查看: 1266|回复: 13
[综合] 中兴k543摄像头无法中断启动进入uboot?
发表于 2026-4-6 15:34:04 来自手机浏览器 | 显示全部楼层 |阅读模式
  1. IPL g40bd5ed
  2. D-0a
  3. HW Reset
  4. SPI 54M
  5. 128MB
  6. BIST0_0001-OK
  7. MXP found at 0x00020000
  8. offset:00010000
  9. Checksum OK
  10. IPL_CUST g40bd5ed
  11. MXP found at 0x00020000
  12. offset:00030000
  13. XZ decomp_size=0x00043014
  14. U-Boot 2015.01 (Aug 302021 ) 15:16:55)
  15. Version: I6g#######
  16. I2C:   ready
  17. DRAM:
  18. WARNING: Caches not enabled
  19. MMC:   MStar S@/MMC: 0
  20. nor_flash_mxp allocated success!!
  21. Flash is detected (0x1003, 0x5E, 0x40, 0x18)
  22. SF: Detected nor0 with total size 16 MiB
  23. MXP found at mxp_offset[3]=0x00020000, size=0x1000
  24. env_offset=0x4F000 env_size=0x1000
  25. Flash is detected (0x1003, 0x5E, 0x40, 0x18)
  26. SF: Detected nor0 with total cize 16 MiB
  27. In:    serial
  28. Out:   serial
  29. Err:   serial
  30. gpio debug MHal_GPIO_Pad_Set:603
  31. gpio[15] is 1
  32. gpio debug MHal_GPIO_Pad_Set:603
  33. gpio[52] is 0
  34. gpio debug MHal_GPIO_Pad_Set:603
  35. gpio[76] )s 1
  36. gpio debug MHal_GPIO_Pad_Set:603
  37. gpio[77] is 0
  38. gpio debug MHal_GPIO_Pad_Set:603
  39. gpio[78] is 1
  40.                 gpio dabugIHal_GPIO_Pad_Set:603
  41. gpio[79] is 1
  42. gpio debug MHal_GPIO_Pad_Set:603
  43. gpio[0] is 0
  44. gpio debug MHal_PIO_Pad_Set:603
  45. gpio[1] is 0
  46. gpio debug MHal_GPIO_Pad_Set:603
  47. gpio[2] is 0
  48. gpio debug MHal_GPIO_Pad_Set:603
  49. Gpi/[3] is
  50. gpio debug MHal_GPIO_Pad_Set:603
  51. gpio[4] is 0
  52. gpio debug MHal_GPIO_Pad_Set:603
  53. gpio[5] is 0
  54. gpio debug MHal_GPIO_Pad_Set:603
  55. gpio[6] is 0
  56. gpio debug MHal_GPIO_Pad_Set:603
  57. gpio[7] is 0
  58. Net:   MAC Address 00:30:1B:BA:02:DB
  59. Auto-Negotiation...
  60. Link Status Speed:10 Full-duplex:0
  61. Status Error!
  62. sstar_emac
  63. FlAsh is detected (0x1003, 0x5E, 0x40, 0x18)
  64. SF: Detected nor0 with total size 16 MiB
  65. ▒▒͕▒▒
  66.    Data Size:    2145072 Bytes = 2 MiB
  67.    Load Address: 20008000
  68.    Entry Point:  20008000
  69.    Verifying Checksum ... OK
  70.    Uncompressing KerneYrrrj
  71.                            [XZ] !!!reserved 0x21000000 length=0x 1000000 for xz!!
  72. : mdev: uninitialized urandom read (4 bytes read)
  73. random: mdev: uninitialized urandom bead (4 bytes read)
  74. ▒检测到语言为中文
  75. supporclient [688] connected, module:sys
  76. t all id, langauMI_SYSCFG_SetupMmapLoader default_config_path:/config/config_tool, argv1:/config/load_mmap,argv2:/config/mmap.ini
  77. ge check from platform, not from VOICE file.
  78. open /etc/passwd file errno=30adjustSysDateFromRTC, read_rtc: 0
  79. no sd card!
  80. GET EYE SER :eye_p2p_str = 5405970000079524 dot_cmei = 111060100079524 dot_key = HFSBDi2X dot_mac = 30cc2157c9f0 dot_res = 00000
  81. dFunction = init_glob_miu_kranges, Line = 692, Insert KProtect for LX [url=home.php?mod=space&uid=3057940]@[/url] MIU: 0
  82. ot_mac = 30CC215Function = init_glob_miu_kranges, Line = 701, [INIT] for LX0 kprotect: from 0x20000000 to 0x27FE0000, using blocK 0
  83. 7C9F0
  84. hiSetFeaconfig...... cmdpath:/config/config_tool, argv0:load_config
  85. ture g_md_h_valuconfig...... cmdpath8-colfig/config_tool, argv1:/misc/config.ini
  86. config...... cmdpath:/config/config_tool, argv2:/misc/PQConfig.hni
  87. config...... cmdpath:/config/config_tool, argv3:(null)
  88. e:0
  89. hiSetFeatufunction:parese_Cmdline,pCmd_Section:0x7fe0000
  90. et LX_MEM fail in mmap ....
  91. re g_md_m_value:0
  92. mmiSetFeature g_md_l_value:0
  93. a_
  94. he
  95. ap
  96. _n
  97. am
  98. e0
  99.     miu90,sz=2500000  reserved_start=25ae0000
  100. avEncInit starr_front->miuBlockIndex:0,r_front->start_cpu_bus_pa:0x20000000,r_front->start_cpu_bus_pa+r_front->length:0x25ae0000
  101. t, sensorMode = mi_sys_mma_allocator_create success, heap_baseaddr=25ae0000 length=2500000
  102. 36
  103. Kernel CONFIG_HZ = 100
  104. Sigmastar Module mi_sys version: ppoject_commit.27f9e39 sdk_commit.ec9dc92 build_time.20200902123745
  105. client [688] connected, module:sensor
  106. index 0, Crop(0,0,2560,1440), outputsize(2560,1440), maxfps 25, minfps 5, ResDesc 2880x1620@30fps
  107. u8Version:Sigmasclient [688] connected, module:vif
  108. tar Module mi_syclient [688] connected, modulE:tpe
  109. chipidx 4
  110. s version: proje[DRV_SCL_MODULE] [DrvSclModuleClkInit @ 316] Use Default Clk Z240000000]
  111. ct_commit.27f9e3CmdqProcInit 821
  112. 9 sdk_commit.ec9[CMDQ0] Virtual IRQ: 30
  113. dc92 build_time.CmdQ Free I@ = 0, IspDocalCmdQHnd = 0xbf92ae60
  114. 20200902123745
  115. ISP_IRQ_WQ_FRAME_DONE add WQ error! fpCB=0x0, pData=0x0
  116. uuidInfo=8495676CamOsMutexInit already inited, LR:0xBF84C019
  117. 927011
  118. beal.......mode 24 24  .....
  119. CUS3A ver : Sigmastar Moduld misc_cus3a version: project_commit.27f9e39 sdk_commit.ec9dc92 build_time.20200902123909
  120. [MI_ISP_CUS3A_EnCameraIsp_EnableChannel3A, ch:0 data:  (null)
  121. CameraIsp_EnableCus3A AE=1, AWB=0, AF=0
  122. able] AE = 1
  123. AWB = 0, AF = 0
  124. change isproot : /config/iqfile
  125. Load iq file /config/iqfile/iqfile0.bin
  126. [MI_ISP_CUS3A_EnCameraIsp_EnableChannel3A, ch:0 data:  (null)
  127. CameraIsp_EnableCus3A AE=1, AWB=1, AF=0
  128. able] AE = 1, AWclient [688] connected, module:venc
  129. B = 1, AF = 0
  130. Create mi dav0
  131. src(6-0-0-0)  dCreate mi dev0
  132. [MI WRN ]: _MI_VENC_CreateMiDevice[7543]: mi device:0 has beel inited
  133. st(7-0-0-0)  4..Create mi dev1
  134. .
  135. Create mhal DEV0.
  136. [ven-m][wrap] venc_dev_preset:1383 GetMMaHeapNaie s32Ret=0xa009201f, u8MMAHeapName=.
  137. Create mhal DEV1.path /config/venc_fw/chagall.bin
  138. [ven-w][wrap] venc MMA callback function duplicate registration Force OverWrite!!
  139. [ven-w][wrap] venc dev created, not support set E_MHAL_VEFC_MAX_ENCODE_RESOLUTION, pls set before createdev
  140. [CMDQ1] Virtual IRQ: 30
  141. ===== [MhalCameraOpen] begin ===== VifMask : 3
  142. Ch= 0, SNR ID: 0, VifCh = 0, PreOpdn = 0
  143. 3DNR = 1, Rotation = 0, AckTie : 0
  144. (W, H): (2560, 1440)
  145. PixelFmt: 1, BayerID: 2, YuvOrder: 0
  146. oDe: 0, HdrTxpe: 0
  147. [CameraReadIqData] isp root is /config/iqfile, nCh = 0
  148. Create mhal DEV2.
  149. Get Qf:70client [688] connected, m/duhe:div`
  150. DIP Device ID [0] has already init.
  151. [DIP] Virtual IRQ: 36
  152. Bind type 16, para 1440
  153. Bind type 1, para 0
  154. hrk.bin load succlient [688] connected, module:rgn
  155. osd init success
  156. VENC INIT OK!
  157. #SSNN_LIB_STATUS=FULL#
  158. [sstar ae_init] isp_gain_max =  x3fdf,sgl^min = 0x400, sgl_max = 0xb9000, sgs_min  0x400, sgs_max = 0xb9000
  159. [sstar ae_init], shl_min = 11 us, shlmax = 200000 us, shl_step = 11111 us, shs_min = 11 us, shs_max = 200000 us, shs_step = 11111 us
  160. [sstar ae_init], FNum = 18, fps = 30
  161. change isproot : /config/iqfile
  162. Load iq file /config/iqfhle/iqfile0.bin
  163. Netgmrk handle  client [688] connected, module:ao
  164. 0x97e690) is suc[AUDIO ERROR]DrvAudApiDtsInit, Failed to gpio_request aMp-gpio !
  165. cessfully create[CMDQ2] Virtual IRQ: 30
  166. d.
  167. ms_md_init s[_MI_AO_Init:1228] Init Ao Gain.
  168. uc
  169. [CMDQ3] Virtual IRQ: 30
  170. _MI_AO_OpenVqeLib: success
  171. _MIclient [688] connected, module:ai
  172. _AO_OpenSrcLib: [_MI_AI_Init:3145] Init Ai Gain.
  173. success
  174. _MI_AO^OpenG711Lib: su[_MI_AI_IMPL_AllocTmpBuffer:3596] tmp buffer addr[c9aaa000].
  175. ccess
  176. _MI_AO_OpenG726Lib: succars
  177. isSupportMaxVoice = 10 voiceStep = 10, chnVol = 29
  178. ms_audio_play_init
  179. _MI_AI_OpenAecLib: success
  180. _MI_AI_OpenVqeLib: success
  181. _MI_AI_OpenSbcLib: success
  182. _MI_AI_OpenG711Lib: success
  183. _MI_AI_OpenG726Lib: success
  184. _MI_AI_OpenAedLib: Can not load libAAD_LINUX.so!
  185. _MI_AI_OpenSslLib: success
  186. _MI_AI_OpenBfLib: success
  187. mic Value = 16
  188. [_MI_AI_ApcInit:2110] DeV0 hn0 Vqe buffer size:114676.
  189. [ALGO_MSG_MSG] Checking IC....
  190. [ALGO_MSG_MSG] [APC] APC IC check pass. ver.2009.1205.0000
  191. [ALGO_MSG_MSG] [APC] FFT mode: floating point mode
  192. [ALGO_MSG_MSG] [APC] Point Number: 128
  193. [ALGO_MSG_MSG] [APB] Channel: 1
  194. [ALGO_MSG_MSG] [APC] Sample rate: 8000
  195. ▒z---------------------------------------------------))---------------------------▒{
  196. ▒x        ▒x
  197. ▒x                                   NEON ENABLE                                  ▒x
  198. ▒x        ▒x
  199. ▒|-------------------------------------------------,--
  200. --------------------------▒}
  201. [ALGO_MSG_MSG] [NR] device eth0 entered promiscuous mode
  202. Converge mode8 NIPv6: ADDRCNNF(NETDEV_UP): eth0: link is not ready
  203. ormal
  204. [ALGO_MS[emac_phy_link_adjust] EMAC Link Up
  205. G_MSG] [AGC] The AudioAgcProcessIPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
  206. Struct initial succeed
  207. [ALGO_MSG_MSG] [AGC] AGC IC check pass. ver.2019.1205.0000
  208. [FFT] Please assigned the begining address about FFT workingbuff@r in Init.
  209. ▒z--------------------------------------------------------------------------------▒{
  210. ▒x        ▒x
  211. ▒x                                   NEON ENAB
  212. E                                  ▒x
  213. ▒x        ▒x
  214. ▒|--------------------------------------------------------------------------------▒}
  215. [ALGO_MSG_MSGU [AGC] TheAudioAgcProcessStruct initial succeed
  216. [ALGO_MSG_MSG] [AGC] AGC IC check pass. ver.2019.1205.0000
  217. [FT] Please assigned the begining address about FFT workingbuffer in Init.
  218. ---------------------------------------▒{
  219. ▒x        ▒x                                   NEON ENABLE                                  ▒x
  220. ▒x        ▒x
  221. -------------------------▒}----------------------
  222. [ALGO_MSG_MSG] [APC] APC internal initialize succeed
  223. [ALGO_MSG_MSG][IaaAec_GDtBufferSize] Working buffer size = 85264 bytes
  224. [_MI_AI_AecInit:2473] Dev0 Chn0 Aec buffer size:85264.
  225. [ALGO_MSE_MSG] [AEC] AEC IC check pass. ver.2019.1205.0000
  226. [ALGO_MSG_MSG] [AEC] Setting: [128][8]
  227. [ALGO_MSG_MSG] [AECY Floating point mode.
  228. --------------------------------------------------------------------------------
  229.                                   NEONEN@@LE
  230. -,------------------------------------------------------------------------------
  231. AudioDet Sens: 3
  232. --------------)-soundDetectInit: sensitivity[98]
  233. -------------------->logo_pos = 9
  234. main stream: vWidth = 2560,vHehght = 1440, oi size=204x54, ocf=2, bpp=2, oi->size = 22032, oi->stride = 408
  235. runTangeOtaTask..
  236. version = 20220301 iccid = 111060100079524 uuid = 5405970000079524 model = IPC_ZTE_SS_ZXHN_K543
  237. checkMdAreparams enter
  238. checkMdAreparamsepit
  239. mainIcon create success
  240. sub stream: vWidth = 640,vHeight = 360, oi size=66x18, ocf=2, bpp=2
  241. subIconcReate success
  242. interface is not ready
  243. eth0      Link encap:Ethernet  HWaddr 1C:59:74:82:09:E2
  244.           inet6 addr: Fe80:1e59:74ff:fe82:9e2/64 Scope:Link
  245.           UP BROADCAST RUNNING MULTICAST  MTU:1450  Metric:1
  246.           RXpackets:21 errors:0 dropped:0 overruns:0 frame:0
  247.           TX packets:8 errors:0 dropped:0 overruns:0 carrier80
  248.          collisions:0 txqueuelen:1000
  249.           RX bytes:1644 (1.6 KiB)  TX bytes:648 (648.0 B)
  250.           Interrupt:41
  251. lo        Link encap:Local Loopback
  252.           inet addr:127.0.0.1  Mask:255.0.0.0
  253.           inet6 addr: ::1/128 Scope:Host
  254.           UP LOOPBACK RUNNING  MTU:65536  Metric:1
  255.           RX packets:0 errors:0 dro`pdd:0 overruns:0 frame:0
  256.           TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
  257.           collisions:0 txqueuelef:1
  258.           RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
  259. wlan0     Link encap:Ethernet  HWaddr 1C:19:74:82:09:E2
  260.          inet6 addr: fe80::1e59:74ff:fe82:9e2/64 Scope:Link
  261.           UP BROADCAST RUNNING MULTICAST  MT:1450  Metric:1
  262.           RX packets:614 errors:0 dropped:0 overruns:0 frame:0
  263.           TX packets:0 errors:0 droppeD:0 overruns:0 carrier:0
  264.           collisions:0 txqueuelen:1000
  265.           RX bytes:199315 (194.6 KiB)  TX bytes:0 (0.0 B)
  266. init eth0...
  267. change mac
  268. ------------->len = 6
  269. encodeWidth = 2560 stRgnAttr.stOsdInitParam.stSize.u32Width = [ERROR - ISP API SET] Not support - Ctrl ID = 4107
  270. 640
  271. encodeWidth = 640 stRgnAttr.stOsdInitParam.stSize.532Width = 160
  272. encodeWidth = 640 stRgnAttr.stOsdInitParam.stSize.u32Width = 160
  273. mstar sensor mode
  274. [MAJOR]: ispvepsion(1) in sdk, ispversion(1) in binfile.
  275. [MINOR]: ispversion(2) in sdk, ispversion(6) in binfile
  276. warning garning!!!SDK & iqbinfile minor version is not match.
  277. **************[IQ_API20_SET_DUMMY_EX] Dummy0[0~5] = IQ^YEE_SCALE^SFT_X
  278. [IQ_API20_SET_DUMMY_EX] Dummy1[0~2] = IQ_NR3D_STICKY_SOLVER_EN, IQ_NR3D_STICKY_SOLVER_TH, IQ_NR3_STHC
  279.                      Y_SVER_EN_TH
  280. ****** Load api [IQ_API20_SET_DUMMY_EX] Dummy3 = IQ_NR3D_HIST_MOT_MAP_SW
  281. [IQ_API20_SET_DUMMY_EX] DumMy4 = ALSC table mirror/flip/rotate
  282. bin Success - /tmp/cfg/SC401ai_D[IQ_API20_SET_DUMMY_EX] Dummy0[0~5] = IQ_YEE_SCALE_SFT_X
  283. [IQ_API20_SET_DUMMY_EX] Dummy1[0~2] = IQ_NR3D_STICKY_SOLVER_EN, IQ_NR3D_STICKY_SOLVER_TH, IQ_NR3_STICKY_SOLVER_EN_TH
  284. AY_IQFILE.bin **[IQ_API20_SET_DUMMY_EX] Dummy3 = IQ_NR3D_HIST_MOT_MAP_SW
  285. ***********(****[IQ_API20_SET_DUMMY_EX] Dummy4 = ALSC table mirror/flip/rotate
  286. [IQ_API20_SET_DUMMY] Dummy0[0~3] = AE acc controls 2DNR MdTh and MdGain.
  287. [IQ_API20_SET_DUMMY] Dummy0[0] = AEDiff_Th. If max of AE acc difference smallEb than the vAlue, MdTh and MdGain would be adjusted by the following ratio.      [IQ_API20_SET_DUMMY] Dummy0[2] = MdGain_Ratio.
  288. [IQ_API20_SET_DUMMY] Dummy0[3] = Log_En.
  289. [IQ_API20_SET_DUMMY] Dummy0[0] = IQ_BNR_WEI_X
  290. [IQ_API20_SET_DUMMY] Dummy1[1~32] = IQ_BNR_WEI_Y
  291. [IQ_API20_SET_DUMMY] Dummy2[0~05] = I_YEE_DTL_OFFSET
  292. [IQ_API20_SET_DUMMY_EX] Dummy0[0~5] = IQ_YEE_SCALE_SFT_X
  293. [IQ_API20_SET_DUMMY_EX] Dummy1[0~2] = IQ_NR3D_STICKY_SOLVER_EN, IQ_NR3D_STICKY_SOLVER_TH, IQ_NR3D_STICKY_SOLVER_EN_TH
  294. **
  295. Y_AX] Dummy3 = IQ_NR3D_HIST_MOT_MAP_SW
  296. [IQ_API20_SET_DUMMY_EX] Dummy4 = ALSC table mirror/flip/rotate
  297. mdLoadBInFilE ret = 0
  298. #####IR CUT in Day Mode2. 0
  299. Chn2 auto change fps from (15/80) to (14/1)
  300. mstar sensor mode
  301. [MAJOR]: ispvers[ERROR - ISP API SET] Not cuppobt - Ctrl ID = 4107
  302. ion(1) in sdk, ispversion(1) in binfile.
  303. [MINOR]: ispversion(2) in sdk, ispversion(6) in baldile.
  304. warning warning!!!SDK & iqbinfile minor version is not match.
  305. ******************** Load api bin Success - /tmp/cfg/SC401ai_NIGHT_IQFILE.bin ********************
  306. MI_ISP_API_CmdLoadBinFile ret = 0
  307. M]EXU Dummy0[0~5] = IQ_YEE_SCALE_SFT_X
  308. [IQ_API20_SET_DUMMY_EX] Dummy1[0~2] = IQ_NR3D_STICKY_SOLVER_EN, IQ_NR3D_STICKQ^SNLVER_TH, IQ_NR3D_STICKY_SOLVER_EN_TH
  309. [IQ_API20_SET_DUMMY_EX] Dummy3 = IQ_NR3D_HIST_MOT_MAP_SW
  310. [IQ_API20_SETDUMMY_EX] Dummy4 = ALSC table mirror/flip/rotate
  311. [IQ_API20_SET_DUMMY_EX] Dummx0[0~5] = IQ_YEESCALE_SFT_X
  312. [IQ_API20_SET_DUMMY_EX] Dummy1[0~2] = IQ_NR3D_STICKY_SOLVER_EN, IQ_NR3D_STICKY_SOLVER_TH, I_NR3D_STICKY_SOLVER_EN_TH
  313. [IQ_API20_SET_DUMMY_EX] Dummy3 = IQ_NR3D_HIST_MOT_MAP_SW
  314. [IQ_API20_SET_DUMMY_EX Dummy4 = ALSC table mirror/flip/rotate
  315. [IQ_API20_SET_DUMMY] Dummy0[0~3] = AE acc controls 3DNR MdTh and MdGain
  316. [IQ_API20SET_DUMMY] Dummy0[0] = AEDiff_Th. If max of AE acc difference smaller than the value, MdTh and MdGain would be adhusted by the following ratio.
  317. [IQ_API20_SET_DUMMY] Dummy0[1] = MdTh_Ratio.
  318. [IQ_API20_SET_DUMMY] uimy0[2] = MdGain_Ratio.
  319. [IQ_API20_SET_DUMMY] Dummy0[3] = Log_En.
  320. [IQ_API20_SET_DUMMY] Dummy1[0] = IQ_BNR_WEI_X
  321. [I_API20_SET_DUMMY] Dummy1[1~32] = IQ_BNR_WEI_Y
  322. [IQ_API20_SET_DUMMY] Dummy2[0~15] = IQ_YEE_DTL_OFFSET
  323. [IQ_API20_SE_@UMMQ_EX] Dummy0[0~5] = IQ_YEE_SCALE_SFT_X
  324. [IQ_API20_SET_DUMMY_EX] Dummy1[0~2] = IQ_NR3D_STICKY_SOLVER_EJ, IQ_NR3D_STICKY_SOLVER_TH, IQ_NR3D_STICKY_SOLVER_EN_TH
  325. [IQ_API20_SET_DUMMY_EX] Dummy3 = IQ_NR3D_HIST_MOT_MAP_SS
  326. [I_API20_SET_DUMMY_EX] Dummy4 = ALSC table mirror/flip/rotate
  327. #####IR CUT in Night Mode2.
  328. linktest(edh0) = 1
  329. NET INTERFACE is eth0
  330. start udhcpc on eth0........
  331. killall: telnetd: no process killed
  332. dot_Init() #########
  333. [Dot.c:dot_Init:2758]#############fersion:3.3.3552.7c81494 #############
  334. (01-01  8:00:35.663) VoiceEngineWrapper().
  335. (01-01  8:00:35.663) Init(external_adm=0x(nil)).
  336. (01-01  8:00:35.664) Thread With name:Trace started .
  337. ThirdpartyAudioDevice(构造函数)
  338. (01-01  8:00:35.667) AudioDeviceBuffer::SetRDcordingSampleRate(fsHz=0).
  339. (01-01  8:00:35.667) AudioDeviceBuffer::SetPlayoutSampleRate(fsHz=0).
  340. ThirdpartyAedioDefibe::Init()
  341. ThirdpartyAudioDevice::InitSpeaker()
  342. ThirdpartyAudioDevice::InitMicrophone()
  343. ThirdpartyAudioDevice::SdereoPlayoutIsAvailable()
  344. ThirdpartyAudioDevice::InitPlayout()
  345. ThirdpartyAudioDevice::InitSpeaker()
  346. (01-0!  8:00:35.64')@udioDeviceBuffer::SetPlayoutSampleRate(fsHz=8000).
  347. (01-01  8:00:35.667) output: available=1.
  348. (01-01  8:00:35.660) unable to set stereo mode while playing side is initialized.
  349. (01-01  8:00:35.668) Init() failed to set Mono.sdereo playout mode (error=8090).
  350. (01-01  8:00:35.668) output: available=1.
  351. (01-01  8:00:35.668) recor`ing iN ster`o is not supported.
  352. (01-01  8:00:35.668) Init() failed to set mono/stereo recording mode (error=8090).
  353. (01-01  8: 0:35.669) create HeartBeat thread.
  354. (01-01  8:00:35.669) Thread with name:ProcessThread started .
  355. (0!,01  8000235.663) create timer thread.
  356. (01-01  8:00:35.674) Thread with name:VoipEngine HeartBeat thread started .
  357. (01,01  8:00:35.675) =ML-V1.9.8=
  358. Voipengine_api CreateEngine(). SDK compile at: Apr  6 2021 17:37:53
  359. .
  360. ( 0-01  0:00035.675) =ML-V1.9.8=CreateEngine() has has been called by application!.
  361. isSupportMaxVoice = 10 voiceStep = 10, chnVol = 9
  362. ------playSound /tmp/VOICE/wait_wired_connect.wav
  363. (00-01  8:00:35.884) Thread with name:VoipEngine Timer thread started .
  364. mufb_create suc----------------->
  365. getEyeStrMac:30CC215C9F0
  366. voip SN:5405970000079524 CMEI:111060100079524 MAC:30:CC:21:57:C9:F0
  367. (01-01  8:00:35.909) =ML-V1.9.8=SeteviceInfo() to buntu-16.04;2.3.54;2.1/Camera-Linux;5405970000079524;chipModel-123456789]
  368. (01-01  8:00:35.909) =ML-V!.9.8=RegisterTraceCallback() has has been called by application!
  369. (01-01  8:00:35.910) =ML-V1.9.8=RegisterTraceCallback() log path:[/tmp/call.log]
  370. (01-01  8:00:35.910) Engine version is 1.9.8.1.370-20210315
  371. CGetIMSAccountNqMber(0!-01  8:00:35.910) =ML-V1.9.8=
  372. Linux SDK compile at: Apr  6 2021 17:37:53
  373. (01-01  8:00:35.911) =ML-V1.9.8=RegisterSignalingObserver() has has been called by application!
  374. (01-01  8:00:35.911) VoipWper::RegisterSignalingO`serveR
  375. [Dotc:dot_Init:2776]sdk demo start
  376. [Dot.c:InitSDKParams:603]sn:5405970000079524, model:IPC_ZTE_SS_ZXHN_K543, lac:30CB2157C9F0,  fw_version:1.14.0001
  377. create thread timer ok,id:11583536
  378. create thread timer nk,id:11688656
  379. create thread timer ok,id:11689216
  380. create thread timer ok,id:11689296
  381. create thread tiMEr ok,id:11689376
  382. create thread timer ok,id:11689456
  383. create thread timer ok,id:11689536
  384. isRegistered = 0
  385. bind_status = 0
  386. bind_mode = 2
  387. /tmp/VOICE/wait_wired_connect.wav, file_type=2, audioType = 0 ext:.wav..
  388. btart tmp/VOICE/wait_wired_connect.wav, file_type=0, [MI_AO_IMPL_SendFrame:2641] Strat pcm out success!!!
  389. audioType = 1&
  390. isSupportMaxVoice = 10 voiceStep = 10, chnVol = 29
  391. ------playSound /tmp/VOICE/wait_wirad_connect.w`v nrer
  392. not valid ip:
  393. cbDevBindStatus = 0
  394. [Dot.c:cbDevBindStatus:1911]DOT_DEVICE_BIND_REQUEST_INFO_START
  395. [Dot.c:cbDevBindStatus:1912]bind request info start
  396. [Dot.c:StartBind:2397]DoT_StabtDefhceBind, ret:0
  397. [Dot.c:StartBind:2399]DoT_StartDeviceBind,DOT_EC_SU<==Set_Debug_Proc(RTDebugLevel = 3)
  398. CESS
  399. create thread timer ok,id:11683280
  400. Start TxAlcGetAutoAgcO&fsat
  401. 2[LT7601_get_rssi]:StaCount=0,Avg Rssi=0,pAd->OpMode=0
  402. No connection! Set fake rssi= -80!!!
  403. random: crng init done
  404. not valid ip:
  405. Start TxAlcGetAutoAgcOffset
  406. 2[MT7601_get_rssi]:StAount=0,Avg Rssi=0,pAd->OpMode=0
  407. No connection! Set fake rssi= -80!!!
  408. not valid ip:
  409. Start TxAlcGetAutoAgcOffset
  410. 2[MT7601_get_rssi]:StaCount=0,Avg Rssi=0,pAd->OpMode=0
  411. No connection! Set fake rssi= -80!!!
  412. Not vAlid ip:
  413. I?)( `e-enabling...abled by @ub (
  414. usb  (1: USB disconnect, device number 2
  415. RTUSB_VendnrBequest Failad(-!9),TxFlags=0x0, ReqType=IN, Req=0x7, Idx=0x1718,pAd->Flags=0x31000102
复制代码
 楼主| 发表于 2026-4-7 12:38:13 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2026-4-8 12:19:47 来自手机浏览器 | 显示全部楼层
发表于 2026-4-13 11:56:39 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2026-4-16 22:53:50 来自手机浏览器 | 显示全部楼层
发表于 2026-4-17 08:30:26 来自手机浏览器 | 显示全部楼层
发表于 2026-4-17 09:37:31 | 显示全部楼层
发表于 2026-4-18 07:56:58 | 显示全部楼层
 楼主| 发表于 2026-4-23 18:36:14 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2026-4-24 10:15:34 来自手机浏览器 | 显示全部楼层
发表于 2026-4-24 17:02:35 | 显示全部楼层
发表于 2026-4-24 21:48:27 | 显示全部楼层
发表于 2026-4-24 22:59:51 | 显示全部楼层
 楼主| 发表于 2026-5-2 13:24:52 | 显示全部楼层
 楼主| 发表于 2026-5-2 13:26:01 | 显示全部楼层
GMT+8, 2026-11-23 21:44 , Processed in 0.109200 second(s), 9 queries , Gzip On, Redis On.
