查看: 2489|回复: 0
通过VSYS和VPN实现园区网业务隔离实验
发表于 2025-2-28 16:45:40 | 显示全部楼层 |阅读模式 IP属地:陕西省西安市 联通
实验需求:
1、IT与Sales业务隔离;(Employee和Guest)
2、两个部门之间防火墙的安全了略需要独立管理;
3、IT部与Sales部之间如果需要通信,必须经过各自防火墙的安全策略检查。
物理拓扑
1、划分VLAN并把端口加入VLAN
SW1
vlan 10
description IT
vlan 20
description Sales
interface GigabitEthernet0/0/1
port link-type access
port default vlan 10
interface GigabitEthernet0/0/2
port default vlan 20
2、SW1和FW1接口配置链路聚合
SW
interface Eth-Trunk1
mode lacp-static
trunkport g0/0/3
trunkport g0/0/4
FW
portswitch
mode lacp-static
trunkport g1/0/3
trunkport g1/0/4
[sw1]display eth-trunk 1
[sw1]display interface Eth-Trunk 1
//接口带宽已变成2G
3.链路聚合接口配置Trunk放通所有vlan
SW
port link-type trunk
port trunk allow-pass vlan 2 to 4094
FW
4.SW1创建VLANIF
interface Vlanif10
ip address 192.168.10.1 255.255.255.0
interface Vlanif20
ip address 192.168.20.1 255.255.255.0
5.SW创建VPN实例并绑定VLANIF
ip vpn-instance IT
ipv4-family
ip vpn-instance Sales
ipv4-family
interface Vlanif10
ip binding vpn-instance IT
interface Vlanif20
ip binding vpn-instance Sales
(绑定后接口IP会清空需重新配)
(创建一条VPN实例相当于创建一个路由器)
6.验证1
PC1>ping 192.168.10.1通
PC2>ping 192.168.20.1通
PC>ping 192.168.20.1不通
[sw1]dis ip routing-table //无直连路由
[sw1]display ip routing-table vpn-instance IT
     //一条直连路由Sales同样
7.创建VLAN30将接口加入及创建vlanif接口
vlan30
q
interface Vlanif30 全局
ip address 192.168.30.1 255.255.255.0
interface GigabitEthernet0/0/5
port default vlan 30
8.R1 配置接口并添加一个Lo0测试接口
interface GigabitEthernet0/0/0
ip address 192.168.30.2 255.255.255.0
interface LoopBack0
ip address 1.1.1.1 255.255.255.255
[R1] ping 192.168.30.1通
9.配置VLANIF 122和124用于两条实例连接防火墙
vlan batch 122 124
interface Vlanif122
ip address 192.168.122.1 255.255.255.0
interface Vlanif124
ip address 192.168.124.1 255.255.255.0
[SW1-Vlanif122]display ip routing-table vpn-instance IT
[SW1-Vlanif122]display ip routing-table vpn-instance Sales
10.FW全局创建vlan和VSYS并把vlan分配给VSYS
vsys en
vlan batch 122 124
vsys name IT
assign vlan 122
vsys name Sales 2
assign vlan 124
11.创建VLANIF 122 124
interface Vlanif122
ip address 192.168.122.2 255.255.255.0
interface Vlanif124
ip address 192.168.124.2 255.255.255.0
12.把vlanif接口加入到信任区域
switch vsys IT
sys
firewall zone trust
add interface Vlanif122
q
q
q
switch vsys Sales
sys
firewall zone trust
add interface Vlanif124
13、验证防火墙连通
[SW1]ping -vpn-instance IT 192.168.122.2通
[SW1]ping -vpn-instance Sales 192.168.124.2通
14.配置Local>Trust安全策略
[FW1-IT-policy-security-rule-Local>Trust]dis th
rule name Local>Trust
  source-zone local
  destination-zone trust
  action permit
[FW1-Sales-policy-security-rule-Local>Trust]dis th
  source-zone local
  action permit
<FW1>ping -vpn-instance IT 192.168.122.1 通
<FW1>ping -vpn-instance Sales 192.168.124.1通
15.SW1配置OSPF
ospf 10 router-id 5.5.5.5 vpn-instance IT
area 0.0.0.0
  network 192.168.122.0 0.0.0.255
  network 192.168.10.0 0.0.0.255
ospf 20 router-id 6.6.6.6 vpn-instance Sales
area 0.0.0.0
  network 192.168.124.0 0.0.0.255
  network 192.168.20.0 0.0.0.255
GMT+8, 2026-11-11 00:24 , Processed in 0.312001 second(s), 13 queries , Gzip On, Redis On.
