查看: 205|回复: 5
大华HDW2233C球机反复重启,如何串口刷机?
发表于 2026-4-18 01:03:05 | 显示全部楼层 |阅读模式
  1. U-Boot 2010.06-svn4581 (Sep 06 2019 - 10:09:22)
  2. I2C:   ready
  3. DRAM:  110 MiB
  4. gBootLogPtr:00b80008.
  5. spinor flash ID is 0xc81840c8
  6. partition file version 2
  7. rootfstype squashfs root /dev/mtdblock5
  8. fail to load bootargsParametersV22.txt
  9. fail to load bootargsParametersV21.txt
  10. fail to init bootargsParametersV2
  11. TEXT_BASE:01000000
  12. Net:   Detected MACID:e0:50:8b:0f:1d:42
  13. PHY:0x001cc816,addr:0x00
  14. phy RTL8201 init
  15. MMC:   sdmmc init
  16. Using ambarella mac device
  17. TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1
  18. Download Filename 'upgrade_info_7db780a713a4.txt'.
  19. Download to address: 0x5000000
  20. Downloading: *
  21. Retry count exceeded; starting again
  22. Try again use backup_serverip
  23. Using ambarella mac device
  24. TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1
  25. Download Filename 'upgrade_info_7db780a713a4.txt'.
  26. Download to address: 0x5000000
  27. Downloading: *
复制代码
发表于 2026-4-18 09:03:53 | 显示全部楼层
 楼主| 发表于 2026-4-19 10:25:21 来自手机浏览器 | 显示全部楼层
发表于 2026-4-19 15:44:01 | 显示全部楼层
发表于 2026-4-28 12:46:27 | 显示全部楼层
 楼主| 发表于 2026-5-2 13:25:54 | 显示全部楼层
GMT+8, 2026-6-8 06:21 , Processed in 0.046801 second(s), 6 queries , Gzip On, Redis On.
