SF2582金士顿E100的好盘拆了贴TH58TAG7S2FBA89颗粒16贴不知怎么总是有颗粒报错,捣了颗粒也不行
<?xml version = "1.0"?>
<Genesis_Log>
<Log_Body>
Overall Summary:
Start Time: Mon, 11/04/2019 @ 06:11:30
End Time: Mon, 11/04/2019 @ 06:11:57
OverallResult: FAIL
ExitCode: (0x10090007:SF_GENESIS_FLASH_TEST_ONLY_ERROR)
Environment Settings:
Input Parameters:
argv[1]: -FLASH_TEST
argv[2]: 3:0:0:0
argv[3]: /root/tmp/FW_PPRO_6_1_8_Release.1115287.release--123456/FW_PPRO_6_1_8_Release.1115287.release.123456.mfp
argv[4]: /root/tmp/FW_PPRO_6_1_8_Release.1115287.release--123456/25139.123456.driveconfig
argv[5]: q
argv[6]: LOG=/root/妗岄潰/1_a_DATETIMESTAMP_3.0.0.0_FLASH_TEST_RESULT.log
Log File: /root/妗岄潰/1_a_DATETIMESTAMP_3.0.0.0_FLASH_TEST_RESULT.log
Hostname: a
Host IP Address: 127.0.0.1
Port Number: 1
DeviceName: /dev/sg1
SF_Genesis Version: v1.5.21.20110919-fc14-32bit
SF_Core Library Version: v1.7.0.20110919-fc14-32bit
SF_OS_Information: Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686
Post Processing Device Information:
WWN OUI: UNKNOWN
WWN UniqueID: UNKNOWN
Serial No.: UNKNOWN
Model No.: UNKNOWN
Firmware Revision: UNKNOWN
ROM Revision: UNKNOWN
NAND Page Size: UNKNOWN
Number Of Chip Enable: UNKNOWN
Logical Sectors: UNKNOWN
NAND ID: UNKNOWN
Flash Manufacturer: UNKNOWN
Flash Device: UNKNOWN
SandForce Genesis Utility v1.5.21.20110919-fc14-32bit
SF_Core Library: v1.7.0.20110919-fc14-32bit
Copyright 2010-2011, SandForce Inc., All Rights Reserved Worldwide.
[Mon 11/04/2019 06:11:30] - SF_Genesis has been invoked with the following parameters:
argv[2]: 3:0:0:0
argv[5]: q
[Mon 11/04/2019 06:11:30] - Instructing the operating system to purge any existing cached data for device: '3:0:0:0'
[Mon 11/04/2019 06:11:35] - Issuing a discovery command for device: '3:0:0:0'
[Mon 11/04/2019 06:11:40] - Discovery command completed...
[Mon 11/04/2019 06:11:40] - Waiting 5 seconds for the system to settle...
[Mon 11/04/2019 06:11:45] - Device designation string '3:0:0:0' is mapped to node '/dev/sg1'
[Mon 11/04/2019 06:11:45] - Proceeding to perform the requested FlashTest() operation on device: /dev/sg1
[Mon 11/04/2019 06:11:45] - Proceeding to process SSD device with the following parameters:
DeviceName = /dev/sg1
MFP Package Filename = /root/tmp/FW_PPRO_6_1_8_Release.1115287.release--123456/FW_PPRO_6_1_8_Release.1115287.release.123456.mfp
Configuration File = /root/tmp/FW_PPRO_6_1_8_Release.1115287.release--123456/25139.123456.driveconfig
Serial No. = -FLASH_TEST
World Wide Name = q
[Mon 11/04/2019 06:11:45] - Successfully received the IDENTIFY data from the drive...
[Mon 11/04/2019 06:11:46] - Successfully opened the package: /root/tmp/FW_PPRO_6_1_8_Release.1115287.release--123456/FW_PPRO_6_1_8_Release.1115287.release.123456.mfp
[Mon 11/04/2019 06:11:46] - Successfully extracted *.DriveConfig file: /root/tmp/FW_PPRO_6_1_8_Release.1115287.release--123456/25139.123456.driveconfig
[Mon 11/04/2019 06:11:46] - Extracted Config_ID: 1 (25139) in DriveConfig file: /root/tmp/FW_PPRO_6_1_8_Release.1115287.release--123456/25139.123456.driveconfig
[Mon 11/04/2019 06:11:46] - Extracted SerialOutputControl: 0
[Mon 11/04/2019 06:11:46] - Successfully extracted Config record: 25139
[Mon 11/04/2019 06:11:46] - Successfully extracted flashware image: 25139_fw_cl_slc_Toshiba_16Gb_TH58TAG7S2FBA89_4Q_4C_2D_PP_R00468_s512.vic
[Mon 11/04/2019 06:11:46] - Successfully extracted manufacturing image: 25139_mf_slc_Toshiba_16Gb_TH58TAG7S2FBA89_4Q_4C_2D_PP_R00468_s512.vic
[Mon 11/04/2019 06:11:46] - Proceeding in ROM mode, download feature 1...
[Mon 11/04/2019 06:11:46] - Successfully downloaded MFB to the drive...
[Mon 11/04/2019 06:11:46] - Waiting (5 sec) for the drive to settle...
[Mon 11/04/2019 06:11:51] - Successfully received the IDENTIFY data from the drive...
[Mon 11/04/2019 06:11:51] - Firmware revision reported to be: '618ABBM0'. This indicates MFB download was successful.
[Mon 11/04/2019 06:11:51] - Successfully enabled SMART capabilities...
[Mon 11/04/2019 06:11:53] - Successfully issued a diagnostic unlock...
[Mon 11/04/2019 06:11:53] - Performing the flash test of block 0 (0x0000)...
[Mon 11/04/2019 06:11:57] - Flash Test Results:
Flash Test Parameters:
Block Count: 0
Page Count: 1
Bus Count: 2
Chip Enabled Count: 8
Die Count: 2
Lane Count: 4
Plane Count: 2
Results Notes:
N1 - At least one page tested and passed with no bit errors.
N2 - No test data available. Test may have aborted, or failed during the testing.
N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
N4 - At least one erased page tested had bit error rate greater than half the correction power.
N5 - Walking zeros test failed.
N6 - Walking ones test failed.
N7 - Block contained factory bad block markings and testing was skipped.
N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
N9 - Block in plane 0 was marked as a factory bad block.
N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
N11 - Block in plane 1 was marked as a factory bad block.
| Bus | CE | Die | Lane | Value | Result Notes | Overall |
| 0 | 0 | 0 | 0 | 0x0180 | N7,N9 | FAIL |
| 0 | 0 | 0 | 1 | 0x0180 | N7,N9 | FAIL |
| 0 | 0 | 0 | 2 | 0x0180 | N7,N9 | FAIL |
| 0 | 0 | 0 | 3 | 0x0180 | N7,N9 | FAIL |
| 0 | 0 | 1 | 0 | 0x0001 | N1 | PASS |
| 0 | 0 | 1 | 1 | 0x0001 | N1 | PASS |
| 0 | 0 | 1 | 2 | 0x0001 | N1 | PASS |
| 0 | 0 | 1 | 3 | 0x0001 | N1 | PASS |
| 0 | 1 | 0 | 0 | 0x0180 | N7,N9 | FAIL |
| 0 | 1 | 0 | 1 | 0x0180 | N7,N9 | FAIL |
| 0 | 1 | 0 | 2 | 0x0180 | N7,N9 | FAIL |
| 0 | 1 | 0 | 3 | 0x0180 | N7,N9 | FAIL |
| 0 | 1 | 1 | 0 | 0x0001 | N1 | PASS |
| 0 | 1 | 1 | 1 | 0x0001 | N1 | PASS |
| 0 | 1 | 1 | 2 | 0x0001 | N1 | PASS |
| 0 | 1 | 1 | 3 | 0x0001 | N1 | PASS |
| 0 | 2 | 0 | 0 | 0x0001 | N1 | PASS |
| 0 | 2 | 0 | 1 | 0x0001 | N1 | PASS |
| 0 | 2 | 0 | 2 | 0x0001 | N1 | PASS |
| 0 | 2 | 0 | 3 | 0x0001 | N1 | PASS |
| 0 | 2 | 1 | 0 | 0x0001 | N1 | PASS |
| 0 | 2 | 1 | 1 | 0x0001 | N1 | PASS |
| 0 | 2 | 1 | 2 | 0x0001 | N1 | PASS |
| 0 | 2 | 1 | 3 | 0x0001 | N1 | PASS |
| 0 | 3 | 0 | 0 | 0x0001 | N1 | PASS |
| 0 | 3 | 0 | 1 | 0x0001 | N1 | PASS |
| 0 | 3 | 0 | 2 | 0x0001 | N1 | PASS |
| 0 | 3 | 0 | 3 | 0x0001 | N1 | PASS |
| 0 | 3 | 1 | 0 | 0x0001 | N1 | PASS |
| 0 | 3 | 1 | 1 | 0x0001 | N1 | PASS |
| 0 | 3 | 1 | 2 | 0x0001 | N1 | PASS |
| 0 | 3 | 1 | 3 | 0x0001 | N1 | PASS |
| 0 | 4 | 0 | 0 | 0x0001 | N1 | PASS |
| 0 | 4 | 0 | 1 | 0x0001 | N1 | PASS |
| 0 | 4 | 0 | 2 | 0x0001 | N1 | PASS |
| 0 | 4 | 0 | 3 | 0x0001 | N1 | PASS |
| 0 | 4 | 1 | 0 | 0x0001 | N1 | PASS |
| 0 | 4 | 1 | 1 | 0x0001 | N1 | PASS |
| 0 | 4 | 1 | 2 | 0x0001 | N1 | PASS |
| 0 | 4 | 1 | 3 | 0x0003 | N1,N3 | WARNING |
| 0 | 5 | 0 | 0 | 0x0001 | N1 | PASS |
| 0 | 5 | 0 | 1 | 0x0001 | N1 | PASS |
| 0 | 5 | 0 | 2 | 0x0001 | N1 | PASS |
| 0 | 5 | 0 | 3 | 0x0001 | N1 | PASS |
| 0 | 5 | 1 | 0 | 0x0001 | N1 | PASS |
| 0 | 5 | 1 | 1 | 0x0001 | N1 | PASS |
| 0 | 5 | 1 | 2 | 0x0001 | N1 | PASS |
| 0 | 5 | 1 | 3 | 0x0001 | N1 | PASS |
| 0 | 6 | 0 | 0 | 0x0001 | N1 | PASS |
| 0 | 6 | 0 | 1 | 0x0001 | N1 | PASS |
| 0 | 6 | 0 | 2 | 0x0001 | N1 | PASS |
| 0 | 6 | 0 | 3 | 0x0001 | N1 | PASS |
| 0 | 6 | 1 | 0 | 0x0001 | N1 | PASS |
| 0 | 6 | 1 | 1 | 0x0001 | N1 | PASS |
| 0 | 6 | 1 | 2 | 0x0001 | N1 | PASS |
| 0 | 6 | 1 | 3 | 0x0001 | N1 | PASS |
| 0 | 7 | 0 | 0 | 0x0001 | N1 | PASS |
| 0 | 7 | 0 | 1 | 0x0001 | N1 | PASS |
| 0 | 7 | 0 | 2 | 0x0001 | N1 | PASS |
| 0 | 7 | 0 | 3 | 0x0001 | N1 | PASS |
| 0 | 7 | 1 | 0 | 0x0001 | N1 | PASS |
| 0 | 7 | 1 | 1 | 0x0001 | N1 | PASS |
| 0 | 7 | 1 | 2 | 0x0001 | N1 | PASS |
| 0 | 7 | 1 | 3 | 0x0001 | N1 | PASS |
| 1 | 0 | 0 | 0 | 0x0001 | N1 | PASS |
| 1 | 0 | 0 | 1 | 0x0001 | N1 | PASS |
| 1 | 0 | 0 | 2 | 0x0001 | N1 | PASS |
| 1 | 0 | 0 | 3 | 0x0001 | N1 | PASS |
| 1 | 0 | 1 | 0 | 0x0001 | N1 | PASS |
| 1 | 0 | 1 | 1 | 0x0001 | N1 | PASS |
| 1 | 0 | 1 | 2 | 0x0001 | N1 | PASS |
| 1 | 0 | 1 | 3 | 0x0001 | N1 | PASS |
| 1 | 1 | 0 | 0 | 0x0001 | N1 | PASS |
| 1 | 1 | 0 | 1 | 0x0001 | N1 | PASS |
| 1 | 1 | 0 | 2 | 0x0001 | N1 | PASS |
| 1 | 1 | 0 | 3 | 0x0001 | N1 | PASS |
| 1 | 1 | 1 | 0 | 0x0001 | N1 | PASS |
| 1 | 1 | 1 | 1 | 0x0001 | N1 | PASS |
| 1 | 1 | 1 | 2 | 0x0001 | N1 | PASS |
| 1 | 1 | 1 | 3 | 0x0001 | N1 | PASS |
| 1 | 2 | 0 | 0 | 0x0001 | N1 | PASS |
| 1 | 2 | 0 | 1 | 0x0001 | N1 | PASS |
| 1 | 2 | 0 | 2 | 0x0001 | N1 | PASS |
| 1 | 2 | 0 | 3 | 0x0001 | N1 | PASS |
| 1 | 2 | 1 | 0 | 0x0001 | N1 | PASS |
| 1 | 2 | 1 | 1 | 0x0001 | N1 | PASS |
| 1 | 2 | 1 | 2 | 0x0001 | N1 | PASS |
| 1 | 2 | 1 | 3 | 0x0001 | N1 | PASS |
| 1 | 3 | 0 | 0 | 0x0001 | N1 | PASS |
| 1 | 3 | 0 | 1 | 0x0001 | N1 | PASS |
| 1 | 3 | 0 | 2 | 0x0001 | N1 | PASS |
| 1 | 3 | 0 | 3 | 0x0001 | N1 | PASS |
| 1 | 3 | 1 | 0 | 0x0001 | N1 | PASS |
| 1 | 3 | 1 | 1 | 0x0001 | N1 | PASS |
| 1 | 3 | 1 | 2 | 0x0001 | N1 | PASS |
| 1 | 3 | 1 | 3 | 0x0001 | N1 | PASS |
| 1 | 4 | 0 | 0 | 0x0001 | N1 | PASS |
| 1 | 4 | 0 | 1 | 0x0180 | N7,N9 | FAIL |
[Mon 11/04/2019 06:11:57] - Completed the requested FlashTest() operation on device: /dev/sg1
[Mon 11/04/2019 06:11:57] - End of Genesis manufacturing log.
[Mon 11/04/2019 06:11:57] - Exiting...
</Log_Body>
<Overall_Summary>
<Start_Time> Mon, 11/04/2019 @ 06:11:30 </Start_Time>
<End_Time> Mon, 11/04/2019 @ 06:11:57 </End_Time>
<Overall_Result> FAIL </Overall_Result>
<Exit_Code> (0x10090007:SF_GENESIS_FLASH_TEST_ONLY_ERROR) </Exit_Code>
</Overall_Summary>
<Environment_Settings>
<Input_Parameters>
argv[2]: 3:0:0:0
argv[5]: q
</Input_Parameters>
<Log_File> /root/妗岄潰/1_a_DATETIMESTAMP_3.0.0.0_FLASH_TEST_RESULT.log </Log_File>
<Hostname> a </Hostname>
<Host_IP_Address> 127.0.0.1 </Host_IP_Address>
<Port_Number> 1 </Port_Number>
<Device_Name> /dev/sg1 </Device_Name>
<SF_Genesis_Version> v1.5.21.20110919-fc14-32bit </SF_Genesis_Version>
<SF_Core_Library_Version> v1.7.0.20110919-fc14-32bit </SF_Core_Library_Version>
<SF_OS_Information> Linux 2.6.35.6-45.fc14.i686 #1 SMP Mon Oct 18 23:56:17 UTC 2010 i686 </SF_OS_Information>
</Environment_Settings>
<Post_Processing_Device_Info>
<WWN_OUI> UNKNOWN </WWN_OUI>
<WWN_UniqueID> UNKNOWN </WWN_UniqueID>
<Serial_Number> UNKNOWN </Serial_Number>
<Model_Number> UNKNOWN </Model_Number>
<Firmware_Revision> UNKNOWN </Firmware_Revision>
<ROM_Revision> UNKNOWN </ROM_Revision>
<NAND_Page_Size> UNKNOWN </NAND_Page_Size>
<Number_Of_Chip_Enable> UNKNOWN </Number_Of_Chip_Enable>
<Logical_Sectors> UNKNOWN </Logical_Sectors>
<NAND_ID> UNKNOWN </NAND_ID>
<Flash_Manufacturer> UNKNOWN </Flash_Manufacturer>
<Flash_Device> UNKNOWN </Flash_Device>
</Post_Processing_Device_Info>
</Genesis_Log>
[Mon 11/04/2019 06:11:57] - Overall Result for Device: /dev/sg1 ****** FAIL ******
用903测试颗粒坏块每颗都是8个坏块高手指教用的 25139 25140的固件都不行
