2-27 15:39:42 | 显示全部楼层
发表于 2026-2-28 11:08:15 | 显示全部楼层
发表于 2026-2-28 15:05:53 | 显示全部楼层
GMT+8, 2026-8-26 05:58 , Processed in 0.280800 second(s), 11 queries , Gzip On, Redis On.
