查看: 822|回复: 4
[软件] 轻量级虚拟机 VirtualBox v7.1.6-167084 官方版
发表于 2025-1-22 11:03:45 | 显示全部楼层 |阅读模式
Oracle VM VirtualBox – 免费开源轻量级虚拟机软件。该软件由德国InnoTek公司开发(后被SUN收购,之后SUN被Oracle公司收购),VirtualBox虚拟电脑软件主要优势是完全免费,而且性能稳定,它可以在Linux和Windows平台中运行,可以在其主机上安装Windows, MacOS, Linux, BSD等类型的客户机操作系统。
软件截图
更新日志
VirtualBox 7.1.6 (released January 21 2025)
This is a maintenance release. The following items were fixed and/or added:
  • VMM: Fixed issue when Windows 11 24H2 guest was experiencing BSOD in rare conditions
  • GUI: Improved representation of disabled preferences contents (mask+font) when it is shown with certain Linux themes
  • GUI: Fixed issue when seamless mode was not properly enabled or disabled in appropriate time according to GA status events
  • GUI: Fixed rare crash on macOS hosts on application exit
  • GUI: Fixed small 7.1.4 regression in preferences windows when filter editor was not in focus
  • GUI: Introduced improvements in Advanced properties/settings dialog area
  • GUI: Restored missing functionality to change bridged adapter at VM startup if current one wasn't found
  • GUI: Fixed issue when Show action duplicates were created on macOS host in attempt to switch between running and powered off VMs
  • GUI: Fixed regression when 3D acceleration check-box was not available for certain guest OS and graphical controller types
  • GUI: Restored lost Help button for preferences windows on macOS
  • GUI: Restored lost Help button shortcuts for certain windows
  • GUI: Fixed issue when error message was shown when VM was starting in full-screen mode
  • VirtioNet: Fixed issue with re-negotiation of features after reset
  • Graphics: Fixed issue with Linux guest screen flickering when guest was using VMSVGA graphics adapter
  • VBoxManage: Added the ability to export and import VMs which contain an NVMe storage controller
  • VBoxManage: Fixed issue when it was not possible to set graphics controller to "QemuRamFB" using modifyvm command
  • Main: Fixed issue when specifying custom proxy server in GUI settings had no effect
  • Network: Added changes which replaced NAT engines with libslirp
  • Guest OSes: Added OS type for Windows Server 2025
  • Linux guest and host: Added more fixes for UBSAN related warnings
  • Linux guest and host: Added initial support for RHEL 9.6 kernel
  • Windows guests and host: Re-implemented driver installation
  • Solaris host: Removed the VirtualBox GUI shared objects libqgtk2styleVBox.so and libqgtk2VBox.so from the Solaris installation packages as they depend on GTK2 which is EOL and no longer supported
  • Linux Guest Additions: Introduced initial support for kernel 6.13
  • Linux Guest Additions: vboxvideo: Added improvement for kernel 6.4 support and fixed issue when graphics could be frozen when using VBoxVGA adapter
  • Linux Guest Additions: Introduced additional fixes for kernel 6.12 in vboxvideo
下载地址
[url=][/url]
发表于 2025-1-22 11:34:34 | 显示全部楼层
发表于 2025-1-22 11:40:03 | 显示全部楼层
发表于 2025-1-22 22:22:51 | 显示全部楼层
发表于 2025-1-23 00:06:03 | 显示全部楼层
GMT+8, 2026-4-2 19:42 , Processed in 0.218401 second(s), 8 queries , Gzip On, Redis On.
