查看: 2674|回复: 71
10块钱的和家亲摄像头刷了OpenIPC
发表于 2026-3-29 23:48:48 | 显示全部楼层 |阅读模式
OpenIPC is an open source operating system from the open community targeting for IP cameras with ARM and MIPS processors from several manufacturers in order to replace that closed, opaque, insecure, often abandoned and unsupported firmware pre-installed by a vendor.
OpenIPC Firmware comes as binary pre-compiled files for easy installation by end-user. Also, we provide full access to the source files for further development and improvement by any capable programmer willing to contribute to the project. OpenIPC source code is released under one of the most simple open source license agreements, MIT License, giving users express permission to reuse code for any purpose, even as part of a proprietary software. We only ask you politely to contribute your improvements back to us and also be sure to contact us if you use our project for commercial purposes. We would be grateful for any feedback and suggestions. The use of the OpenIPC project and its components for military purposes is not permitted.
还有一些专注于专业装备的项目,例如用于安装在无人机上的相机、用于安装在建筑安全帽上的设备、用于勘测工具的设备、用于视觉器官医学研究的设备、水下捕鱼设备等。
  1. reading linux_sstar.bin
  2. ** Unable to read file linux_sstar.bin **
  3. check ret error! pls check!
  4. Flash is detected (0x0C08, 0x20, 0x60, 0x18)
  5. SF: Detected nor0 with total size 16 MiB
  6. SF: 2097152 bytes [url=home.php?mod=space&uid=3057940]@[/url] 0x50000 Read: OK
  7. ##  Booting kernel from Legacy Image at 22000000 ...
  8.    Image Name:   MVX4##I6B0g#######KL_LX409##[BR:
  9.    Image Type:   ARM Linux Kernel Image (lzma compressed)
  10.    Data Size:    2081568 Bytes = 2 MiB
  11.    Load Address: 20008000
  12.    Entry Point:  20008000
  13.    Verifying Checksum ... OK
  14.    Uncompressing Kernel Image ...
  15. [XZ] !!!reserved 0x21000000 length=0x 1000000 for xz!!
  16.    XZ: uncompressed size=0x41a000, ret=7
  17. OK
  18. atags:0x20000000
  19. Starting kernel ...
  20. Booting Linux on physical CPU 0x0
  21. Linux version 4.9.84 (zxz@ubuntu) (gcc version 4.9.4 (Buildroot 2017.08-gc7bbae9        -dirty) ) #32 PREEMPT Mon Nov 23 20:41:28 CST 2020
  22. CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c53c7d
  23. CPU: div instructions available: patching division code
  24. CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
  25. early_atags_to_fdt() success
  26. OF: fdt:Machine model: INFINITY6B0 SSC009A-S01A QFN88
  27. LXmem is 0x3fe0000 PHYS_OFFSET is 0x20000000
  28. Add mem start 0x20000000 size 0x3fe0000!!!!
  29. LX_MEM  = 0x20000000, 0x3fe0000
  30. LX_MEM2 = 0x0, 0x0
  31. LX_MEM3 = 0x0, 0x0
  32. EMAC_LEN= 0x0
  33. DRAM_LEN= 0x0
  34. deal_with_reserve_mma_heap memblock_reserve success mma_config[0].reserved_start        =
  35. 0x22b00000
  36. cma: Reserved 2 MiB at 0x22800000
  37. Memory policy: Data cache writeback
  38. CPU: All CPU(s) started in SVC mode.
  39. Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16224
  40. Kernel command line: console=ttyS0,115200 root=/dev/mtdblock2 rootfstype=squashf        s ro init=/linuxrc LX_MEM=0x3fe0000 mma_heap=mma_heap_name0,miu=0,sz=0x14e0000
  41. PID hash table entries: 256 (order: -2, 1024 bytes)
  42. Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
  43. Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
  44. Memory: 36828K/65408K available (2548K kernel code, 227K rwdata, 1172K rodata, 1        04K init, 174K bss, 26532K reserved, 2048K cma-reserved)
  45. Virtual kernel memory layout:
  46.     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
  47.     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
  48.     vmalloc : 0xc4000000 - 0xff800000   ( 952 MB)
  49.     lowmem  : 0xc0000000 - 0xc3fe0000   (  63 MB)
  50.     modules : 0xbf800000 - 0xc0000000   (   8 MB)
  51.       .text : 0xc0008000 - 0xc0285570   (2550 kB)
  52.       .init : 0xc03ce000 - 0xc03e8000   ( 104 kB)
  53.       .data : 0xc03e8000 - 0xc0420eb0   ( 228 kB)
  54.        .bss : 0xc0422000 - 0xc044d8c8   ( 175 kB)
  55. SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
  56. Preemptible hierarchical RCU implementation.
  57.         Build-time adjustment of leaf fanout to 32.
  58. NR_IRQS:16 nr_irqs:16 16
  59. ms_init_main_intc: np->name=ms_main_intc, parent=gic
  60. ms_init_pm_intc: np->name=ms_pm_intc, parent=ms_main_intc
  61. ss_init_gpi_intc: np->name=ms_gpi_intc, parent=ms_main_intc
  62. Find CLK_cpupll_clk, hook ms_cpuclk_ops
  63. arm_arch_timer: Architected cp15 timer(s) running at 6.00MHz (virt).
  64. clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1623fa770, m        ax_idle_ns: 440795202238 ns
  65. sched_clock: 56 bits at 6MHz, resolution 166ns, wraps every 4398046511055ns
  66. Switching to timer-based delay loop, resolution 166ns
  67. console [ttyS0] enabled
  68. Calibrating delay loop (skipped), value calculated using timer frequency.. 12.00        BogoMIPS (lpj=60000)
  69. pid_max: default: 4096 minimum: 301
  70. Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
  71. Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
  72. CPU: Testing write buffer coherency: ok
  73. Setting up static identity map for 0x200081c0 - 0x200081f0
  74. devtmpfs: initialized
  75. VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
  76. clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911        2604462750000 ns
  77. futex hash table entries: 16 (order: -4, 448 bytes)
  78. NET: Registered protocol family 16
  79. DMA: preallocated 256 KiB pool for atomic coherent allocations
  80. Version : MVX4##I6B0g#######KL_LX409##[BR:g]#XVM
  81. GPIO: probe end[ss_gpi_intc_domain_alloc] hw:42 -> v:49
  82. [MS_PM_INTC] hw:20 -> v:52
  83. hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
  84. hw-breakpoint: maximum watchpoint size is 8 bytes.
  85. clocksource: Switched to clocksource arch_sys_counter
  86. NET: Registered protocol family 2
  87. TCP established hash table entries: 1024 (order: 0, 4096 bytes)
  88. TCP bind hash table entries: 1024 (order: 2, 20480 bytes)
  89. TCP: Hash tables configured (established 1024 bind 1024)
  90. UDP hash table entries: 128 (order: 0, 6144 bytes)
  91. UDP-Lite hash table entries: 128 (order: 0, 6144 bytes)
  92. NET: Registered protocol family 1
  93. RPC: Registered named UNIX socket transport module.
  94. RPC: Registered udp transport module.
  95. RPC: Registered tcp transport module.
  96. RPC: Registered tcp NFSv4.1 backchannel transport module.
  97. hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
  98. workingset: timestamp_bits=30 max_order=14 bucket_order=0
  99. squashfs: version 4.0 (2009/01/31) Phillip Lougher
  100. NFS: Registering the id_resolver key type
  101. Key type id_resolver registered
  102. Key type id_legacy registered
  103. jffs2: version 2.2. © 2001-2006 Red Hat, Inc.
  104. io scheduler noop registered
  105. io scheduler deadline registered (default)
  106. libphy: Fixed MDIO Bus: probed
  107. i2c /dev entries driver
  108. 1f221000.uart0: ttyS0 at MMIO 0x0 (irq = 37, base_baud = 10800000) is a unknown
  109. 1f221200.uart1: ttyS1 at MMIO 0x0 (irq = 38, base_baud = 10800000) is a unknown
  110. 1f220400.uart2: ttyS2 at MMIO 0x0 (irq = 40, base_baud = 10800000) is a unknown
  111. MSYS: DMEM request: [emac0_buff]:0x00000812
  112. MSYS: DMEM request: [emac0_buff]:0x00000812 success, CPU phy:@0x22844000, virt:[url=home.php?mod=space&uid=3057940]@[/url]        0xC2844000
  113. libphy: mdio: probed
  114. mdio_bus mdio-bus@emac0: /soc/emac0/mdio-bus/ethernet-phy[url=home.php?mod=space&uid=3613015]@0[/url] has invalid PHY addr        ess
  115. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 0
  116. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 1
  117. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 2
  118. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 3
  119. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 4
  120. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 5
  121. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 6
  122. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 7
  123. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 8
  124. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 9
  125. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 10
  126. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 11
  127. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 12
  128. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 13
  129. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 14
  130. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 15
  131. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 16
  132. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 17
  133. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 18
  134. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 19
  135. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 20
  136. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 21
  137. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 22
  138. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 23
  139. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 24
  140. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 25
  141. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 26
  142. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 27
  143. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 28
  144. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 29
  145. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 30
  146. mdio_bus mdio-bus@emac0: scan phy ethernet-phy at address 31
  147. [emac_phy_connect][3328] connected mac emac0 to PHY at mdio-bus@emac0:00 [uid=11        112222, driver=SStar 10/100 Ethernet Phy]
  148. [gpioi2c] sda-gpio=8, scl-gpio=9
  149. MSYS: DMEM request: [BDMA_FSP_WBUFF]:0x00010040
  150. MSYS: DMEM request: [BDMA_FSP_WBUFF]:0x00010040 success, CPU phy:@0x22850000, vi        rt:@0xC2850000
  151. [Ser flash] phys=0x22850000, virt=0xc2850000, bus=0x02850000 len:0x10040
  152. [FSP] Unknown flash type (0xFF, 0xFF, 0xFF) and use default flash type 0x0000
  153. [FSP] 1-1-1 FAST_READ MODE
  154. mtd .name = NOR_FLASH, .size = 0x01000000 (16MiB)
  155. .erasesize = 0x00010000 .numeraseregions = 0
  156. MXP_PARTS!!
  157. MXP found at mxp_offset[3]=0x00020000, size=0x1000
  158. Creating 4 MTD partitions on "NOR_FLASH":
  159. 0x000000000000-0x000000050000 : "BOOT"
  160. 0x000000050000-0x000000250000 : "KERNEL"
  161. 0x000000250000-0x0000007d0000 : "rootfs"
  162. 0x0000007d0000-0x000001000000 : "appfs"
  163. MSYS: DMEM request: [AESDMA_ENG]:0x00001000
  164. MSYS: DMEM request: [AESDMA_ENG]:0x00001000 success, CPU phy:@0x22845000, virt:@        0xC2845000
  165. MSYS: DMEM request: [AESDMA_ENG1]:0x00001000
  166. MSYS: DMEM request: [AESDMA_ENG1]:0x00001000 success, CPU phy:@0x22846000, virt:        @0xC2846000
  167. [ms_cpufreq_init] Current clk=799999872
  168. [NOTICE]Each grp bit0 must be enabled!
  169. [NOTICE]pwm-isr(53) success. If not i6e or i6b0, pls confirm it on .dtsi
  170. NET: Registered protocol family 10
  171. sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
  172. NET: Registered protocol family 17
  173. Key type dns_resolver registered
  174. ThumbEE CPU extension supported.
  175. hctosys: unable to open rtc device (rtc0)
  176. OF: fdt:not creating '/sys/firmware/fdt': CRC check failed
  177. VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
  178. devtmpfs: mounted
  179. This architecture does not have kernel memory protection.
  180. random: linuxrc: uninitialized urandom read (4 bytes read)
  181. random: rcS: uninitialized urandom read (4 bytes read)
  182. random: mount: uninitialized urandom read (4 bytes read)
  183. random: mkdir: uninitialized urandom read (4 bytes read)
  184. random: mkdir: uninitialized urandom read (4 bytes read)
  185. random: mount: uninitialized urandom read (4 bytes read)
  186. mount: can't find devpts in /etcrandom: mdev: uninitialized urandom read (4 byte        s read)
  187. /fstab
  188. random: sysctl: uninitialized urandom read (4 bytes read)
  189. net.core.rmem_default = 163840
  190. random: mkdir: uninitialized urandom read (4 bytes read)
  191. net.core.rmem_max = 163840
  192. net.random: mount: uninitialized urandom read (4 bytes read)
  193. core.wmem_default = 524288
  194. net.core.wmem_max = 1048576
  195. net.ipv4.tcp_mem = 924  1232  1848
  196. net.ipv4.tcp_rmem = 4096  87380  325120
  197. net.ipv4.tcp_wmem = 4096  131072  393216
  198. mount: mounting none on /sys failed: Device or resource busy
  199. mount: mounting none on /sys/kernel/debug/ failed: Device or resource busy
  200. [emac_phy_link_adjust] EMAC Link Down
  201. tuya comm packet
  202. get sensor name from /mnt/mtd/SystemConfig.ini,sensor is jxq03
  203. get device type from /mnt/mtd/SystemConfig.ini,type is SSC335_E95AM2H_E_CFG_YD
  204. usbcore: registered new interface driver usbfs
  205. usbcore: registered new interface driver hub
  206. usbcore: registered new device driver usb
  207. ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  208. ehci monitor start running
  209. Mstar_ehc_init version:20180309
  210. Sstar-ehci-1 H.W init
  211. Get power-enable-pad from DTS GPIO(80)
  212. Titania3_series_start_ehc start
  213. [USB] config miu select [70] [e8] [ef] [ef]
  214. [USB] enable miu lower bound address subtraction
  215. [USB] init squelch level 0x2
  216. [USB] no platform_data, device tree coming
  217. [USB][EHC] dma coherent_mask 0xffffffffffffffff mask 0xffffffffffffffff
  218. BC disable
  219. <blockquote>
复制代码
参与人数 2家元 +126 收起 理由
天地科技 + 6 優秀文章
家睦 + 120
本帖被以下淘专辑推荐:
 楼主| 发表于 2026-3-29 23:48:49 | 显示全部楼层
 楼主| 发表于 2026-3-30 00:05:34 | 显示全部楼层
 楼主| 发表于 2026-3-30 00:22:07 | 显示全部楼层
 楼主| 发表于 2026-3-30 00:44:20 | 显示全部楼层
 楼主| 发表于 2026-3-30 09:04:59 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2026-3-30 09:05:37 来自手机浏览器 | 显示全部楼层
发表于 2026-3-30 09:26:40 | 显示全部楼层
发表于 2026-3-30 10:14:30 | 显示全部楼层
发表于 2026-3-30 12:42:27 | 显示全部楼层
 楼主| 发表于 2026-3-30 13:18:36 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2026-3-30 13:20:30 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2026-3-30 13:27:05 来自手机浏览器 | 显示全部楼层
参与人数 1家元 +6 收起 理由
暗影男爵 + 6 歡迎探討
发表于 2026-3-30 14:23:36 | 显示全部楼层
 楼主| 发表于 2026-3-30 15:49:54 来自手机浏览器 | 显示全部楼层
发表于 2026-3-30 16:46:02 | 显示全部楼层
发表于 2026-3-30 16:52:06 | 显示全部楼层
 楼主| 发表于 2026-3-30 22:30:04 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2026-3-30 22:32:20 来自手机浏览器 | 显示全部楼层
参与人数 1家元 +6 收起 理由
暗影男爵 + 6 歡迎探討
GMT+8, 2026-11-5 07:29 , Processed in 0.780001 second(s), 16 queries , Gzip On, Redis On.
